    非oop方法编写一个节点提示找不到rclpy
    动手学ROS2
    ros2 节点创建 动手学ros2
    1.5k
    • T
      TsharkYang
      ROS2创建节点日志报错
      问题描述:
      在学习动手学ROS2教程中的3.4章节,使用非oop方法编写一个节点,步骤紧跟教程文档操作,但是还是报错找不到rclpy
      具体细节和上下文:
      环境使用的是ubuntu18,ROS2 dashing python 3.6 以下图片是整个节点创建完成后的截图(已经执行source):
      尝试运行节点:ros2 run village_li li4_node 出现报错找不到模组rclpy,日志如下:
      (ros2_dashing_env) root@carl:~/town_ws# ros2 run village_li li4_node
      Failed to load entry point 'launch': No module named 'rclpy._rclpy'
      The C extension '/opt/ros/dashing/lib/python3.6/site-packages/rclpy/_rclpy.cpython-38-x86_64-linux-gnu.so' isn't present on the system. Please refer to '[https://index.ros.org/doc/ros2/Troubleshooting/Installation-Troubleshooting/#import-failing-without-library-present-on-the-system](https://index.ros.org/doc/ros2/Troubleshooting/Installation-Troubleshooting/#import-failing-without-library-present-on-the-system)' for possible solutions
      Failed to load entry point 'info': No module named 'rclpy._rclpy'
      Failed to load entry point 'list': No module named 'rclpy._rclpy'
      Failed to load entry point 'send_goal': No module named 'rclpy._rclpy'
      Failed to load entry point 'show': No module named 'rclpy._rclpy'
      Failed to load entry point 'load': No module named 'rclpy._rclpy'
      Failed to load entry point 'standalone': No module named 'rclpy._rclpy'
      Failed to load entry point 'types': No module named 'rclpy._rclpy'
      Failed to load entry point 'unload': No module named 'rclpy._rclpy'
      Failed to load entry point 'start': No module named 'rclpy._rclpy'
      Failed to load entry point 'status': No module named 'rclpy._rclpy'
      Failed to load entry point 'stop': No module named 'rclpy._rclpy'
      Failed to load entry point 'get': No module named 'rclpy._rclpy'
      Failed to load entry point 'nodes': No module named 'rclpy._rclpy'
      Failed to load entry point 'set': No module named 'rclpy._rclpy'
      Failed to load entry point 'delete': No module named 'rclpy._rclpy'
      Failed to load entry point 'create_key': cannot import name 'etree' from 'lxml' (/usr/lib/python3/dist-packages/lxml/**init**.py)
      Failed to load entry point 'create_keystore': cannot import name 'etree' from 'lxml' (/usr/lib/python3/dist-packages/lxml/**init**.py)
      Failed to load entry point 'create_permission': cannot import name 'etree' from 'lxml' (/usr/lib/python3/dist-packages/lxml/**init**.py)
      Failed to load entry point 'distribute_key': cannot import name 'etree' from 'lxml' (/usr/lib/python3/dist-packages/lxml/**init**.py)
      Failed to load entry point 'generate_artifacts': cannot import name 'etree' from 'lxml' (/usr/lib/python3/dist-packages/lxml/**init**.py)
      Failed to load entry point 'generate_policy': cannot import name 'etree' from 'lxml' (/usr/lib/python3/dist-packages/lxml/**init**.py)
      Failed to load entry point 'list_keys': cannot import name 'etree' from 'lxml' (/usr/lib/python3/dist-packages/lxml/**init**.py)
      Failed to load entry point 'call': No module named 'rclpy._rclpy'
      Failed to load entry point 'bw': No module named 'rclpy._rclpy'
      Failed to load entry point 'delay': No module named 'rclpy._rclpy'
      Failed to load entry point 'echo': No module named 'rclpy._rclpy'
      Failed to load entry point 'hz': No module named 'rclpy._rclpy'
      Failed to load entry point 'pub': No module named 'rclpy._rclpy'
      File "/root/town_ws/install/village_li/lib/village_li/li4_node", line 11, in <module>
      load_entry_point('village-li==0.0.0', 'console_scripts', 'li4_node')()
      File "/usr/lib/python3/dist-packages/pkg_resources/**init**.py", line 480, in load_entry_point
      return get_distribution(dist).load_entry_point(group, name)
      File "/usr/lib/python3/dist-packages/pkg_resources/**init**.py", line 2693, in load_entry_point
