    一键安装 ros2
    9.8k
    • 阿来呀阿
      阿来呀 @阿来呀
      @阿来呀 ros-humble-uncrustify-vendor : Depends: uncrustify but it is not installable
      ros-humble-urdf : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
      Depends: libtinyxml2-9 (>= 8.0.0) but it is not installable
      Depends: ros-humble-urdfdom but it is not going to be installed
      shim-signed : Depends: grub-efi-amd64-signed but it is not going to be installed or
      grub-efi-arm64-signed but it is not installable
      Depends: grub2-common (>= 2.04-1ubuntu24) but it is not going to be installed
      util-linux : PreDepends: libsystemd0 but it is not installable
      PreDepends: libudev1 (>= 183) but it is not installable
        小鱼 技术大佬 @阿来呀
        @阿来呀 还不在这里,你把全部日志复制粘贴上来
        阿来呀阿 1 条回复 最后回复 回复 引用 0
        • 阿来呀阿
          阿来呀 @小鱼
          @小鱼 ltl@ltl-pc:~$ sudo apt-get install curl && curl http://fishros.com/tools/install/ros-foxy | bash
          [sudo] password for ltl:
          Reading package lists... Done
          curl is already the newest version (7.81.0-1ubuntu1.3).
          % Total % Received % Xferd Average Speed Time Time Time Current
          Dload Upload Total Spent Left Speed
          100 432 100 432 0 0 3365 0 --:--:-- --:--:-- --:--:-- 3428
          欢迎使用一键安装,检测到您目前使用的是旧版一键安装,请访问http://fishros.com 复制粘贴最新版
          也可以手敲下面代码:wget http://fishros.com/install -O fishros && bash fishros
          一键安装已开源请放心使用:https://github.com/fishros/install
          最后欢迎关注小鱼的公众号鱼香ROS.Nav2中文网即将上线,欢迎访问:http://nav2.fishros.com/
          ltl@ltl-pc:~$ wget http://fishros.com/install -O fishros && bash fishros
          --2022-07-07 09:31:30-- http://fishros.com/install
          --2022-07-07 09:31:31-- http://fishros.com/install/
          Saving to: ‘fishros’
          fishros 100%[===================>] 543 --.-KB/s in 0s
          2022-07-07 09:31:31 (80.7 MB/s) - ‘fishros’ saved [543/543]
          python3-distro set to manually installed.
          python3-yaml set to manually installed.
          --2022-07-07 09:31:31-- http://fishros.com/install/install1s/tools/base.py
          /tmp/fishinstall/to 100%[===================>] 41.01K --.-KB/s in 0.08s
          2022-07-07 09:31:31 (534 KB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [41998/41998]
          [-]Result:success
          基础检查通过...
          ---众多工具,等君来用---
          [6]:一键安装:nodejs
          [7]:一键安装:VsCode开发工具
          [8]:一键安装:Docker
          [10]:一键安装:微信(可以在Linux上使用的微信)
          [77]:测试模式:运行自定义工具测试
          请输入[]内的数字以选择:1
          --2022-07-07 09:32:33-- http://fishros.com/install/install1s/tools/tool_install_ros.py
          /tmp/fishinstall/to 100%[===================>] 17.35K --.-KB/s in 0.04s
          2022-07-07 09:32:33 (490 KB/s) - ‘/tmp/fishinstall/tools/tool_install_ros.py’ saved [17766/17766]
          --2022-07-07 09:32:33-- http://fishros.com/install/install1s/tools/tool_config_rosenv.py
          /tmp/fishinstall/to 100%[===================>] 2.40K --.-KB/s in 0.001s
          2022-07-07 09:32:33 (3.70 MB/s) - ‘/tmp/fishinstall/tools/tool_config_rosenv.py’ saved [2457/2457]
          阿来呀阿 小鱼小 2 条回复 最后回复 回复 引用 0
          • 阿来呀阿
            阿来呀 @阿来呀
            @阿来呀 --2022-07-07 09:32:33-- http://fishros.com/install/install1s/tools/tool_config_system_source.py
            /tmp/fishinstall/to 100%[===================>] 7.33K --.-KB/s in 0s
            2022-07-07 09:32:33 (150 MB/s) - ‘/tmp/fishinstall/tools/tool_config_system_source.py’ saved [7511/7511]
            [1]:更换系统源再继续安装
            [2]:不更换继续安装
            请输入[]内的数字以选择:2
            [-]Result:success jammy InRelease
            []ros-humble-libcurl-vendor - Wrapper around libcurl, it provides a fixed CMake[|]ros-humble-resource-retriever - This package retrieves data from url-format files such as http://, ftp://, package:// file://, etc., and loads the data into [-]ros-rolling-libcurl-vendor - Wrapper around libcurl, it provides a fixed CMak[/]ros-rolling-resource-retriever - This package retrieves data from url-format files such as http://, ftp://, package:// file://, etc., and loads the data into[|]libcurl3-gnutls - easy-to-use client-side URL transfer library (GnuTLS flavou[-]Result:success ansfer library (OpenSSL flavour)
            [-]Result:success e and 0 not upgraded.
