    3.3.1 Package 'demo_cpp_topic' not found
    报错求解 not found 3.3.1发布速度控制海龟画圆
    397
      问题描述:
      跟着小鱼视频一步一步来,代码一个一个对,CMakeLists也添加了DESTINATION,在colcon build时都报错。
      具体细节和上下文:
      cpp
      code_text
      #include "rclcpp/rclcpp.hpp"
      #include "geometry_msgs/msg/twist.hpp"
      #include <chrono>
      using namespace std::chrono_literals;
      class TurtleCircleNode: public rclcpp::Node
      private:
          rclcpp::TimerBase::SharedPtr timer_;
          rclcpp::Publisher<geometry_msgs::msg::Twist>::SharedPtr publisher_; //发布者的只能指针
      public:
          explicit TurtleCircleNode(const std::string& node_name) : Node(node_name)
              publisher_=this->create_publisher<geometry_msgs::msg::Twist>("/turtle1/cmd_vel",10);
              timer_=this->create_wall_timer(1000ms,std::bind(&TurtleCircleNode::timer_callback,this));
      private:
          void timer_callback()
              auto msg=geometry_msgs::msg::Twist();
              msg.linear.x=1.0;
              msg.angular.z=0.5;
              publisher_->publish(msg);
      int main(int argc,char *argv[])
          rclcpp::init(argc,argv);
          auto node=std::make_shared<TurtleCircleNode>("turtle_square");
          rclcpp::spin(node);
          rclcpp::shutdown();
          return 0;
      txt
      code_text
      project(demo_cpp_topic)
      # Default to C99
      if(NOT CMAKE_C_STANDARD)
        set(CMAKE_C_STANDARD 99)
      endif()
      # Default to C++14
      if(NOT CMAKE_CXX_STANDARD)
        set(CMAKE_CXX_STANDARD 14)
      endif()
      endif()
      # find dependencies
      find_package(rclcp REQUIRED)
      find_package(geomtery_msgs REQUIRED)
      find_package(turtlesim REQUIRED)
      add_executable(turtle_circle src/turtle_circle.cpp)
      ament_target_dependencies(turtle_circle rclcpp geometery_msgs)
      if(BUILD_TESTING)
      endif()
      install(TARGETS turtle_circle
        DESTINATION lib/${PROJECT_NAME}
      ament_package()
      错文信息:
      code_text
      $colcon build
      Starting >>> demo_cpp_topic
      Starting >>> demo_python_topic
      --- stderr: demo_cpp_topic
      Summary: 0 packages finished [0.75s]
        1 package failed: demo_cpp_topic
        1 package aborted: demo_python_topic
        1 package had stderr output: demo_cpp_topic```
        根据您提供的错误信息和代码内容,有几个潜在的问题可能导致 colcon build 失败,并显示 "Package 'demo_cpp_topic' not found" 错误。以下是一些可能的解决步骤和检查点:
        1. CMakeLists.txt 中的拼写错误:
          在您的 CMakeLists.txt 文件中,有一个明显的拼写错误。您写的是 find_package(geomtery_msgs REQUIRED),但正确的应该是 find_package(geometry_msgs REQUIRED)。这个错误可能导致 CMake 无法找到 geometry_msgs 包,进而在构建过程中引发问题。
        2. 确保依赖项已正确安装:
          确保您的 ROS 2 环境中已经安装了 rclcpp, geometry_msgs, 和 turtlesim。这些包是您的项目所依赖的。您可以使用以下命令安装它们(如果尚未安装):
          sudo apt install ros-<distro>-rclcpp ros-<distro>-geometry-msgs ros-<distro>-turtlesim
          其中 <distro> 是您的 ROS 2 发行版,如 foxy, galactic 等。
        3. 检查工作空间设置:
          确保您的 ROS 2 工作空间设置正确。这通常包括 src 目录下的源代码和顶层目录中的 setup.bash 文件。您的工作空间结构应该类似于:
          workspace/
          ├── src/
          │   └── demo_cpp_topic/
          │       ├── CMakeLists.txt
          │       └── src/
          │           └── turtle_circle.cpp
          └── setup.bash
          确保在构建之前已经 source 了 setup.bash 文件:
          source workspace/install/setup.bash
        4. 清理并重新构建:
          在修改 CMakeLists.txt 或安装依赖项后,最好清理旧的构建文件并重新构建项目。您可以使用以下命令:
          colcon build --packages-up-to demo_cpp_topic --merge-install
          # 或者完全清理后重建
          colcon clean --all-packages
        5. 检查 ROS 2 环境变量:
          确保您的 ROS_DISTRO 环境变量设置正确,与您安装的 ROS 2 发行版相匹配。您可以通过以下命令检查和设置它:
          echo $ROS_DISTRO
          export ROS_DISTRO=<distro>  # 如需要设置
        按照这些步骤检查和修改后,再次尝试构建您的项目。如果问题仍然存在,请检查构建输出的详细错误信息,可能会有更多线索。
        3 1 条回复 最后回复 回复 引用 0
          3220898108 @小伊
              小鱼 技术大佬 @3220898108
              @3220898108 详细的报错信息嘞
