    一行代码安装ROS1/ROS2,提示apt异常,最终只能用国外源进行安装,导致安装速度变慢
    一键安装 ros1ros2 apt存在问题
    1.7k
    • HH
      H
      最近给几台电脑安装ROS1/ROS2,尝试过用手机热点、家用有线/无线、公司有线/无线,都会出现问题。换源三次
      列表都失败了,最终还是用了ROS的官方源,安装变得很慢。
      [-]Result:code:100                           /ros/ubuntu focal/main amd64 Packages [698 kB]130 80]
      当前apt存在问题,推荐使用一键换源处理...若无法处理,请将下列错误信息告知小鱼...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: Failed to fetch http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu/dists/focal/main/binary-amd64/Packages.gz  File has unexpected size (1079790 != 1092928). Mirror sync in progress? [IP: 101.6.15.130 80]\n', '   Hashes of expected file:\n', '    - Filesize:1092928 [weak]\n', '    - SHA256:399489b1137d48ad19917f0f55c395a01cf8b2a9653c573ada099bccaffcdf2e\n', '    - SHA1:e4c6e9e39176f3385ef4bd56ebe78e4e60fee11a [weak]\n', '    - MD5Sum:e3c5c5b8bc863ab11413cc4d22d697bf [weak]\n', '   Release file created at: Fri, 01 Jul 2022 19:53:27 +0000\n', 'E: Some index files failed to download. They have been ignored, or old ones used instead.\n']
      [-]Result:success
      [-]Result:code:100                           untu focal/main amd64 Packages [698 kB]0.233.177.156 443]
      当前apt存在问题,推荐使用一键换源处理...若无法处理,请将下列错误信息告知小鱼...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: Failed to fetch https://repo.huaweicloud.com/ros2/ubuntu/dists/focal/main/binary-amd64/Packages.gz  File has unexpected size (1079790 != 1092928). Mirror sync in progress? [IP: 120.233.177.156 443]\n', '   Hashes of expected file:\n', '    - Filesize:1092928 [weak]\n', '    - SHA256:399489b1137d48ad19917f0f55c395a01cf8b2a9653c573ada099bccaffcdf2e\n', '    - SHA1:e4c6e9e39176f3385ef4bd56ebe78e4e60fee11a [weak]\n', '    - MD5Sum:e3c5c5b8bc863ab11413cc4d22d697bf [weak]\n', '   Release file created at: Fri, 01 Jul 2022 19:53:27 +0000\n', 'E: Some index files failed to download. They have been ignored, or old ones used instead.\n']
        小鱼 技术大佬 @H
        @H 这个是因为某服的问题,目前没有比较好的解决方法,特定地区的网络就会有这个问题。
        HH 1 条回复 最后回复 回复 引用 0
        • HH
          H @小鱼
          @小鱼 感谢~ 看来广州被针对了
