    [开源硬件探索]LiCheePI NANO
    嵌入式系统
    fishros explore
    1.4k
      核心镜像
      docker run --rm -it -v /dev:/dev --privileged fishros2/licheepi /bin/bash
      基本流程
      1.编译uboot
      cd u-boot/
      git checkout nano-v2018.01
      make ARCH=arm CROSS_COMPILE=arm-linux-gnueabi- licheepi_nano_spiflash_defconfig
      # ====配置====
       make ARCH=arm menuconfig
          取消勾选 [] Enable a default value for bootcmd
          勾选 [v] Enable boot arguments;
          在下方一项中填入 bootargs 参数:
              console=ttyS0,115200 panic=5 rootwait root=/dev/mtdblock3 rw rootfstype=jffs2
      # =====配置/workspace/u-boot/include/configs/suniv.h======
       * Configuration settings for new Allwinner F-series (suniv) CPU
       * SPDX-License-Identifier:	GPL-2.0+
      #ifndef __CONFIG_H
      #define __CONFIG_H
      #define CONFIG_SUNXI_USB_PHYS 1
       * Include common sunxi configuration where most the settings are
      #include <configs/sunxi-common.h>
      #define CONFIG_BOOTCOMMAND   "sf probe 0 50000000; "                           \
                                   "sf read 0x80C00000 0x100000 0x4000; "  \
                                   "sf read 0x80008000 0x110000 0x400000; " \
                                   "bootz 0x80008000 - 0x80C00000"
      #endif /* __CONFIG_H */
      # ----配置 /workspace/u-boot1/drivers/mtd/spi/spi_flash_ids.c
      # LINE@175
       {"xt25f128b", INFO(0x0b4018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP | SECT_4K) },
      make ARCH=arm CROSS_COMPILE=arm-linux-gnueabi- -j12
      结果如下
      2.编译linux内核
      git clone --depth=1 -b master https://gitee.com/LicheePiNano/Linux.git
      cd Linux
      make ARCH=arm f1c100s_nano_linux_defconfig
      make ARCH=arm CROSS_COMPILE=arm-linux-gnueabi- -j12 INSTALL_MOD_PATH=out modules_install
      3.编译根文件系统
      wget https://buildroot.org/downloads/buildroot-2021.02.4.tar.gz
      tar xvf buildroot-2021.02.4.tar.gz
      cd buildroot-2021.02.4/
      make menuconfig
      配置:https://wiki.sipeed.com/soft/Lichee/zh/Nano-Doc-Backup/build_sys/rootfs.html
      4.合并
      #!/bin/sh
      UBOOT_FILE=./u-boot/u-boot-sunxi-with-spl.bin
      DTB_FILE=./Linux/arch/arm/boot/dts/suniv-f1c100s-licheepi-nano.dtb
      KERNEL_FILE=./Linux/arch/arm/boot/zImage
      ROOTFS_FILE=./buildroot-2021.02.4/output/images/rootfs.tar
      MOD_FILE=./Linux/out/lib/modules/4.15.0-rc8-licheepi-nano+
      dd if=/dev/zero of=flashimg.bin bs=1M count=16 &&\
      dd if=$UBOOT_FILE of=flashimg.bin bs=1K conv=notrunc &&\
      dd if=$DTB_FILE of=flashimg.bin bs=1K seek=1024 conv=notrunc &&\
      dd if=$KERNEL_FILE of=flashimg.bin bs=1K seek=1088 conv=notrunc &&\
      mkdir rootfs
      tar -xvf $ROOTFS_FILE -C ./rootfs &&\
      cp -r $MOD_FILE rootfs/lib/modules/ &&\
      #为根文件系统制作jffs2镜像包
      #--pad参数指定 jffs2大小
      #由此计算得到 0x1000000(16M)-0x10000(64K)-0x100000(1M)-0x400000(4M)=0xAF0000
      mkfs.jffs2 -s 0x100 -e 0x10000 --pad=0xAF0000 -d rootfs/ -o jffs2.img &&\
      dd if=jffs2.img of=flashimg.bin bs=1K seek=5184 conv=notrunc &&\
      rm -rf rootfs &&\
      rm jffs2.img
      5.下载
      开机任意输入,进入uboot,清除原有uboot
      sf probe 0
      sf erase 0 0x100000
      reset
       wget https://ghproxy.com/https://github.com/linux-sunxi/sunxi-tools/raw/master/bin/fel-sdboot.sunxi
      dd if=fel-sdboot.sunxi of=/dev/sda bs=1024 seek=8
      sudo sunxi-fel -p spiflash-write 0 flashimg.bin
      Docker构建
      使用docker创建uboot、xboot、sunxi-tools环境.
