    清华源一键安装失败
    wsl2 arm64 一键安装 失败
    3.3k
      电脑是ARM架构,win11,使用了清华源。在wsl里进行一键安装,ros2humble失败,请问怎么样解决啊
      --2025-06-25 10:22:23--  http://fishros.com/install
      Resolving fishros.com (fishros.com)... 47.119.165.169
      Connecting to fishros.com (fishros.com)|47.119.165.169|:80... connected.
      --2025-06-25 10:22:23--  http://fishros.com/install/
      Length: 960 [application/octet-stream]
      Saving to: ‘fishros’
      fishros                       100%[=================================================>]     960  --.-KB/s    in 0s
      2025-06-25 10:22:23 (47.9 MB/s) - ‘fishros’ saved [960/960]
      Reading package lists... Done
      python3-distro is already the newest version (1.7.0-1).
      python3-yaml is already the newest version (5.4.1-1ubuntu1).
      The following packages were automatically installed and are no longer required:
        acl adwaita-icon-theme alsa-topology-conf alsa-ucm-conf at-spi2-core cpu-checker dconf-gsettings-backend
        dconf-service fontconfig glib-networking glib-networking-common glib-networking-services gsettings-desktop-schemas
        gstreamer1.0-plugins-base gstreamer1.0-x gtk-update-icon-cache hicolor-icon-theme humanity-icon-theme
        ibverbs-providers ipxe-qemu ipxe-qemu-256k-compat-efi-roms libaa1 libaio1 libasound2 libasound2-data libasyncns0
        libatk-bridge2.0-0 libatk1.0-0 libatk1.0-data libatspi2.0-0 libavahi-client3 libavahi-common-data libavahi-common3
        libavc1394-0 libboost-iostreams1.74.0 libboost-thread1.74.0 libbrlapi0.8 libcaca0 libcacard0 libcairo-gobject2
        libcairo2 libcdparanoia0 libcolord2 libcups2 libdatrie1 libdaxctl1 libdconf1 libdecor-0-0 libdecor-0-plugin-1-cairo
        libdv4 libepoxy0 libfdt1 libflac8 libgbm1 libgdk-pixbuf-2.0-0 libgdk-pixbuf2.0-bin libgdk-pixbuf2.0-common libgfapi0
        libgfrpc0 libgfxdr0 libglusterfs0 libgraphite2-3 libgstreamer-plugins-base1.0-0 libgstreamer-plugins-good1.0-0
        libgtk-3-0 libgtk-3-bin libgtk-3-common libgudev-1.0-0 libharfbuzz0b libibverbs1 libiec61883-0 libiscsi7
        libjack-jackd2-0 liblcms2-2 libmp3lame0 libmpg123-0 libndctl6 libnl-route-3-200 libnspr4 libnss3 libogg0 libopus0
        liborc-0.4-0 libpango-1.0-0 libpangocairo-1.0-0 libpangoft2-1.0-0 libpcsclite1 libpixman-1-0 libpmem1 libpmemobj1
        libproxy1v5 libpulse0 librados2 libraw1394-11 librbd1 librdmacm1 librsvg2-2 librsvg2-common libsamplerate0
        libsdl2-2.0-0 libshout3 libslirp0 libsndfile1 libspeex1 libspice-server1 libtag1v5 libtag1v5-vanilla libthai-data
        libthai0 libtheora0 libtwolame0 libusbredirparser1 libv4l-0 libv4lconvert0 libvirglrenderer1 libvisual-0.4-0
        libvorbis0a libvorbisenc2 libvpx7 libvte-2.91-0 libvte-2.91-common libwavpack1 libwayland-client0 libwayland-cursor0
        libwayland-egl1 libwayland-server0 libxcb-render0 libxcursor1 libxdamage1 libxkbcommon0 ovmf seabios
        session-migration ubuntu-mono
      Use 'sudo apt autoremove' to remove them.
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      --2025-06-25 10:22:25--  http://mirror.fishros.com/install/tools/base.py
      Resolving mirror.fishros.com (mirror.fishros.com)... 47.119.165.169
      Connecting to mirror.fishros.com (mirror.fishros.com)|47.119.165.169|:80... connected.
      Length: 51510 (50K) [application/octet-stream]
      Saving to: ‘/tmp/fishinstall//tools/base.py’
      /tmp/fishinstall//tools/base. 100%[=================================================>]  50.30K  --.-KB/s    in 0.1s
      2025-06-25 10:22:25 (398 KB/s) - ‘/tmp/fishinstall//tools/base.py’ saved [51510/51510]
      [-][0.00s] CMD Result:success
      Run CMD Task:[wget http://mirror.fishros.com/install/tools/translation/translator.py -O /tmp/fishinstall//tools/translation/translator.py --no-check-certificate]
      [-][0.38s] CMD Result:success
      Run CMD Task:[wget http://mirror.fishros.com/install/tools/translation/assets/zh_CN.py -O /tmp/fishinstall//tools/translation/assets/zh_CN.py --no-check-certificate]
      [-][0.19s] CMD Result:success
      Run CMD Task:[wget http://mirror.fishros.com/install/tools/translation/assets/en_US.py -O /tmp/fishinstall//tools/translation/assets/en_US.py --no-check-certificate]
      [-][0.20s] CMD Result:success
      Run CMD Task:[wget https://fishros.org.cn/forum/topic/1733 -O /tmp/t1733 -q  --timeout 10 && rm -rf /tmp/t1733]
      [-][0.80s] CMD Result:success
      已为您切换语言至当前所在国家语言:zh_CN
      基础检查通过...
                      .'// 可以多看看小鱼的文章  | 关注B站鱼香ROS机器人 \ `.