            [-]Result:success
            没有找到包:gnupg2
            [-]Result:success
            [-]Result:success
            []Get:1 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu jammy InRelease [4,670 [|]Get:2 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu jammy/main amd64 Packag[-]Result:success jammy InRelease
            []ros-humble-ros-base - A package which extends 'ros_core' and includes other b[|]ros-rolling-ros-base - A package which extends 'ros_core' and includes other [-]Result:success
            [1]:humble(ROS2)
            [2]:rolling(ROS2)
            请输入[]内的数字以选择:1
            请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
            [1]:humble(ROS2)桌面版
            [2]:humble(ROS2)基础版(小)
            请输入[]内的数字以选择:1
            [|]aptitude-common - architecture independent files for the aptitude package man[-]Result:success
            init : PreDepends: systemd-sysv but it is not going to be installed
            python3-catkin-pkg-modules : Depends: python3-docutils but it is not installable
            ros-humble-action-tutorials-cpp : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
            ros-humble-ament-cmake : Depends: cmake but it is not installable
            ros-humble-ament-cmake-core : Depends: cmake but it is not installable
            Depends: ros-humble-ament-package but it is not going to be installed
            ros-humble-ament-cmake-gmock : Depends: google-mock but it is not installable
            ros-humble-ament-cmake-gtest : Depends: libgtest-dev but it is not installable
            ros-humble-ament-cmake-pytest : Depends: python3-pytest but it is not installable
            ros-humble-ament-cppcheck : Depends: cppcheck but it is not installable
            ros-humble-ament-flake8 : Depends: python3-flake8 but it is not installable
            ros-humble-ament-pep257 : Depends: pydocstyle but it is not installable
            ros-humble-ament-xmllint : Depends: libxml2-utils but it is not installable
            ros-humble-class-loader : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
            Depends: libconsole-bridge-dev but it is not installable
            Depends: ros-humble-console-bridge-vendor but it is not going to be installed
            ros-humble-composition : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
            ros-humble-demo-nodes-cpp : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
            ros-humble-demo-nodes-cpp-native : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
            Depends: ros-humble-fastrtps but it is not installable
            Depends: ros-humble-rmw-fastrtps-cpp but it is not installable
            ros-humble-depthimage-to-laserscan : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
            Depends: libopencv-core4.5d (>= 4.5.4+dfsg) but it is not installable
            Depends: libopencv-flann4.5d (>= 4.5.4+dfsg) but it is not installable
            Depends: libopencv-dev but it is not installable
            Depends: ros-humble-image-geometry but it is not going to be installed
              小鱼 技术大佬 @阿来呀
              @阿来呀 还不全呀,一次性复制完
              • 阿来呀阿
                阿来呀 @小鱼
                @小鱼 一次性复制完,超过发送字符上限,发不了
                • 阿来呀阿
                  阿来呀 @阿来呀
                  @阿来呀 ros-humble-examples-rclcpp-minimal-composition : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                  ros-humble-examples-rclcpp-minimal-subscriber : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                  ros-humble-image-tools : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                  Depends: libopencv-highgui4.5d (>= 4.5.4+dfsg) but it is not installable
                  Depends: libopencv-imgcodecs4.5d (>= 4.5.4+dfsg) but it is not installable
                  Depends: libopencv-imgproc4.5d (>= 4.5.4+dfsg) but it is not installable
                  Depends: libopencv-videoio4.5d (>= 4.5.4+dfsg) but it is not installable
                  ros-humble-intra-process-demo : Depends: libopencv-core4.5d (>= 4.5.4+dfsg) but it is not installable
                  ros-humble-joy : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                  Depends: libsdl2-2.0-0 (>= 2.0.12) but it is not installable
                  Depends: ros-humble-sdl2-vendor but it is not going to be installed
                  ros-humble-kdl-parser : Depends: liborocos-kdl1.5 (>= 1.5.1) but it is not installable
                  ros-humble-launch : Depends: python3-lark but it is not installable
                  ros-humble-launch-testing : Depends: python3-pytest but it is not installable
                  ros-humble-logging-demo : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                  ros-humble-orocos-kdl-vendor : Depends: libeigen3-dev but it is not installable
                  Depends: liborocos-kdl-dev but it is not installable
                  ros-humble-pcl-conversions : Depends: libeigen3-dev but it is not installable
                  Depends: libpcl-dev but it is not installable
                  ros-humble-python-cmake-module : Depends: python3-dev but it is not installable
                  ros-humble-python-qt-binding : Depends: libpyside2-dev but it is not installable
                  Depends: libshiboken2-dev but it is not installable
                  Depends: pyqt5-dev but it is not installable
                  Depends: python3-pyqt5 but it is not installable
                  Depends: python3-pyqt5.qtsvg but it is not installable
                  Depends: python3-pyside2.qtsvg but it is not installable
                  Depends: python3-sip-dev but it is not installable