      docker run -it  --privileged -v /dev:/dev fishros2/licheepi /bin/bash
      Dockerfile
      FROM ubuntu:16.04
      # ENV https_proxy=http://192.168.1.107:7890
      # ENV http_proxy=http://192.168.1.107:7890
      # ENV all_proxy=socks5://192.168.1.107:7890
      RUN apt update \
          && apt install wget python3-yaml -y  \
          # 安装melodic
          && echo "chooses:\n" > fish_install.yaml \
          && echo "- {choose: 5, desc: '一键安装:ROS(支持ROS和ROS2,树莓派Jetson)'}\n" >> fish_install.yaml \
          && echo "- {choose: 2, desc: 更换源继续安装}\n" >> fish_install.yaml \
          && echo "- {choose: 2, desc: 清理三方源}\n" >> fish_install.yaml \
          && wget http://fishros.com/install  -O fishros && /bin/bash fishros \
          # 进行最后的清理
          && rm -rf /var/lib/apt/lists/*  /tmp/* /var/tmp/* \
          && apt-get clean && apt autoclean
      RUN apt update && \
          apt install gcc make cmake rsync wget unzip build-essential git bc swig libncurses-dev libpython3-dev libssl-dev -y
          #  python3-distutils android-tools-mkbootimg
      RUN wget http://releases.linaro.org/components/toolchain/binaries/7.2-2017.11/arm-linux-gnueabi/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabi.tar.xz && \
          tar -vxJf gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabi.tar.xz
      RUN sudo cp -r ./gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabi /opt/ && \
          echo 'PATH="$PATH:/opt/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabi/bin"' >> /etc/bash.bashrc
      RUN apt install git -y && \
          git clone https://gitee.com/LicheePiNano/u-boot.git /workspace/u-boot && \
          cd /workspace/u-boot && \
          git checkout nano-lcd800480
      RUN apt install python2.7 python-dev -y
      WORKDIR /workspace
      #========================================uboot========================================================
      # 此处告知make采用arm-linux-gnueabi下的所有交叉编译工具,目标架构为Arm,设定各项默认配置为 nano 的spiflash支持版
      # make ARCH=arm CROSS_COMPILE=arm-linux-gnueabi- f1c100s_nano_uboot_defconfig
      # 若不带spi-flash的板子,请换成 licheepi_nano_defconfig
      # make ARCH=arm menuconfig
      # make ARCH=arm CROSS_COMPILE=arm-linux-gnueabi- -j8
      #========================================sunxi-tools====================================================
      RUN sudo apt-get install pkg-config libusb-1.0-0-dev -y && \
          git clone -b f1c100s-spiflash https://github.com/Icenowy/sunxi-tools.git && \
          cd sunxi-tools && \
          make && sudo make install
      #========================================xboot========================================================
      RUN git clone https://github.91chi.fun/https://github.com/xboot/xboot.git
      RUN apt install cpio -y && \
          cd xboot && \
          make CROSS_COMPILE=/opt/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabi/bin/arm-linux-gnueabi- PLATFORM=arm32-f1c100s
      # docker run -it fishros2/licheepi /bin/bash
      #https://wiki.sipeed.com/soft/Lichee/zh/Nano-Doc-Backup/get_started/first_eat.html#%E4%B8%8B%E8%BD%BD%E5%B7%A5%E5%85%B7-sunxi-tools-%E5%AE%89%E8%A3%85
