    使用一键安装过程中遇到程序崩溃
    ros1 一键安装 wsl2
    1.0k
    • C
      Cyan
      标题:使用一键安装过程中遇到程序崩溃
        File "/tmp/fishinstall/tools/base.py", line 1478, in run_tool_file
        File "/tmp/fishinstall/tools/tool_install_ros.py", line 417, in run
        File "/tmp/fishinstall/tools/tool_install_ros.py", line 408, in install_ros
        File "/tmp/fishinstall/tools/tool_install_ros.py", line 367, in choose_and_install_ros
        File "/tmp/fishinstall/tools/base.py", line 1041, in run
        File "/tmp/fishinstall/tools/base.py", line 1011, in run_command
        File "/tmp/fishinstall/tools/base.py", line 1024, in is_command_finish
      AttributeError: 'CmdTask' object has no attribute 'sub'
      -bash: /usr/bin/sudo: Input/output error
      -bash: /home/cyan/.bashrc: Input/output error
