    我在进行carttographer安装时,在编译过程出现这个报错应该怎么解决,系统是Ubuntu20.04 ros是ros2foxy版本。
    cartographer ros2编译
    1.7k
    • 6350870946
      Lecn Nop
      • 6350870946
        Lecn Nop
        $ git branch -a
        • foxy
          remotes/origin/HEAD -> origin/humble
          remotes/origin/feature/base_control
          remotes/origin/feture/v1.0.0
          remotes/origin/foxy
          remotes/origin/humble
          remotes/origin/master
          remotes/origin/navgation2
          remotes/origin/v1.0.0
        • 6350870946
          Lecn Nop
          /opt/ros/foxy/include/cartographer/mapping/proto/serialization.pb.h:1192:33: error: ‘InternalMetadataWithArena’ in namespace ‘google::protobuf::internal’ does not name a type; did you mean ‘InternalMetadata’?
          1192 | ::google::protobuf::internal::InternalMetadataWithArena internal_metadata;
          | InternalMetadata
          /opt/ros/foxy/include/cartographer/mapping/proto/serialization.pb.h:1140:31: error: ‘cartographer::mapping::proto::SerializationHeader* cartographer::mapping::proto::SerializationHeader::New() const’ marked ‘final’, but is not virtual
          1140 | inline SerializationHeader* New() const final {
          /opt/ros/foxy/include/cartographer/mapping/proto/serialization.pb.h:1147:8: error: ‘void cartographer::mapping::proto::SerializationHeader::CopyFrom(const google::protobuf::Message&)’ marked ‘final’, but is not virtual
          1147 | void CopyFrom(const ::google::protobuf::Message& from) final;
          /opt/ros/foxy/include/cartographer/mapping/proto/serialization.pb.h:1155:8: error: ‘bool cartographer::mapping::proto::SerializationHeader::MergePartialFromCodedStream(google::protobuf::io::CodedInputStream*)’ marked ‘final’, but is not virtual
          1155 | bool MergePartialFromCodedStream(
          /opt/ros/foxy/include/cartographer/mapping/proto/serialization.pb.h:1157:8: error: ‘void cartographer::mapping::proto::SerializationHeader::SerializeWithCachedSizes(google::protobuf::io::CodedOutputStream*) const’ marked ‘final’, but is not virtual
          1157 | void SerializeWithCachedSizes(
          /opt/ros/foxy/include/cartographer/mapping/proto/serialization.pb.h:1159:30: error: ‘google::protobuf::uint8* cartographer::mapping::proto::SerializationHeader::InternalSerializeWithCachedSizesToArray(bool, google::protobuf::uint8*) const’ marked ‘final’, but is not virtual
          1159 | ::google::protobuf::uint8* InternalSerializeWithCachedSizesToArray(
          /opt/ros/foxy/include/cartographer/mapping/proto/serialization.pb.h:1424:33: error: ‘InternalMetadataWithArena’ in namespace ‘google::protobuf::internal’ does not name a type; did you mean ‘InternalMetadata’?
          1424 | ::google::protobuf::internal::InternalMetadataWithArena internal_metadata;
          | InternalMetadata
          /opt/ros/foxy/include/cartographer/mapping/proto/serialization.pb.h:1256:26: error: ‘cartographer::mapping::proto::SerializedData* cartographer::mapping::proto::SerializedData::New() const’ marked ‘final’, but is not virtual
          1256 | inline SerializedData* New() const final {
          /opt/ros/foxy/include/cartographer/mapping/proto/serialization.pb.h:1263:8: error: ‘void cartographer::mapping::proto::SerializedData::CopyFrom(const google::protobuf::Message&)’ marked ‘final’, but is not virtual
          1263 | void CopyFrom(const ::google::protobuf::Message& from) final;
          /opt/ros/foxy/include/cartographer/mapping/proto/serialization.pb.h:1271:8: error: ‘bool cartographer::mapping::proto::SerializedData::MergePartialFromCodedStream(google::protobuf::io::CodedInputStream*)’ marked ‘final’, but is not virtual
          1271 | bool MergePartialFromCodedStream(
          /opt/ros/foxy/include/cartographer/mapping/proto/serialization.pb.h:1273:8: error: ‘void cartographer::mapping::proto::SerializedData::SerializeWithCachedSizes(google::protobuf::io::CodedOutputStream*) const’ marked ‘final’, but is not virtual
          1273 | void SerializeWithCachedSizes(
          /opt/ros/foxy/include/cartographer/mapping/proto/serialization.pb.h:1275:30: error: ‘google::protobuf::uint8* cartographer::mapping::proto::SerializedData::InternalSerializeWithCachedSizesToArray(bool, google::protobuf::uint8*) const’ marked ‘final’, but is not virtual
          1275 | ::google::protobuf::uint8* InternalSerializeWithCachedSizesToArray(
          /opt/ros/foxy/include/cartographer/mapping/proto/serialization.pb.h: In member function ‘void cartographer::mapping::proto::LocalSlamResultData::clear_timestamp()’:
          /opt/ros/foxy/include/cartographer/mapping/proto/serialization.pb.h:2095:16: error: ‘GOOGLE_LONGLONG’ was not declared in this scope; did you mean ‘GOOGLE_DLOG’?
          2095 | timestamp_ = GOOGLE_LONGLONG(0);
          | GOOGLE_DLOG
          make[2]: *** [CMakeFiles/cartographer_ros.dir/build.make:154: CMakeFiles/cartographer_ros.dir/cartographer_ros/tf_bridge.cc.o] Error 1
          make[2]: *** [CMakeFiles/cartographer_ros.dir/build.make:76: CMakeFiles/cartographer_ros.dir/cartographer_ros/msg_conversion.cc.o] Error 1
          make[2]: *** [CMakeFiles/cartographer_ros.dir/build.make:141: CMakeFiles/cartographer_ros.dir/cartographer_ros/sensor_bridge.cc.o] Error 1
          make[2]: *** [CMakeFiles/cartographer_ros.dir/build.make:63: CMakeFiles/cartographer_ros.dir/cartographer_ros/map_builder_bridge.cc.o] Error 1
          make[2]: *** [CMakeFiles/cartographer_ros.dir/build.make:193: CMakeFiles/cartographer_ros.dir/cartographer_ros/submap.cc.o] Error 1
          make[2]: *** [CMakeFiles/cartographer_ros.dir/build.make:89: CMakeFiles/cartographer_ros.dir/cartographer_ros/node.cc.o] Error 1
          make[1]: *** [CMakeFiles/Makefile2:104: CMakeFiles/cartographer_ros.dir/all] Error 2
          make: *** [Makefile:141: all] Error 2
          Failed <<< cartographer_ros [22.3s, exited with code 2]
          Aborted <<< nav2_bt_navigator [26.0s]
          Aborted <<< nav2_costmap_2d [1min 54s]
          Summary: 17 packages finished [5min 16s]
          1 package failed: cartographer_ros
          2 packages aborted: nav2_bt_navigator nav2_costmap_2d
          5 packages had stderr output: cartographer_ros cartographer_ros_msgs dwb_msgs nav2_msgs nav_2d_msgs
          18 packages not processed
            小鱼 技术大佬 @635087094
            @635087094 你系统啥版本?
            6350870946 1 条回复 最后回复 回复 引用 0
            • 6350870946
              Lecn Nop @小鱼
              @小鱼 系统是ubuntu20.04,ros的版本是ros2foxy
