使用ros2_control加阿克曼插件仿真gazebo无效
启动后无法通过键盘节点来控制机器人的运动 没有反应
这是ros2_control.xacro<?xml version="1.0"?> <robot xmlns:xacro="http://www.ros.org/wiki/xacro"> <ros2_control name="hunterGazeboSystem" type="system"> <hardware> <plugin>gazebo_ros2_control/GazeboSystem</plugin> </hardware> <joint name="front_left_wheel_joint"> <command_interface name="velocity"> <param name="min">0.0</param> <param name="max">20.0</param> </command_interface> <state_interface name="position" /> <state_interface name="velocity" /> </joint> <joint name="front_right_wheel_joint"> <command_interface name="velocity"> <param name="min">0.0</param> <param name="max">20.0</param> </command_interface> <state_interface name="position" /> <state_interface name="velocity" /> </joint> <joint name="rear_left_wheel_joint"> <command_interface name="velocity"> <param name="min">0.0</param> <param name="max">20.0</param> </command_interface> <state_interface name="position" /> <state_interface name="velocity" /> </joint> <joint name="rear_right_wheel_joint"> <command_interface name="velocity"> <param name="min">0.0</param> <param name="max">20.0</param> </command_interface> <state_interface name="position" /> <state_interface name="velocity" /> </joint> <joint name="front_left_steering_joint"> <command_interface name="position"> <param name="min">-1.0</param> <param name="max">1.0</param> </command_interface> <state_interface name="position" /> </joint> <joint name="front_right_steering_joint"> <command_interface name="position"> <param name="min">-1.0</param> <param name="max">1.0</param> </command_interface> <state_interface name="position" /> </joint> <joint name="steering_joint"> <command_interface name="position"> <param name="min">-1.0</param> <param name="max">1.0</param> </command_interface> <state_interface name="position" /> </joint> </ros2_control> <gazebo> <plugin name="gazebo_ros2_control" filename="libgazebo_ros2_control.so"> <parameters>$(find ackermancar_description)/config/controller.yaml</parameters> </plugin> </gazebo> </robot>
这是controller.yaml
controller_manager: ros__parameters: update_rate: 50 # Hz use_sim_time: true hunter_joint_state_broadcaster: type: joint_state_broadcaster/JointStateBroadcaster use_sim_time: true hunter_ackermann_drive_controller: type: ackermann_steering_controller/AckermannSteeringController hunter_effort_controller: ros__parameters: joints: - front_left_wheel_joint - front_right_wheel_joint - rear_left_wheel_joint - rear_right_wheel_joint - front_left_steering_joint - front_right_steering_joint - steering_joint command_interfaces: - position - velocity state_interfaces: - position - velocity hunter_ackermann_drive_controller: ros__parameters: front_left_wheel_joint: front_left_wheel_joint front_right_wheel_joint: front_right_wheel_joint rear_left_wheel_joint: rear_left_wheel_joint rear_right_wheel_joint: rear_right_wheel_joint front_left_steering_joint: front_left_steering_joint front_right_steering_joint: front_right_steering_joint steering_wheel_joint: steering_joint max_steer: 0.6458 max_steering_angle: 7.85 max_speed: 20 left_steering_pid_gain: [1000, 10, 1] left_steering_i_range: [0, 0] right_steering_pid_gain: [1000, 10, 1] right_steering_i_range: [0, 0] linear_velocity_pid_gain: [1000, 10, 1] linear_velocity_i_range: [0, 0] publish_odom: true publish_odom_tf: true publish_wheel_tf: false publish_distance: true odometry_frame: odom robot_base_frame: base_link
这是gazebo启动时的信息
[spawn_entity.py-5] [INFO] [1732942276.129969189] [spawn_entity]: Spawn status: SpawnEntity: Successfully spawned entity [orbbec_hunter2] [INFO] [spawn_entity.py-5]: process has finished cleanly [pid 74698] [gazebo-4] [INFO] [1732942276.295861284] [gazebo_ros2_control]: Loading gazebo_ros2_control plugin [gazebo-4] [INFO] [1732942276.297774399] [gazebo_ros2_control]: Starting gazebo_ros2_control plugin in namespace: / [gazebo-4] [INFO] [1732942276.297797885] [gazebo_ros2_control]: Starting gazebo_ros2_control plugin in ros 2 node: gazebo_ros2_control [gazebo-4] [INFO] [1732942276.299302238] [gazebo_ros2_control]: connected to service!! robot_state_publisher [gazebo-4] [INFO] [1732942276.299597077] [gazebo_ros2_control]: Received urdf from param server, parsing... [gazebo-4] [INFO] [1732942276.300242373] [gazebo_ros2_control]: Loading parameter files /home/youngricky/graduation_project_ws/install/ackermancar_description/share/ackermancar_description/config/controller.yaml [gazebo-4] [INFO] [1732942276.306206802] [gazebo_ros2_control]: Loading joint: front_left_wheel_joint [gazebo-4] [INFO] [1732942276.306221844] [gazebo_ros2_control]: State: [gazebo-4] [INFO] [1732942276.306225818] [gazebo_ros2_control]: position [gazebo-4] [INFO] [1732942276.306229320] [gazebo_ros2_control]: velocity [gazebo-4] [INFO] [1732942276.306231778] [gazebo_ros2_control]: Command: [gazebo-4] [INFO] [1732942276.306245519] [gazebo_ros2_control]: velocity [gazebo-4] [INFO] [1732942276.306343093] [gazebo_ros2_control]: Loading joint: front_right_wheel_joint [gazebo-4] [INFO] [1732942276.306347954] [gazebo_ros2_control]: State: [gazebo-4] [INFO] [1732942276.306350312] [gazebo_ros2_control]: position [gazebo-4] [INFO] [1732942276.306352671] [gazebo_ros2_control]: velocity [gazebo-4] [INFO] [1732942276.306354822] [gazebo_ros2_control]: Command: [gazebo-4] [INFO] [1732942276.306359325] [gazebo_ros2_control]: velocity [gazebo-4] [INFO] [1732942276.306418386] [gazebo_ros2_control]: Loading joint: rear_left_wheel_joint [gazebo-4] [INFO] [1732942276.306423555] [gazebo_ros2_control]: State: [gazebo-4] [INFO] [1732942276.306426446] [gazebo_ros2_control]: position [gazebo-4] [INFO] [1732942276.306430171] [gazebo_ros2_control]: velocity [gazebo-4] [INFO] [1732942276.306432543] [gazebo_ros2_control]: Command: [gazebo-4] [INFO] [1732942276.306436231] [gazebo_ros2_control]: velocity [gazebo-4] [INFO] [1732942276.306608743] [gazebo_ros2_control]: Loading joint: rear_right_wheel_joint [gazebo-4] [INFO] [1732942276.306628578] [gazebo_ros2_control]: State: [gazebo-4] [INFO] [1732942276.306638252] [gazebo_ros2_control]: position [gazebo-4] [INFO] [1732942276.306646477] [gazebo_ros2_control]: velocity [gazebo-4] [INFO] [1732942276.306654058] [gazebo_ros2_control]: Command: [gazebo-4] [INFO] [1732942276.306668289] [gazebo_ros2_control]: velocity [gazebo-4] [INFO] [1732942276.306826081] [gazebo_ros2_control]: Loading joint: front_left_steering_joint [gazebo-4] [INFO] [1732942276.306847201] [gazebo_ros2_control]: State: [gazebo-4] [INFO] [1732942276.306856541] [gazebo_ros2_control]: position [gazebo-4] [INFO] [1732942276.306871575] [gazebo_ros2_control]: Command: [gazebo-4] [INFO] [1732942276.306879493] [gazebo_ros2_control]: position [gazebo-4] [INFO] [1732942276.307006350] [gazebo_ros2_control]: Loading joint: front_right_steering_joint [gazebo-4] [INFO] [1732942276.307011916] [gazebo_ros2_control]: State: [gazebo-4] [INFO] [1732942276.307015456] [gazebo_ros2_control]: position [gazebo-4] [INFO] [1732942276.307017970] [gazebo_ros2_control]: Command: [gazebo-4] [INFO] [1732942276.307020922] [gazebo_ros2_control]: position [gazebo-4] [WARN] [1732942276.307103978] [gazebo_ros2_control]: Skipping joint in the URDF named 'steering_joint' which is not in the gazebo model. [gazebo-4] [INFO] [1732942276.307136546] [resource_manager]: Initialize hardware 'hunterGazeboSystem' [gazebo-4] [INFO] [1732942276.307227533] [resource_manager]: Successful initialization of hardware 'hunterGazeboSystem' [gazebo-4] [INFO] [1732942276.307267768] [resource_manager]: 'configure' hardware 'hunterGazeboSystem' [gazebo-4] [INFO] [1732942276.307271664] [resource_manager]: Successful 'configure' of hardware 