    Nav2启动时地图无法加载的问题
    Nav2
    nav2 地图加载
      小徐要早睡
      Nav2启动时Rviz2里无法正常加载地图。
      系统配置如下:
      Linux:Ubuntu 22.04
      ROS2:Humble
      雷达话题:/scan
      里程计话题:bringup发布的是/odom1,和IMU通过ekf融合后输出的话题是/odom
      配置文件如下:
      amcl:
      ros__parameters:
      use_sim_time: False
      alpha1: 0.2
      alpha2: 0.2
      alpha3: 0.2
      alpha4: 0.2
      alpha5: 0.2
      beam_skip_distance: 0.5
      beam_skip_threshold: 0.3
      do_beamskip: false
      global_frame_id: "map"
      lambda_short: 0.1
      laser_max_range: 100.0
      laser_min_range: -1.0
      max_beams: 60
      max_particles: 2000
      min_particles: 500
      odom_frame_id: "odom"
      pf_err: 0.05
      pf_z: 0.99
      recovery_alpha_fast: 0.0
      recovery_alpha_slow: 0.0
      resample_interval: 1
      save_pose_rate: 0.5
      sigma_hit: 0.2
      tf_broadcast: true
      transform_tolerance: 1.0
      update_min_a: 0.2
      update_min_d: 0.25
      z_hit: 0.5
      z_max: 0.05
      z_rand: 0.5
      z_short: 0.05
      scan_topic: scan
      amcl_map_client:
      ros__parameters:
      use_sim_time: False
      amcl_rclcpp_node:
      ros__parameters:
      use_sim_time: False
      bt_navigator:
      ros__parameters:
      use_sim_time: False
      global_frame: map
      robot_base_frame: base_link
      odom_topic: /odom
      bt_loop_duration: 10
      default_server_timeout: 20
      # default_bt_xml_filename: "/home/hermes/161/fishbot/src/fishbot_navigation2/xml/my_xml.xml"
      # default_nav_to_pose_bt_xml: "/home/hermes/161/fishbot/src/fishbot_navigation2/xml/my_xml.xml"
      plugin_lib_names:
      - nav2_spin_action_bt_node
      - nav2_wait_action_bt_node
      - nav2_back_up_action_bt_node
      - nav2_recovery_node_bt_node
      - nav2_single_trigger_bt_node
      - nav2_wait_cancel_bt_node
      - nav2_spin_cancel_bt_node
      - nav2_back_up_cancel_bt_node
      bt_navigator_rclcpp_node:
      ros__parameters:
      use_sim_time: False
      controller_server:
      ros__parameters:
      use_sim_time: False
      controller_frequency: 20.0
      min_y_velocity_threshold: 0.001
      failure_tolerance: 0.9
      # Progress checker parameters
      progress_checker:
        required_movement_radius: 3.14
        movement_time_allowance: 50.0
      # Goal checker parameters
      #precise_goal_checker:
      #  xy_goal_tolerance: 0.25
      #  yaw_goal_tolerance: 0.25
      #  stateful: True
      general_goal_checker:
        stateful: True
      # DWB parameters
      FollowPath:
        min_vel_x: -0.0
        min_vel_y: -0.0
        max_vel_x: 0.23
        max_vel_y: 0.0
        max_vel_theta: 0.81 # 修改最大角速度
        min_speed_xy: -0.0
        max_speed_xy: 0.22
        min_speed_theta: -0.11
        acc_lim_x: 1.0
        acc_lim_y: 1.0
        acc_lim_theta: 6.1 # 修改角速度加速度限制
        decel_lim_x: -2.5
        decel_lim_y: 0.0
        decel_lim_theta: -0.3 # 修改角速度减速度限制
        vx_samples: 30 # 增加线速度样本数量
        vy_samples: 10
        vtheta_samples: 20
        sim_time: 3.0
        linear_granularity: 0.05
        angular_granularity: 0.025
        transform_tolerance: 0.2
        trans_stopped_velocity: 0.25
        stateful: True
        BaseObstacle.scale: 0.01 # 减小与障碍物距离的权重
        PathAlign.scale: 48.0 # 增加与路径对齐的权重
        GoalAlign.scale: 36.0 # 增加与目标对齐的权重
        PathDist.scale: 48.0 # 增加路径距离的权重
        GoalDist.scale: 36.0 # 增加目标距离的权重
        RotateToGoal.scale: 32.0
      ros__parameters:
      use_sim_time: False
      local_costmap:
      local_costmap:
      ros__parameters:
      update_frequency: 5.0
      publish_frequency: 2.0
      global_frame: odom
      use_sim_time: False
      rolling_window: true
      width: 3
      height: 3
      resolution: 0.05
      robot_radius: 0.45
      inflation_layer:
      cost_scaling_factor: 3.0
      inflation_radius: 0.6