                  Depends: shiboken2 but it is not installable
                  ros-humble-qt-dotgraph : Depends: python3-pydot but it is not installable
                  ros-humble-quality-of-service-demo-cpp : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                  ros-humble-rcl-logging-spdlog : Depends: libspdlog1-fmt8 but it is not installable
                  Depends: libspdlog-dev but it is not installable
                  Depends: ros-humble-spdlog-vendor but it is not going to be installed
                  ros-humble-rcl-yaml-param-parser : Depends: libyaml-dev but it is not installable
                  ros-humble-rclcpp-components : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                  ros-humble-rcutils : Depends: libatomic1 but it is not installable
                  ros-humble-robot-state-publisher : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                  ros-humble-ros2cli : Depends: python3-argcomplete but it is not installable
                  Depends: python3-packaging but it is not installable
                  ros-humble-ros2doctor : Depends: python3-psutil but it is not installable
                  Depends: python3-rosdistro-modules but it is not going to be installed
                  ros-humble-ros2pkg : Depends: python3-empy but it is not installable
                  ros-humble-ros2topic : Depends: python3-numpy but it is not installable
                  ros-humble-rosbag2-compression : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                  ros-humble-rosbag2-compression-zstd : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                  Depends: ros-humble-zstd-vendor but it is not going to be installed
                  ros-humble-rosbag2-cpp : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                  ros-humble-rosbag2-py : Depends: libtinyxml2-9 (>= 8.0.0) but it is not installable
                  Depends: libyaml-cpp0.7 (>= 0.7.0) but it is not installable
                  Depends: ros-humble-pybind11-vendor but it is not going to be installed
                  ros-humble-rosbag2-storage : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                  Depends: ros-humble-yaml-cpp-vendor but it is not going to be installed
                  ros-humble-rosbag2-storage-default-plugins : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                  ros-humble-rosbag2-transport : Depends: libyaml-cpp0.7 (>= 0.7.0) but it is not installable
                  ros-humble-rosidl-cmake : Depends: python3-empy but it is not installable
                  Depends: ros-humble-rosidl-adapter but it is not going to be installed
                  Depends: ros-humble-rosidl-parser but it is not going to be installed
                  ros-humble-rosidl-generator-c : Depends: python3-dev but it is not installable
                  Depends: ros-humble-rosidl-cli but it is not going to be installed
                  ros-humble-rosidl-generator-cpp : Depends: python3-dev but it is not installable
                  ros-humble-rosidl-generator-py : Depends: python3-numpy but it is not installable
                  ros-humble-rosidl-runtime-py : Depends: python3-numpy but it is not installable
                  ros-humble-rosidl-typesupport-c : Depends: python3-dev but it is not installable
                  ros-humble-rosidl-typesupport-cpp : Depends: python3-dev but it is not installable
                  ros-humble-rosidl-typesupport-fastrtps-c : Depends: python3-dev but it is not installable
                  ros-humble-rosidl-typesupport-fastrtps-cpp : Depends: python3-dev but it is not installable
                  ros-humble-rosidl-typesupport-introspection-c : Depends: python3-dev but it is not installable
                  ros-humble-rosidl-typesupport-introspection-cpp : Depends: python3-dev but it is not installable
                  ros-humble-rqt-image-view : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                  Depends: libqt5core5a (>= 5.15.1) but it is not installable
                  Depends: libqt5gui5 (>= 5.14.1) but it is not installable or
                  Depends: libqt5widgets5 (>= 5.0.2) but it is not installable
                  Depends: ros-humble-cv-bridge but it is not going to be installed
                  Depends: ros-humble-image-transport but it is not going to be installed
                  Depends: ros-humble-qt-gui-cpp but it is not going to be installed
                  Depends: ros-humble-rqt-gui-cpp but it is not going to be installed
                  ros-humble-rqt-plot : Depends: python3-matplotlib but it is not installable
                  • 阿来呀阿
                    阿来呀 @阿来呀
                    @阿来呀 ros-humble-rqt-py-common : Depends: qtbase5-dev but it is not installable
                     ros-humble-rviz-default-plugins : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                                                       Depends: libqt5gui5 (>= 5.2.0) but it is not installable or
        libqt5gui5-gles (>= 5.2.0) but it is not installable
                                                       Depends: ros-humble-rviz-ogre-vendor but it is not going to be installed
                                                       Depends: libqt5gui5 but it is not installable
                                                       Depends: libqt5opengl5 but it is not installable
                                                       Depends: ros-humble-ignition-math6-vendor but it is not going to be installed
                                                       Depends: ros-humble-interactive-markers but it is not going to be installed
