    第五章python发布动态TF
    ros2 tf
    3.5k
      输入ros2 run demo_python_tf dynamic_tf_broadcaster后
      File "/home/kc/chapt5/chapt5_ws/install/demo_python_tf/lib/demo_python_tf/dynamic_tf_broadcaster", line 33, in <module>
      sys.exit(load_entry_point('demo-python-tf==0.0.0', 'console_scripts', 'dynamic_tf_broadcaster')())
      File "/home/kc/chapt5/chapt5_ws/install/demo_python_tf/lib/demo_python_tf/dynamic_tf_broadcaster", line 25, in importlib_load_entry_point
      return next(matches).load()
      File "/usr/lib/python3.10/importlib/metadata/init.py", line 173, in load
      return functools.reduce(getattr, attrs, module)
      AttributeError: module 'demo_python_tf.dynamic_tf_broadcaster' has no attribute 'main'
        2200623940 @3109368643
        @3109368643 看下你dynamic_tf_broadcaster和setup.py里的代码吧,可以贴出来看下,报错是main函数的问题,是不是main函数写错,或者是setup.py里的配置问题吗