      obstacle_layer:
      enabled: True
      observation_sources: scan
      scan:
      topic: /scan
      max_obstacle_height: 2.0
      clearing: True
      marking: True
      data_type: "LaserScan"
      raytrace_max_range: 3.0
      raytrace_min_range: 0.0
      obstacle_max_range: 2.5
      obstacle_min_range: 0.0
      voxel_layer:
      enabled: True
      publish_voxel_map: True
      origin_z: 0.0
      z_resolution: 0.05
      z_voxels: 16
      mark_threshold: 0
      scan:
      topic: /scan
      clearing: True
      marking: True
      static_layer:
      local_costmap_client:
      ros__parameters:
      use_sim_time: False
      local_costmap_rclcpp_node:
      ros__parameters:
      use_sim_time: False
      global_costmap:
      global_costmap:
      ros__parameters:
      update_frequency: 1.0
      publish_frequency: 1.0
      global_frame: map
      use_sim_time: False
      robot_radius: 0.45
      resolution: 0.05
      track_unknown_space: true
      obstacle_layer:
      enabled: True
      scan:
      topic: /scan
      clearing: True
      marking: True
      static_layer:
      inflation_layer:
      global_costmap_client:
      ros__parameters:
      use_sim_time: False
      global_costmap_rclcpp_node:
      ros__parameters:
      use_sim_time: False
      map_server:
      ros__parameters:
      use_sim_time: False
      map_saver:
      ros__parameters:
      use_sim_time: False
      save_map_timeout: 5.0
      free_thresh_default: 0.25
      occupied_thresh_default: 0.65
      planner_server:
      ros__parameters:
      use_sim_time: False
      GridBased:
      tolerance: 0.5
      use_astar: false
      allow_unknown: true
      planner_server_rclcpp_node:
      ros__parameters:
      use_sim_time: False
      smoother_server:
      ros__parameters:
      use_sim_time: False
      simple_smoother:
      tolerance: 1.0e-10
      max_its: 1000
      do_refinement: True
      behavior_server:
      ros__parameters:
      cycle_frequency: 10.0
      behavior_plugins: ["spin", "backup", "drive_on_heading", "wait"]
      spin:
      plugin: "nav2_behaviors/Spin"
      backup:
      drive_on_heading:
      wait:
      plugin: "nav2_behaviors/Wait"
      global_frame: odom
      transform_tolerance: 0.1
      use_sim_time: False
      simulate_ahead_time: 2.0
      max_rotational_vel: 1.0
      min_rotational_vel: 0.4
      rotational_acc_lim: 3.2
      robot_state_publisher:
      ros__parameters:
      use_sim_time: False
      waypoint_follower:
      ros__parameters:
      loop_rate: 20
      stop_on_failure: false
      wait_at_waypoint:
      enabled: True
      waypoint_pause_duration: 200
      报错如下:
      [INFO] [launch]: All log files can be found below /home/agx/.ros/log/2025-05-14-08-08-56-824411-ubuntu-7779
      [INFO] [component_container_isolated-1]: process started with pid [7792]
      [INFO] [rviz2-2]: process started with pid [7794]
      [component_container_isolated-1] [INFO] [1747224537.918626279] [nav2_container]: Load Library: /home/agx/nav2_ws/install/nav2_map_server/lib/libmap_server_core.so
      [component_container_isolated-1] [INFO] [1747224537.962328846] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_map_server::CostmapFilterInfoServer>
      [component_container_isolated-1] [INFO] [1747224537.962416269] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_map_server::MapSaver>
      [component_container_isolated-1] [INFO] [1747224537.962429933] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_map_server::MapServer>
      [component_container_isolated-1] [INFO] [1747224537.962438829] [nav2_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nav2_map_server::MapServer>
      [component_container_isolated-1] [INFO] [1747224537.976989477] [map_server]:
      [component_container_isolated-1] map_server lifecycle node launched.
