    重新运行代码时出现:UnsupportedTypeSupport: Could not import 'rosidl_typesupport_c' for package 'village_interfaces'
    ros2 humble 错误
    2.0k
    • A
      曼森的林佳树甜甜甜
      重新运行小鱼ros2课程中的代码,出现如题错误(之前可以运行),请问如何解决,谢谢!
      ps:网上有同样问题,但没有解决
      https://answers.ros.org/question/369159/could-not-import-rosidl_typesupport_c-for-package-packagename/
      https://answers.ros.org/question/373256/ros2-could-not-import-rosidl_typesupport_c-for-package/
      andrew@ros2:~/town_ws$ ros2 run village_li li3_node
      [INFO] [1673964726.513490206] [li3]: 大家好,我是李三,李四他哥,我可以白嫖李四的小说!
        File "<frozen importlib._bootstrap>", line 674, in _load_unlocked
        File "<frozen importlib._bootstrap>", line 571, in module_from_spec
        File "<frozen importlib._bootstrap_external>", line 1176, in create_module
      ImportError: /home/andrew/town_ws/install/village_interfaces/lib/libvillage_interfaces__rosidl_generator_c.so: ELF file's phentsize not the expected size
        File "/home/andrew/town_ws/install/village_li/lib/village_li/li3_node", line 33, in <module>
          sys.exit(load_entry_point('village-li==0.0.0', 'console_scripts', 'li3_node')())
        File "/home/andrew/town_ws/install/village_li/lib/python3.10/site-packages/village_li/li3.py", line 60, in main
          node = Li3Node("li3")  # 新建一个节点
        File "/home/andrew/town_ws/install/village_li/lib/python3.10/site-packages/village_li/li3.py", line 18, in __init__
          self.borrow_client =self.create_client(BorrowMoney,"borrow_money")
        File "/home/andrew/town_ws/install/village_interfaces/local/lib/python3.10/dist-packages/village_interfaces/srv/_borrow_money.py", line 301, in __import_type_support__
          module = import_type_support('village_interfaces')
      rosidl_generator_py.import_type_support_impl.UnsupportedTypeSupport: Could not import 'rosidl_typesupport_c' for package 'village_interfaces'
      A 小鱼小 2 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @andrew_liumuran
        @andrew_liumuran 贴一下CmakeKList.txt 问题应该是没添加依赖造成的
        BUG表现如下
        自定义消息,编译不报错,运行就出错
        File "/opt/ros/foxy/lib/python3.8/site-packages/rosidl_generator_py/import_type_support_impl.py", line 46, in import_type_support
        File "/usr/lib/python3.8/importlib/init.py", line 127, in import_module
        File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
        File "<frozen importlib._bootstrap>", line 991, in _find_and_load
        File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
        File "<frozen importlib._bootstrap>", line 657, in _load_unlocked
        File "<frozen importlib._bootstrap>", line 556, in module_from_spec
        File "<frozen importlib._bootstrap_external>", line 1166, in create_module
        File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
        ImportError: /home/ros2/code/town_ws/install/village_interfaces/lib/libvillage_interfaces__rosidl_generator_c.so: undefined symbol: sensor_msgs__msg__Image__init
        File "/home/ros2/code/town_ws/install/village_li/lib/village_li/li4_node", line 11, in <module>
        load_entry_point('village-li==0.0.0', 'console_scripts', 'li4_node')()
        File "/home/ros2/code/town_ws/install/village_li/lib/python3.8/site-packages/village_li/li4.py", line 46, in main
        node = Li4Node() # 新建一个节点
        File "/home/ros2/code/town_ws/install/village_li/lib/python3.8/site-packages/village_li/li4.py", line 23, in init
        self.borrow_server = self.create_service(BorrowMoney,"borrow_money",self.borrow_money_callback)
        File "/opt/ros/foxy/lib/python3.8/site-packages/rclpy/node.py", line 1295, in create_service
        File "/opt/ros/foxy/lib/python3.8/site-packages/rclpy/type_support.py", line 29, in check_for_type_support
