    运行驱动雷达时候报错
    二驱机器人 雷达驱动
    350
      shawn
      1,背景
      运行以下命令时候出现的问题
      sk@sk-virtual-machine:~$ xhost + && sudo docker run -it --rm -v /dev:/dev -v /dev/shm:/dev/shm --privileged -v /tmp/.X11-unix:/tmp/.X11-unix --device /dev/snd -e DISPLAY=unix$DISPLAY -p 8889:8888 registry.cn-hangzhou.aliyuncs.com/fishros/fishbot_laser
      1. WIFI转串口测试
      2. 驱动雷达
      3. 建图测试
      4. 退出
      2,历史
      在此之前运行1:WIFI转串口测试时候一直等待TCP连接: 0.0.0.0:8888
      1. WIFI转串口测试
      2. 驱动雷达
      3. 建图测试
      4. 退出
        #? 1
        [INFO] [launch]: All log files can be found below /root/.ros/log/2025-05-21-04-34-59-859928-54f59d59956a-58
        [INFO] [ydlidar_tcp_node-1]: process started with pid [59]
        [ydlidar_tcp_node-1] [INFO] [1747802100.203626086] [ydlidar_node]: 等待激光雷达TCP连接: 0.0.0.0:8888
      和客服沟通后更换雷达和驱动板后,还是报如上错误。
      但是我发现,重启后不运行nc -l 8889 ,直接运行WIFI转串口测试时候激光雷达能够连接
      1. WIFI转串口测试
      2. 驱动雷达
      3. 建图测试
      4. 退出
        #? 1
        [INFO] [launch]: All log files can be found below /root/.ros/log/2025-05-21-04-37-37-024833-678890575e23-58
        [ydlidar_tcp_node-1] [INFO] [1747802257.698494317] [ydlidar_node]: 等待激光雷达TCP连接: 0.0.0.0:8888
        [ydlidar_tcp_node-1] [INFO] [1747802258.099266293] [ydlidar_node]: 激光雷达已连接: ('192.168.1.102', 50711)
        随后,跟着课程,退出输入2时候出现问题,报如下错误
        #? 2
        [INFO] [launch]: All log files can be found below /root/.ros/log/2025-05-21-04-38-25-908601-678890575e23-86
        [INFO] [ydlidar_tcp_node-1]: process started with pid [87]
        [ydlidar_tcp_node-1] Traceback (most recent call last):
        [ydlidar_tcp_node-1] File "/workspace/install/ydlidar/lib/ydlidar/ydlidar_tcp_node", line 33, in <module>
        [ydlidar_tcp_node-1] sys.exit(load_entry_point('ydlidar==0.0.0', 'console_scripts', 'ydlidar_tcp_node')())
        [ydlidar_tcp_node-1] File "/workspace/install/ydlidar/lib/python3.10/site-packages/ydlidar/ydlidar_tcp_node.py", line 321, in main
        [ydlidar_tcp_node-1] node = YdlidarNode()
        [ydlidar_tcp_node-1] File "/workspace/install/ydlidar/lib/python3.10/site-packages/ydlidar/ydlidar_tcp_node.py", line 26, in init
        [ydlidar_tcp_node-1] self._init_tcp()
        [ydlidar_tcp_node-1] File "/workspace/install/ydlidar/lib/python3.10/site-packages/ydlidar/ydlidar_tcp_node.py", line 57, in _init_tcp
        [ydlidar_tcp_node-1] self.sock.bind((host, port))
        [ydlidar_tcp_node-1] OSError: [Errno 98] Address already in use
        [ERROR] [ydlidar_tcp_node-1]: process has died [pid 87, exit code 1, cmd '/workspace/install/ydlidar/lib/ydlidar/ydlidar_tcp_node --ros-args'].
