    一键安装报错 ROS
    一键安装ros 一键安装报错
    • 机械小青年机
      机械小青年
      [链接文本](```
      * 链接地址
      需要下载 53.8 MB/622 MB 的归档。
      解压缩后会消耗 3,163 MB 的额外空间。
      错误:1 https://packages.ros.org/ros/ubuntu focal/main amd64 libgazebo11 amd64 11.10.2-1~focal
        Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in the certificate verification. [IP: 140.211.166.134 443]
      错误:2 https://packages.ros.org/ros/ubuntu focal/main amd64 gazebo11-common all 11.10.2-1~focal
      错误:3 https://packages.ros.org/ros/ubuntu focal/main amd64 gazebo11 amd64 11.10.2-1~focal
      错误:4 https://packages.ros.org/ros/ubuntu focal/main amd64 libignition-transport8-core-dev amd64 8.2.1-1~focal
      E: 无法下载 https://packages.ros.org/ros/ubuntu/pool/main/g/gazebo11/libgazebo11_11.10.2-1~focal_amd64.deb  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in the certificate verification. [IP: 140.211.166.134 443]
      E: 无法下载 https://packages.ros.org/ros/ubuntu/pool/main/g/gazebo11/gazebo11-common_11.10.2-1~focal_all.deb  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in the certificate verification. [IP: 140.211.166.134 443]
      E: 无法下载 https://packages.ros.org/ros/ubuntu/pool/main/g/gazebo11/gazebo11_11.10.2-1~focal_amd64.deb  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in the certificate verification. [IP: 140.211.166.134 443]
      E: 无法下载 https://packages.ros.org/ros/ubuntu/pool/main/i/ignition-transport8/libignition-transport8-core-dev_8.2.1-1~focal_amd64.deb  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in the certificate verification. [IP: 140.211.166.134 443]
      Run CMD Task:[sudo apt install   ros-noetic-desktop-full -y]
      [/]  docutils-common dpkg-dev dwz fakeroot fltk1.3-doc fluid fonts-lato fonts-ly[|]  gazebo11-plugin-base gcc gcc-7-base gcc-8 gcc-8-base gcc-9 gdal-data gettex[|]  libarpack2 libarpack2-dev libasan4 libasan5 libass9 libassimp-dev libassimp[/]  libevent-core-2.1-7 libevent-dev libevent-extra-2.1-7 libevent-openssl-2.1-[/]  libfltk-cairo1.3 libfltk-forms1.3 libfltk-gl1.3 libfltk-images1.3 libfltk1.[\]  libglvnd-dev libglx-dev libgme0 libgpg-error-dev libgpgme-dev libgphoto2-de[|]  libhwloc-plugins libhwloc15 libibverbs-dev libibverbs1 libice-dev libicu-de[-]  libignition-tools-dev libignition-transport8 libignition-transport8-core-de[/]  libpocodataodbc62 libpocodatasqlite62 libpocoencodings62 libpocofoundation6[/]  libqt5dbus5 libqt5designer5 libqt5designercomponents5 libqt5gui5 libqt5help[|]  libsimbody-dev libsimbody3.6 libsm-dev libsnappy1v5 libsndio7.0 libsocket++[/]  libxmu-headers libxnvctrl0 libxrandr-dev libxrender-dev libxss-dev libxt-de[-]  ros-noetic-rosmake ros-noetic-rosmaster ros-noetic-rosmsg ros-noetic-rosnod[-]  ros-noetic-smach-ros ros-noetic-smclib ros-noetic-stage ros-noetic-stage-ro[|]  shiboken2 sip-dev tango-icon-theme tcl tcl-dev tcl-vtk7 tcl8.6 tcl8.6-dev t[/]  texlive-latex-base texlive-latex-recommended dvipng ffmpeg inkscape ipython[|]  docutils-common dpkg-dev dwz fakeroot fltk1.3-doc fluid fonts-lato fonts-ly[/]  gazebo11-plugin-base gcc gcc-7-base gcc-8 gcc-8-base gcc-9 gdal-data gettex[/]  libarpack2 libarpack2-dev libasan4 libasan5 libass9 libassimp-dev libassimp[|]  libevent-core-2.1-7 libevent-dev libevent-extra-2.1-7 libevent-openssl-2.1-[|]  libfltk-cairo1.3 libfltk-forms1.3 libfltk-gl1.3 libfltk-images1.3 libfltk1.