    如何使用roslaunch 调用不同工作空间的功能包?
    功能包调用 工作空间
    9.0k
    • 空白空
      空白 @Lorry
      @Lorry 嗯嗯,目前来看这个方法算比较简单的
      • 空白空
        空白 @小鱼
        @小鱼 我在我包含moveit的工作空间
        ~/ws_moveit2$ sudo colcon build --merge-install --install-base /opt/ros/humble/
        然后编译通过了,在/opt/ros/humble/share 里面也可以找到相应的名字
        内容和/home/xxx/ws_moveit2/install/moveit_configs_utils/share里面内容一样
        (本来share里面好像就没有local_setup.bash),只在/home/xxx/ws_moveit2/install
        里面看到了
        然后出现的现象如上图所示,尝试有:
        1.在原ws_moveit2空间使用
        可以继续编译成功,但是使用colcon build会出现
        [0.605s] ERROR:colcon.colcon_core.environment:Exception in shell extension 'dsv': [Errno 13] Permission denied: '/home/pan/ws_moveit2/install/moveit_resources_panda_description/share/moveit_resources_panda_description/package.dsv'
          File "/usr/lib/python3/dist-packages/colcon_core/environment/__init__.py", line 131, in create_environment_scripts_only
            retval = extension.create_package_script(
          File "/usr/lib/python3/dist-packages/colcon_core/shell/dsv.py", line 30, in create_package_script
            expand_template(
          File "/usr/lib/python3/dist-packages/colcon_core/shell/template/__init__.py", line 54, in expand_template
            with destination_path.open('w') as h:
          File "/usr/lib/python3.10/pathlib.py", line 1119, in open
            return self._accessor.open(self, mode, buffering, encoding, errors,
        PermissionError: [Errno 13] Permission denied: '/home/pan/ws_moveit2/install/moveit_resources_panda_description/share/moveit_resources_panda_description/package.dsv'
        --- stderr: moveit_resources_panda_description
        CMake Error at cmake_install.cmake:86 (file):
          file INSTALL cannot set permissions on
          "/home/pan/ws_moveit2/install/moveit_resources_panda_description/share/moveit_resources_panda_description/package.dsv":
          Operation not permitted.
        Failed   <<< moveit_resources_panda_description [0.24s, exited with code 1]
        Aborted  <<< moveit_resources_pr2_description [0.22s]
        Aborted  <<< moveit_resources_prbt_support [0.22s]
        Aborted  <<< moveit_common [0.24s]
        Aborted  <<< moveit_resources_fanuc_description [0.23s]
        Aborted  <<< srdfdom [0.24s]
        Aborted  <<< rviz_marker_tools [0.22s]
        Aborted  <<< rosparam_shortcuts [0.22s]
        Aborted  <<< moveit_task_constructor_msgs [0.34s]
        Aborted  <<< launch_param_builder [0.35s]
        Summary: 0 packages finished [0.61s]
          1 package failed: moveit_resources_panda_description
          9 packages aborted: launch_param_builder moveit_common moveit_resources_fanuc_description moveit_resources_pr2_description moveit_resources_prbt_support moveit_task_constructor_msgs rosparam_shortcuts rviz_marker_tools srdfdom
          5 packages had stderr output: moveit_common moveit_resources_fanuc_description moveit_resources_panda_description moveit_resources_pr2_description moveit_resources_prbt_support
          46 packages not processed
        2.除直接通过Ctrl+Alt+T会出现上述现象外,在其他没有改动的工作空间下面采用
        source install/setup.bash
        也会出现相同的错误
        目前想到的尝试方法有:
        1.是否可以通过在/opt/ros/humble/ 里面colcon build 尝试会不会改变这个底层空间的setup.bash从而解决办法
        2.如果实在不行应该如何还原?是直接像二进制那样autoremove moveit相关就可,还是只能把这些全删掉重新搞?
          小鱼 技术大佬 @空白
          @空白 这个是因为之前安装用了sudo导致权限变了的原因,你可以后续编译都用sudo来进行,或者将原有编译出来的文件删除重新编译即可。
          另外就是你之前是否有加到.bashrc下的关于功能包的配置,有的话可以删掉。
          空白空 2 条回复 最后回复 回复 引用 0
          • 空白空
            空白 @小鱼
            @小鱼 原有编译删掉是指将/opt/ros/humble/share里面多出来的功能包删掉即可吗?
              小鱼 技术大佬 @空白
              @空白 是你工作空间下的,因为采用sudo编译,导致build和log文件夹权限被修改成root用户了,后续直接使用colcon会没有权限。
              空白空 1 条回复 最后回复 回复 引用 0
              • 空白空
                空白 @小鱼
                @小鱼 .bashrc里面没有其他工作空间配置,只有source /opt/ros/humble/setup.bash
                • 空白空
                  空白 @小鱼
                  @小鱼 刚刚试了下,在ws_moveit工作空间采用colcon build 和source install/setup.bash没有问题了,但是打开终端还是会显示
                  not found: "/opt/ros/humble/share/moveit_planners_chomp/local_setup.bash"
                  这类错误
                    小鱼 技术大佬 @空白
                    @空白 直接删掉工作空间下install即可,如果不需要将这些功能包安装到系统,也可以直接删掉系统/opt/目录下的相关功能包文件。
                      小鱼 技术大佬 @空白
                      @空白 不确定moveit功能包和我这边测试的是否有什么不同之处导致这一问题,你可以先把系统的功能包删掉,我抽空再次测试一下比较复杂的工程安装到系统的方法。
                      • 空白空
                        空白 @小鱼
                        @小鱼 嗯嗯,为将系统的share里面功能包删除后就不会出问题了,然后用第一种方法完成了,效果来看目前没有问题
                        • 空白空 空白 将这个主题标记为已解决,在
                        • 空白空 空白 在 中 引用了 这个主题