      [INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/map_server' in container '/nav2_container'
      [component_container_isolated-1] Waiting on external lifecycle transitions to activate
      [component_container_isolated-1] See https://design.ros2.org/articles/node_lifecycle.html for more information.
      [component_container_isolated-1] [INFO] [1747224537.977090020] [map_server]: Creating
      [component_container_isolated-1] [INFO] [1747224537.983997123] [nav2_container]: Load Library: /home/agx/nav2_ws/install/nav2_amcl/lib/libamcl_core.so
      [component_container_isolated-1] [INFO] [1747224537.997021194] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_amcl::AmclNode>
      [component_container_isolated-1] [INFO] [1747224537.997120297] [nav2_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nav2_amcl::AmclNode>
      [component_container_isolated-1] [INFO] [1747224538.011386499] [amcl]:
      [component_container_isolated-1] amcl lifecycle node launched.
      [component_container_isolated-1] [INFO] [1747224538.016541139] [amcl]: Creating
      [INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/amcl' in container '/nav2_container'
      [component_container_isolated-1] [INFO] [1747224538.031733797] [nav2_container]: Load Library: /home/agx/nav2_ws/install/nav2_lifecycle_manager/lib/libnav2_lifecycle_manager_core.so
      [component_container_isolated-1] [INFO] [1747224538.035436258] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_lifecycle_manager::LifecycleManager>
      [component_container_isolated-1] [INFO] [1747224538.035504577] [nav2_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nav2_lifecycle_manager::LifecycleManager>
      [component_container_isolated-1] [INFO] [1747224538.049036003] [lifecycle_manager_localization]: Creating
      [INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/lifecycle_manager_localization' in container '/nav2_container'
      [component_container_isolated-1] [INFO] [1747224538.056538269] [lifecycle_manager_localization]: Creating and initializing lifecycle service clients
      [component_container_isolated-1] [INFO] [1747224538.057436692] [nav2_container]: Load Library: /home/agx/nav2_ws/install/nav2_controller/lib/libcontroller_server_core.so
      [component_container_isolated-1] [INFO] [1747224538.071887117] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_controller::ControllerServer>
      [component_container_isolated-1] [INFO] [1747224538.071976044] [nav2_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nav2_controller::ControllerServer>
      [component_container_isolated-1] [INFO] [1747224538.087189726] [lifecycle_manager_localization]: Starting managed nodes bringup...