      return ep.load()
      File "/usr/lib/python3/dist-packages/pkg_resources/**init**.py", line 2324, in load
      return self.resolve()
      File "/usr/lib/python3/dist-packages/pkg_resources/**init**.py", line 2330, in resolve
      module = **import**(self.module_name, fromlist=['**name**'], level=0)
      File "/root/town_ws/install/village_li/lib/python3.8/site-packages/village_li/li4.py", line 2, in <module>
      from rclpy.node import Node
      File "/opt/ros/dashing/lib/python3.6/site-packages/rclpy/node.py", line 39, in <module>
      from rclpy.client import Client
      File "/opt/ros/dashing/lib/python3.6/site-packages/rclpy/client.py", line 22, in <module>
      File "/opt/ros/dashing/lib/python3.6/site-packages/rclpy/impl/implementation_singleton.py", line 31, in <module>
      rclpy_implementation = _import('._rclpy')
      File "/opt/ros/dashing/lib/python3.6/site-packages/rclpy/impl/**init**.py", line 22, in _import
      return importlib.import_module(name, package='rclpy')
      File "/usr/lib/python3.8/importlib/**init**.py", line 127, in import_module
      ModuleNotFoundError: No module named 'rclpy._rclpy'
      尝试过的解决方法:
      排错1:编写脚本查看是否能正常导入rclpy和创建节点,脚本代码如下:
      import sys
      import rclpy
      print(sys.version)
      print(sys.path)
      print(rclpy.__file__)
      try:
          import rclpy
          print("Successfully imported rclpy and Node.")
      except ImportError as e:
          print(f"Failed to import rclpy or Node: {e}")
      def main(args=None):
          rclpy.init(args=args)
          try:
              node = Node("test_node")
              print("Successfully created Node.")
          except Exception as e:
              print(f"Failed to create Node: {e}")
          finally:
              rclpy.shutdown()
      if __name__ == "__main__":
      执行结果如下:
      (ros2_dashing_env) root@carl:~/town_ws# python3 env_test.py
      3.6.13 |Anaconda, Inc.| (default, Jun  4 2021, 14:25:59)
      [GCC 7.5.0]
      ['/root/town_ws', '/opt/ros/dashing/lib/python3.6/site-packages', '/root/anaconda3/envs/ros2_dashing_env/lib/python36.zip', '/root/anaconda3/envs/ros2_dashing_env/lib/python3.6', '/root/anaconda3/envs/ros2_dashing_env/lib/python3.6/lib-dynload', '/root/anaconda3/envs/ros2_dashing_env/lib/python3.6/site-packages']
      /opt/ros/dashing/lib/python3.6/site-packages/rclpy/__init__.py
      结果显示能正常导入rclpy and Node并且能创建节点。
      排错2:编写脚本查看环境变量,代码如下:
      echo "Checking if rclpy is installed..."
      if pip list | grep -q rclpy; then
        echo "rclpy is installed."
      else
        echo "rclpy is not installed. Please install it using 'pip install rclpy'."
      fi
      echo "Checking PYTHONPATH..."
      echo $PYTHONPATH
      echo "Testing rclpy import..."
      python -c "import rclpy; from rclpy.node import Node; print('rclpy imported successfully')" || echo "Failed to import rclpy"
      echo "Sourcing ROS 2 environment..."
      source /opt/ros/dashing/setup.bash
      echo "Checking ROS environment variables..."
      printenv | grep ROS
      执行结果如下:
      (ros2_dashing_env) root@carl:~/town_ws# bash check_ros_env.sh
      ERROR: Pipe to stdout was broken
      Exception ignored in: <_io.TextIOWrapper name='<stdout>' mode='w' encoding='UTF-8'>
      BrokenPipeError: [Errno 32] Broken pipe
      rclpy is installed.
      ROS_VERSION=2
      ROS_PYTHON_VERSION=3
      ROS_DISTRO=dashing
      本人只会这两种排查方式,排查后仍无法解决问题,请各位大佬指教。
        小鱼 技术大佬 @TsharkYang
        @TsharkYang 跟你的虚拟环境有关系,3.8 应该是ubuntu20的默认版本, 3.6 才是ubuntu18 的系统。
        你可以参考下这个:
        https://fishros.org.cn/forum/topic/554/jupyter新建python3文件终端报错-导入rclpy报错/2
        T 1 条回复 最后回复 回复 引用 0
        • T
          TsharkYang @小鱼
          @小鱼 你好,我的虚拟环境是python3.6的,并且我在setup.py中指定了编译版本为3.6,但是编译出来的文件还是3.8的26b7feb2-6547-48f8-a7bb-912b4de0e1f8-image.png