      RUN Choose Task:[请输入括号内的数字]
      ---众多工具,等君来用---
      ROS相关:
      常用软件:
        [6]:一键安装:NodeJS环境
        [7]:一键安装:VsCode开发工具
        [8]:一键安装:Docker
        [10]:一键安装:微信(可以在Linux上使用的微信)
        [15]:一键安装:QQ for Linux
      配置工具:
        [13]:一键配置:python国内源
      [0]:quit
      请输入[]内的数字以选择:1
      Run CMD Task:[wget http://mirror.fishros.com/install/tools/tool_install_ros.py -O /tmp/fishinstall/tools/tool_install_ros.py --no-check-certificate]
      [-][0.37s] CMD Result:success
      Run CMD Task:[wget http://mirror.fishros.com/install/tools/tool_config_rosenv.py -O /tmp/fishinstall/tools/tool_config_rosenv.py --no-check-certificate]
      [-][0.21s] CMD Result:success
      Run CMD Task:[wget http://mirror.fishros.com/install/tools/tool_config_system_source.py -O /tmp/fishinstall/tools/tool_config_system_source.py --no-check-certificate]
      [-][0.16s] CMD Result:success
      小鱼:检测当前系统ubuntu22.04:jammy 支持一键安装ROS
      [1]:更换系统源再继续安装
      [2]:不更换继续安装
      [0]:quit
      请输入[]内的数字以选择:2
      ============正在添加ROS源密钥=================
      [-][12.17s] Get:28 https://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports noble-updates/restricted arm64 c-n-f Metadata [440 [-][13.08s] Get:32 https://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports noble-updates/universe arm64 c-n-f Metadata [25.4 k[-][13.17s] Get:36 https://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports noble-updates/multiverse arm64 c-n-f Metadata [408 [/][13.21s] Get:41 https://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports noble-backports/restricted arm64 c-n-f Metadata [11[/][13.37s] Get:45 https://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports noble-backports/universe arm64 c-n-f Metadata [1300[\][13.37s] Get:46 https://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports noble-backports/multiverse arm64 c-n-f Metadata [11[-][38.42s]   Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4000:1::19). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4000:1::16). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4002:1::10a). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4002:1::10c). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4002:1::10b). - connect (101: Network is unreachable) Could not connect to ports.ubuntu.com:80 (91.189.91.104), connection timed out Could not connect to ports.ubuntu.com:80 (91.189.91.102), connection timed out Could not connect to ports.ubuntu.com:80 (185.125.190.39), connection timed out Could not connect to ports.ubuntu.com:80 (91.189.91.103), connection timed out Could not connect to ports.ubuntu.com:80 (185.[/][38.42s]   Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4000:1::19). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4000:1::16). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4002:1::10a). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4002:1::10c). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4002:1::10b). - connect (101: Network is unreachable) Could not connect to ports.ubuntu.com:80 (91.189.91.104), connection timed out Could not connect to ports.ubuntu.com:80 (91.189.91.102), connection timed out Could not connect to ports.ubuntu.com:80 (185.125.190.39), connection timed out Could not connect to ports.ubuntu.com:80 (91.189.91.103), connection timed out Could not connect to ports.ubuntu.com:80 (185.[-][38.60s] CMD Result:code:100
      apt更新失败,后续程序可能会继续尝试...,[]
      Run CMD Task:[sudo apt search curl ]
      [-][0.12s]   This package retrieves data from url-format files such as http://, ftp://, package:// file://, etc., and lo[-][0.12s]   This package retrieves data from url-format files such as http://, ftp://, package:// file://, etc., and lo[-][0.12s]   This package retrieves data from url-format files such as http://, ftp://, package:// file://, etc., and lo[-][0.12s] CMD Result:success
      [-][0.18s] CMD Result:success
      Run CMD Task:[sudo apt search gnupg2 ]
      [-][0.11s] CMD Result:success
      没有找到包:gnupg2
      正在挑选最快的密钥服务:['https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc', 'https://raw.githubusercontent.com/ros/rosdistro/master/ros.asc']
      - https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc          延时:0.55s
      - https://raw.githubusercontent.com/ros/rosdistro/master/ros.asc                超时
      已自动选择最快密钥服务:https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc
      [-][0.66s] CMD Result:success
      没有找到包:aptitude
      Run CMD Task:[sudo apt install   ros-humble-desktop -y]
      Some packages could not be installed. This may mean that you have
      requested an impossible situation or if you are using the unstable
      distribution that some required packages have not yet been created
      or been moved out of Incoming.
      The following information may help to resolve the situation:
       python3-catkin-pkg-modules : Depends: python3-dateutil but it is not installable
                                    Depends: python3-docutils but it is not installable
       ros-humble-action-tutorials-cpp : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
       ros-humble-ament-cmake : Depends: cmake but it is not installable
       ros-humble-ament-cmake-core : Depends: cmake but it is not installable
                                     Depends: ros-humble-ament-package but it is not going to be installed
       ros-humble-ament-cmake-gmock : Depends: google-mock but it is not installable
       ros-humble-ament-cmake-gtest : Depends: libgtest-dev but it is not installable
       ros-humble-ament-cmake-pytest : Depends: python3-pytest but it is not installable
       ros-humble-ament-cppcheck : Depends: cppcheck but it is not installable
       ros-humble-ament-flake8 : Depends: python3-flake8 but it is not installable
       ros-humble-ament-pep257 : Depends: pydocstyle but it is not installable
       ros-humble-ament-xmllint : Depends: libxml2-utils but it is not installable
       ros-humble-class-loader : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                                 Depends: libconsole-bridge-dev but it is not installable
                                 Depends: ros-humble-console-bridge-vendor but it is not going to be installed
       ros-humble-composition : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
       ros-humble-demo-nodes-cpp : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
       ros-humble-demo-nodes-cpp-native : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                                          Depends: ros-humble-fastrtps but it is not installable
                                          Depends: ros-humble-rmw-fastrtps-cpp but it is not installable
       ros-humble-depthimage-to-laserscan : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                                            Depends: libopencv-core4.5d (>= 4.5.4+dfsg) but it is not installable
                                            Depends: libopencv-flann4.5d (>= 4.5.4+dfsg) but it is not installable
                                            Depends: libopencv-dev but it is not installable
                                            Depends: ros-humble-image-geometry but it is not going to be installed
       ros-humble-examples-rclcpp-minimal-composition : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
       ros-humble-examples-rclcpp-minimal-subscriber : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
       ros-humble-image-tools : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                                Depends: libopencv-highgui4.5d (>= 4.5.4+dfsg) but it is not installable
                                Depends: libopencv-imgcodecs4.5d (>= 4.5.4+dfsg) but it is not installable
                                Depends: libopencv-imgproc4.5d (>= 4.5.4+dfsg) but it is not installable
                                Depends: libopencv-videoio4.5d (>= 4.5.4+dfsg) but it is not installable
       ros-humble-intra-process-demo : Depends: libopencv-core4.5d (>= 4.5.4+dfsg) but it is not installable
       ros-humble-joy : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                        Depends: ros-humble-sdl2-vendor but it is not going to be installed
       ros-humble-kdl-parser : Depends: liborocos-kdl1.5 (>= 1.5.1) but it is not installable
       ros-humble-launch : Depends: python3-lark but it is not installable
       ros-humble-launch-testing : Depends: python3-pytest but it is not installable
       ros-humble-logging-demo : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
       ros-humble-orocos-kdl-vendor : Depends: libeigen3-dev but it is not installable
                                      Depends: liborocos-kdl-dev but it is not installable
       ros-humble-pcl-conversions : Depends: libeigen3-dev but it is not installable
                                    Depends: libpcl-common1.12 but it is not installable
                                    Depends: libpcl-dev but it is not installable
                                    Depends: libpcl-io1.12 but it is not installable
       ros-humble-python-cmake-module : Depends: python3-dev but it is not installable
       ros-humble-python-orocos-kdl-vendor : Depends: python3-pykdl but it is not installable
                                             Depends: ros-humble-pybind11-vendor but it is not going to be installed
       ros-humble-python-qt-binding : Depends: libpyside2-dev but it is not installable
                                      Depends: libshiboken2-dev but it is not installable
                                      Depends: pyqt5-dev but it is not installable
                                      Depends: python3-pyqt5 but it is not installable
                                      Depends: python3-pyqt5.qtsvg but it is not installable
                                      Depends: python3-pyside2.qtsvg but it is not installable
                                      Depends: python3-sip-dev but it is not installable
                                      Depends: shiboken2 but it is not installable
       ros-humble-qt-dotgraph : Depends: python3-pydot but it is not installable
       ros-humble-quality-of-service-demo-cpp : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
       ros-humble-rcl-logging-spdlog : Depends: libspdlog1-fmt8 but it is not installable
                                       Depends: libspdlog-dev but it is not installable
                                       Depends: ros-humble-spdlog-vendor but it is not going to be installed
       ros-humble-rcl-yaml-param-parser : Depends: libyaml-dev but it is not installable
       ros-humble-rclcpp-components : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
       ros-humble-robot-state-publisher : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
       ros-humble-ros2cli : Depends: python3-argcomplete but it is not installable
                            Depends: python3-packaging but it is not installable
       ros-humble-ros2doctor : Depends: python3-psutil but it is not installable
                               Depends: python3-rosdistro-modules but it is not going to be installed
       ros-humble-ros2pkg : Depends: python3-empy but it is not installable
       ros-humble-ros2topic : Depends: python3-numpy but it is not installable
       ros-humble-rosbag2-compression : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                                        Depends: libtinyxml2-9 (>= 8.0.0) but it is not installable
       ros-humble-rosbag2-compression-zstd : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                                             Depends: ros-humble-zstd-vendor but it is not going to be installed
       ros-humble-rosbag2-cpp : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
       ros-humble-rosbag2-py : Depends: libtinyxml2-9 (>= 8.0.0) but it is not installable
                               Depends: libyaml-cpp0.7 (>= 0.7.0) but it is not installable
       ros-humble-rosbag2-storage : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                                    Depends: ros-humble-yaml-cpp-vendor but it is not going to be installed
       ros-humble-rosbag2-storage-default-plugins : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
       ros-humble-rosbag2-transport : Depends: libyaml-cpp0.7 (>= 0.7.0) but it is not installable
       ros-humble-rosidl-cmake : Depends: python3-empy but it is not installable
                                 Depends: ros-humble-rosidl-adapter but it is not going to be installed
                                 Depends: ros-humble-rosidl-parser but it is not going to be installed
       ros-humble-rosidl-generator-c : Depends: python3-dev but it is not installable
                                       Depends: ros-humble-rosidl-cli but it is not going to be installed
       ros-humble-rosidl-generator-cpp : Depends: python3-dev but it is not installable
       ros-humble-rosidl-generator-py : Depends: python3-numpy but it is not installable
       ros-humble-rosidl-runtime-py : Depends: python3-numpy but it is not installable
       ros-humble-rosidl-typesupport-c : Depends: python3-dev but it is not installable
       ros-humble-rosidl-typesupport-cpp : Depends: python3-dev but it is not installable
       ros-humble-rosidl-typesupport-fastrtps-c : Depends: python3-dev but it is not installable
       ros-humble-rosidl-typesupport-fastrtps-cpp : Depends: python3-dev but it is not installable
       ros-humble-rosidl-typesupport-introspection-c : Depends: python3-dev but it is not installable
       ros-humble-rosidl-typesupport-introspection-cpp : Depends: python3-dev but it is not installable
       ros-humble-rqt-bag-plugins : Depends: python3-cairo but it is not installable
                                    Depends: python3-pil but it is not installable
       ros-humble-rqt-image-view : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                                   Depends: libqt5core5a (>= 5.15.1) but it is not installable
                                   Depends: libqt5gui5 (>= 5.14.1) but it is not installable or
                                            libqt5gui5-gles (>= 5.14.1) but it is not installable
                                   Depends: libqt5widgets5 (>= 5.0.2) but it is not installable
                                   Depends: ros-humble-cv-bridge but it is not going to be installed
                                   Depends: ros-humble-image-transport but it is not going to be installed
                                   Depends: ros-humble-qt-gui-cpp but it is not going to be installed
                                   Depends: ros-humble-rqt-gui-cpp but it is not going to be installed
       ros-humble-rqt-plot : Depends: python3-matplotlib but it is not installable
       ros-humble-rqt-py-common : Depends: qtbase5-dev but it is not installable
       ros-humble-rviz-default-plugins : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                                         Depends: libqt5core5a (>= 5.14.1) but it is not installable
                                         Depends: libqt5gui5 (>= 5.2.0) but it is not installable or
                                                  libqt5gui5-gles (>= 5.2.0) but it is not installable
                                         Depends: ros-humble-rviz-ogre-vendor but it is not going to be installed
                                         Depends: libqt5gui5 but it is not installable
                                         Depends: libqt5opengl5 but it is not installable
                                         Depends: ros-humble-ignition-math6-vendor but it is not going to be installed
                                         Depends: ros-humble-interactive-markers but it is not going to be installed
                                         Depends: ros-humble-laser-geometry but it is not going to be installed
                                         Depends: ros-humble-resource-retriever but it is not going to be installed
                                         Depends: ros-humble-rviz-common but it is not going to be installed
                                         Depends: ros-humble-rviz-rendering but it is not going to be installed
       ros-humble-rviz2 : Depends: libqt5widgets5 (>= 5.0.2) but it is not installable
       ros-humble-sqlite3-vendor : Depends: libsqlite3-dev but it is not installable
       ros-humble-sros2 : Depends: python3-lxml but it is not installable
       ros-humble-tango-icons-vendor : Depends: tango-icon-theme but it is not installable
       ros-humble-teleop-twist-joy : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
       ros-humble-tf2 : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
       ros-humble-tf2-bullet : Depends: libbullet-dev but it is not installable
       ros-humble-tf2-eigen : Depends: libeigen3-dev but it is not installable
       ros-humble-tf2-eigen-kdl : Depends: liborocos-kdl1.5 (>= 1.5.1) but it is not installable
       ros-humble-tf2-geometry-msgs : Depends: python3-numpy but it is not installable
       ros-humble-tf2-ros : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
       ros-humble-tf2-sensor-msgs : Depends: libeigen3-dev but it is not installable
                                    Depends: ros-humble-sensor-msgs-py but it is not going to be installed
       ros-humble-tf2-tools : Depends: graphviz but it is not installable
       ros-humble-tinyxml2-vendor : Depends: libtinyxml2-dev but it is not installable
       ros-humble-turtlesim : Depends: libqt5core5a (>= 5.0.2) but it is not installable
       ros-humble-uncrustify-vendor : Depends: uncrustify but it is not installable
       ros-humble-urdf : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                         Depends: ros-humble-urdfdom but it is not going to be installed
      E: Unable to correct problems, you have held broken packages.
      [|][0.02s]  ros-humble-depthimage-to-laserscan : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installabl[-][0.02s]  ros-humble-examples-rclcpp-minimal-composition : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is no[/][0.02s]  ros-humble-examples-rclcpp-minimal-subscriber : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not[-][0.02s]                                        Depends: ros-humble-pybind11-vendor but it is not going to be installe[\][0.02s]  ros-humble-quality-of-service-demo-cpp : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not instal[\][0.02s]  ros-humble-rosbag2-compression-zstd : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installab[/][0.02s]  ros-humble-rosbag2-storage-default-plugins : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not in[|][0.02s]                                               Depends: ros-humble-yaml-cpp-vendor but it is not going to be i[/][0.03s]                                             Depends: ros-humble-rosidl-cli but it is not going to be installe[|][0.03s]                                               Depends: ros-humble-rosidl-cli but it is not going to be instal[/][0.03s]                                                  Depends: ros-humble-rosidl-cli but it is not going to be ins[\][0.03s]                                                  Depends: ros-humble-rosidl-parser but it is not going to be [-][0.03s]                                                    Depends: ros-humble-rosidl-cli but it is not going to be i[/][0.03s]                                                    Depends: ros-humble-rosidl-parser but it is not going to b[-][0.03s]                                    Depends: ros-humble-ignition-math6-vendor but it is not going to be instal[\][0.03s]                                    Depends: ros-humble-interactive-markers but it is not going to be installe[-][0.03s] CMD Result:code:100        lled
      请注意我,检测你在安装过程中出现依赖问题,请在稍后输入n,再选择y,即可解决(若无法解决,清在稍后手动运行命令: sudo aptitude install ros-humble-desktop)
      确认了解情况,请输入回车继续安装
      Run CMD Task:[sudo aptitude install   ros-humble-desktop]
      sudo: aptitude: command not found
      Run CMD Task:[sudo aptitude install   ros-humble-desktop -y]
      [-][0.00s] CMD Result:code:1
      Run CMD Task:[sudo apt search python3-colcon-common-extensions ]
      [-][0.06s] CMD Result:success
      [-][0.04s] CMD Result:code:100
      Run CMD Task:[sudo apt search python3-argcomplete ]
      [-][0.05s] CMD Result:success
      没有找到包:python3-argcomplete
      [-][0.08s] CMD Result:code:100
      Run CMD Task:[ls /opt/ros/humble/setup.bash]
      [-][0.03s] CMD Result:code:2
      [-][0.00s] CMD Result:code:2
      3 1 条回复 最后回复 回复 引用 0
        3487802191 @3487802191
        最后由 3487802191 编辑
        似乎复制粘贴的有点乱,在评论里把整个运行输出放一下
        基础检查通过...
        ---众多工具,等君来用---
        ROS相关:
        常用软件:
          [6]:一键安装:NodeJS环境
          [7]:一键安装:VsCode开发工具
          [8]:一键安装:Docker
        配置工具:
          [13]:一键配置:python国内源
        [0]:quit
        请输入[]内的数字以选择:1
        [1]:更换系统源再继续安装
        [2]:不更换继续安装
        [0]:quit
        请输入[]内的数字以选择:2
          最后由 3487802191 编辑
          没有找到包:gnupg2
          • https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc 延时:0.55s
          • https://raw.githubusercontent.com/ros/rosdistro/master/ros.asc 超时
          [/][0.00s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][0.11s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][0.51s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][0.61s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][0.71s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][0.81s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][0.91s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][1.01s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][1.12s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][1.22s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][1.32s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][1.42s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][1.52s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][1.62s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][1.72s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][1.82s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][1.92s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][2.02s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][2.12s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][2.22s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][2.33s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][2.43s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][2.53s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][2.63s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][2.73s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][2.83s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][2.93s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][3.03s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][3.13s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][3.23s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][3.33s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][3.43s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][3.53s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][3.64s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][3.74s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][3.84s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][3.94s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][4.04s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][4.14s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][4.24s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][4.34s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][4.44s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][4.54s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][4.64s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][4.74s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][4.84s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][4.94s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][5.05s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][5.15s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][5.25s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][5.35s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][5.45s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][5.55s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][5.65s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][5.75s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][5.85s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][5.95s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][6.05s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][6.15s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][6.25s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][6.35s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][6.45s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][6.55s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][6.66s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][6.76s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][6.86s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][6.96s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][7.06s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][7.16s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][7.26s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][7.36s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][7.46s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][7.56s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][7.66s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][7.76s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][7.86s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][7.96s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][8.06s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][8.16s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][8.26s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][8.36s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][8.46s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][8.56s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][8.66s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][8.77s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][8.87s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][8.97s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][9.07s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][9.17s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][9.27s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][9.37s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][9.47s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][9.57s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][9.67s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][9.77s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][9.87s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][9.97s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17[][10.08s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][10.18s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][10.28s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][10.38s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][10.48s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][10.58s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][10.68s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][10.78s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][10.89s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][10.99s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][11.09s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][11.19s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][11.29s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][11.40s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][11.50s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][11.60s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][11.70s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][11.80s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][11.90s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][12.00s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][12.10s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][12.20s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][12.30s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][12.40s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][12.50s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][12.60s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][12.70s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][12.80s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][12.91s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][13.01s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][13.11s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][13.21s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][13.31s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][13.41s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][13.51s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][13.61s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][13.71s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][13.81s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][13.91s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][14.01s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][14.11s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][14.21s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][14.31s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][14.42s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][14.52s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][14.62s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][14.72s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][14.82s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][14.92s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][15.02s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][15.12s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][15.22s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][15.32s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][15.42s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][15.52s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][15.62s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][15.72s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][15.83s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][15.93s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][16.03s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][16.13s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][16.23s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][16.33s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][16.43s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][16.53s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][16.63s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][16.73s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][16.83s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][16.93s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][17.03s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][17.13s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][17.23s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][17.34s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][17.44s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][17.54s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][17.64s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][17.74s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][17.84s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][17.94s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][18.04s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][18.14s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][18.24s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][18.34s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][18.44s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][18.54s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][18.64s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][18.74s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][18.85s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][18.95s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][19.05s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][19.15s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][19.25s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][19.35s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][19.45s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][19.55s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][19.65s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][19.75s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][19.85s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][19.96s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][20.06s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][20.16s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][20.26s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][20.36s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][20.46s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][20.56s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][20.66s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][20.76s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][20.87s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][20.97s] Executing: /tmp/apt-key-
            最后由 3487802191 编辑
            gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][21.07s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][21.17s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][21.27s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][21.37s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][21.47s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][21.58s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][21.68s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][21.78s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][21.88s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][21.98s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][22.08s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][22.18s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][22.28s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][22.38s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][22.48s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][22.58s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][22.69s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][22.79s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][22.89s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][22.99s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][23.09s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][23.19s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][23.29s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][23.39s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][23.49s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][23.59s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][23.69s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][23.79s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][23.89s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][23.99s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][24.09s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][24.20s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][24.30s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][24.40s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][24.50s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][24.60s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][24.70s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][24.80s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][24.90s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][25.00s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][25.10s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][25.20s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][25.30s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][25.40s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][25.51s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][25.61s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][25.71s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][25.81s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][25.91s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][26.01s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][26.11s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][26.21s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][26.31s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][26.41s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][26.51s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][26.62s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][26.72s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][26.82s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][26.92s