    一键安装里没有ros1可选项(20.04/18.04)
    一键安装 ubuntu 20.04 ubuntu18.04 ros1
    6.4k
      小鱼 技术大佬 @2805188071
      @2805188071 提供下完整的日志的信息,全部复制粘贴下日志,晚点我也测试一下
        2805188071 @小鱼
        @小鱼 刚刚把虚拟机移除了,稍等我重装一下20.04
          每次终端打开第一遍开启一键安装都会失败,如下:
          slam@ubuntu:~$ wget http://fishros.com/install -O fishros && . fishros
          --2024-07-24 06:13:09-- http://fishros.com/install
          Resolving fishros.com (fishros.com)... 47.119.165.169
          Connecting to fishros.com (fishros.com)|47.119.165.169|:80... connected.
          --2024-07-24 06:13:11-- http://fishros.com/install/
          Length: 987 [text/html]
          Saving to: ‘fishros’
          fishros 100%[===================>] 987 --.-KB/s in 0s
          2024-07-24 06:13:11 (58.3 MB/s) - ‘fishros’ saved [987/987]
          bash: html: No such file or directory
          bash: head: No such file or directory
          bash: fishros: line 3: syntax error near unexpected token (' bash: fishros: line 3: <script language="javascript">setTimeout("try{setCookie();}catch(error){};location.replace(location.href.split("#")[0])",2000);</scrip'>
            第二遍开启一键安装成功,不过没有ros1可选如下:(ubuntu20.04,ustc源)
            --2024-07-24 06:13:13-- http://fishros.com/install
            --2024-07-24 06:13:13-- http://fishros.com/install/
            Length: 579 [application/octet-stream]
            fishros 100%[===================>] 579 --.-KB/s in 0s
            2024-07-24 06:13:13 (94.3 MB/s) - ‘fishros’ saved [579/579]
            [sudo] password for slam:
            Reading package lists... Done
            Building dependency tree
            python3-distro is already the newest version (1.4.0-1).
            python3-distro set to manually installed.
            python3-yaml is already the newest version (5.3.1-1ubuntu0.1).
            python3-yaml set to manually installed.
            0 upgraded, 0 newly installed, 0 to remove and 282 not upgraded.
            --2024-07-24 06:13:18-- http://mirror.fishros.com/install/tools/base.py
            Resolving mirror.fishros.com (mirror.fishros.com)... 47.119.165.169
            Connecting to mirror.fishros.com (mirror.fishros.com)|47.119.165.169|:80... connected.
            Length: 44650 (44K) [application/octet-stream]
            /tmp/fishinstall/tools/base.py 100%[==============================================================================================>] 43.60K --.-KB/s in 0.08s
            2024-07-24 06:13:18 (553 KB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [44650/44650]
            [-]Result:success
            [-]Result:success
            基础检查通过...
            ---众多工具,等君来用---
            ROS相关:
            常用软件:
            [6]:一键安装:NodeJS环境
            [7]:一键安装:VsCode开发工具
            [8]:一键安装:Docker
            [10]:一键安装:微信(可以在Linux上使用的微信)
            [14]:一键安装:科学上网代理工具
            [15]:一键安装:QQ for Linux
            配置工具:
            [13]:一键配置:python国内源
            请输入[]内的数字以选择:1
            --2024-07-24 06:13:39-- http://mirror.fishros.com/install/tools/tool_install_ros.py
            Length: 19723 (19K) [application/octet-stream]
            /tmp/fishinstall/tools/tool_install_ros.py 100%[==============================================================================================>] 19.26K --.-KB/s in 0.04s
            2024-07-24 06:13:39 (512 KB/s) - ‘/tmp/fishinstall/tools/tool_install_ros.py’ saved [19723/19723]
            --2024-07-24 06:13:39-- http://mirror.fishros.com/install/tools/tool_config_rosenv.py
            Length: 2455 (2.4K) [application/octet-stream]
            /tmp/fishinstall/tools/tool_config_rosenv.py 100%[==============================================================================================>] 2.40K --.-KB/s in 0s
            2024-07-24 06:13:41 (243 MB/s) - ‘/tmp/fishinstall/tools/tool_config_rosenv.py’ saved [2455/2455]
            --2024-07-24 06:13:41-- http://mirror.fishros.com/install/tools/tool_config_system_source.py
            Length: 7738 (7.6K) [application/octet-stream]
            /tmp/fishinstall/tools/tool_config_system_sou 100%[==============================================================================================>] 7.56K --.-KB/s in 0.001s
            2024-07-24 06:13:41 (8.57 MB/s) - ‘/tmp/fishinstall/tools/tool_config_system_source.py’ saved [7738/7738]
            小鱼:检测当前系统ubuntu20.04:focal 支持一键安装ROS
            [1]:更换系统源再继续安装
            [2]:不更换继续安装
            0:quit
            请输入[]内的数字以选择:2
            [-]Result:success st --upgradable' to see them.
