    catkin_make一个功能包时报错
    catkinmake ros一键安装
    3.4k
    • 8277495898
      雪漫似穹天.
      系统:ubuntu 22.04
      ros安装方式 docker+melodic(vscode加插件开发)
      出现的问题 运行catkin_make时报错:
      root@10e25021c658:/home/caochuang/ws15# catkin_make
      Base path: /home/caochuang/ws15
      Source space: /home/caochuang/ws15/src
      Build space: /home/caochuang/ws15/build
      Devel space: /home/caochuang/ws15/devel
      Install space: /home/caochuang/ws15/install
      Running command: "make cmake_check_build_system" in "/home/caochuang/ws15/build"
      -- Using CATKIN_DEVEL_PREFIX: /home/caochuang/ws15/devel
      -- Using CMAKE_PREFIX_PATH: /opt/ros/melodic
      -- This workspace overlays: /opt/ros/melodic
      -- Found PythonInterp: /usr/bin/python2 (found suitable version "2.7.17", minimum required is "2")
      -- Using PYTHON_EXECUTABLE: /usr/bin/python2
      -- Using Debian Python package layout
      -- Using empy: /usr/bin/empy
      -- Using CATKIN_ENABLE_TESTING: ON
      -- Call enable_testing()
      -- Using CATKIN_TEST_RESULTS_DIR: /home/caochuang/ws15/build/test_results
      -- Found gtest sources under '/usr/src/googletest': gtests will be built
      -- Found gmock sources under '/usr/src/googletest': gmock will be built
      -- Found PythonInterp: /usr/bin/python2 (found version "2.7.17")
      -- Using Python nosetests: /usr/bin/nosetests-2.7
      -- catkin 0.7.29
      -- BUILD_SHARED_LIBS is on
      -- ~~ traversing 15 packages in topological order:
      -- ~~ - playgrounds
      -- ~~ - common
      -- ~~ - vehicle_model
      -- ~~ - forward_simulator
      -- ~~ - motion_predictor
      -- ~~ - vehicle_msgs
      -- ~~ - aux_tools
      -- ~~ - phy_simulator
      -- ~~ - semantic_map_manager
      -- ~~ - route_planner
      -- ~~ - behavior_planner
      -- ~~ - ai_agent_planner
      -- ~~ - eudm_planner
      -- ~~ - ssc_planner
      -- ~~ - planning_integrated
      -- +++ processing catkin package: 'playgrounds'
      -- ==> add_subdirectory(EPSILON/core/playgrounds)
      -- +++ processing catkin package: 'common'
      -- ==> add_subdirectory(EPSILON/core/common)
      -- Using these message generators: gencpp;geneus;genlisp;gennodejs;genpy
      CMake Error at /usr/share/cmake-3.10/Modules/FindPackageHandleStandardArgs.cmake:137 (message):
      Could NOT find Glog (missing: GLOG_INCLUDE_DIR GLOG_LIBRARY)
      /usr/share/cmake-3.10/Modules/FindPackageHandleStandardArgs.cmake:378 (_FPHSA_FAILURE_MESSAGE)
      EPSILON/core/common/cmake/FindGlog.cmake:40 (find_package_handle_standard_args)
      EPSILON/core/common/CMakeLists.txt:25 (find_package)
      -- Configuring incomplete, errors occurred!
      See also "/home/caochuang/ws15/build/CMakeFiles/CMakeOutput.log".
      See also "/home/caochuang/ws15/build/CMakeFiles/CMakeError.log".
      Makefile:320: recipe for target 'cmake_check_build_system' failed
      make: *** [cmake_check_build_system] Error 1
      Invoking "make cmake_check_build_system" failed
      • 8277495898
        雪漫似穹天.
        实在不知道咋弄了,求解答~~
          小鱼 技术大佬 @827749589
          @827749589 在 catkin_make一个功能包时报错 中说:
          没有gloh
          参考
          https://stackoverflow.com/questions/65588745/could-not-find-glog-missing-glog-include-dir-glog-library
          $ sudo apt install libgoogle-glog-dev
          Also,
          $ sudo apt-get install libgflags-dev
          $ sudo apt-get install protobuf-compiler libprotobuf-dev
          since initially I didn't have any of them installed.
          试一试看~
          最后建议
          8277495898 1 条回复 最后回复 回复 引用 0
          • 8277495898
            雪漫似穹天. @小鱼
            @小鱼 在 catkin_make一个功能包时报错 中说:
            感谢解答,都已经安装了但是没用
              小鱼 技术大佬 @827749589
              @827749589
              首先确认已经装了
              如果装了还不行
              那应该就是环境变量问题,检查下PATH,
              echo $PATH
              然后试试
              sudo sh -c "echo '/usr/local/lib' >> /etc/ld.so.conf"
              sudo ldconfig
              之后再次编译
              • 8277495898
                雪漫似穹天. @小鱼
                @小鱼 $ sudo apt-get install libgflags-dev
                我有个疑问,就是在docker容器外用上面这些命令安装这些库,那这些库在docker容器里面会生效吗?
                  小鱼 技术大佬 @827749589
                  @827749589 不会生效,所有的操作都要在容器里操作
                  • 8277495898
                    雪漫似穹天. @小鱼
                    @小鱼 那在容器里,这些命令就没办法使用了,需要自己手动安装吧
