使用imu_utils标定,拥有了db3文件了,使用ros2 launch启动编译好的imu_an节点报错,启动不了
ysh@ysh:~/ros2_ws/src$ ros2 launch imu_utils A3_launch.py [INFO] [launch]: All log files can be found below /home/ysh/.ros/log/2024-08-06-16-06-45-531408-ysh-121452 [INFO] [launch]: Default logging verbosity is set to INFO [INFO] [imu_an-1]: process started with pid [121453] [imu_an-1] [INFO] [1722931605.611123480] [imu_an]: Waiting for IMU data... [imu_an-1] [ERROR] [1722931605.611210670] [imu_an]: Failed to load imu_topic [imu_an-1] [ERROR] [1722931605.612426206] [imu_an]: Failed to load imu_name [imu_an-1] [ERROR] [1722931605.612452157] [imu_an]: Failed to load data_save_path [imu_an-1] [ERROR] [1722931605.612457508] [imu_an]: Failed to load max_time_min [imu_an-1] [ERROR] [1722931605.612460949] [imu_an]: Failed to load max_cluster [imu_an-1] terminate called after throwing an instance of 'rclcpp::exceptions::RCLError' [imu_an-1] what(): could not create subscription: rcl node's context is invalid, at ./src/rcl/node.c:428 [ERROR] [imu_an-1]: process has died [pid 121453, exit code -6, cmd '/home/ysh/ros2_ws/install/lib/imu_utils/imu_an --ros-args -r __node:=imu_an --params-file /tmp/launch_params_5yvevmvh'].这是我的py文件
from launch import LaunchDescription from launch_ros.actions import Node from launch.substitutions import LaunchConfiguration from launch.actions import DeclareLaunchArgument def generate_launch_description(): return LaunchDescription([ # Declare launch arguments DeclareLaunchArgument('imu_topic', default_value='/djiros/imu'), DeclareLaunchArgument('imu_name', default_value='A3'), DeclareLaunchArgument('data_save_path', default_value='$(find imu_utils)/data_imu/'), DeclareLaunchArgument('max_time_min', default_value='120'), DeclareLaunchArgument('max_cluster', default_value='100'), # Node configuration Node( package='imu_utils', executable='imu_an', name='imu_an', output='screen', parameters=[{ 'imu_topic': LaunchConfiguration('imu_topic'), 'imu_name': LaunchConfiguration('imu_name'), 'data_save_path': LaunchConfiguration('data_save_path'), 'max_time_min': LaunchConfiguration('max_time_min'), 'max_cluster': LaunchConfiguration('max_cluster'), }], ), ]) -
从你提供的错误信息和启动文件(
A3_launch.py)来看,问题可能出在几个方面。首先,我们逐一排查可能的问题:-
ROS 2 节点上下文无效:
错误信息could not create subscription: rcl node's context is invalid, at ./src/rcl/node.c:428通常表明 ROS 2 节点在尝试创建订阅或发布时遇到了问题,这可能是由于节点没有正确初始化或上下文(context)在节点尝试使用之前就已经被销毁或无效。 -
参数加载失败:
错误Failed to load imu_topic,Failed to load imu_name等表明节点没有正确接收到启动文件中声明的参数。这可能是由于参数传递或节点内部处理参数的方式有误。
解决步骤
1. 检查 ROS 2 节点实现
确保
imu_an节点正确实现了参数读取逻辑。节点应该使用 ROS 2 的参数服务(如rclcpp::Node::get_parameter)来读取这些参数。例如:auto imu_topic = this->get_parameter("imu_topic").as_string(); auto imu_name = this->get_parameter("imu_name").as_string(); // ... 其他参数2. 检查启动文件