      [component_container_isolated-1] [INFO] [1747224538.087283613] [lifecycle_manager_localization]: Configuring map_server
      [component_container_isolated-1] [INFO] [1747224538.087617402] [map_server]: Configuring
      [component_container_isolated-1] [INFO] [1747224538.087746201] [map_io]: Loading yaml file: /home/agx/semantic_map_ws/install/bot_navigation2/share/bot_navigation2/maps/indoor_labelled.yaml
      [component_container_isolated-1] [INFO] [1747224538.088744751] [map_io]: resolution: 0.05
      [component_container_isolated-1] [INFO] [1747224538.088790319] [map_io]: origin[0]: -44.4
      [component_container_isolated-1] [INFO] [1747224538.088801359] [map_io]: origin[1]: -50
      [component_container_isolated-1] [INFO] [1747224538.088807951] [map_io]: origin[2]: 0
      [component_container_isolated-1] [INFO] [1747224538.088813615] [map_io]: free_thresh: 0.25
      [component_container_isolated-1] [INFO] [1747224538.088818702] [map_io]: occupied_thresh: 0.65
      [component_container_isolated-1] [INFO] [1747224538.088827598] [map_io]: mode: trinary
      [component_container_isolated-1] [INFO] [1747224538.088835342] [map_io]: negate: 0
      [component_container_isolated-1] [INFO] [1747224538.094173052] [map_io]: Loading image_file: /home/agx/semantic_map_ws/install/bot_navigation2/share/bot_navigation2/maps/indoor.pgm
      [component_container_isolated-1] [INFO] [1747224538.095581551] [controller_server]:
      [component_container_isolated-1] controller_server lifecycle node launched.
      [component_container_isolated-1] [INFO] [1747224538.126407759] [controller_server]: Creating controller server
      [component_container_isolated-1] [INFO] [1747224538.146205525] [local_costmap.local_costmap]:
      [component_container_isolated-1] local_costmap lifecycle node launched.
      [component_container_isolated-1] [INFO] [1747224538.151738274] [local_costmap.local_costmap]: Creating Costmap
      [INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/controller_server' in container '/nav2_container'
      [component_container_isolated-1] [INFO] [1747224538.159312699] [nav2_container]: Load Library: /home/agx/nav2_ws/install/nav2_smoother/lib/libsmoother_server_core.so
      [component_container_isolated-1] [INFO] [1747224538.166488856] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_smoother::SmootherServer>
      [component_container_isolated-1] [INFO] [1747224538.166576695] [nav2_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nav2_smoother::SmootherServer>
      [component_container_isolated-1] [INFO] [1747224538.186081696] [smoother_server]:
      [component_container_isolated-1] smoother_server lifecycle node launched.
      [component_container_isolated-1] [INFO] [1747224538.191682892] [smoother_server]: Creating smoother server
      [INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/smoother_server' in container '/nav2_container'
      [component_container_isolated-1] [INFO] [1747224538.197455926] [nav2_container]: Load Library: /home/agx/nav2_ws/install/nav2_planner/lib/libplanner_server_core.so
      [component_container_isolated-1] [INFO] [1747224538.201347089] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_planner::PlannerServer>
      [component_container_isolated-1] [INFO] [1747224538.201407857] [nav2_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nav2_planner::PlannerServer>
      [component_container_isolated-1] [INFO] [1747224538.217642233] [planner_server]:
      [component_container_isolated-1] planner_server lifecycle node launched.
      [component_container_isolated-1] [INFO] [1747224538.223365731] [planner_server]: Creating
      [component_container_isolated-1] [INFO] [1747224538.242474129] [global_costmap.global_costmap]:
      [component_container_isolated-1] global_costmap lifecycle node launched.
      [component_container_isolated-1] [INFO] [1747224538.244314815] [global_costmap.global_costmap]: Creating Costmap
      [INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/planner_server' in container '/nav2_container'
      [component_container_isolated-1] [INFO] [1747224538.254491968] [nav2_container]: Load Library: /home/agx/nav2_ws/install/nav2_behaviors/lib/libbehavior_server_core.so
      [component_container_isolated-1] [INFO] [1747224538.268253279] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<behavior_server::BehaviorServer>
      [component_container_isolated-1] [INFO] [1747224538.268321567] [nav2_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<behavior_server::BehaviorServer>
      [component_container_isolated-1] [INFO] [1747224538.284715461] [behavior_server]:
      [component_container_isolated-1] behavior_server lifecycle node launched.
      [INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/behavior_server' in container '/nav2_container'
      [component_container_isolated-1] [INFO] [1747224538.296269241] [nav2_container]: Load Library: /home/agx/nav2_ws/install/nav2_bt_navigator/lib/libbt_navigator_core.so
      [component_container_isolated-1] [INFO] [1747224538.304106480] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_bt_navigator::BtNavigator>
      [component_container_isolated-1] [INFO] [1747224538.304175119] [nav2_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nav2_bt_navigator::BtNavigator>
      [component_container_isolated-1] [INFO] [1747224538.321664651] [bt_navigator]:
      [component_container_isolated-1] bt_navigator lifecycle node launched.
      [component_container_isolated-1] [INFO] [1747224538.321792426] [bt_navigator]: Creating
      [INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/bt_navigator' in container '/nav2_container'
      [component_container_isolated-1] [INFO] [1747224538.325634406] [nav2_container]: Load Library: /home/agx/nav2_ws/install/nav2_waypoint_follower/lib/libwaypoint_follower_core.so
      [component_container_isolated-1] [INFO] [1747224538.328594635] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_waypoint_follower::WaypointFollower>
      [component_container_isolated-1] [INFO] [1747224538.328644714] [nav2_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nav2_waypoint_follower::WaypointFollower>
      [component_container_isolated-1] [INFO] [1747224538.344109561] [waypoint_follower]:
      [component_container_isolated-1] waypoint_follower lifecycle node launched.
      [component_container_isolated-1] [INFO] [1747224538.347691000] [waypoint_follower]: Creating
      [INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/waypoint_follower' in container '/nav2_container'
      [component_container_isolated-1] [INFO] [1747224538.352402988] [nav2_container]: Load Library: /home/agx/nav2_ws/install/nav2_velocity_smoother/lib/libvelocity_smoother_core.so
      [component_container_isolated-1] [INFO] [1747224538.356282727] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_velocity_smoother::VelocitySmoother>
      [component_container_isolated-1] [INFO] [1747224538.356422374] [nav2_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nav2_velocity_smoother::VelocitySmoother>
      [component_container_isolated-1] [INFO] [1747224538.375497492] [velocity_smoother]:
      [INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/velocity_smoother' in container '/nav2_container'
      [component_container_isolated-1] velocity_smoother lifecycle node launched.
      [component_container_isolated-1] [INFO] [1747224538.378981395] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_lifecycle_manager::LifecycleManager>
      [component_container_isolated-1] [INFO] [1747224538.379051154] [nav2_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nav2_lifecycle_manager::LifecycleManager>
      [component_container_isolated-1] [INFO] [1747224538.393011536] [lifecycle_manager_navigation]: Creating
      [INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/lifecycle_manager_navigation' in container '/nav2_container'
      [component_container_isolated-1] [INFO] [1747224538.397875298] [lifecycle_manager_navigation]: Creating and initializing lifecycle service clients
      [component_container_isolated-1] [INFO] [1747224538.401186307] [map_io]: Read map /home/agx/semantic_map_ws/install/bot_navigation2/share/bot_navigation2/maps/indoor.pgm: 1531 X 1510 map @ 0.05 m/cell
      [component_container_isolated-1] [INFO] [1747224538.415737531] [lifecycle_manager_localization]: Configuring amcl
      [component_container_isolated-1] [INFO] [1747224538.415991641] [amcl]: Configuring
      [component_container_isolated-1] [INFO] [1747224538.416156727] [amcl]: initTransforms
      [component_container_isolated-1] [INFO] [1747224538.444377231] [amcl]: initPubSub
      [component_container_isolated-1] [INFO] [1747224538.449217474] [lifecycle_manager_navigation]: Starting managed nodes bringup...
      [component_container_isolated-1] [INFO] [1747224538.449367520] [lifecycle_manager_navigation]: Configuring controller_server
      [component_container_isolated-1] [INFO] [1747224538.449921755] [controller_server]: Configuring controller interface
      [component_container_isolated-1] [INFO] [1747224538.450360087] [controller_server]: getting goal checker plugins..
      [component_container_isolated-1] [INFO] [1747224538.450577941] [controller_server]: Controller frequency set to 20.0000Hz
      [component_container_isolated-1] [INFO] [1747224538.450642740] [local_costmap.local_costmap]: Configuring
      [component_container_isolated-1] [INFO] [1747224538.458376652] [amcl]: Subscribed to map topic.
      [component_container_isolated-1] [INFO] [1747224538.460541560] [local_costmap.local_costmap]: Using plugin "static_layer"
      [component_container_isolated-1] [INFO] [1747224538.477393658] [local_costmap.local_costmap]: Subscribing to the map topic (/map) with transient local durability
      [component_container_isolated-1] [INFO] [1747224538.482347596] [local_costmap.local_costmap]: Initialized plugin "static_layer"
      [component_container_isolated-1] [INFO] [1747224538.482412875] [local_costmap.local_costmap]: Using plugin "obstacle_layer"
      [component_container_isolated-1] [INFO] [1747224538.484549463] [lifecycle_manager_localization]: Activating map_server
      [component_container_isolated-1] [INFO] [1747224538.484803733] [map_server]: Activating
      [component_container_isolated-1] [INFO] [1747224538.485179761] [local_costmap.local_costmap]: Subscribed to Topics: scan
      [component_container_isolated-1] [INFO] [1747224538.486572388] [map_server]: Creating bond (map_server) to lifecycle manager.
      [component_container_isolated-1] malloc(): invalid size (unsorted)
      [component_container_isolated-1] Magick: abort due to signal 6 (SIGABRT) "Abort"...
      [rviz2-2] [INFO] [1747224538.742160396] [rviz2]: Stereo is NOT SUPPORTED
      [rviz2-2] [INFO] [1747224538.742477769] [rviz2]: OpenGl version: 4.6 (GLSL 4.6)
      [rviz2-2] [INFO] [1747224538.824175565] [rviz2]: Stereo is NOT SUPPORTED
      [ERROR] [component_container_isolated-1]: process has died [pid 7792, exit code -6, cmd '/opt/ros/humble/lib/rclcpp_components/component_container_isolated --ros-args --log-level info --ros-args -r __node:=nav2_container --params-file /tmp/launch_params_02dgqwm7 --params-file /tmp/launch_params_tcc1vpuj -r /tf:=tf -r /tf_static:=tf_static'].
      [rviz2-2] [INFO] [1747224539.960257189] [rviz2]: Message Filter dropping message: frame 'laser' at time 1747224539.063 for reason 'discarding message because the queue is full'
      [rviz2-2] [INFO] [1747224540.055364491] [rviz2]: Message Filter dropping message: frame 'laser' at time 1747224539.150 for reason 'discarding message because the queue is full'
      [rviz2-2] [INFO] [1747224540.119518419] [rviz2]: Message Filter dropping message: frame 'laser' at time 1747224539.230 for reason 'discarding message because the queue is full'
      [rviz2-2] [INFO] [1747224540.215937772] [rviz2]: Message Filter dropping message: frame 'laser' at time 1747224539.310 for reason 'discarding message because the queue is full'
      [rviz2-2] [INFO] [1747224540.279572121] [rviz2]: Message Filter dropping message: frame 'laser' at time 1747224539.390 for reason 'discarding message because the queue is full'
      [rviz2-2] [INFO] [1747224540.375857876] [rviz2]: Message Filter dropping message: frame 'laser' at time 1747224539.469 for reason 'discarding message because the queue is full'
      [rviz2-2] [INFO] [1747224540.439654143] [rviz2]: Message Filter dropping message: frame 'laser' at time 1747224539.555 for reason 'discarding message because the queue is full'
      TF树如下:
      节点话题关系如下:
