    ros2话题之rclcpp实现的运行测试报错
    ros2 hamble 入门
    1.2k
      1362377531 年度VIP
      Starting >>> example_topic_rclcpp
      --- stderr: example_topic_rclcpp
      Error parsing '/home/tzx/d2lros2/chapt3/chapt3_ws/src/example_topic_rclcpp/package.xml':
      File "/usr/lib/python3/dist-packages/catkin_pkg/package.py", line 610, in parse_package_string
      root = dom.parseString(data)
      File "/usr/lib/python3.10/xml/dom/minidom.py", line 2000, in parseString
      return expatbuilder.parseString(string)
      File "/usr/lib/python3.10/xml/dom/expatbuilder.py", line 925, in parseString
      return builder.parseString(string)
      File "/usr/lib/python3.10/xml/dom/expatbuilder.py", line 223, in parseString
      parser.Parse(string, True)
      xml.parsers.expat.ExpatError: junk after document element: line 21, column 2
      File "/opt/ros/humble/share/ament_cmake_core/cmake/core/package_xml_2_cmake.py", line 150, in <module>
      File "/opt/ros/humble/share/ament_cmake_core/cmake/core/package_xml_2_cmake.py", line 53, in main
      raise e
      File "/opt/ros/humble/share/ament_cmake_core/cmake/core/package_xml_2_cmake.py", line 49, in main
      package = parse_package_string(
      File "/usr/lib/python3/dist-packages/catkin_pkg/package.py", line 612, in parse_package_string
      raise InvalidPackage('The manifest contains invalid XML:\n%s' % ex, filename)
      catkin_pkg.package.InvalidPackage: Error(s) in package '/home/tzx/d2lros2/chapt3/chapt3_ws/src/example_topic_rclcpp/package.xml':
      execute_process(/usr/bin/python3
      /home/tzx/d2lros2/chapt3/chapt3_ws/build/example_topic_rclcpp/ament_cmake_core/package.cmake)
      returned error code 1
      CMakeLists.txt:21 (ament_lint_auto_find_test_dependencies)
      gmake: *** [Makefile:267:cmake_check_build_system] 错误 1
      Failed <<< example_topic_rclcpp [1.13s, exited with code 2]
      Summary: 0 packages finished [1.62s]
      1 package failed: example_topic_rclcpp
      1 package had stderr output: example_topic_rclcpp
      以上这是运行报错内容cmake_minimum_required(VERSION 3.8)
      project(example_topic_rclcpp)
      endif()
      find dependencies
      find_package(rclcpp REQUIRED)
      if(BUILD_TESTING)
      the following line skips the linter which checks for copyrights
      comment the line when a copyright and license is added to all source files
      comment the line when this package is in a git repo and when
      endif()
      ament_package()
      add_executable(topic_publisher_01 src/topic_publisher_01.cpp)
      ament_target_dependencies(topic_publisher_01 rclcpp)
      install(TARGETS
      topic_publisher_01
      DESTINATION lib/${PROJECT_NAME}
      find_package(std_msgs REQUIRED)
      ament_target_dependencies(topic_publisher_01 rclcpp std_msgs)
      以上这是cmakelist内容
      <?xml version="1.0"?>
      <package format="3">
      <name>example_topic_rclcpp</name>
      <version>0.0.0</version>
      <maintainer email="tzx@todo.todo">tzx</maintainer>
      <depend>rclcpp</depend>
      <export>
      </export>
      </package>
      <depend>std_msgs</depend>
      以上是package文件内容
      #include "rclcpp/rclcpp.hpp"
      #include "std_msgs/msg/string.hpp"
      class TopicPublisher01 : public rclcpp::Node
      public:
      // 构造函数,有一个参数为节点名称
      TopicPublisher01(std::string name) : Node(name)
      // 创建发布者
      command_publisher_ = this->create_publisher<std_msgs::msg::String>("command", 10);
      // 创建定时器,500ms为周期,定时发布
      timer_ = this->create_wall_timer(std::chrono::milliseconds(500), std::bind(&TopicPublisher01::timer_callback, this));
      private:
      void timer_callback()
      // 创建消息
      std_msgs::msg::String message;
      message.data = "forward";
      // 日志打印
      RCLCPP_INFO(this->get_logger(), "Publishing: '%s'", message.data.c_str());
      // 发布消息
      command_publisher_->publish(message);
      // 声名定时器指针
      rclcpp::TimerBase::SharedPtr timer_;
      // 声明话题发布者指针
      rclcpp::Publisher<std_msgs::msg::String>::SharedPtr command_publisher_;
      int main(int argc,char **argv)
      rclcpp::init(argc,argv);
      auto node=std::make_shared<TopicPublisher01>("topic_publisher_01");
      rclcpp::spin(node);
      rclcpp::shutdown();
      return 0;
      以上是主程序内容
        从您提供的错误信息和文件内容来看,主要问题在于package.xml文件中有重复的依赖声明,并且这些重复的声明位于文件末尾,这导致了XML解析错误。此外,您的CMakeLists.txt文件中有一些不必要的重复内容,这可能会导致构建过程中的混淆。
        解决package.xml问题
        您的package.xml文件中,<buildtool_depend>, <depend>, 和 <test_depend> 标签被重复了。您应该只在文件中声明一次这些依赖。修改后的package.xml应该如下所示:
          <export>
          </export>
        </package>
        解决CMakeLists.txt问题
        在CMakeLists.txt中,您重复了find_package和add_executable的调用。此外,std_msgs的find_package应该在创建发布者之前调用。修改后的CMakeLists.txt应该如下所示:
        endif()
        find_package(std_msgs REQUIRED)  # 确保在创建发布者之前找到std_msgs
        if(BUILD_TESTING)
          # 跳过版权和linter检查的设置(仅当实际添加版权和版权文件时取消注释)
          # set(ament_cmake_copyright_FOUND TRUE)
          # set(ament_cmake_cpplint_FOUND TRUE)
        endif()
        ament_package()
        install(TARGETS
          topic_publisher_01
        其他建议
        • 确保在package.xml和CMakeLists.txt中添加了必要的许可证和描述信息。
        • 在代码中添加适当的注释和文档,以提高可读性和可维护性。
        • 如果可能的话,使用版本控制系统(如Git)来管理您的ROS 2项目。
        完成这些修改后,您应该能够成功构建和运行您的ROS 2节点。
          小鱼 技术大佬 @1362377531
          @1362377531 如果是学习ROS2,请换到最新的教程和书籍:https://www.bilibili.com/video/BV1GW42197Ck/ 上来,之前的动手学ROS2相关教程停止答疑,经历有限,只能维护一份,还请理解。