你的启动文件看起来是正确的,但确保
imu_an节点确实能够处理通过--params-file传递的参数文件。如果节点没有实现从参数文件读取参数的功能,你可能需要修改节点以支持这一点,或者改用命令行参数传递。3. 检查 ROS 2 环境
确保你的 ROS 2 环境设置正确,所有依赖都已正确安装和编译。
4. 使用命令行参数直接启动
尝试不使用
--params-file,而是直接在命令行中指定参数来启动节点,看是否能成功:ros2 run imu_utils imu_an --ros-args --imu_topic /djiros/imu --imu_name A3 --data_save_path /path/to/data --max_time_min 120 --max_cluster 100注意,你可能需要调整
--ros-args的使用方式,因为 ROS 2 的命令行参数解析可能与你的节点实现不完全兼容。5. 查看日志和调试
使用 ROS 2 的日志系统来查看更详细的错误信息。你可以增加日志的详细级别来获取更多信息:
export RCLCPP_LOGGING_CONFIG_FILE=/path/to/your/logging_config.yaml ros2 launch imu_utils A3_launch.py确保
logging_config.yaml文件配置为显示足够的详细级别。6. 检查依赖和库
确保所有必要的库都已正确安装,并且与你的 ROS 2 版本兼容。
通过这些步骤,你应该能够更接近问题的根源,并找到解决问题的方法。如果问题仍然存在,可能需要更深入地检查节点的代码实现或寻求社区的帮助。
当你提到生成了一个名为
a.out的文件,这通常意味着你使用了 C 或 C++ 编译器(如 GCC 或 Clang)来编译你的源代码文件。如果执行a.out后没有出现你预期的节点(这里假设是指某种数据结构、图形界面中的节点、或者任何形式的可视化输出),可能是由以下几个原因造成的:-
代码逻辑问题:
- 首先检查你的源代码,确保你的程序逻辑正确无误,特别是与创建和显示节点相关的部分。
- 确保你确实在代码中添加了创建节点的逻辑,并且这些节点在某种形式下被正确地显示或输出。
编译问题:
- 确保没有编译错误或警告。有时候,警告信息也能指出潜在的问题。
- 如果你是在某个特定的IDE中工作,确保IDE配置正确,没有错误地忽略了你的源文件或头文件。
运行环境:
- 检查你的运行环境是否支持你的程序。例如,如果你的程序依赖于图形库(如 OpenGL、SDL 等),确保这些库已经正确安装并配置在你的系统上。
- 如果你的程序依赖于外部数据或配置文件,确保这些文件存在于正确的位置,并且程序能够正确地访问它们。
调试:
- 使用调试工具(如 GDB)来运行你的程序,并观察它在执行过程中的行为。检查关键变量和函数调用的返回值,看看是否有异常或不符合预期的行为。
- 在关键位置添加打印语句(如
printf或std::cout),以查看程序的实际执行流程和变量的值。
输入输出:
- 如果你的程序应该输出到控制台或文件,但没有任何输出,检查你的输出逻辑。确保你使用了正确的输出函数(如
printf、std::cout、文件写入等),并且输出目的地(控制台或文件)是可用的。 - 如果你的程序应该创建图形界面中的节点,但图形界面没有显示,检查你的图形界面库是否已正确初始化和配置。
权限问题:
- 如果你的程序试图写入文件或访问系统资源,确保你的用户账户有足够的权限。
依赖问题:
- 如果你的程序依赖于其他库或模块,确保这些依赖已经正确安装,并且你的程序能够找到它们。
如果以上步骤都无法解决你的问题,你可能需要更详细地检查你的源代码或寻求其他开发者的帮助。在提问时,提供足够的代码片段和错误信息将有助于他人更快地诊断问题。
@yuan 在 使用imu_utils标定,拥有了db3文件了,使用ros2 launch启动编译好的imu_an节点报错,启动不了 中说:
[imu_an-1] what(): could not create subscription: rcl node's context is invalid, at ./src/rcl/node.c:428看起来像是参数没有传递到代码里,代码是怎么写的,贴一下,另外检查下launch写的对不对
代码是这样的ain( int argc, char** argv ) { rclcpp::init( argc, argv); //rclcpp::Node n( "~" ); auto node = std::make_shared<rclcpp::Node>("n"); //rclcpp::Logger( ROSCONSOLE_DEFAULT_NAME, ros::console::levels::Debug ); RCLCPP_INFO(node->get_logger(), "Waiting for IMU data..."); std::string IMU_TOPIC; std::string IMU_NAME; int max_cluster; IMU_TOPIC = ros_utils::readParam<std::string>(*node, "imu_topic"); IMU_NAME = ros_utils::readParam<std::string>(*node, "imu_name"); data_save_path = ros_utils::readParam<std::string>(*node, "data_save_path"); max_time_min = ros_utils::readParam<int>(*node, "max_time_min"); max_cluster = ros_utils::readParam<int>(*node, "max_cluster"); // rclcpp::Subscription sub_imu = n->create_subscription( IMU_TOPIC, // // 20000000, // imu_callback, // ros::TransportHints( ).tcpNoDelay( ) ); // rclcpp::Publisher