    安装好moveit2后,运行ros2 launch moveit2_tutorials demo.launch.py,rviz2出现在屏幕外,看不到rviz2界面
    ros2 moveit2 demo
    1.4k
      wwwzy
      wzy@DESKTOP-AOGOC7F:~/ws_moveit2$ ros2 launch moveit2_tutorials demo.launch.py
      [INFO] [launch]: All log files can be found below /home/wzy/.ros/log/2025-08-02-09-38-00-675071-DESKTOP-AOGOC7F-27823
      [INFO] [rviz2-1]: process started with pid [27824]
      [INFO] [static_transform_publisher-2]: process started with pid [27826]
      [INFO] [robot_state_publisher-3]: process started with pid [27828]
      [INFO] [move_group-4]: process started with pid [27830]
      [INFO] [ros2_control_node-5]: process started with pid [27832]
      [INFO] [spawner-6]: process started with pid [27834]
      [INFO] [spawner-7]: process started with pid [27836]
      [INFO] [spawner-8]: process started with pid [27838]
      [static_transform_publisher-2] [WARN] [1754098680.948028663] []: Old-style arguments are deprecated; see --help for new-style arguments
      [static_transform_publisher-2] [INFO] [1754098680.982169551] [static_transform_publisher]: Spinning until stopped - publishing transform
      [static_transform_publisher-2] translation: ('0.000000', '0.000000', '0.000000')
      [static_transform_publisher-2] from 'world' to 'panda_link0'
      [robot_state_publisher-3] [INFO] [1754098681.018522512] [robot_state_publisher]: got segment panda_hand
      [robot_state_publisher-3] [INFO] [1754098681.018726372] [robot_state_publisher]: got segment panda_leftfinger
      [robot_state_publisher-3] [INFO] [1754098681.018737042] [robot_state_publisher]: got segment panda_link0
      [robot_state_publisher-3] [INFO] [1754098681.018742690] [robot_state_publisher]: got segment panda_link1
      [robot_state_publisher-3] [INFO] [1754098681.018747510] [robot_state_publisher]: got segment panda_link2
      [robot_state_publisher-3] [INFO] [1754098681.018752171] [robot_state_publisher]: got segment panda_link3
      [robot_state_publisher-3] [INFO] [1754098681.018757723] [robot_state_publisher]: got segment panda_link4
      [robot_state_publisher-3] [INFO] [1754098681.018762458] [robot_state_publisher]: got segment panda_link5
      [robot_state_publisher-3] [INFO] [1754098681.018767225] [robot_state_publisher]: got segment panda_link6
      [robot_state_publisher-3] [INFO] [1754098681.018771981] [robot_state_publisher]: got segment panda_link7
      [robot_state_publisher-3] [INFO] [1754098681.018776685] [robot_state_publisher]: got segment panda_link8
      [robot_state_publisher-3] [INFO] [1754098681.018781409] [robot_state_publisher]: got segment panda_rightfinger
      [ros2_control_node-5] [WARN] [1754098681.025856905] [controller_manager]: [Deprecated] Passing the robot description parameter directly to the control_manager node is deprecated. Use '~/robot_description' topic from 'robot_state_publisher' instead.