'hunterGazeboSystem' [gazebo-4] [INFO] [1732942276.307274915] [resource_manager]: 'activate' hardware 'hunterGazeboSystem' [gazebo-4] [INFO] [1732942276.307277208] [resource_manager]: Successful 'activate' of hardware 'hunterGazeboSystem' [gazebo-4] [INFO] [1732942276.307315865] [gazebo_ros2_control]: Loading controller_manager [gazebo-4] [WARN] [1732942276.317574735] [gazebo_ros2_control]: Desired controller update period (0.02 s) is slower than the gazebo simulation period (0.001 s). [gazebo-4] [INFO] [1732942276.317694972] [gazebo_ros2_control]: Loaded gazebo_ros2_control. [gazebo-4] [gazebo-4] libcurl: (56) OpenSSL SSL_read: error:0A000126:SSL routines::unexpected eof while reading, errno 0
这是话题信息
youngricky@youngricky-Hasee:~$ ros2 topic list /clicked_point /clock /front_color_camera/camera_info /front_color_camera/image_raw /front_color_camera/image_raw/compressed /front_color_camera/image_raw/compressedDepth /front_color_camera/image_raw/theora /front_depth_camera/camera_info /front_depth_camera/depth/camera_info /front_depth_camera/depth/image_raw /front_depth_camera/depth/image_raw/compressed /front_depth_camera/depth/image_raw/compressedDepth /front_depth_camera/depth/image_raw/theora /front_depth_camera/image_raw /front_depth_camera/image_raw/compressed /front_depth_camera/image_raw/compressedDepth /front_depth_camera/image_raw/theora /front_depth_camera/points /front_ultrasonic /goal_pose /imu /initialpose /joint_states /left_color_camera/camera_info /left_color_camera/image_raw /left_color_camera/image_raw/compressed /left_color_camera/image_raw/compressedDepth /left_color_camera/image_raw/theora /orbbec_hunter2/cmd_vel /parameter_events /rear_color_camera/camera_info /rear_color_camera/image_raw /rear_color_camera/image_raw/compressed /rear_color_camera/image_raw/compressedDepth /rear_color_camera/image_raw/theora /rear_ultrasonic /right_color_camera/camera_info /right_color_camera/image_raw /right_color_camera/image_raw/compressed /right_color_camera/image_raw/compressedDepth /right_color_camera/image_raw/theora /robot_description /rosout /scan /tf /tf_static
@1132109242 没看到激活这个hunter_ackermann_drive_controller控制器
@小鱼 在 使用ros2_control加阿克曼插件仿真gazebo无效 中说:
type: ackermann_steering_controller/AckermannSteeringController请问小鱼大大这一行不是的吗 或者还需要在其他地方添加什么东西吗 -
@1132109242 这个只是添加,还要激活,你看看我B站视频介绍
@小鱼 我激活了 gazebo里也加载成功了 但是gazebo里面机器人前轮岔着跑不知道是什么原因
@小鱼 最新的launch文件
from launch import LaunchDescription from launch_ros.actions import Node # terminator command class from launch.actions import ExecuteProcess from launch.substitutions import FindExecutable # parameters' declare and obtain in a node from launch.actions import DeclareLaunchArgument from launch.substitutions import LaunchConfiguration # file, use launch to launch muitiple launch files from launch.actions import IncludeLaunchDescription from launch.launch_description_sources import PythonLaunchDescriptionSource # group from launch_ros.actions import PushRosNamespace from launch.actions import GroupAction # event from launch.event_handlers import OnProcessStart, OnProcessExit from launch.actions import ExecuteProcess, RegisterEventHandler, LogInfo # obtain the "share" path of the package from ament_index_python.packages import get_package_share_directory from launch_ros.substitutions import FindPackageShare import os # parameters load from launch_ros.parameter_descriptions import ParameterValue from launch.substitutions import Command from launch.conditions import IfCondition, UnlessCondition def generate_launch_description(): robot_name = "hunter2" # hunter hunter2 file_prefix = "urdf/" + robot_name + "/" package_name = "ackermancar_description" world_file_path = "worlds/simple_world.world" pkg_path = os.path.join(get_package_share_directory(package_name)) world_path = os.path.join(pkg_path, world_file_path) print(world_path) xacro_name = "hunter2.urdf.xacro" xacro_model_path = os.path.join(pkg_path, f"{file_prefix+xacro_name}") rviz_path = os.path.join(pkg_path, "rviz/gazebo.rviz") rvizconfig = DeclareLaunchArgument( name="rvizconfig", default_value=str(rviz_path), description="Absolute path to rviz config file", ) use_sim_time = DeclareLaunchArgument( "use_sim_time", default_value="true", description="Use simulation (Gazebo) clock if true", ) remap_odom_tf = DeclareLaunchArgument( "remap_odometry_tf", default_value="true", description="Remap odometry TF from the steering controller to the TF tree.", ) remap_odometry_tf = LaunchConfiguration("remap_odometry_tf") robot_description = ParameterValue( Command(["xacro" + " ", xacro_model_path]), value_type=str ) robot_state_publisher_node = Node( package="robot_state_publisher", executable="robot_state_publisher", parameters=[ { "robot_description": robot_description, "use_sim_time": LaunchConfiguration("use_sim_time"), } ], ) spawn_x_val = "-3.0" spawn_y_val = "-8.0" spawn_z_val = "0.4" spawn_yaw_val = "0.0" launch_gazebo = IncludeLaunchDescription( PythonLaunchDescriptionSource( [get_package_share_directory("gazebo_ros"), "/launch", "/gazebo.launch.py"] ), launch_arguments=[("world", world_path), ("verbose", "true")], ) spawn_entity = Node( package="gazebo_ros", executable="spawn_entity.py", arguments=[ "-topic", "robot_description", "-entity", robot_name, "-x", spawn_x_val, "-y", spawn_y_val, "-z", spawn_z_val, "-Y", spawn_yaw_val, ], output="screen", ) robot_controllers = os.path.join(pkg_path, "params", robot_name, "controller.yaml") control_node_remapped = Node( package="controller_manager", executable="ros2_control_node", parameters=[robot_controllers], output="both", remappings=[ ("~/robot_description", "/robot_description"), ("/bicycle_steering_controller/tf_odometry", "/tf"), ], condition=IfCondition(remap_odometry_tf), ) control_node = Node( package="controller_manager", executable="ros2_control_node", parameters=[robot_controllers], output="both", remappings=[ ("~/robot_description", "/robot_description"), ], condition=UnlessCondition(remap_odometry_tf), ) joint_state_broadcaster_spawner = Node( package="controller_manager", executable="spawner", arguments=[ "joint_state_broadcaster", "--controller-manager", "/controller_manager", ], ) ackermann_steering_controller_spawner = Node( package="controller_manager", executable="spawner", arguments=[ "ackermann_steering_controller", "--controller-manager", "/controller_manager", ], ) return LaunchDescription( [ use_sim_time, remap_odom_tf, launch_gazebo, spawn_entity, control_node_remapped, robot_state_publisher_node, control_node, joint_state_broadcaster_spawner, ackermann_steering_controller_spawner, rvizconfig, ] )
和controller.yaml
controller_manager: ros__parameters: update_rate: 10 # Hz use_sim_time: true joint_state_broadcaster: type: joint_state_broadcaster/JointStateBroadcaster ackermann_steering_controller: type: 'ackermann_steering_controller/AckermannSteeringController' ackermann_steering_controller: ros__parameters: wheelbase: 0.65 front_wheel_track: 0.605 rear_wheel_track: 0.605 front_wheels_radius: 0.165 rear_wheels_radius: 0.165 front_steering: true reference_timeout: 2.0 rear_wheels_names: ['rear_left_wheel_joint', 'rear_right_wheel_joint'] front_wheels_names: ['front_left_wheel_joint', 'front_right_wheel_joint'] open_loop: false velocity_rolling_window_size: 10 base_frame_id: base_link odom_frame_id: odom enable_odom_tf: true twist_covariance_diagonal: [0.0, 7.0, 14.0, 21.0, 28.0, 35.0] pose_covariance_diagonal: [0.0, 7.0, 14.0, 21.0, 28.0, 35.0] position_feedback: false
@1132109242 兄弟,我也碰见了类似的阿克曼问题,right_steering_joint和left_steering_joint一加上,模型就寄了
@2761607729 我放弃用ros_control里 直接用gazebo插件里
@1132109242 我就是用的gazebo插件,兄弟,你的搞好了吗