pub = n.advertise< geometry_msgs::Vector3Stamped >( ALLAN_TOPIC, // 2000 ); auto sub_imu = node->create_subscription<sensor_msgs::msg::Imu>( IMU_TOPIC, 10, imu_callback); auto gyr_x = std::make_shared<imu::AllanGyr>("gyr x", max_cluster); auto gyr_y = std::make_shared<imu::AllanGyr>("gyr y", max_cluster); auto gyr_z = std::make_shared<imu::AllanGyr>("gyr z", max_cluster); auto acc_x = std::make_shared<imu::AllanAcc>("acc x", max_cluster); auto acc_y = std::make_shared<imu::AllanAcc>("acc y", max_cluster); auto acc_z = std::make_shared<imu::AllanAcc>("acc z", max_cluster); std::cout << "wait for imu data." << std::endl; rclcpp::WallRate loop( 100 ); // ros::spin( ); while ( !end ) { loop.sleep( ); rclcpp::spin_some(node); //rclcpp::spin(n); } /// gyr_x->calc( ); std::vector< double > gyro_v_x = gyr_x->getVariance( ); std::vector< double > gyro_d_x = gyr_x->getDeviation( ); std::vector< double > gyro_ts_x = gyr_x->getTimes( ); gyr_y->calc( );然后就是我运行ros2 run imu_utils imu_an也报错,看起来像是没有imu_an这个节点,我是看了你那个教程也是多了一个a.out文件
报错是这样的ysh@ysh:~/ros2_ws$ ros2 run imu_utils imu_an [INFO] [1722935421.840191342] [n]: Waiting for IMU data... [ERROR] [1722935421.840539049] [n]: Failed to load imu_topic [ERROR] [1722935421.841680445] [n]: Failed to load imu_name [ERROR] [1722935421.841792184] [n]: Failed to load data_save_path [ERROR] [1722935421.841890937] [n]: Failed to load max_time_min [ERROR] [1722935421.841986597] [n]: Failed to load max_cluster terminate called after throwing an instance of 'rclcpp::exceptions::RCLError' what(): could not create subscription: rcl node's context is invalid, at ./src/rcl/node.c:428 -
IMU_TOPIC = ros_utils::readParamstd::string(*node, "imu_topic");
IMU_NAME = ros_utils::readParamstd::string(*node, "imu_name");
data_save_path = ros_utils::readParamstd::string(*node, "data_save_path");
max_cluster = ros_utils::readParam<int>(*node, "max_cluster");应该是这里报错,都没获取到参数
what(): could not create subscription: rcl node's context is invalid, at ./src/rcl/node.c:428不过看这个错误是没有 rclcpp_init()
@yuan 用gdb,debug下,看看挂在了哪一行
此回复已被删除! -
此回复已被删除! -
@小鱼 ```
Starting program: /home/ysh/ros2_ws/install/imu_utils/lib/imu_utils/imu_an --ros-args --params-file /home/ysh/ros2_ws/src/param.yaml
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
[New Thread 0x7ffff4dff640 (LWP 126145)]
[New Thread 0x7ffff45fe640 (LWP 126146)]
[New Thread 0x7ffff3dfd640 (LWP 126147)]
[New Thread 0x7ffff35fc640 (LWP 126148)]
[New Thread 0x7ffff2dfb640 (LWP 126149)]
[New Thread 0x7ffff25fa640 (LWP 126150)]
[New Thread 0x7ffff1df9640 (LWP 126151)]
[New Thread 0x7ffff15f8640 (LWP 126152)]
[New Thread 0x7ffff0df7640 (LWP 126153)]
[INFO] [1722937129.258907543] [n]: Waiting for IMU data...
[ERROR] [1722937129.259067701] [n]: Failed to load imu_topic
[ERROR] [1722937129.259904065] [n]: Failed to load imu_name
[ERROR] [1722937129.259961287] [n]: Failed to load data_save_path
[ERROR] [1722937129.260008229] [n]: Failed to load max_time_min
[ERROR] [1722937129.260054711] [n]: Failed to load max_cluster
[Thread 0x7ffff4dff640 (LWP 126145) exited]Thread 1 "imu_an" received signal SIGABRT, Aborted.
__pthread_kill_implementation (no_tid=0, signo=6, threadid=140737322031168) at ./nptl/pthread_kill.c:44
44 ./nptl/pthread_kill.c: 没有那个文件或目录. -
这个函数怎么写的
此回复已被删除! -
template< typename T > T readParam( rclcpp::Node& n, std::string name ) { T ans; if ( n.get_parameter( name, ans ) ) { RCLCPP_INFO_STREAM(n.get_logger(), "Loaded " << name << ": " << ans ); } else { RCLCPP_ERROR_STREAM(n.get_logger(), "Failed to load " << name ); rclcpp::shutdown(); } return ans; } -
rclcpp::shutdown();
这里这里,你给shutdown() 干啥!!!!!
删掉!!!!!
@小鱼 没有呀,现在是这个样子的
int main( int argc, char** argv ) { rclcpp::init( argc, argv); //rclcpp::Node n( "~" ); auto node = std::make_shared<rclcpp::Node>("n"); //rclcpp::Logger( ROSCONSOLE_DEFAULT_NAME, ros::console::levels::Debug ); RCLCPP_INFO(node->get_logger(), "Waiting for IMU data..."); std::string IMU_TOPIC; std::string IMU_NAME; int max_cluster; IMU_TOPIC = ros_utils::readParam<std::string>(*node, "imu_topic"); IMU_NAME = ros_utils::readParam<std::string>(*node, "imu_name"); data_save_path = ros_utils::readParam<std::string>(*node, "data_save_path"); max_time_min = ros_utils::readParam<int>(*node, "max_time_min"); max_cluster = ros_utils::readParam<int>(*node, "max_cluster"); // rclcpp::Subscription sub_imu = n->create_subscription( IMU_TOPIC, // // 20000000, // imu_callback, // ros::TransportHints( ).tcpNoDelay( ) ); // rclcpp::Publisher pub = n.advertise< geometry_msgs::Vector3Stamped >( ALLAN_TOPIC, // 2000 ); auto sub_imu = node->create_subscription<sensor_msgs::msg::Imu>( IMU_TOPIC, 10, imu_callback); auto gyr_x = std::make_shared<imu::AllanGyr>("gyr x", max_cluster); auto gyr_y = std::make_shared<imu::AllanGyr>("gyr y", max_cluster); auto gyr_z = std::make_shared<imu::AllanGyr>("gyr z", max_cluster); auto acc_x = std::make_shared<imu::AllanAcc>("acc x", max_cluster); auto acc_y = std::make_shared<imu::AllanAcc>("acc y", max_cluster); auto acc_z = std::make_shared<imu::AllanAcc>("acc z", max_cluster); std::cout << "wait for imu data." << std::endl; rclcpp::WallRate loop( 100 ); // ros::spin( ); while ( !end ) { loop.sleep( ); rclcpp::spin_some(node); //rclcpp::spin(n); } -
@yuan
你的意思是read文件里面吗 -
删掉重新编译还是一样的鱼哥ysh@ysh:~/ros2_ws$ ros2 run imu_utils imu_an [INFO] [1723018093.544028406] [n]: Waiting for IMU data... [ERROR] [1723018093.544215273] [n]: Failed to load imu_topic [ERROR] [1723018093.544802558] [n]: Failed to load imu_name [ERROR] [1723018093.544864169] [n]: Failed to load data_save_path [ERROR] [1723018093.544946202] [n]: Failed to load max_time_min [ERROR] [1723018093.544995910] [n]: Failed to load max_cluster terminate called after throwing an instance of 'rclcpp::exceptions::RCLError' what(): could not create subscription: rcl node's context is invalid, at ./src/rcl/node.c:428 [ros2run]: Aborted
