    一键安装失败
    一键安装,ros2 ubuntu20.04
    1.5k
    • 4
      42235046
      树莓派3B+UBUNTU20.04,打算安装ROS2,但是未能安装成功
      一键安装的链接:
      **安装过程的显示:**
      ubuntu@ubuntu:~$ wget http://fishros.com/install -O fishros && bash fishros
      --2022-03-30 10:55:14--  http://fishros.com/install
      --2022-03-30 10:55:14--  http://fishros.com/install/
      Length: 300 [application/octet-stream]
      Saving to: ‘fishros’
      fishros             100%[===================>]     300  --.-KB/s    in 0s
      2022-03-30 10:55:14 (6.78 MB/s) - ‘fishros’ saved [300/300]
      --2022-03-30 10:55:15--  http://fishros.com/install/install1s/tools/base.py
      Length: 36343 (35K) [application/octet-stream]
      /tmp/fishinstall/to 100%[===================>]  35.49K  --.-KB/s    in 0.06s
      2022-03-30 10:55:15 (596 KB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [36343/36343]
      [-]Result:success
      基础检查通过...
      RUN Choose Task:[请输入括号内的数字]
      ---众多工具,等君来用---
      [6]:一键安装:nodejs开发环境(通过nodejs可以预览小鱼官网噢)
      [7]:一键安装:VsCode
      [8]:一键安装:Docker
      [77]:测试模式:运行自定义工具测试
      [0]:quit
      请输入[]内的数字以选择:1
      --2022-03-30 10:55:37--  http://fishros.com/install/install1s/tools/tool_install_ros.py
      Length: 7949 (7.8K) [application/octet-stream]
      /tmp/fishinstall/t 100%[================>]   7.76K  --.-KB/s    in 0s
      2022-03-30 10:55:37 (44.9 MB/s) - ‘/tmp/fishinstall/tools/tool_install_ros.py’ saved [7949/7949]
      --2022-03-30 10:55:37--  http://fishros.com/install/install1s/tools/tool_config_rosenv.py
      Length: 2307 (2.3K) [application/octet-stream]
      /tmp/fishinstall/t 100%[================>]   2.25K  --.-KB/s    in 0s
      2022-03-30 10:55:38 (42.6 MB/s) - ‘/tmp/fishinstall/tools/tool_config_rosenv.py’ saved [2307/2307]
      --2022-03-30 10:55:38--  http://fishros.com/install/install1s/tools/tool_config_system_source.py
      Length: 5001 (4.9K) [application/octet-stream]
      /tmp/fishinstall/t 100%[================>]   4.88K  --.-KB/s    in 0s
      2022-03-30 10:55:38 (51.3 MB/s) - ‘/tmp/fishinstall/tools/tool_config_system_source.py’ saved [5001/5001]
      =========接下来这一步很重要,请小白关注,大佬请忽略========
      墙裂建议小白一定换源并清理三方源,换源!!!系统默认国外源容易失败!!
      [1]:更换系统源再继续安装
      [2]:不更换继续安装
      [0]:quit
      请输入[]内的数字以选择:1
      欢迎使用模板工程,本工具由作者小鱼提供
      欢迎使用一键换源工具,本工具由[鱼香ROS]小鱼贡献..
      请选择换源方式
      [1]:仅更换系统源
      [2]:更换系统源并清理第三方源
      [0]:quit
      请输入[]内的数字以选择:
      [-]Result:success                           --upgradable' to see it.eleasee
      [-]Result:success
      删除一个资源文件
      [-]Result:success
      [-]Result:suc
      检测到当前系统架构为[armhf],正在为你更换对应源..
      替换完成,尝试第一次更新....
      搞定了,不信你看,累死宝宝了,还不快去给小鱼点个赞~
      ['Hit:1 https://mirrors.ustc.edu.cn/ubuntu-ports focal InRelease', 'Hit:2 https://mirrors.ustc.edu.cn/ubuntu-ports focal-updates InRelease', 'Hit:3 https://mirrors.ustc.edu.cn/ubuntu-ports focal-backports InRelease', 'Hit:4 https://mirrors.ustc.edu.cn/ubuntu-ports focal-security InRelease', 'Reading package lists...', 'Building dependency tree...', 'Reading state information...', "1 package can be upgraded. Run 'apt list --upgradable' to see it.", '']
      镜像修复完成.....