        小鱼 技术大佬 @shawn
        @shawn
        @shawn 在 运行驱动雷达时候报错 中说:
        [ydlidar_tcp_node-1] OSError: [Errno 98] Address already in use 端口占用,不要用nc 和驱动两者是冲突的,
        重启下电脑再测试一次
        S 2 条回复 最后回复 回复 引用 0
          shawn @小鱼
          @小鱼 还是不行还是报错
          1. WIFI转串口测试
          2. 驱动雷达
          3. 建图测试
          4. 退出
            #? 1
            [INFO] [launch]: All log files can be found below /root/.ros/log/2025-05-21-05-11-45-756903-c29ca861fb21-58
            [ydlidar_tcp_node-1] [INFO] [1747804306.055214187] [ydlidar_node]: 等待激光雷达TCP连接: 0.0.0.0:8888
            [ydlidar_tcp_node-1] [INFO] [1747804306.256195371] [ydlidar_node]: 激光雷达已连接: ('192.168.1.102', 53796)
            [ydlidar_tcp_node-1] File "/workspace/install/ydlidar/lib/python3.10/site-packages/ydlidar/ydlidar_tcp_node.py", line 322, in main
            [ydlidar_tcp_node-1] rclpy.spin(node)
            [ydlidar_tcp_node-1] File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/init.py", line 222, in spin
            [ydlidar_tcp_node-1] executor.spin_once()
            [ydlidar_tcp_node-1] File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/executors.py", line 704, in spin_once
            [ydlidar_tcp_node-1] handler, entity, node = self.wait_for_ready_callbacks(timeout_sec=timeout_sec)
            [ydlidar_tcp_node-1] File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/executors.py", line 690, in wait_for_ready_callbacks
            [ydlidar_tcp_node-1] return next(self._cb_iter)
            [ydlidar_tcp_node-1] File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/executors.py", line 619, in _wait_for_ready_callbacks
            [ydlidar_tcp_node-1] if tmr.handle.pointer in timers_ready:
            [ydlidar_tcp_node-1] File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/timer.py", line 36, in handle
            [ydlidar_tcp_node-1] @property
            [ydlidar_tcp_node-1] KeyboardInterrupt
            [ERROR] [ydlidar_tcp_node-1]: process has died [pid 59, exit code -2, cmd '/workspace/install/ydlidar/lib/ydlidar/ydlidar_tcp_node --ros-args'].
            #? 2
            [INFO] [launch]: All log files can be found below /root/.ros/log/2025-05-21-05-11-50-512720-c29ca861fb21-86
            shawn @小鱼
            @小鱼 报错内容和上面的一样
              小鱼 技术大佬 @shawn
              退出
              退出后再进来试试
              S 1 条回复 最后回复 回复 引用 0
                shawn @小鱼
                1)退出后不重启小车直接输入 xhost + && sudo docker run -it --rm -v /dev:/dev -v /dev/shm:/dev/shm --privileged -v /tmp/.X11-unix:/tmp/.X11-unix --device /dev/snd -e DISPLAY=unix$DISPLAY -p 8889:8888 registry.cn-hangzhou.aliyuncs.com/fishros/fishbot_laser
                选择2后终端报:
                1. WIFI转串口测试
                2. 驱动雷达
                3. 建图测试
                4. 退出
                  #? 2
                  [INFO] [launch]: All log files can be found below /root/.ros/log/2025-05-22-06-07-17-593240-c88ec6ad0dda-58
                  [ydlidar_tcp_node-1] [INFO] [1747894037.948174067] [ydlidar_node]: 等待激光雷达TCP连接: 0.0.0.0:8888
                卡在等待激光雷达TCP连接
                2)小车重启后输入命令,直接选择2.驱动雷达,终端报:
                1. WIFI转串口测试
                2. 驱动雷达
                3. 建图测试
                4. 退出
                  #? 2
                  [INFO] [launch]: All log files can be found below /root/.ros/log/2025-05-22-06-11-02-000224-18ad5fa9cad9-58
                  [ydlidar_tcp_node-1] [INFO] [1747894262.589658925] [ydlidar_node]: 等待激光雷达TCP连接: 0.0.0.0:8888
                  [ydlidar_tcp_node-1] [INFO] [1747894263.090458116] [ydlidar_node]: 激光雷达已连接: ('192.168.1.102', 54697)
                卡在激光雷达已连接
                3)ctrl+c后输入2终端报:
                #? 2
                [INFO] [launch]: All log files can be found below /root/.ros/log/2025-05-22-06-11-44-061844-18ad5fa9cad9-86
                报上面相同错误
                  小鱼 技术大佬 @shawn
                  @shawn nc -l 8889 有数据流吗
                    shawn @小鱼
                    @小鱼 没有数据流,只有在小车重启后输入会有招呼语
                      小鱼 技术大佬 @shawn
                      @shawn 拍一下雷达板照片
                        shawn @小鱼
                          小鱼 技术大佬 @shawn
                          @shawn 微信联系我下
                            shawn
                            最终发现,跳线帽插错了,注意是两个跳线帽都要变。感谢大佬感谢感谢感感谢!跪谢大佬的协助!