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][27.02s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][27.12s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][27.22s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][27.32s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][27.42s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][27.52s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][27.62s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][27.72s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][27.82s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][27.93s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][28.03s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][28.13s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][28.23s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][28.33s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][28.43s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][28.53s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][28.63s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][28.73s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][28.83s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][28.93s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][29.03s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][29.13s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][29.23s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][29.34s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][29.44s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][29.54s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][29.64s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][29.74s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][29.84s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][29.94s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][30.04s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][30.14s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][30.24s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][30.34s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][30.44s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][30.54s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][30.64s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][30.75s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][30.85s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][30.95s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][31.05s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][31.15s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][31.25s] Executing: /tmp/apt-key-
            gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][31.35s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][31.45s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][31.55s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][31.65s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][31.75s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][31.85s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][31.96s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][32.06s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][32.16s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][32.26s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][32.36s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][32.46s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][32.56s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][32.66s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][32.76s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][32.86s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][32.96s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][33.06s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][33.16s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][33.26s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][33.37s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][33.47s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][33.57s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][33.67s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][33.77s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][33.87s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][33.97s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][34.07s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][34.17s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][34.27s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][34.37s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][34.47s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][34.57s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][34.67s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][34.77s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][34.88s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][34.98s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][35.08s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][35.18s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][35.28s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][35.38s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][35.48s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][35.58s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][35.68s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][35.78s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][35.88s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][35.98s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][36.08s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][36.18s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][36.29s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][36.39s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][36.49s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][36.59s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][36.69s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][36.79s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][36.89s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][36.99s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][37.09s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][37.19s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][37.29s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][37.39s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][37.50s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][37.60s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][37.70s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][37.80s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][37.90s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][38.00s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][38.10s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][38.21s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][38.31s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][38.41s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][38.51s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][38.61s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][38.71s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][38.81s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][38.91s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][39.01s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][39.11s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][39.21s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][39.31s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][39.41s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][39.51s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][39.62s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][39.72s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][39.82s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][39.92s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][40.02s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][40.12s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][40.22s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][40.32s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][40.42s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][40.52s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][40.62s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][40.73s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][40.83s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][40.93s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][41.03s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][41.13s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][41.23s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][41.33s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][41.43s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][41.53s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][41.63s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][41.73s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][41.83s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][41.93s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][42.03s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][42.13s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][42.24s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][42.34s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][42.44s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][42.54s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][42.64s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][42.74s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][42.84s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][42.94s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][43.04s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][43.14s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][43.24s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][43.34s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][43.44s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][43.55s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][43.65s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][43.75s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][43.85s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][43.95s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][44.05s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][44.15s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][44.25s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][44.35s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][44.45s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][44.55s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][44.65s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][44.75s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][44.85s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][44.95s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][45.05s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][45.15s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][45.25s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[][45.36s] Executing: /tmp/apt-key-gpghome.19cP1Qffeq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB1[-][45.46s] CMD Result:code:2
            Run CMD Task:[curl -s https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc | sudo gpg --no-default-keyring --keyring gnupg-ring:/etc/apt/trusted.gpg.d/ros.gpg --import]
            [-][0.57s] CMD Result:success
            Run CMD Task:[sudo chmod 644 /etc/apt/trusted.gpg.d/ros.gpg]
            [-][0.00s] CMD Result:success
            [-][0.01s] CMD Result:success
            根据您的系统,为您推荐安装源为['http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu/']
              [-][38.46s] Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4002:1::10c). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4002:1::10b). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4002:1::10a). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4000:1::19). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4000:1::16). - connect (101: Network is unreachable) Could not connect to ports.ubuntu.com:80 (91.189.91.102), connection timed out Could not connect to ports.ubuntu.com:80 (91.189.91.104), connection timed out Could not connect to ports.ubuntu.com:80 (91.189.91.103), connection timed out Could not connect to ports.ubuntu.com:80 (185.125.190.39), connection timed out Could not connect to ports.ubuntu.com:80 (185.[/][38.46s] Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4002:1::10c). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4002:1::10b). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4002:1::10a). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4000:1::19). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4000:1::16). - connect (101: Network is unreachable) Could not connect to ports.ubuntu.com:80 (91.189.91.102), connection timed out Could not connect to ports.ubuntu.com:80 (91.189.91.104), connection timed out Could not connect to ports.ubuntu.com:80 (91.189.91.103), connection timed out Could not connect to ports.ubuntu.com:80 (185.125.190.39), connection timed out Could not connect to ports.ubuntu.com:80 (185.[/][38.52s] Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4002:1::10c). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4002:1::10b). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4002:1::10a). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4000:1::19). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4000:1::16). - connect (101: Network is unreachable) Could not connect to ports.ubuntu.com:80 (91.189.91.102), connection timed out Could not connect to ports.ubuntu.com:80 (91.189.91.104), connection timed out Could not connect to ports.ubuntu.com:80 (91.189.91.103), connection timed out Could not connect to ports.ubuntu.com:80 (185.125.190.39), connection timed out Could not connect to ports.ubuntu.com:80 (185.[/][38.62s] Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4002:1::10c). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4002:1::10b). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4002:1::10a). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4000:1::19). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4000:1::16). - connect (101: Network is unreachable) Could not connect to ports.ubuntu.com:80 (91.189.91.102), connection timed out Could not connect to ports.ubuntu.com:80 (91.189.91.104), connection timed out Could not connect to ports.ubuntu.com:80 (91.189.91.103), connection timed out Could not connect to ports.ubuntu.com:80 (185.125.190.39), connection timed out Could not connect to ports.ubuntu.com:80 (185.[-][38.86s] CMD Result:code:100
              apt更新失败,后续程序可能会继续尝试...,[]
              Run CMD Task:[sudo apt search ros-base ]
              [-][0.13s] Node that enables connected ROS-based devices or robots to exchange ROS messages via an MQTT broker using t[-][0.13s] Node that enables connected ROS-based devices or robots to exchange ROS messages via an MQTT broker using t[-][0.13s] Node that enables connected ROS-based devices or robots to exchange ROS messages via an MQTT broker using t[-][0.13s] CMD Result:success
              [-][0.05s] Node that enables connected ROS-based devices or robots to exchange ROS messages via an MQTT broker using t[-][0.05s] Node that enables connected ROS-based devices or robots to exchange ROS messages via an MQTT broker using t[-][0.05s] Node that enables connected ROS-based devices or robots to exchange ROS messages via an MQTT broker using t[-][0.05s] CMD Result:success
              RUN Choose Task:[请输入括号内的数字]
              [1]:humble(ROS2)
              [2]:iron(ROS2)
              [3]:rolling(ROS2)
              [0]:quit
              请输入[]内的数字以选择:1
              请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
              [1]:humble(ROS2)桌面版
              [2]:humble(ROS2)基础版(小)
              [0]:quit
              请输入[]内的数字以选择:1
              Run CMD Task:[sudo apt search aptitude ]
              [-][0.06s] CMD Result:success
              没有找到包:aptitude
              Run CMD Task:[sudo apt install ros-humble-desktop -y]
              Reading package lists... Done
              Some packages could not be installed. This may mean that you have
              requested an impossible situation or if you are using the unstable
              distribution that some required packages have not yet been created
              or been moved out of Incoming.