[-]  libglvnd-dev libglx-dev libgme0 libgpg-error-dev libgpgme-dev libgphoto2-de[/]  libhwloc-plugins libhwloc15 libibverbs-dev libibverbs1 libice-dev libicu-de[\]  libignition-tools-dev libignition-transport8 libignition-transport8-core-de[|]  libpocodataodbc62 libpocodatasqlite62 libpocoencodings62 libpocofoundation6[|]  libqt5dbus5 libqt5designer5 libqt5designercomponents5 libqt5gui5 libqt5help[/]  libsimbody-dev libsimbody3.6 libsm-dev libsnappy1v5 libsndio7.0 libsocket++[|]  libxmu-headers libxnvctrl0 libxrandr-dev libxrender-dev libxss-dev libxt-de[\]  ros-noetic-rosmake ros-noetic-rosmaster ros-noetic-rosmsg ros-noetic-rosnod[\]  ros-noetic-smach-ros ros-noetic-smclib ros-noetic-stage ros-noetic-stage-ro[/]  shiboken2 sip-dev tango-icon-theme tcl tcl-dev tcl-vtk7 tcl8.6 tcl8.6-dev t[|]升级了 0 个软件包,新安装了 1106 个软件包,要卸载 0 个软件包,有 1 个软件包未[\]错误:1 https://packages.ros.org/ros/ubuntu focal/main amd64 libgazebo11 amd64[|]  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in th[-]错误:2 https://packages.ros.org/ros/ubuntu focal/main amd64 gazebo11-common a[/]  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in th[\]错误:3 https://packages.ros.org/ros/ubuntu focal/main amd64 gazebo11 amd64 11[|]  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in th[-]错误:4 https://packages.ros.org/ros/ubuntu focal/main amd64 libignition-trans[/]  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in th[-]Result:code:100                            443]
      Run CMD Task:[sudo apt-cache search python3-catkin-tools ]
      [-]Result:success                            for working with catkin.
      Run CMD Task:[sudo apt install python3-catkin-tools -y]
      [\]升级了 0 个软件包,新安装了 13 个软件包,要卸载 0 个软件包,有 1 个软件包未被[/]获取:1 https://mirrors.ustc.edu.cn/ubuntu focal/main amd64 python3-more-itert[\]获取:2 https://mirrors.ustc.edu.cn/ubuntu focal/main amd64 python3-zipp all 1[|]获取:3 https://mirrors.ustc.edu.cn/ubuntu focal/main amd64 python3-importlib-[-]错误:4 https://packages.ros.org/ros/ubuntu focal/main amd64 python3-osrf-pyco[/]  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in th[\]错误:5 https://packages.ros.org/ros/ubuntu focal/main amd64 python3-catkin-to[|]  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in th[-]Result:code:100                           0 443]
      [\]python3-rosdep2 - rosdep package manager abstraction tool for Robot OS (Pytho[-]Result:success                           anager abstraction tool for ROS
      [\]升级了 0 个软件包,新安装了 12 个软件包,要卸载 0 个软件包,有 1 个软件包未被[/]错误:1 https://packages.ros.org/ros/ubuntu focal/main amd64 python3-rosdep al[\]  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in th[-]Result:code:100                           0 443]
      Run CMD Task:[ls /opt/ros/noetic/setup.bash]
      [-]Result:code:2
      [-]Result:code:2
        小鱼 技术大佬 @机械小青年
        @机械小青年 下面指令应该可以解决证书错误
        sudo su
        touch /etc/apt/apt.conf.d/99verify-peer.conf
        echo  "Acquire { https::Verify-Peer false }" > /etc/apt/apt.conf.d/99verify-peer.conf
        exit
        sudo apt update
        机械小青年机 1 条回复 最后回复 回复 引用 0
        • 机械小青年机
          机械小青年 @小鱼
          @小鱼 谢谢小🐟