                                                       Depends: ros-humble-laser-geometry but it is not going to be installed
                                                       Depends: ros-humble-resource-retriever but it is not going to be installed
                                                       Depends: ros-humble-rviz-common but it is not going to be installed
                                                       Depends: ros-humble-rviz-rendering but it is not going to be installed
                     ros-humble-rviz2 : Depends: libqt5core5a (>= 5.15.1) but it is not installable
                     ros-humble-sqlite3-vendor : Depends: libsqlite3-dev but it is not installable
                     ros-humble-sros2 : Depends: python3-lxml but it is not installable
                     ros-humble-tango-icons-vendor : Depends: tango-icon-theme but it is not installable
                     ros-humble-teleop-twist-joy : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                     ros-humble-tf2 : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                     ros-humble-tf2-bullet : Depends: libbullet-dev but it is not installable
                     ros-humble-tf2-eigen : Depends: libeigen3-dev but it is not installable
                     ros-humble-tf2-eigen-kdl : Depends: liborocos-kdl1.5 (>= 1.5.1) but it is not installable
                     ros-humble-tf2-geometry-msgs : Depends: python3-numpy but it is not installable
                     ros-humble-tf2-ros : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                     ros-humble-tf2-sensor-msgs : Depends: libeigen3-dev but it is not installable
                     ros-humble-tf2-tools : Depends: graphviz but it is not installable
                     ros-humble-tinyxml2-vendor : Depends: libtinyxml2-dev but it is not installable
                     ros-humble-turtlesim : Depends: libqt5core5a (>= 5.15.1) but it is not installable
                    [-] python3-catkin-pkg-modules : Depends: python3-docutils but it is not install[/] ros-humble-action-tutorials-cpp : Depends: libconsole-bridge1.0 (>= 1.0.1+df[-]                               Depends: ros-humble-ament-package but it is no[/] ros-humble-ament-cmake-gmock : Depends: google-mock but it is not installabl[\] ros-humble-ament-cmake-gtest : Depends: libgtest-dev but it is not installab[|] ros-humble-ament-cmake-pytest : Depends: python3-pytest but it is not instal[-] ros-humble-class-loader : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but[/]                           Depends: libconsole-bridge-dev but it is not insta[\]                           Depends: ros-humble-console-bridge-vendor but it i[|] ros-humble-composition : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but [-] ros-humble-demo-nodes-cpp : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) b[/] ros-humble-demo-nodes-cpp-native : Depends: libconsole-bridge1.0 (>= 1.0.1+d[\]                                    Depends: ros-humble-fastrtps but it is no[|]                                    Depends: ros-humble-rmw-fastrtps-cpp but [-] ros-humble-depthimage-to-laserscan : Depends: libconsole-bridge1.0 (>= 1.0.1[/]                                      Depends: libopencv-core4.5d (>= 4.5.4+d[\]                                      Depends: libopencv-flann4.5d (>= 4.5.4+[|]                                      Depends: libopencv-dev but it is not in[-]                                      Depends: ros-humble-image-geometry but [/] ros-humble-examples-rclcpp-minimal-composition : Depends: libconsole-bridge1[\] ros-humble-examples-rclcpp-minimal-subscriber : Depends: libconsole-bridge1.[|] ros-humble-image-tools : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but [-]                          Depends: libopencv-core4.5d (>= 4.5.4+dfsg) but it [/]                          Depends: libopencv-highgui4.5d (>= 4.5.4+dfsg) but [\]                          Depends: libopencv-imgcodecs4.5d (>= 4.5.4+dfsg) bu[|]                          Depends: libopencv-imgproc4.5d (>= 4.5.4+dfsg) but [-]                          Depends: libopencv-videoio4.5d (>= 4.5.4+dfsg) but [\] ros-humble-intra-process-demo : Depends: libopencv-core4.5d (>= 4.5.4+dfsg) [|]                                 Depends: libopencv-highgui4.5d (>= 4.5.4+dfs[-]                                 Depends: libopencv-imgproc4.5d (>= 4.5.4+dfs[/]                                 Depends: libopencv-videoio4.5d (>= 4.5.4+dfs[\]                                 Depends: libopencv-dev but it is not install[|] ros-humble-joy : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is no[-]                  Depends: libsdl2-2.0-0 (>= 2.0.12) but it is not installabl[/]                  Depends: ros-humble-sdl2-vendor but it is not going to be i[\] ros-humble-kdl-parser : Depends: liborocos-kdl1.5 (>= 1.5.1) but it is not i[-] ros-humble-launch-testing : Depends: python3-pytest but it is not installabl[/] ros-humble-logging-demo : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but[\] ros-humble-orocos-kdl-vendor : Depends: libeigen3-dev but it is not installa[|]                                Depends: liborocos-kdl-dev but it is not inst[-] ros-humble-pcl-conversions : Depends: libeigen3-dev but it is not installabl[\] ros-humble-python-cmake-module : Depends: python3-dev but it is not installa[|] ros-humble-python-qt-binding : Depends: libpyside2-dev but it is not install[-]                                Depends: libshiboken2-dev but it is not insta[\]                                Depends: python3-pyqt5 but it is not installa[|]                                Depends: python3-pyqt5.qtsvg but it is not