      Run CMD Task:[sudo apt install curl gnupg2 -y]
      [-]Result:success                           e and 1 not upgraded.
      [-]Result:success
      ['http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu/', 'http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu/']
      [-]Result:success
      Run CMD Task:[sudo mkdir -p /etc/apt/sources.list.d/]
      [-]Result:success
      [|]Get:2 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu focal InRelease [4,[-]Get:3 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu focal Release [3,794[\]Get:5 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu focal Release.gpg [8[\]Get:9 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu focal/main armhf Pa[|]Get:10 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu focal/main armhf Pa[-]Result:success                           --upgradable' to see it.
      [\]libpam-krb5-migrate-heimdal - PAM module for migrating to Heimdal Kerbero[/]ros-noetic-ros-base - A metapackage which extends ros_core and includes other basic non-robot tools like actionlib, dynamic reconfigure, nodelets, an[-]Result:succ
      请选择你要安装的ROS版本名称:
      [1]:noetic
      [0]:quit
      请输入[]内的数字以选择:0
      请选择安装的具体版本:
      [1]:quit完全版
      [2]:quit基础版(小)
      [0]:quit
      请输入[]内的数字以选择:1
      Run CMD Task:[sudo apt install ros-quit-desktop -y]
      Reading package lists... Done
      E: Unable to locate package ros-quit-desktop
      [-]Result:code:100
      安装失败了,请打开鱼香社区-https://fishros.org.cn/forum 在一键安装专区反馈问题...
      欢迎加入机器人学习交流QQ群:139707339
      鱼香ROS机器人社区上线了!!快快打开链接:-https://fishros.org.cn/forum,一起交流学习机器人问题吧~
      没有ROS2版本代号的选择
      小鱼小 2 条回复 最后回复 回复 引用 0
      • 4
        42235046 @小鱼
        @小鱼 在 一键安装失败 中说:
        sudo apt install ros-foxy-desktop
        试过了,现在安装成功了。原因如下:
        ROS2 foxy 需要的是64位的ubuntu. 即使手动安装还是会出现各种各样的问题,后面没有通过sudo apt install ,而是 sudo apititude
          小鱼 技术大佬 @42235046
          @42235046 推测可能是源导致,晚上我做一下更新后你再测试。
            小鱼 技术大佬 @42235046
            @42235046 已完成对应的armhf架构源的优化,可以再次尝试,有问题可以持续反馈。😁
            4 1 条回复 最后回复 回复 引用 0
            • 4
              42235046 @小鱼
              @小鱼 还是找不到ROS2安装版本
              ubuntu@ubuntu:~$ wget http://fishros.com/install -O fishros && . fishros
              --2022-03-31 01:08:45--  http://fishros.com/install
              --2022-03-31 01:08:46--  http://fishros.com/install/
              2022-03-31 01:08:46 (5.33 MB/s) - ‘fishros’ saved [300/300]
              --2022-03-31 01:08:46--  http://fishros.com/install/install1s/tools/base.py
              Length: 36533 (36K) [application/octet-stream]
              /tmp/fishinstall/to 100%[===================>]  35.68K  --.-KB/s    in 0.03s
              2022-03-31 01:08:46 (1.17 MB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [36533/36533]
              [-]Result:success
              基础检查通过...
