    ROS2获取当前系统时间的方法
    ros2 时间戳
    4.7k
    • 首飞Kevin首
      首飞Kevin
      最后由 首飞Kevin 编辑
      C++ 标准库中的三种时钟
      std::chrono::system_clock
        const auto start = std::chrono::system_clock::now();
      #include <iostream>
      #include <iomanip>
      #include <vector>
      #include <numeric>
      #include <chrono>
      volatile int sink;
      int main()
          std::cout << std::fixed << std::setprecision(9) << std::left;
          for (auto size = 1ull; size < 1000'000'000ull; size *= 100) {
              // record start time
              // do some work
              std::vector<int> v(size, 42);
              sink = std::accumulate(v.begin(), v.end(), 0u); // make sure it's a side effect
              // record end time
              auto end = std::chrono::system_clock::now();
              std::chrono::duration<double> diff = end - start;
              std::cout << "Time to fill and iterate a vector of " << std::setw(9)
                        << size << " ints : " << diff.count() << " s\n";
      /* 输出
      Time to fill and iterate a vector of 1         ints : 0.000006568 s
      Time to fill and iterate a vector of 100       ints : 0.000002854 s
      Time to fill and iterate a vector of 10000     ints : 0.000116290 s
      Time to fill and iterate a vector of 1000000   ints : 0.011742752 s
      Time to fill and iterate a vector of 100000000 ints : 0.505534949 s
      //https://en.cppreference.com/w/cpp/chrono/system_clock/now
      system_clock是系统范围的时钟。它是可修改的。比如同步网络时间。所以系统的时间差可能不准。
      std::chrono::steady_clock
      #include <iostream>
      #include <iomanip>
      #include <ctime>
      #include <chrono>
      int main()
          std::chrono::system_clock::time_point now = std::chrono::system_clock::now();
          std::time_t now_c = std::chrono::system_clock::to_time_t(now - std::chrono::hours(24));
          std::cout << "24 hours ago, the time was "
                    << std::put_time(std::localtime(&now_c), "%F %T") << '\n';
          std::chrono::steady_clock::time_point start = std::chrono::steady_clock::now();
          std::cout << "Hello World\n";
          std::chrono::steady_clock::time_point end = std::chrono::steady_clock::now();
          std::cout << "Printing took "
                    << std::chrono::duration_cast<std::chrono::microseconds>(end - start).count()
                    << "us.\n";
      /*输出
      24 hours ago, the time was 2011-10-25 12:00:08
      Hello World
      Printing took 84us.
      https://www.apiref.com/cpp-zh/cpp/chrono/time_point.html
      steady_clock是单调时钟。此时钟的时间点无法减少,像物理秒表一样。通常精度能达到纳秒级别,适合用来计算程序执行时间。
      std::chrono::high_resolution_clock
      #include <iostream>
      #include <ctime>
      #include <ratio>
      #include <chrono>
      int main ()
        using namespace std::chrono;
        high_resolution_clock::time_point t1 = high_resolution_clock::now();
        std::cout << "printing out 1000 stars...\n";
        for (int i=0; i<1000; ++i) std::cout << "*";
        std::cout << std::endl;
        high_resolution_clock::time_point t2 = high_resolution_clock::now();
        duration<double> time_span = duration_cast<duration<double>>(t2 - t1);
        std::cout << "It took me " << time_span.count() << " seconds.";
        return 0;
      /* 输出
      It took me 0.091001 seconds.
      //参考:https://cplusplus.com/reference/chrono/high_resolution_clock/now/
      high_resolution_clock在不同标准库之间有不同的实现。
      通常它只是 std::chrono::steady_clock 或 std::chrono::system_clock 的别名,但实际是哪个取决于库或配置。例如对于 gcc的 libstdc++ 它是 system_clock ,对于 MSVC 它是 steady_clock ,而对于clang的 libc++ 它取决于配置。
      所以推荐直接使用对应的时钟而不是high_resolution_clock。
      ROS2中的时间戳
      ROS2中定义了三种时钟。默认是使用RCL_SYSTEM_TIME。它和C++中的std::chrono::system_clock是一样的,即系统时间。
      typedef enum rcl_clock_type_t
        /// Clock uninitialized
        RCL_CLOCK_UNINITIALIZED = 0,
        /// Use ROS time
        RCL_ROS_TIME,
        /// Use system time
        RCL_SYSTEM_TIME,
        /// Use a steady clock time
        RCL_STEADY_TIME
      } rcl_clock_type_t;
      ROS2中存在两种时间戳。一种是实际的物理系统时间,另一种是仿真时间。仿真时间通常是Gazebo发出的/clock话题。
      /clock话题
      clock:
        sec: 65
        nanosec: 212000000
      clock:
        sec: 65
        nanosec: 298000000
      clock:
        sec: 65
        nanosec: 388000000
      当需要在仿真环境中测试程序时,要将use_sim_time置为True。不然会出现下面的报错信息。表示时间不匹配。tf关系不能正常找到。
      报错信息:
      [controller_server]: Extrapolation Error: Lookup would require extrapolation into the future.  Requested time 1646190408.221065 but the latest data is at time 19.413000, when looking up transform from frame [map] to frame [odom]