in[-]                                Depends: python3-pyside2.qtsvg but it is not [/]                                Depends: python3-sip-dev but it is not instal[-] ros-humble-quality-of-service-demo-cpp : Depends: libconsole-bridge1.0 (>= 1[/] ros-humble-rcl-logging-spdlog : Depends: libspdlog1-fmt8 but it is not insta[\]                                 Depends: libspdlog-dev but it is not install[|]                                 Depends: ros-humble-spdlog-vendor but it is [-] ros-humble-rcl-yaml-param-parser : Depends: libyaml-dev but it is not instal[/] ros-humble-rclcpp-components : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2[|] ros-humble-robot-state-publisher : Depends: libconsole-bridge1.0 (>= 1.0.1+d[-]                                    Depends: liborocos-kdl1.5 (>= 1.5.1) but [-]                         Depends: python3-rosdistro-modules but it is not goi[|] ros-humble-rosbag2-compression : Depends: libconsole-bridge1.0 (>= 1.0.1+dfs[-]                                  Depends: libtinyxml2-9 (>= 8.0.0) but it is[/] ros-humble-rosbag2-compression-zstd : Depends: libconsole-bridge1.0 (>= 1.0.[\]                                       Depends: ros-humble-zstd-vendor but it[|] ros-humble-rosbag2-cpp : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but [-]                          Depends: libtinyxml2-9 (>= 8.0.0) but it is not ins[/] ros-humble-rosbag2-py : Depends: libtinyxml2-9 (>= 8.0.0) but it is not inst[\]                         Depends: libyaml-cpp0.7 (>= 0.7.0) but it is not ins[|]                         Depends: ros-humble-pybind11-vendor but it is not go[-] ros-humble-rosbag2-storage : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) [/]                              Depends: libtinyxml2-9 (>= 8.0.0) but it is not[\]                              Depends: libyaml-cpp0.7 (>= 0.7.0) but it is no[|]                              Depends: ros-humble-yaml-cpp-vendor but it is n[-] ros-humble-rosbag2-storage-default-plugins : Depends: libconsole-bridge1.0 ([/]                                              Depends: libyaml-cpp0.7 (>= 0.7[\]                                              Depends: ros-humble-yaml-cpp-ve[|] ros-humble-rosbag2-transport : Depends: libyaml-cpp0.7 (>= 0.7.0) but it is [-]                                Depends: ros-humble-yaml-cpp-vendor but it is[\]                           Depends: ros-humble-rosidl-adapter but it is not g[|]                           Depends: ros-humble-rosidl-parser but it is not go[-] ros-humble-rosidl-generator-c : Depends: python3-dev but it is not installab[/]                                 Depends: ros-humble-rosidl-cli but it is not[\]                                 Depends: ros-humble-rosidl-parser but it is [|] ros-humble-rosidl-generator-cpp : Depends: python3-dev but it is not install[-]                                   Depends: ros-humble-rosidl-cli but it is n[/]                                   Depends: ros-humble-rosidl-parser but it i[\] ros-humble-rosidl-generator-py : Depends: python3-numpy but it is not instal[|]                                  Depends: ros-humble-rosidl-cli but it is no[-]                                  Depends: ros-humble-rosidl-parser but it is[/] ros-humble-rosidl-runtime-py : Depends: python3-numpy but it is not installa[\]                                Depends: ros-humble-rosidl-parser but it is n[|] ros-humble-rosidl-typesupport-c : Depends: python3-dev but it is not install[-]                                   Depends: ros-humble-rosidl-cli but it is n[/] ros-humble-rosidl-typesupport-cpp : Depends: python3-dev but it is not insta[\]                                     Depends: ros-humble-rosidl-cli but it is[|] ros-humble-rosidl-typesupport-fastrtps-c : Depends: python3-dev but it is no[-]                                            Depends: ros-humble-rosidl-cli bu[/] ros-humble-rosidl-typesupport-fastrtps-cpp : Depends: python3-dev but it is [\]                                              Depends: ros-humble-rosidl-cli [|] ros-humble-rosidl-typesupport-introspection-c : Depends: python3-dev but it [-]                                                 Depends: ros-humble-rosidl-c[/]                                                 Depends: ros-humble-rosidl-p[\] ros-humble-rosidl-typesupport-introspection-cpp : Depends: python3-dev but i[|]                                                   Depends: ros-humble-rosidl[-]                                                   Depends: ros-humble-rosidl[/] ros-humble-rqt-image-view : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) b[\]                             Depends: libopencv-core4.5d (>= 4.5.4+dfsg) but [|]                             Depends: libopencv-imgproc4.5d (>= 4.5.4+dfsg) b[-]                             Depends: libqt5core5a (>= 5.15.1) but it is not [/]                             Depends: libqt5gui5 (>= 5.14.1) but it is not in[\]                                      libqt5gui5-gles (>= 5.14.1) but it is n[|]                             Depends: libqt5widgets5 (>= 5.0.2) but it is not[-]                             Depends: ros-humble-cv-bridge but it is not goin[/]                             Depends: ros-humble-image-transport but it is no[\]                             Depends: ros-humble-qt-gui-cpp but it is not goi[|]                             Depends: ros-humble-rqt-gui-cpp but it is not go[|] ros-humble-rviz-default-plugins : Depends: libconsole-bridge1.0 (>= 1.0.1+df[-]                                   Depends: liborocos-kdl1.5 (>= 1.5.1) but i[/]                                   Depends: libqt5core5a (>= 5.15.1) but it i[\]                                   Depends: libqt5gui5 (>= 5.2.0) but it is