              ---众多工具,等君来用---
              [6]:一键安装:nodejs
              [7]:一键安装:VsCode开发工具
              [8]:一键安装:Docker
              [77]:测试模式:运行自定义工具测试
              [0]:quit
              请输入[]内的数字以选择:1
              请输入[]内的数字以选择:1
              --2022-03-31 01:09:02--  http://fishros.com/install/install1s/tools/tool_install_ros.py
              Length: 7929 (7.7K) [application/octet-stream]
              /tmp/fishinstall/to 100%[===================>]   7.74K  --.-KB/s    in 0s
              2022-03-31 01:09:02 (20.7 MB/s) - ‘/tmp/fishinstall/tools/tool_install_ros.py’ saved [7929/7929]
              --2022-03-31 01:09:02--  http://fishros.com/install/install1s/tools/tool_config_rosenv.py
              /tmp/fishinstall/to 100%[===================>]   2.25K  --.-KB/s    in 0s
              2022-03-31 01:09:02 (37.8 MB/s) - ‘/tmp/fishinstall/tools/tool_config_rosenv.py’ saved [2307/2307]
              --2022-03-31 01:09:02--  http://fishros.com/install/install1s/tools/tool_config_system_source.py
              /tmp/fishinstall/to 100%[===================>]   4.88K  --.-KB/s    in 0s
              2022-03-31 01:09:02 (73.0 MB/s) - ‘/tmp/fishinstall/tools/tool_config_system_source.py’ saved [5001/5001]
              [1]:更换系统源再继续安装
              [2]:不更换继续安装
              [0]:quit
              请输入[]内的数字以选择:1
              欢迎使用模板工程,本工具由作者小鱼提供
              请选择换源方式
              [1]:仅更换系统源
              [2]:更换系统源并清理第三方源
              [0]:quit
              请输入[]内的数字以选择:2
              [-]Result:success                            --upgradable' to see them.asee
              [-]Result:success
              删除一个资源文件
              [-]Result:success
              [-]Result:success
              替换完成,尝试第一次更新....
              ['Hit:1 https://mirrors.ustc.edu.cn/ubuntu-ports focal InRelease', 'Hit:2 https://mirrors.ustc.edu.cn/ubuntu-ports focal-updates InRelease', 'Hit:3 https://mirrors.ustc.edu.cn/ubuntu-ports focal-backports InRelease', 'Hit:4 https://mirrors.ustc.edu.cn/ubuntu-ports focal-security InRelease', 'Reading package lists...', 'Building dependency tree...', 'Reading state information...', "5 packages can be upgraded. Run 'apt list --upgradable' to see them.", '']
              镜像修复完成.....
              [-]Result:success                           e and 5 not upgraded.
              [-]Result:success
              [-]Result:success
              根据您的系统,为您推荐安装源为['http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu/', 'http://packages.ros.org/ros2/ubuntu/']
              [-]Result:success
              [-]Get:3 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu focal Release.gpg [833 B[\]Get:9 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu focal/main armhf Package[|]Get:10 http://packages.ros.org/ros2/ubuntu focal/main armhf Packages [72.3 kB[-]Result:success                            --upgradable' to see them.
              [/]ros-noetic-ros-base - A metapackage which extends ros_core and includes other basic non-robot tools like actionlib, dynamic reconfigure, nodelets, and plugin[-]Result:success
              请选择你要安装的ROS版本名称:
              [1]:noetic
              [0]:quit
              请输入[]内的数字以选择:0
              请选择安装的具体版本:
              [1]:quit完全版
              [2]:quit基础版(小)
              [0]:quit
              请输入[]内的数字以选择:0
              欢迎使用一键配置ROS开发环境,本工具由作者小鱼提供
              Run CMD Task:[ls /opt/ros/*/setup.bash]
              [-]Result:success
              Run CMD Task:[ls /home/*/.bashrc]
              [-]Result:success
              恭喜你,安装成功了,再附赠你机器人学习宝藏网站:鱼香社区-https://fishros.org.cn/forum
              ubuntu@ubuntu:~$
                小鱼 技术大佬 @42235046
                @42235046 直接敲命令行试试,不行我抽时间在我这边树莓派试试,非常奇怪的问题。
                • 4
                  42235046 @小鱼
                  @小鱼 在 一键安装失败 中说:
                  试过了,现在安装成功了。原因如下:
                  • 小鱼小 小鱼 将这个主题转为问答主题,在
                  • 小鱼小 小鱼 将这个主题标记为已解决,在