        msg_type.class.import_type_support()
        File "/home/ros2/code/town_ws/install/village_interfaces/lib/python3.8/site-packages/village_interfaces/srv/_borrow_money.py", line 316, in import_type_support
        File "/opt/ros/foxy/lib/python3.8/site-packages/rosidl_generator_py/import_type_support_impl.py", line 48, in import_type_support
        原因:
        自定义消息未添加对其他消息的依赖
        解决办法,添加依赖在CMakeists.txt中
        #---msg---
        "msg/Novel.msg"
        #---srv---
        "srv/BorrowMoney.srv"
        "srv/SellNovel.srv"
        DEPENDENCIES std_msgs sensor_msgs
        版权声明:本文为CSDN博主「鱼香ROS」的原创文章,遵循CC 4.0 BY-SA版权协议,转载请附上原文出处链接及本声明。
        原文链接:https://blog.csdn.net/qq_27865227/article/details/119651587
        A 1 条回复 最后回复 回复 引用 0
        • A
          曼森的林佳树甜甜甜 @andrew_liumuran
          @andrew_liumuran
          类似的问题 链接文本
            BUG表现如下
            自定义消息,编译不报错,运行就出错
            原因:
            自定义消息未添加对其他消息的依赖
            #---msg---
            "msg/Novel.msg"
            #---srv---
            "srv/SellNovel.srv"
            • 小鱼小 小鱼 将这个主题标记为已解决,在
            • A
              曼森的林佳树甜甜甜 @小鱼
              小鱼您好,这是CmakeKList.txt,修改编译运行后仍有相同错误,还得麻烦您,谢谢!
              # /home/andrew/town_ws/src/village_interfaces/CMakeLists.txt
              project(village_interfaces)
              endif()
              # find dependencies
              if(BUILD_TESTING)
                #添加对sensor_msgs的
                # comment the line when a copyright and license is added to all source files
                # comment the line when this package is in a git repo and when
                # a copyright and license is added to all source files
              endif()
              #添加消息文件和依赖
                "msg/Novel.msg"
                "srv/SellNovel.srv"
              ament_package()
                @andrew_liumuran 在 重新运行代码时出现:UnsupportedTypeSupport: Could not import 'rosidl_typesupport_c' for package 'village_interfaces' 中说:
                #添加对sensor_msgs的
                把这个移到
                if(BUILD_TESTING)
                之前
                • A
                  曼森的林佳树甜甜甜 @小鱼
                  小鱼您好,修改之后,还是相同的报错 😰 😰 谢谢您
                  endif()
                  # find dependencies
                  find_package(std_msgs REQUIRED)
                  if(BUILD_TESTING)
                    #添加对sensor_msgs的
                  endif()
                  #添加消息文件和依赖
                    "msg/Novel.msg"
                    "srv/SellNovel.srv"
                  ament_package()
                  以下是报错
                  [INFO] [1674031680.523058434] [li3]: 大家好,我是李三,李四他哥,我可以白嫖李四的小说!
                    @andrew_liumuran 把你的消息文件内容贴一下
                    • A
                      曼森的林佳树甜甜甜 @小鱼
                      @小鱼 😊
                      /home/andrew/town_ws/src/village_interfaces/msg/Novel.msg
                      # 直接使用ROS2原始的数据类型
                      string content
                      # 图像消息,调用sensor_msgs下的Image类型
                      sensor_msgs/Image image
                        @andrew_liumuran 看起来没啥问题, 改成这样试试
                        endif()
                        # find dependencies
                        if(BUILD_TESTING)
                        endif()
                        #添加消息文件和依赖
                          "msg/Novel.msg"
                          "srv/SellNovel.srv"
                        ament_package()
                        另外还不行可以直接去掉
                          @andrew_liumuran 另外记得把build和install目录删除掉,重新colcon build试试
                          • A
                            曼森的林佳树甜甜甜 @小鱼
                            謝謝小魚,刪除目錄有效,可以運行了!
                            • 8421452488 842145248 在 中 引用了 这个主题