n[|]                                            libqt5gui5-gles (>= 5.2.0) but it[-]                                   Depends: libqt5widgets5 (>= 5.0.2) but it [/]                                   Depends: libtinyxml2-9 (>= 8.0.0) but it i[\]                                   Depends: ros-humble-rviz-ogre-vendor but i[|]                                   Depends: libqt5gui5 but it is not installa[-]                                   Depends: libqt5opengl5 but it is not insta[/]                                   Depends: ros-humble-ignition-math6-vendor [\]                                   Depends: ros-humble-image-transport but it[|]                                   Depends: ros-humble-interactive-markers bu[-]                                   Depends: ros-humble-laser-geometry but it [/]                                   Depends: ros-humble-resource-retriever but[\]                                   Depends: ros-humble-rviz-common but it is [|]                                   Depends: ros-humble-rviz-rendering but it [-] ros-humble-rviz2 : Depends: libqt5core5a (>= 5.15.1) but it is not installab[/]                    Depends: libqt5widgets5 (>= 5.0.2) but it is not installa[\]                    Depends: ros-humble-rviz-common but it is not going to be[|]                    Depends: ros-humble-rviz-ogre-vendor but it is not going [-] ros-humble-sqlite3-vendor : Depends: libsqlite3-dev but it is not installabl[\] ros-humble-tango-icons-vendor : Depends: tango-icon-theme but it is not inst[|] ros-humble-teleop-twist-joy : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2)[-] ros-humble-tf2 : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is no[\]                  Depends: ros-humble-console-bridge-vendor but it is not goi[/] ros-humble-tf2-eigen-kdl : Depends: liborocos-kdl1.5 (>= 1.5.1) but it is no[|] ros-humble-tf2-geometry-msgs : Depends: python3-numpy but it is not installa[-] ros-humble-tf2-ros : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it i[/] ros-humble-tf2-sensor-msgs : Depends: libeigen3-dev but it is not installabl[|] ros-humble-tinyxml2-vendor : Depends: libtinyxml2-dev but it is not installa[-] ros-humble-turtlesim : Depends: libqt5core5a (>= 5.15.1) but it is not insta[/]                        Depends: libqt5gui5 (>= 5.2.0) but it is not installa[\]                                 libqt5gui5-gles (>= 5.2.0) but it is not ins[|]                        Depends: libqt5widgets5 (>= 5.0.2) but it is not inst[\] ros-humble-urdf : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is n[|]                   Depends: libtinyxml2-9 (>= 8.0.0) but it is not installabl[-]                   Depends: ros-humble-urdfdom but it is not going to be inst[/] shim-signed : Depends: grub-efi-amd64-signed but it is not going to be insta[|]               Depends: grub2-common (>= 2.04-1ubuntu24) but it is not going [-]Result:code:100                           ) but it is not installable
                      小鱼 技术大佬 @阿来呀
                      @阿来呀 用代码块包裹下,别人都是可以的,可能因为你短时间发太多次了
                      一定要代码块包裹
                        小鱼 技术大佬 @阿来呀
                        @阿来呀 我想看到的是aptitude安装的时候的提示是什么
                        • 阿来呀阿
                          阿来呀 @小鱼
                          [-]Result:success
                          基础检查通过...
                          ---众多工具,等君来用---
                          [6]:一键安装:nodejs
                          [7]:一键安装:VsCode开发工具
                          [8]:一键安装:Docker
                          [77]:测试模式:运行自定义工具测试
                          请输入[]内的数字以选择:1
                          [1]:更换系统源再继续安装
                          [2]:不更换继续安装
                          请输入[]内的数字以选择:2
                          [\]ros-humble-libcurl-vendor - Wrapper around libcurl, it provides a fixed CMake[|]ros-humble-resource-retriever - This package retrieves data from url-format files such as http://, ftp://, package:// file://, etc., and loads the data into [-]ros-rolling-libcurl-vendor - Wrapper around libcurl, it provides a fixed CMak[/]ros-rolling-resource-retriever - This package retrieves data from url-format files such as http://, ftp://, package:// file://, etc., and loads the data into[|]libcurl3-gnutls - easy-to-use client-side URL transfer library (GnuTLS flavou[-]Result:success                           ansfer library (OpenSSL flavour)
                          [-]Result:success
                          没有找到包:gnupg2
                          [-]Result:success
                          [-]Result:success
                          [\]Get:1 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu jammy InRelease [4,670 [|]Get:2 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu jammy/main amd64 Packag[-]Result:success                            jammy InRelease
                          [\]ros-humble-ros-base - A package which extends 'ros_core' and includes other b[|]ros-rolling-ros-base - A package which extends 'ros_core' and includes other [-]Result:success
                          [1]:humble(ROS2)
                          [2]:rolling(ROS2)
                          请输入[]内的数字以选择:1
                          [1]:humble(ROS2)桌面版
                          请输入[]内的数字以选择:1
                          • 阿来呀阿
                            阿来呀 @阿来呀
                            @阿来呀 is not going to be installed
                            确认了解情况,请输入回车继续安装
                            Run CMD Task:[sudo aptitude install   ros-humble-desktop]
                              ros-humble-desktop{b}
                            0 packages upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                            Need to get 6,558 B of archives. After unpacking 46.1 kB will be used.