            [-]Result:success tu3 amd64ck app4ntu1~bpo0-0ubuntu0.20.04 amd64bpo0-0ubuntu0.20.04 alll alll
            [-]Result:success buntu9.9) ...deb ... ...ed.)l amd64 7.68.0-1ubuntu2.22 [161 kB] kB]
            [-]Result:success ent (dummy transitional package)ubuntu2.2 all
            [-]Result:success ...u2.2_all.deb ...stalled.) gnupg2 all 2.2.19-3ubuntu2.2 [5,316 B]
            [-]Result:success
            [-]Result:success
            [-]Result:code:100 ros2/ubuntu focal/main amd64 Packages [1,192 kB]
            apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', "E: Failed to fetch http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu/dists/focal/InRelease Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)\n", "E: The repository 'http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu focal InRelease' is not signed.\n"]
            [-]Result:success includes other basic functionalities like tf2 and urdf.
            [1]:foxy(ROS2)
            [2]:galactic(ROS2)
            [3]:rolling(ROS2)
            0:quit
            请输入[]内的数字以选择:0
            你选择退出。。。。
            Run CMD Task:[ls /opt/ros/None/setup.bash]
            [-]Result:code:2
            [-]Result:code:2
            2 小鱼小 3 条回复 最后回复 回复 引用 0
              2805188071 @2805188071
              @2805188071 三个选项都是ros2没有ros1...
                小鱼 技术大佬 @2805188071
                @2805188071 奇怪了,我刚测试的18
                [-]Result:success                           -upgradable’ 来查看它们。 amd64 Packages [809 kB]
                [-]Result:success                           d includes other basic non-robot tools like actionlib, dynamic reconfigure, nodelets, and pluginlib.
                [1]:bouncy(ROS2)
                [2]:crystal(ROS2)
                [3]:dashing(ROS2)
                [4]:eloquent(ROS2)
                [5]:melodic(ROS1)
                请输入[]内的数字以选择:
                  小鱼 技术大佬 @2805188071
                  @2805188071 在 一键安装里没有ros1可选项(20.04/18.04) 中说:
                  应该是这个问题
                    小鱼 技术大佬 @2805188071
                    @小伊 怎么解决
                      这个错误提示表明你在尝试通过apt包管理器从清华大学(Tsinghua University)的ROS镜像源(mirrors.tuna.tsinghua.edu.cn/ros/ubuntu)更新或安装ROS 1时遇到了问题。错误指出InRelease文件验证失败,并且该仓库未签名。
                      以下是几个可能的解决步骤:
                      1. 检查网络连接:
                        确保你的网络连接是稳定的,并且没有需要认证的代理或VPN。
                      2. 检查镜像源URL:
                        确认你添加的ROS仓库URL是否正确。对于ROS Melodic(通常与Ubuntu 18.04一起使用)和ROS Noetic(通常与Ubuntu 20.04一起使用),你应该使用正确的版本代号。
                      3. 临时禁用该镜像源:
                        你可以临时从/etc/apt/sources.list或/etc/apt/sources.list.d/下的相关文件中注释掉或删除该镜像源,然后运行sudo apt update来尝试使用默认的Ubuntu仓库。
                      4. 更换其他镜像源:
                        如果清华大学的镜像源有问题,你可以尝试更换为其他ROS镜像源,如ROS官方源或其他大学的镜像源。
                      5. 清理APT缓存:
                        运行以下命令来清理APT缓存和修复软件包列表:
                        sudo apt clean
                        sudo apt autoclean
                        sudo apt update --fix-missing
                      6. 手动下载并导入GPG密钥:
                        如果ROS仓库的GPG密钥没有正确导入,你可能需要手动下载并导入它。对于ROS的官方仓库,这通常可以在ROS的Wiki或安装指南中找到。
                      7. 检查防火墙/安全设置:
                        确保没有任何防火墙或安全软件阻止了你对ROS仓库的访问。
                      8. 使用https而不是http:
                        尝试将仓库URL中的http更改为https,这可以提供更好的安全性,并可能解决某些连接问题。
                      9. 检查系统时间:
                        确保你的系统时间是正确的,因为错误的系统时间可能会导致SSL证书验证失败。
                      10. 尝试重新安装ROS:
                        如果以上步骤都无法解决问题,你可能需要完全卸载ROS,并重新按照官方安装指南进行安装。
                      在进行任何更改之前,请确保你备份了所有重要数据,并了解你正在执行的操作。如果你不确定某个步骤,最好先查阅相关文档或寻求社区帮助。
                        2805188071 @小鱼
                        最后由 2805188071 编辑
                        @小鱼 谢谢小鱼,我看到‘apt does not have a stable CLI interface’警告之后把校园网换成了自己的热点,然后就成功出现ros1了,可能是我们学校的校园网有点bug与apt连接不稳定,现在已经解决!👍
                        1 条回复 最后回复 回复 引用 2
                        • 2 2805188071 将这个主题转为问答主题,在
                        • 2 2805188071 将这个主题标记为已解决,在
