    makefile编译ros_humble
    ros2-humble makefile
    • 8477189568
      H.
      最后由 847718956 编辑
      版本: ros_humble
      cpp程序
      #include "rclcpp/rclcpp.hpp"
      #include "std_msgs/msg/string.hpp"
      class TopicPublisher01 : public rclcpp::Node
      public:
          // 构造函数,有一个参数为节点名称
          TopicPublisher01(std::string name) : Node(name)
              RCLCPP_INFO(this->get_logger(), "大家好,我是%s.", name.c_str());
              // 创建发布者
              command_publisher_ = this->create_publisher<std_msgs::msg::String>("command", 10);
              // 创建定时器,500ms为周期,定时发布
              timer_ = this->create_wall_timer(std::chrono::milliseconds(500), std::bind(&TopicPublisher01::timer_callback, this));
      private:
          void timer_callback()
              // 创建消息
              std_msgs::msg::String message;
              message.data = "forward";
              // 日志打印
              RCLCPP_INFO(this->get_logger(), "Publishing: '%s'", message.data.c_str());
              // 发布消息
              command_publisher_->publish(message);
          // 声名定时器指针
          // 声明话题发布者指针
          rclcpp::Publisher<std_msgs::msg::String>::SharedPtr command_publisher_;
          rclcpp::init(argc, argv);
          /*产生一个的节点*/
          auto node = std::make_shared<TopicPublisher01>("first_node");
          /* 运行节点,并检测退出信号*/
          rclcpp::spin(node);
          rclcpp::shutdown();
          return 0;
      makefile程序
      build:
      	g++ ros2_makefile.cpp \
      	-I /opt/ros/humble/include/rclcpp/ \
          -I /opt/ros/humble/include/rcl/ \
          -I /opt/ros/humble/include/rcutils/ \
          -I /opt/ros/humble/include/rmw \
          -I /opt/ros/humble/include/rcl_yaml_param_parser/ \
          -I /opt/ros/humble/include/rosidl_runtime_c \
          -I /opt/ros/humble/include/rosidl_typesupport_interface \
          -I /opt/ros/humble/include/rcpputils \
          -I /opt/ros/humble/include/builtin_interfaces \
          -I /opt/ros/humble/include/rosidl_runtime_cpp \
          -I /opt/ros/humble/include/tracetools \
          -I /opt/ros/humble/include/rcl_interfaces \
          -I /opt/ros/humble/include/libstatistics_collector \
          -I /opt/ros/humble/include/statistics_msgs \
      	-I /opt/ros/humble/include/std_msgs \
          -L /opt/ros/humble/lib/ \
          -lrclcpp -lrcutils -lrcl -ltracetools -lrmw \
          -o first_node
      # 顺便小鱼加个clean指令,用来删掉first_node
      clean:
      	rm first_node
      报错
      ~/Desktop/IGH_Master/ROS2_Makefile$ make build
          -o first_node
      /usr/bin/ld: /tmp/ccH6HcBC.o: in function `std::enable_if<rosidl_generator_traits::is_message<std_msgs::msg::String_<std::allocator<void> > >::value, rosidl_message_type_support_t const&>::type rclcpp::get_message_type_support_handle<std_msgs::msg::String_<std::allocator<void> > >()':
      ros2_makefile.cpp:(.text._ZN6rclcpp31get_message_type_support_handleIN8std_msgs3msg7String_ISaIvEEEEENSt9enable_ifIXsrN23rosidl_generator_traits10is_messageIT_EE5valueERK29rosidl_message_type_support_tE4typeEv[_ZN6rclcpp31get_message_type_support_handleIN8std_msgs3msg7String_ISaIvEEEEENSt9enable_ifIXsrN23rosidl_generator_traits10is_messageIT_EE5valueERK29rosidl_message_type_support_tE4typeEv]+0x10): undefined reference to `rosidl_message_type_support_t const* rosidl_typesupport_cpp::get_message_type_support_handle<std_msgs::msg::String_<std::allocator<void> > >()'
      make: *** [makefile:2:build] 错误 1
      • 8477189568 847718956 将这个主题转为问答主题,在
        小鱼 技术大佬 @847718956
        @847718956 因为你引入了std_msgs这个包了,所以指令里也要包含这个,不过用gcc非常的不方便,还是推荐你用ROS2的工程或者CmakeLists.txt文件来生成可执行文件
        @847718956 在 makefile编译ros_humble 中说:
