    老师,b站视频课6.2.2,这里我按照视频里的代码写的,但是在执行的时候报错了
    rviz 运行
    1.6k
      2586375669 年度VIP
      下面是我的代码
      import launch
      import launch_ros
      import os
      import launch_ros.parameter_descriptions
      urdf_package_path=get_package_share_directory('fishbot_description')
      default_urdf_path=os.path.join(urdf_package_path,'urdf','first_robot.urdf')
      action_declare_arg_mode_path=launch.actions.DeclareLaunchArgument(
          name='model',default_value=str(default_urdf_path),description='加载的模型文件路径'
      substitutions_result=launch.substitutions.Command(['cat ',launch.substitutions.launch_configuration('model')])
      robot_description_value=launch_ros.parameter_descriptions.ParameterValue(substitutions_result,value_type=str)
      action_robot_state_publisher=launch_ros.actions.Node(
          parameters=[{'robot_description':robot_description_value}]
      action_joint_state_publisher=launch_ros.actions.Node(
          package='joint_state_publisher',
          executable='joint_state_publisher',
      action_rviz_node=launch_ros.actions.Node(
          package='rviz2',
          executable='rviz2',
      return launch.launch_description([
          action_declare_arg_mode_path,
          action_robot_state_publisher,
          action_joint_state_publisher,
          action_rviz_node,