      [ros2_control_node-5] [INFO] [1754098681.026141049] [resource_manager]: Loading hardware 'PandaFakeSystem'
      [ros2_control_node-5] [INFO] [1754098681.027842303] [resource_manager]: Initialize hardware 'PandaFakeSystem'
      [ros2_control_node-5] [INFO] [1754098681.027915165] [resource_manager]: Successful initialization of hardware 'PandaFakeSystem'
      [ros2_control_node-5] [INFO] [1754098681.027931621] [resource_manager]: Loading hardware 'PandaHandFakeSystem'
      [ros2_control_node-5] [INFO] [1754098681.027939477] [resource_manager]: Initialize hardware 'PandaHandFakeSystem'
      [ros2_control_node-5] [INFO] [1754098681.027947482] [resource_manager]: Successful initialization of hardware 'PandaHandFakeSystem'
      [ros2_control_node-5] [INFO] [1754098681.027976540] [resource_manager]: 'configure' hardware 'PandaHandFakeSystem'
      [ros2_control_node-5] [INFO] [1754098681.027981912] [resource_manager]: Successful 'configure' of hardware 'PandaHandFakeSystem'
      [ros2_control_node-5] [INFO] [1754098681.027985447] [resource_manager]: 'activate' hardware 'PandaHandFakeSystem'
      [ros2_control_node-5] [INFO] [1754098681.027989407] [resource_manager]: Successful 'activate' of hardware 'PandaHandFakeSystem'
      [ros2_control_node-5] [INFO] [1754098681.027992411] [resource_manager]: 'configure' hardware 'PandaFakeSystem'
      [ros2_control_node-5] [INFO] [1754098681.027995490] [resource_manager]: Successful 'configure' of hardware 'PandaFakeSystem'
      [ros2_control_node-5] [INFO] [1754098681.027999716] [resource_manager]: 'activate' hardware 'PandaFakeSystem'
      [ros2_control_node-5] [INFO] [1754098681.028002784] [resource_manager]: Successful 'activate' of hardware 'PandaFakeSystem'
      [ros2_control_node-5] [INFO] [1754098681.034155736] [controller_manager]: update rate is 100 Hz
      [ros2_control_node-5] [INFO] [1754098681.034214457] [controller_manager]: Spawning controller_manager RT thread with scheduler priority: 50
      [ros2_control_node-5] [WARN] [1754098681.034386819] [controller_manager]: No real-time kernel detected on this system. See [https://control.ros.org/master/doc/ros2_control/controller_manager/doc/userdoc.html] for details on how to enable realtime scheduling.
      [move_group-4] [INFO] [1754098681.078095853] [moveit_rdf_loader.rdf_loader]: Loaded robot model in 0.0255684 seconds
      [move_group-4] [INFO] [1754098681.078675744] [moveit_robot_model.robot_model]: Loading robot model 'panda'...
      [rviz2-1] QStandardPaths: wrong permissions on runtime directory /run/user/1000/, 0755 instead of 0700
      [move_group-4] [INFO] [1754098681.159887565] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Publishing maintained planning scene on 'monitored_planning_scene'
      [move_group-4] [INFO] [1754098681.160116226] [moveit.ros_planning_interface.moveit_cpp]: Listening to 'joint_states' for joint states
      [move_group-4] [INFO] [1754098681.162039400] [moveit_ros.current_state_monitor]: Listening to joint states on topic 'joint_states'
      [move_group-4] [INFO] [1754098681.162783887] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to '/attached_collision_object' for attached collision objects
      [move_group-4] [INFO] [1754098681.162818359] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Starting planning scene monitor
      [move_group-4] [INFO] [1754098681.163241146] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to '/planning_scene'
      [move_group-4] [INFO] [1754098681.163270066] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Starting world geometry update monitor for collision objects, attached objects, octomap updates.
      [move_group-4] [INFO] [1754098681.163695220] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to 'collision_object'
      [move_group-4] [INFO] [1754098681.164021427] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to 'planning_scene_world' for planning scene world geometry
      [move_group-4] [WARN] [1754098681.167018499] [moveit.ros.occupancy_map_monitor.middleware_handle]: Resolution not specified for Octomap. Assuming resolution = 0.1 instead
      [move_group-4] [ERROR] [1754098681.167064034] [moveit.ros.occupancy_map_monitor.middleware_handle]: No 3D sensor plugin(s) defined for octomap updates
      [move_group-4] [INFO] [1754098681.168733346] [moveit.ros_planning_interface.moveit_cpp]: Loading planning pipeline 'ompl'
      [move_group-4] [INFO] [1754098681.211638444] [moveit.ros_planning.planning_pipeline]: Using planning interface 'OMPL'
      [ros2_control_node-5] [INFO] [1754098681.220138025] [controller_manager]: Loading controller 'joint_state_broadcaster'
      [move_group-4] [INFO] [1754098681.220852886] [moveit_ros.add_time_optimal_parameterization]: Param 'ompl.path_tolerance' was not set. Using default value: 0.100000
      [move_group-4] [INFO] [1754098681.220880861] [moveit_ros.add_time_optimal_parameterization]: Param 'ompl.resample_dt' was not set. Using default value: 0.100000
      [move_group-4] [INFO] [1754098681.220885140] [moveit_ros.add_time_optimal_parameterization]: Param 'ompl.min_angle_change' was not set. Using default value: 0.001000
      [move_group-4] [INFO] [1754098681.220908528] [moveit_ros.fix_workspace_bounds]: Param 'ompl.default_workspace_bounds' was not set. Using default value: 10.000000
      [move_group-4] [INFO] [1754098681.220917648] [moveit_ros.fix_start_state_bounds]: Param 'ompl.start_state_max_bounds_error' was set to 0.100000
      [move_group-4] [INFO] [1754098681.220922362] [moveit_ros.fix_start_state_bounds]: Param 'ompl.start_state_max_dt' was not set. Using default value: 0.500000
      [move_group-4] [INFO] [1754098681.220929114] [moveit_ros.fix_start_state_collision]: Param 'ompl.start_state_max_dt' was not set. Using default value: 0.500000
      [move_group-4] [INFO] [1754098681.220933191] [moveit_ros.fix_start_state_collision]: Param 'ompl.jiggle_fraction' was not set. Using default value: 0.020000
      [move_group-4] [INFO] [1754098681.220944635] [moveit_ros.fix_start_state_collision]: Param 'ompl.max_sampling_attempts' was not set. Using default value: 100
      [move_group-4] [INFO] [1754098681.220951632] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Add Time Optimal Parameterization'
      [move_group-4] [INFO] [1754098681.220956643] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Resolve constraint frames to robot links'
      [move_group-4] [INFO] [1754098681.220959223] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Workspace Bounds'
      [move_group-4] [INFO] [1754098681.220961888] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Start State Bounds'
      [move_group-4] [INFO] [1754098681.220964287] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Start State In Collision'
      [move_group-4] [INFO] [1754098681.220966792] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Start State Path Constraints'
      [move_group-4] [INFO] [1754098681.225317516] [moveit.ros_planning_interface.moveit_cpp]: Loading planning pipeline 'chomp'
      [ros2_control_node-5] [INFO] [1754098681.235021707] [controller_manager]: Loading controller 'panda_arm_controller'
      [move_group-4] [INFO] [1754098681.239313157] [moveit.ros_planning.planning_pipeline]: Using planning interface 'CHOMP'
      [move_group-4] [INFO] [1754098681.244663501] [moveit_ros.add_time_optimal_parameterization]: Param 'chomp.path_tolerance' was not set. Using default value: 0.100000
      [move_group-4] [INFO] [1754098681.244708580] [moveit_ros.add_time_optimal_parameterization]: Param 'chomp.resample_dt' was not set. Using default value: 0.100000
      [move_group-4] [INFO] [1754098681.244714472] [moveit_ros.add_time_optimal_parameterization]: Param 'chomp.min_angle_change' was not set. Using default value: 0.001000
      [move_group-4] [INFO] [1754098681.244730843] [moveit_ros.fix_workspace_bounds]: Param 'chomp.default_workspace_bounds' was not set. Using default value: 10.000000
      [move_group-4] [INFO] [1754098681.244744931] [moveit_ros.fix_start_state_bounds]: Param 'chomp.start_state_max_bounds_error' was set to 0.100000
      [move_group-4] [INFO] [1754098681.244750070] [moveit_ros.fix_start_state_bounds]: Param 'chomp.start_state_max_dt' was not set. Using default value: 0.500000
      [move_group-4] [INFO] [1754098681.244760039] [moveit_ros.fix_start_state_collision]: Param 'chomp.start_state_max_dt' was not set. Using default value: 0.500000
      [move_group-4] [INFO] [1754098681.244765007] [moveit_ros.fix_start_state_collision]: Param 'chomp.jiggle_fraction' was not set. Using default value: 0.020000
      [move_group-4] [INFO] [1754098681.244770836] [moveit_ros.fix_start_state_collision]: Param 'chomp.max_sampling_attempts' was not set. Using default value: 100
      [move_group-4] [INFO] [1754098681.244780921] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Add Time Optimal Parameterization'
      [move_group-4] [INFO] [1754098681.244785540] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Workspace Bounds'
      [move_group-4] [INFO] [1754098681.244789277] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Start State Bounds'
      [move_group-4] [INFO] [1754098681.244792610] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Start State In Collision'
      [move_group-4] [INFO] [1754098681.244796390] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Start State Path Constraints'
      [move_group-4] [INFO] [1754098681.246144820] [moveit.ros_planning_interface.moveit_cpp]: Loading planning pipeline 'pilz_industrial_motion_planner'
      [spawner-6] [INFO] [1754098681.253890689] [spawner_joint_state_broadcaster]: Loaded joint_state_broadcaster
      [move_group-4] [INFO] [1754098681.257121138] [moveit.pilz_industrial_motion_planner.joint_limits_aggregator]: Reading limits from namespace robot_description_planning
      [move_group-4] [WARN] [1754098681.258871006] [moveit.pilz_industrial_motion_planner.joint_limits_aggregator]: Multi-DOF-Joint 'virtual_joint' not supported.