                             ros-humble-desktop : Depends: ros-humble-action-tutorials-cpp but it is not installable
                                                  Depends: ros-humble-action-tutorials-interfaces but it is not installable
                                                  Depends: ros-humble-action-tutorials-py but it is not installable
                                                  Depends: ros-humble-angles but it is not installable
                                                  Depends: ros-humble-composition but it is not installable
                                                  Depends: ros-humble-demo-nodes-cpp but it is not installable
                                                  Depends: ros-humble-demo-nodes-cpp-native but it is not installable
                                                  Depends: ros-humble-demo-nodes-py but it is not installable
                                                  Depends: ros-humble-depthimage-to-laserscan but it is not installable
                                                  Depends: ros-humble-dummy-map-server but it is not installable
                                                  Depends: ros-humble-dummy-robot-bringup but it is not installable
                                                  Depends: ros-humble-dummy-sensors but it is not installable
                                                  Depends: ros-humble-examples-rclcpp-minimal-action-client but it is not installable
                                                  Depends: ros-humble-examples-rclcpp-minimal-action-server but it is not installable
                                                  Depends: ros-humble-examples-rclcpp-minimal-client but it is not installable
                                                  Depends: ros-humble-examples-rclcpp-minimal-composition but it is not installable
                                                  Depends: ros-humble-examples-rclcpp-minimal-publisher but it is not installable
                                                  Depends: ros-humble-examples-rclcpp-minimal-service but it is not installable
                                                  Depends: ros-humble-examples-rclcpp-minimal-subscriber but it is not installable
                                                  Depends: ros-humble-examples-rclcpp-minimal-timer but it is not installable
                                                  Depends: ros-humble-examples-rclcpp-multithreaded-executor but it is not installable
                                                  Depends: ros-humble-examples-rclpy-executors but it is not installable
                                                  Depends: ros-humble-examples-rclpy-minimal-action-client but it is not installable
                                                  Depends: ros-humble-examples-rclpy-minimal-action-server but it is not installable
                                                  Depends: ros-humble-examples-rclpy-minimal-client but it is not installable
                                                  Depends: ros-humble-examples-rclpy-minimal-publisher but it is not installable
                                                  Depends: ros-humble-examples-rclpy-minimal-service but it is not installable
                                                  Depends: ros-humble-examples-rclpy-minimal-subscriber but it is not installable
                                                  Depends: ros-humble-image-tools but it is not installable
                                                  Depends: ros-humble-intra-process-demo but it is not installable
                                                  Depends: ros-humble-joy but it is not installable
                                                  Depends: ros-humble-lifecycle but it is not installable
                                                  Depends: ros-humble-logging-demo but it is not installable
                                                  Depends: ros-humble-pcl-conversions but it is not installable
                                                  Depends: ros-humble-pendulum-control but it is not installable
                                                  Depends: ros-humble-pendulum-msgs but it is not installable
                                                  Depends: ros-humble-quality-of-service-demo-cpp but it is not installable
                                                  Depends: ros-humble-quality-of-service-demo-py but it is not installable
                                                  Depends: ros-humble-ros-base but it is not installable
                                                  Depends: ros-humble-rqt-common-plugins but it is not installable
                                                  Depends: ros-humble-rviz-default-plugins but it is not installable
                                                  Depends: ros-humble-teleop-twist-joy but it is not installable
                                                  Depends: ros-humble-teleop-twist-keyboard but it is not installable
                                                  Depends: ros-humble-tlsf but it is not installable
                                                  Depends: ros-humble-tlsf-cpp but it is not installable
                                                  Depends: ros-humble-topic-monitor but it is not installable
                                                  Depends: ros-humble-turtlesim but it is not installable
                                                  Depends: ros-humble-ros-workspace but it is not going to be installed
                            Accept this solution? [Y/n/q/?] y
                            0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                            Need to get 0 B of archives. After unpacking 0 B will be used.
                            Run CMD Task:[sudo aptitude install   ros-humble-desktop -y]
                            [\] ros-humble-desktop : Depends: ros-humble-action-tutorials-cpp but it is not [|]                      Depends: ros-humble-action-tutorials-interfaces but it [-]                      Depends: ros-humble-action-tutorials-py but it is not i[\]                      Depends: ros-humble-composition but it is not installab[|]                      Depends: ros-humble-demo-nodes-cpp but it is not instal[-]                      Depends: ros-humble-demo-nodes-cpp-native but it is not[/]                      Depends: ros-humble-demo-nodes-py but it is not install[\]                      Depends: ros-humble-depthimage-to-laserscan but it is n[|]                      Depends: ros-humble-dummy-map-server but it is not inst[-]                      Depends: ros-humble-dummy-robot-bringup but it is not i[/]                      Depends: ros-humble-dummy-sensors but it is not install[\]                      Depends: ros-humble-examples-rclcpp-minimal-action-clie[|]                      Depends: ros-humble-examples-rclcpp-minimal-action-serv[-]                      Depends: ros-humble-examples-rclcpp-minimal-client but [/]                      Depends: ros-humble-examples-rclcpp-minimal-composition[\]                      Depends: ros-humble-examples-rclcpp-minimal-publisher b[|]                      Depends: ros-humble-examples-rclcpp-minimal-service but[-]                      Depends: ros-humble-examples-rclcpp-minimal-subscriber [/]                      Depends: ros-humble-examples-rclcpp-minimal-timer but i[\]                      Depends: ros-humble-examples-rclcpp-multithreaded-execu[|]                      Depends: ros-humble-examples-rclpy-executors but it is [-]                      Depends: ros-humble-examples-rclpy-minimal-action-clien[/]                      Depends: ros-humble-examples-rclpy-minimal-action-serve[\]                      Depends: ros-humble-examples-rclpy-minimal-client but i[|]                      Depends: ros-humble-examples-rclpy-minimal-publisher bu[-]                      Depends: ros-humble-examples-rclpy-minimal-service but [/]                      Depends: ros-humble-examples-rclpy-minimal-subscriber b[\]                      Depends: ros-humble-image-tools but it is not installab[|]                      Depends: ros-humble-intra-process-demo but it is not in[\]                      Depends: ros-humble-logging-demo but it is not installa[|]                      Depends: ros-humble-pcl-conversions but it is not insta[-]                      Depends: ros-humble-pendulum-control but it is not inst[/]                      Depends: ros-humble-pendulum-msgs but it is not install[\]                      Depends: ros-humble-quality-of-service-demo-cpp but it [|]                      Depends: ros-humble-quality-of-service-demo-py but it i[/]                      Depends: ros-humble-rqt-common-plugins but it is not in[\]                      Depends: ros-humble-rviz-default-plugins but it is not [-]                      Depends: ros-humble-teleop-twist-joy but it is not inst[/]                      Depends: ros-humble-teleop-twist-keyboard but it is not[-]                      Depends: ros-humble-topic-monitor but it is not install[\]                      Depends: ros-humble-ros-workspace but it is not going t[-]Result:success                           ing 0 B will be used.upgraded.
                            [\]python3-colcon-common-extensions - Meta package aggregating colcon-core and c[-]Result:success
                            [-] python3-catkin-pkg-modules : Depends: python3-docutils but it is not install[/] python3-colcon-argcomplete : Depends: python3-argcomplete but it is not inst[|]                       Recommends: python3-pytest-cov but it is not installab[-] python3-colcon-notification : Depends: python3-notify2 but it is not install[/] python3-colcon-python-setup-py : Depends: python3-setuptools but it is not i[-]Result:code:100
                            [-]Result:success
                            [-]Result:success                           anager abstraction tool for ROS
                            [-] python3-rosdep-modules : Depends: python3-rospkg-modules (>= 1.4.0) but it i[/]                          Depends: python3-catkin-pkg-modules (>= 0.4.0) but [\]                          Depends: python3-rosdistro-modules (>= 0.7.5) but i[|]                          Depends: python3-setuptools but it is not installab[-]Result:code:100
                            [-]Result:code:2
                            [-]Result:code:2
                              小鱼 技术大佬 @阿来呀
                              @阿来呀 我来给你改一个,你看下如何用代码块包裹哈
                              • 阿来呀阿
                                阿来呀 @小鱼
                                @小鱼 我把所有的命令行分两次发的,麻烦你看一下。全部过程就在这
                                • 阿来呀阿
                                  阿来呀
                                  @小鱼我刚刚重新试一下一键安装,之前选的不换源,我现在选择换源,接着换源方式应该选啥呢?
                                  [1]:更换系统源再继续安装
                                  [2]:不更换继续安装
                                  请输入[]内的数字以选择:1
                                  欢迎使用一键换源工具,本工具由[鱼香ROS]小鱼贡献..
                                  请选择换源方式,如果不知道选什么请选2
                                  [1]:仅更换系统源
                                  [2]:更换系统源并清理第三方源
                                  请输入[]内的数字以选择:
                                    小鱼 技术大佬 @阿来呀
                                    @阿来呀 我改了一下,你再试一次
                                    • 阿来呀阿
                                      阿来呀 @小鱼
                                      @小鱼 我现在要选择换源方式,我应该咋选
                                        小鱼 技术大佬 @阿来呀
                                        @阿来呀 建议换一下吧,你之前是不是手动安装过
                                        阿来呀阿 2 条回复 最后回复 回复 引用 0
                                        • 阿来呀阿
                                          阿来呀 @小鱼
                                          @小鱼 是的,之前是手动装过
                                          • 阿来呀阿
                                            阿来呀 @小鱼
                                            @小鱼 请选择换源方式,如果不知道选什么请选2
                                            [1]:仅更换系统源
                                            [2]:更换系统源并清理第三方源
                                            请输入[]内的数字以选择:
                                            我是选1还是2呢
