    【求助】ros2 humble下gazebo&moveit联合仿真,ros2 control node加载失败
    ros2 humble gazebo&moveit
    • S
      swh
      报错信息:[ros2_control_node-6] [INFO] [1750770401.570871549] [resource_manager]: Loading hardware 'GazeboSystem'
      [ros2_control_node-6] terminate called after throwing an instance of 'pluginlib::LibraryLoadException'
      [ros2_control_node-6] what(): According to the loaded plugin descriptions the class gazebo_ros2_control/GazeboSystem with base class type hardware_interface::SystemInterface does not exist. Declared types are fake_components/GenericSystem mock_components/GenericSystem test_hardware_components/TestSystemCommandModes test_hardware_components/TestTwoJointSystem
      我的相关包版本:
      ros-humble-ros2-control is already the newest version (2.51.0-1jammy.20250617.234359);
      ros-humble-ros2-controllers is already the newest version (2.47.0-1jammy.20250618.000355);
      ros-humble-gazebo-ros2-control is already the newest version (0.4.10-1jammy.20250617.235819);
      ros-humble-gazebo-ros-pkgs is already the newest version (3.9.0-1jammy.20250618.001012);
      在/opt/ros/humble/share/gazebo_ros2_control/gazebo_hardware_plugins.xml描述性文件下,其定义的基类是gazebo_ros2_control::GazeboSystemInterface,而非系统提示的hardware_interface::SystemInterface,请问该如何解决?
      我的ros2_control.xacro配置如下:
      <hardware>
      <plugin>gazebo_ros2_control/GazeboSystem</plugin>
      <param name="robot_sim_type">gazebo_ros2_control/GazeboSystem</param>
      </hardware>
      <gazebo>
      <plugin name="gazebo_ros2_control" filename="libgazebo_ros2_control.so">
      <parameters>$(find robot_description)/config/swhbot_ros2_controllers.yaml</parameters>
      <robot_sim_type>gazebo_ros2_control/GazeboSystem</robot_sim_type>
      <robot_param>/robot_description</robot_param>
      </plugin>
      </gazebo>