      置位use_sim_time可以写在launch文件中。如下所示:
          use_sim_time = LaunchConfiguration('use_sim_time', default='false')
          return LaunchDescription([
              DeclareLaunchArgument(
                  'use_sim_time',
                  default_value=use_sim_time,
                  description='Use simulation (Gazebo) clock if true'),
              Node(
                  package='time_api_test',
                  executable='time_api_test',
                  arguments=[],
                  output='screen'),
      在ROS2中获取当前时间戳
      下面的代码片段罗列了获取系统时间的几种方法:
          auto t = rclcpp::Clock().now();
          RCLCPP_INFO(this->get_logger(), "[rclcpp::Clock().now()] sec:%lf nano:%ld", t.seconds(), t.nanoseconds());
          auto t1 = std::chrono::system_clock::now();
          time_t tt = std::chrono::system_clock::to_time_t ( t1 );
          RCLCPP_INFO(this->get_logger(), "[std::chrono::system_clock::now()] sec:%ld", tt);
          std::chrono::steady_clock::time_point td = std::chrono::steady_clock::now();
          std::chrono::steady_clock::duration dtn = td.time_since_epoch();
          double secs = dtn.count() * std::chrono::steady_clock::period::num / std::chrono::steady_clock::period::den;
          RCLCPP_INFO(this->get_logger(), "[std::chrono::steady_clock::now()] sec:%lf", secs);
          auto t2 = this->get_clock()->now();
          RCLCPP_INFO(this->get_logger(), "[get_clock()->now()] sec:%lf nano:%ld", t2.seconds(), t2.nanoseconds());
          auto t3 = this->now();
          RCLCPP_INFO(this->get_logger(), "[this->now()] sec:%lf nano:%ld", t3.seconds(), t3.nanoseconds());
      注意,完整的示例代码可在公众号《首飞》中回复“time” 获取到。
      当use_sim_time为false时,运行上面测试代码的结果为:
      [time_api_test-1] [INFO 1658498046.378262276] [time_api_test]: [rclcpp::Clock().now()] sec:1658498046.378260 nano:1658498046378260389
      [time_api_test-1] [INFO 1658498046.378315552] [time_api_test]: [std::chrono::system_clock::now()] sec:1658498046
      [time_api_test-1] [INFO 1658498046.378325479] [time_api_test]: [std::chrono::steady_clock::now()] sec:5906.000000
      [time_api_test-1] [INFO 1658498046.378333539] [time_api_test]: [get_clock()->now()] sec:1658498046.378333 nano:1658498046378333309
      [time_api_test-1] [INFO 1658498046.378341987] [time_api_test]: [this->now()] sec:1658498046.378342 nano:1658498046378341769
      可以发现,rclcpp::Clock().now(),get_clock()->now()和this->now()获取到的时间与std::chrono::system_clock::now()是一致的。
      这里需要注意的一点是,rclcpp::Clock().now(),get_clock()->now()和this->now()获取到的时间戳均包含seconds()和nanoseconds()方法。seconds()和nanoseconds()方法都返回了当前的时间,是等价的,只是单位不一样。一个是以秒为单位,一个是纳秒为单位。
      auto t = this->get_clock()->now()
      builtin_interfaces::msg::Time tt = t;
      RCLCPP_INFO(this->get_logger(), "sec: %lf nano: %lf  tt_sec: %ld tt_nano: %ld", t.seconds(), t.nanoseconds(), tt.sec, tt.nanosec);
      但是ROS2中的时间类型builtin_interfaces::msg::Time是需要把秒和纳秒组合起来才能表示当前时间的。
      double now_sec = msg->header.stamp.sec + msg->header.stamp.nanosec * 1e-9;
      now_sec是以秒为单位的时间。
      当use_sim_time为true时,运行上面测试代码的结果为:
      注意,运行测试代码前。我运行了turtlebot3的gazebo仿真环境。以便系统中有/clock话题来提供仿真时间。
      [time_api_test-1] [INFO 1658498456.593959180] [time_api_test]: [rclcpp::Clock().now()] sec:1658498456.593951 nano:1658498456593951346
      [time_api_test-1] [INFO 1658498456.594114487] [time_api_test]: [std::chrono::system_clock::now()] sec:1658498456
      [time_api_test-1] [INFO 1658498456.594132577] [time_api_test]: [std::chrono::steady_clock::now()] sec:6316.000000
      [time_api_test-1] [INFO 1658498456.594142330] [time_api_test]: [get_clock()->now()] sec:300.636000 nano:300636000000
      [time_api_test-1] [INFO 1658498456.594149351] [time_api_test]: [this->now()] sec:300.636000 nano:300636000000
      可以看到,rclcpp::Clock().now()还是与std::chrono::system_clock::now()保持一致。说明rclcpp::Clock().now()不能返回仿真时间。
      get_clock()->now()和this->now()是等效的。他们均返回了仿真时间。
      经过测试对比,可得出结论,rclcpp::Clock().now()无法正确获取仿真时间。所以代码中要获取时间戳时,可调用get_clock()->now()和this->now()接口。这样可以保证在标志位use_sim_time变化时,代码各处使用的时间戳是一致的。
      计算程序运行时间的方法
      rclcpp::Clock steady_clock_{RCL_STEADY_TIME};
      auto start_time = steady_clock_.now();
      //do something ...
      auto cycle_duration = steady_clock_.now() - start_time;
      RCLCPP_INFO(get_logger(), "Cost %.4f s", cycle_duration.seconds());
      使用RCL_STEADY_TIME时钟去计算程序运行时间是比较准确的。
      我是首飞,一位帮大家填坑的机器人开发攻城狮。