              The following information may help to resolve the situation:
              python3-catkin-pkg-modules : Depends: python3-dateutil but it is not installable
              Depends: python3-docutils but it is not installable
              ros-humble-action-tutorials-cpp : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              ros-humble-ament-cmake : Depends: cmake but it is not installable
              ros-humble-ament-cmake-core : Depends: cmake but it is not installable
              Depends: ros-humble-ament-package but it is not going to be installed
              ros-humble-ament-cmake-gmock : Depends: google-mock but it is not installable
              ros-humble-ament-cmake-gtest : Depends: libgtest-dev but it is not installable
              ros-humble-ament-cmake-pytest : Depends: python3-pytest but it is not installable
              ros-humble-ament-cppcheck : Depends: cppcheck but it is not installable
              ros-humble-ament-flake8 : Depends: python3-flake8 but it is not installable
              ros-humble-ament-pep257 : Depends: pydocstyle but it is not installable
              ros-humble-ament-xmllint : Depends: libxml2-utils but it is not installable
              ros-humble-class-loader : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              Depends: libconsole-bridge-dev but it is not installable
              Depends: ros-humble-console-bridge-vendor but it is not going to be installed
              ros-humble-composition : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              ros-humble-demo-nodes-cpp : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              ros-humble-demo-nodes-cpp-native : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              Depends: ros-humble-fastrtps but it is not installable
              Depends: ros-humble-rmw-fastrtps-cpp but it is not installable
              ros-humble-depthimage-to-laserscan : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              Depends: libopencv-core4.5d (>= 4.5.4+dfsg) but it is not installable
              Depends: libopencv-flann4.5d (>= 4.5.4+dfsg) but it is not installable
              Depends: libopencv-dev but it is not installable
              Depends: ros-humble-image-geometry but it is not going to be installed
              ros-humble-examples-rclcpp-minimal-composition : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              ros-humble-examples-rclcpp-minimal-subscriber : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              ros-humble-image-tools : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              Depends: libopencv-highgui4.5d (>= 4.5.4+dfsg) but it is not installable
              Depends: libopencv-imgcodecs4.5d (>= 4.5.4+dfsg) but it is not installable
              Depends: libopencv-imgproc4.5d (>= 4.5.4+dfsg) but it is not installable
              Depends: libopencv-videoio4.5d (>= 4.5.4+dfsg) but it is not installable
              ros-humble-intra-process-demo : Depends: libopencv-core4.5d (>= 4.5.4+dfsg) but it is not installable
              ros-humble-joy : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              Depends: ros-humble-sdl2-vendor but it is not going to be installed
              ros-humble-kdl-parser : Depends: liborocos-kdl1.5 (>= 1.5.1) but it is not installable
              ros-humble-launch : Depends: python3-lark but it is not installable
              ros-humble-launch-testing : Depends: python3-pytest but it is not installable
              ros-humble-logging-demo : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              ros-humble-orocos-kdl-vendor : Depends: libeigen3-dev but it is not installable
              Depends: liborocos-kdl-dev but it is not installable
              ros-humble-pcl-conversions : Depends: libeigen3-dev but it is not installable
              Depends: libpcl-common1.12 but it is not installable
              Depends: libpcl-dev but it is not installable
              Depends: libpcl-io1.12 but it is not installable
              ros-humble-python-cmake-module : Depends: python3-dev but it is not installable
              ros-humble-python-orocos-kdl-vendor : Depends: python3-pykdl but it is not installable
              Depends: ros-humble-pybind11-vendor but it is not going to be installed
              ros-humble-python-qt-binding : Depends: libpyside2-dev but it is not installable
              Depends: libshiboken2-dev but it is not installable
              Depends: pyqt5-dev but it is not installable
              Depends: python3-pyqt5 but it is not installable
              Depends: python3-pyqt5.qtsvg but it is not installable
              Depends: python3-pyside2.qtsvg but it is not installable
              Depends: python3-sip-dev but it is not installable
              Depends: shiboken2 but it is not installable
              ros-humble-qt-dotgraph : Depends: python3-pydot but it is not installable
              ros-humble-quality-of-service-demo-cpp : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              ros-humble-rcl-logging-spdlog : Depends: libspdlog1-fmt8 but it is not installable
              Depends: libspdlog-dev but it is not installable
              Depends: ros-humble-spdlog-vendor but it is not going to be installed
              ros-humble-rcl-yaml-param-parser : Depends: libyaml-dev but it is not installable
              ros-humble-rclcpp-components : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              ros-humble-robot-state-publisher : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              ros-humble-ros2cli : Depends: python3-argcomplete but it is not installable
              Depends: python3-packaging but it is not installable
              ros-humble-ros2doctor : Depends: python3-psutil but it is not installable
              Depends: python3-rosdistro-modules but it is not going to be installed
              ros-humble-ros2pkg : Depends: python3-empy but it is not installable
              ros-humble-ros2topic : Depends: python3-numpy but it is not installable
              ros-humble-rosbag2-compression : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              Depends: libtinyxml2-9 (>= 8.0.0) but it is not installable
              ros-humble-rosbag2-compression-zstd : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              Depends: ros-humble-zstd-vendor but it is not going to be installed
              ros-humble-rosbag2-cpp : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              ros-humble-rosbag2-py : Depends: libtinyxml2-9 (>= 8.0.0) but it is not installable
              Depends: libyaml-cpp0.7 (>= 0.7.0) but it is not installable
              ros-humble-rosbag2-storage : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              Depends: ros-humble-yaml-cpp-vendor but it is not going to be installed
              ros-humble-rosbag2-storage-default-plugins : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              ros-humble-rosbag2-transport : Depends: libyaml-cpp0.7 (>= 0.7.0) but it is not installable
              ros-humble-rosidl-cmake : Depends: python3-empy but it is not installable
              Depends: ros-humble-rosidl-adapter but it is not going to be installed