      [move_group-4] [WARN] [1754098681.258911933] [moveit.pilz_industrial_motion_planner.joint_limits_aggregator]: Multi-DOF-Joint 'virtual_joint' not supported.
      [ros2_control_node-5] [WARN] [1754098681.259039619] [panda_arm_controller]: [Deprecated]: "allow_nonzero_velocity_at_trajectory_end" is set to true. The default behavior will change to false.
      [ros2_control_node-5] [INFO] [1754098681.264976958] [controller_manager]: Loading controller 'panda_hand_controller'
      [move_group-4] [INFO] [1754098681.268577785] [moveit.pilz_industrial_motion_planner]: Available plugins: pilz_industrial_motion_planner/PlanningContextLoaderCIRC pilz_industrial_motion_planner/PlanningContextLoaderLIN pilz_industrial_motion_planner/PlanningContextLoaderPTP
      [move_group-4] [INFO] [1754098681.268612215] [moveit.pilz_industrial_motion_planner]: About to load: pilz_industrial_motion_planner/PlanningContextLoaderCIRC
      [move_group-4] [INFO] [1754098681.272577957] [moveit.pilz_industrial_motion_planner]: Registered Algorithm [CIRC]
      [move_group-4] [INFO] [1754098681.272618693] [moveit.pilz_industrial_motion_planner]: About to load: pilz_industrial_motion_planner/PlanningContextLoaderLIN
      [move_group-4] [INFO] [1754098681.274551799] [moveit.pilz_industrial_motion_planner]: Registered Algorithm [LIN]
      [move_group-4] [INFO] [1754098681.274577013] [moveit.pilz_industrial_motion_planner]: About to load: pilz_industrial_motion_planner/PlanningContextLoaderPTP
      [move_group-4] [INFO] [1754098681.276563181] [moveit.pilz_industrial_motion_planner]: Registered Algorithm [PTP]
      [move_group-4] [INFO] [1754098681.276630936] [moveit.ros_planning.planning_pipeline]: Using planning interface 'Pilz Industrial Motion Planner'
      [spawner-7] [INFO] [1754098681.279872189] [spawner_panda_arm_controller]: Loaded panda_arm_controller
      [move_group-4] [INFO] [1754098681.281572348] [moveit_ros.fix_workspace_bounds]: Param 'pilz_industrial_motion_planner.default_workspace_bounds' was not set. Using default value: 10.000000
      [move_group-4] [INFO] [1754098681.281615441] [moveit_ros.fix_start_state_bounds]: Param 'pilz_industrial_motion_planner.start_state_max_bounds_error' was not set. Using default value: 0.050000
      [move_group-4] [INFO] [1754098681.281641781] [moveit_ros.fix_start_state_bounds]: Param 'pilz_industrial_motion_planner.start_state_max_dt' was not set. Using default value: 0.500000
      [move_group-4] [INFO] [1754098681.281656825] [moveit_ros.fix_start_state_collision]: Param 'pilz_industrial_motion_planner.start_state_max_dt' was not set. Using default value: 0.500000
      [move_group-4] [INFO] [1754098681.281660870] [moveit_ros.fix_start_state_collision]: Param 'pilz_industrial_motion_planner.jiggle_fraction' was not set. Using default value: 0.020000
      [move_group-4] [INFO] [1754098681.281666019] [moveit_ros.fix_start_state_collision]: Param 'pilz_industrial_motion_planner.max_sampling_attempts' was not set. Using default value: 100
      [move_group-4] [INFO] [1754098681.281673578] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Workspace Bounds'
      [move_group-4] [INFO] [1754098681.281677581] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Start State Bounds'
      [move_group-4] [INFO] [1754098681.281680160] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Start State In Collision'
      [move_group-4] [INFO] [1754098681.281682815] [moveit.ros_planning.planning_pipeline]: Using planning request adapter 'Fix Start State Path Constraints'
      [ros2_control_node-5] [INFO] [1754098681.284886675] [controller_manager]: Configuring controller 'joint_state_broadcaster'
      [ros2_control_node-5] [INFO] [1754098681.285011676] [joint_state_broadcaster]: 'joints' or 'interfaces' parameter is empty. All available state interfaces will be published
      [ros2_control_node-5] [INFO] [1754098681.295113767] [controller_manager]: Configuring controller 'panda_arm_controller'
      [ros2_control_node-5] [INFO] [1754098681.295307382] [panda_arm_controller]: No specific joint names are used for command interfaces. Using 'joints' parameter.
      [ros2_control_node-5] [INFO] [1754098681.295334232] [panda_arm_controller]: Command interfaces are [position] and state interfaces are [position velocity].
      [ros2_control_node-5] [INFO] [1754098681.295371273] [panda_arm_controller]: Using 'splines' interpolation method.
      [ros2_control_node-5] [INFO] [1754098681.296666165] [panda_arm_controller]: Controller state will be published at 50.00 Hz.
      [ros2_control_node-5] [INFO] [1754098681.299208427] [panda_arm_controller]: Action status changes will be monitored at 20.00 Hz.
      [spawner-8] [INFO] [1754098681.302633400] [spawner_panda_hand_controller]: Loaded panda_hand_controller
      [ros2_control_node-5] [INFO] [1754098681.314797380] [controller_manager]: Configuring controller 'panda_hand_controller'
      [ros2_control_node-5] [INFO] [1754098681.314898344] [panda_hand_controller]: Action status changes will be monitored at 20.000000 Hz.
      [move_group-4] [INFO] [1754098681.340365531] [moveit.plugins.moveit_simple_controller_manager]: Added FollowJointTrajectory controller for panda_arm_controller
      [move_group-4] [INFO] [1754098681.340436450] [moveit.plugins.moveit_simple_controller_manager]: Max effort set to 0.0
      [move_group-4] [INFO] [1754098681.343265394] [moveit.plugins.moveit_simple_controller_manager]: Added GripperCommand controller for panda_hand_controller
      [move_group-4] [INFO] [1754098681.343448181] [moveit.plugins.moveit_simple_controller_manager]: Returned 2 controllers in list
      [move_group-4] [INFO] [1754098681.343482037] [moveit.plugins.moveit_simple_controller_manager]: Returned 2 controllers in list
      [move_group-4] [INFO] [1754098681.344029485] [moveit_ros.trajectory_execution_manager]: Trajectory execution is managing controllers
      [move_group-4] [INFO] [1754098681.344054030] [move_group.move_group]: MoveGroup debug mode is ON
      [spawner-7] [INFO] [1754098681.345556897] [spawner_panda_arm_controller]: Configured and activated panda_arm_controller
      [spawner-8] [INFO] [1754098681.365403658] [spawner_panda_hand_controller]: Configured and activated panda_hand_controller
      [move_group-4] [INFO] [1754098681.373568953] [move_group.move_group]:
      [move_group-4]
      [move_group-4] ********************************************************
      [move_group-4] * MoveGroup using:
      [move_group-4] * - ApplyPlanningSceneService
      [move_group-4] * - ClearOctomapService
      [move_group-4] * - CartesianPathService
      [move_group-4] * - ExecuteTrajectoryAction
      [move_group-4] * - GetPlanningSceneService
      [move_group-4] * - KinematicsService
      [move_group-4] * - MoveAction
      [move_group-4] * - MotionPlanService
      [move_group-4] * - QueryPlannersService
      [move_group-4] * - StateValidationService
      [move_group-4]
      [move_group-4] [INFO] [1754098681.373633024] [moveit_move_group_capabilities_base.move_group_context]: MoveGroup context using planning plugin ompl_interface/OMPLPlanner
      [move_group-4] [INFO] [1754098681.373640361] [moveit_move_group_capabilities_base.move_group_context]: MoveGroup context initialization complete
      [move_group-4] Loading 'move_group/ApplyPlanningSceneService'...
      [move_group-4] Loading 'move_group/ClearOctomapService'...
      [move_group-4] Loading 'move_group/MoveGroupCartesianPathService'...
      [move_group-4] Loading 'move_group/MoveGroupExecuteTrajectoryAction'...
      [move_group-4] Loading 'move_group/MoveGroupGetPlanningSceneService'...
      [move_group-4] Loading 'move_group/MoveGroupKinematicsService'...
      [move_group-4] Loading 'move_group/MoveGroupMoveAction'...
      [move_group-4] Loading 'move_group/MoveGroupPlanService'...
      [move_group-4] Loading 'move_group/MoveGroupQueryPlannersService'...
      [move_group-4] Loading 'move_group/MoveGroupStateValidationService'...
      [move_group-4]
      [move_group-4] You can start planning now!
      [move_group-4]
      [spawner-6] [INFO] [1754098681.395830899] [spawner_joint_state_broadcaster]: Configured and activated joint_state_broadcaster
      [INFO] [spawner-7]: process has finished cleanly [pid 27836]
      [INFO] [spawner-8]: process has finished cleanly [pid 27838]
      [INFO] [spawner-6]: process has finished cleanly [pid 27834]
      [rviz2-1] [INFO] [1754098682.876993663] [rviz2]: Stereo is NOT SUPPORTED
      [rviz2-1] [INFO] [1754098682.877202779] [rviz2]: OpenGl version: 4.2 (GLSL 4.2)
      [rviz2-1] [INFO] [1754098682.939618229] [rviz2]: Stereo is NOT SUPPORTED
      [rviz2-1] Warning: class_loader.impl: SEVERE WARNING!!! A namespace collision has occurred with plugin factory for class rviz_default_plugins::displays::InteractiveMarkerDisplay. New factory will OVERWRITE existing one. This situation occurs when libraries containing plugins are directly linked against an executable (the one running right now generating this message). Please separate plugins out into their own library or just don't link against the library and use either class_loader::ClassLoader/MultiLibraryClassLoader to open.
      [rviz2-1] at line 253 in /opt/ros/humble/include/class_loader/class_loader/class_loader_core.hpp
      [rviz2-1] [ERROR] [1754098684.391233886] [moveit_ros_visualization.motion_planning_frame]: Action server: /recognize_objects not available
      [rviz2-1] [INFO] [1754098684.416077505] [moveit_ros_visualization.motion_planning_frame]: MoveGroup namespace changed: / -> . Reloading params.
      [rviz2-1] [INFO] [1754098684.439471913] [moveit_rdf_loader.rdf_loader]: Loaded robot model in 0.019429 seconds
      [rviz2-1] [INFO] [1754098684.439552867] [moveit_robot_model.robot_model]: Loading robot model 'panda'...
      [rviz2-1] [INFO] [1754098684.924842025] [moveit_rdf_loader.rdf_loader]: Loaded robot model in 0.0057921 seconds
      [rviz2-1] [INFO] [1754098684.924890851] [moveit_robot_model.robot_model]: Loading robot model 'panda'...
      [rviz2-1] [INFO] [1754098685.030988045] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Starting planning scene monitor
      [rviz2-1] [INFO] [1754098685.031812303] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to '/monitored_planning_scene'
      [rviz2-1] [INFO] [1754098685.033134825] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Starting planning scene monitor
      [rviz2-1] [INFO] [1754098685.034485947] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Listening to '/monitored_planning_scene'
      [rviz2-1] [INFO] [1754098685.046524906] [interactive_marker_display_109031445708608]: Connected on namespace: /rviz_moveit_motion_planning_display/robot_interaction_interactive_marker_topic
      [rviz2-1] [INFO] [1754098685.056351081] [moveit_ros_visualization.motion_planning_frame]: group panda_arm
      [rviz2-1] [INFO] [1754098685.056388669] [moveit_ros_visualization.motion_planning_frame]: Constructing new MoveGroup connection for group 'panda_arm' in namespace ''
      [rviz2-1] [INFO] [1754098685.068290581] [move_group_interface]: Ready to take commands for planning group panda_arm.
      [rviz2-1] [INFO] [1754098685.069730020] [interactive_marker_display_109031445708608]: Sending request for interactive markers
      [rviz2-1] [INFO] [1754098685.093844896] [interactive_marker_display_109031445708608]: Service response received for initialization
      整个运行信息看着是正常的。有朋友遇到这个问题吗,是怎么解决的