              Depends: ros-humble-rosidl-parser but it is not going to be installed
              ros-humble-rosidl-generator-c : Depends: python3-dev but it is not installable
              Depends: ros-humble-rosidl-cli but it is not going to be installed
              ros-humble-rosidl-generator-cpp : Depends: python3-dev but it is not installable
              ros-humble-rosidl-generator-py : Depends: python3-numpy but it is not installable
              ros-humble-rosidl-runtime-py : Depends: python3-numpy but it is not installable
              ros-humble-rosidl-typesupport-c : Depends: python3-dev but it is not installable
              ros-humble-rosidl-typesupport-cpp : Depends: python3-dev but it is not installable
              ros-humble-rosidl-typesupport-fastrtps-c : Depends: python3-dev but it is not installable
              ros-humble-rosidl-typesupport-fastrtps-cpp : Depends: python3-dev but it is not installable
              ros-humble-rosidl-typesupport-introspection-c : Depends: python3-dev but it is not installable
              ros-humble-rosidl-typesupport-introspection-cpp : Depends: python3-dev but it is not installable
              ros-humble-rqt-bag-plugins : Depends: python3-cairo but it is not installable
              Depends: python3-pil but it is not installable
              ros-humble-rqt-image-view : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              Depends: libqt5core5a (>= 5.15.1) but it is not installable
              Depends: libqt5gui5 (>= 5.14.1) but it is not installable or
              libqt5gui5-gles (>= 5.14.1) but it is not installable
              Depends: libqt5widgets5 (>= 5.0.2) but it is not installable
              Depends: ros-humble-cv-bridge but it is not going to be installed
              Depends: ros-humble-image-transport but it is not going to be installed
              Depends: ros-humble-qt-gui-cpp but it is not going to be installed
              Depends: ros-humble-rqt-gui-cpp but it is not going to be installed
              ros-humble-rqt-plot : Depends: python3-matplotlib but it is not installable
              ros-humble-rqt-py-common : Depends: qtbase5-dev but it is not installable
              ros-humble-rviz-default-plugins : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              Depends: libqt5core5a (>= 5.14.1) but it is not installable
              Depends: libqt5gui5 (>= 5.2.0) but it is not installable or
              libqt5gui5-gles (>= 5.2.0) but it is not installable
              Depends: ros-humble-rviz-ogre-vendor but it is not going to be installed
              Depends: libqt5gui5 but it is not installable
              Depends: libqt5opengl5 but it is not installable
              Depends: ros-humble-ignition-math6-vendor but it is not going to be installed
              Depends: ros-humble-interactive-markers but it is not going to be installed
              Depends: ros-humble-laser-geometry but it is not going to be installed
              Depends: ros-humble-resource-retriever but it is not going to be installed
              Depends: ros-humble-rviz-common but it is not going to be installed
              Depends: ros-humble-rviz-rendering but it is not going to be installed
              ros-humble-rviz2 : Depends: libqt5widgets5 (>= 5.0.2) but it is not installable
              ros-humble-sqlite3-vendor : Depends: libsqlite3-dev but it is not installable
              ros-humble-sros2 : Depends: python3-lxml but it is not installable
              ros-humble-tango-icons-vendor : Depends: tango-icon-theme but it is not installable
              ros-humble-teleop-twist-joy : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              ros-humble-tf2 : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              ros-humble-tf2-bullet : Depends: libbullet-dev but it is not installable
              ros-humble-tf2-eigen : Depends: libeigen3-dev but it is not installable
              ros-humble-tf2-eigen-kdl : Depends: liborocos-kdl1.5 (>= 1.5.1) but it is not installable
              ros-humble-tf2-geometry-msgs : Depends: python3-numpy but it is not installable
              ros-humble-tf2-ros : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              ros-humble-tf2-sensor-msgs : Depends: libeigen3-dev but it is not installable
              Depends: ros-humble-sensor-msgs-py but it is not going to be installed
              ros-humble-tf2-tools : Depends: graphviz but it is not installable
              ros-humble-tinyxml2-vendor : Depends: libtinyxml2-dev but it is not installable
              ros-humble-turtlesim : Depends: libqt5core5a (>= 5.0.2) but it is not installable
              ros-humble-uncrustify-vendor : Depends: uncrustify but it is not installable
              ros-humble-urdf : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
              Depends: ros-humble-urdfdom but it is not going to be installed
              E: Unable to correct problems, you have held broken packages.
              [|][0.02s] ros-humble-depthimage-to-laserscan : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installabl[-][0.02s] ros-humble-examples-rclcpp-minimal-composition : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is no[/][0.02s] ros-humble-examples-rclcpp-minimal-subscriber : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not[-][0.02s] Depends: ros-humble-pybind11-vendor but it is not going to be installe[][0.02s] ros-humble-quality-of-service-demo-cpp : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not instal[][0.02s] ros-humble-rosbag2-compression-zstd : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installab[/][0.02s] ros-humble-rosbag2-storage-default-plugins : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not in[|][0.02s] Depends: ros-humble-yaml-cpp-vendor but it is not going to be i[/][0.03s] Depends: ros-humble-rosidl-cli but it is not going to be installe[|][0.03s] Depends: ros-humble-rosidl-cli but it is not going to be instal[/][0.03s] Depends: ros-humble-rosidl-cli but it is not going to be ins[][0.03s] Depends: ros-humble-rosidl-parser but it is not going to be [-][0.03s] Depends: ros-humble-rosidl-cli but it is not going to be i[/][0.03s] Depends: ros-humble-rosidl-parser but it is not going to b[-][0.03s] Depends: ros-humble-ignition-math6-vendor but it is not going to be instal[][0.03s] Depends: ros-humble-interactive-markers but it is not going to be installe[-][0.03s] CMD Result:code:100 lled
              请注意我,检测你在安装过程中出现依赖问题,请在稍后输入n,再选择y,即可解决(若无法解决,清在稍后手动运行命令: sudo aptitude install ros-humble-desktop)
              确认了解情况,请输入回车继续安装
              Run CMD Task:[sudo aptitude install ros-humble-desktop]
              sudo: aptitude: command not found
              Run CMD Task:[sudo aptitude install ros-humble-desktop -y]
              [-][0.00s] CMD Result:code:1
              Run CMD Task:[sudo apt search python3-colcon-common-extensions ]
              [-][0.04s] CMD Result:code:100
              Run CMD Task:[sudo apt search python3-argcomplete ]
              没有找到包:python3-argcomplete
              [-][0.11s] CMD Result:success
              [-][0.08s] CMD Result:code:100
              Run CMD Task:[ls /opt/ros/humble/setup.bash]
              [-][0.03s] CMD Result:code:2
              [-][0.00s] CMD Result:code:2
