    rviz不能显示环境模型,且机器人模型也不在
    ros2机器人 launch gazebo11
    2.4k
    • yudonghou123Y
      小猴同学
      最后由 yudonghou123 编辑
      各位大佬,我运行项目的时候,机器人也能在gazebo环境中加载出来,但不在rviz中显示,终端报出以下问题:
      [INFO] [launch]: All log files can be found below /home/user2/.ros/log/2023-02-17-20-10-20-236922-user2-1009600
      redefining global symbol: range
      when instantiating macro: pressure_plugin_macro (/home/user2/auv_ws/install/uuv_sensor_ros_plugins/share/uuv_sensor_ros_plugins/urdf/pressure_snippets.xacro)
      instantiated from: default_pressure (/home/user2/auv_ws/install/uuv_sensor_ros_plugins/share/uuv_sensor_ros_plugins/urdf/pressure_snippets.xacro)
      instantiated from: eca_a9_base (/home/user2/auv_ws/install/eca_a9_description/share/eca_a9_description/urdf/eca_a9_base.xacro)
      in file: /home/user2/auv_ws/install/eca_a9_description/share/eca_a9_description/urdf/eca_a9_sensors.xacro
      included from: /home/user2/auv_ws/install/eca_a9_description/share/eca_a9_description/robots/eca_a9_default.urdf.xacro
      redefining global symbol: gamma
      when instantiating macro: chemical_concentration_sensor_macro (/home/user2/auv_ws/install/uuv_sensor_ros_plugins/share/uuv_sensor_ros_plugins/urdf/chemical_concentration_snippets.xacro)
      instantiated from: default_chemical_concentration_sensor (/home/user2/auv_ws/install/uuv_sensor_ros_plugins/share/uuv_sensor_ros_plugins/urdf/chemical_concentration_snippets.xacro)
      [INFO] [spawn_entity.py-1]: process started with pid [1009650]
      [INFO] [robot_state_publisher-2]: process started with pid [1009652]
      [INFO] [uuv_message_to_tf-3]: process started with pid [1009654]
      [INFO] [finned_uuv_teleop.py-4]: process started with pid [1009656]
      [INFO] [joy_node-5]: process started with pid [1009658]
      [INFO] [rviz2-6]: process started with pid [1009660]
      [rviz2-6] WARNING: CPU random generator seem to be failing, disabling hardware random number generation
      [rviz2-6] WARNING: RDRND generated: 0xffffffff 0xffffffff 0xffffffff 0xffffffff
      [rviz2-6] qt.qpa.plugin: Could not find the Qt platform plugin "wayland" in ""
      [spawn_entity.py-1] [INFO] [1676635822.866889330] [eca_a9.urdf_spawner]: Spawn Entity started
      [spawn_entity.py-1] [INFO] [1676635822.867159779] [eca_a9.urdf_spawner]: Loading entity published on topic robot_description
      [spawn_entity.py-1] /opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/qos.py:307: UserWarning: DurabilityPolicy.RMW_QOS_POLICY_DURABILITY_TRANSIENT_LOCAL is deprecated. Use DurabilityPolicy.TRANSIENT_LOCAL instead.
      [spawn_entity.py-1]   warnings.warn(
      [joy_node-5] [INFO] [1676635823.094236435] [eca_a9.joystick]: No haptic (rumble) available, skipping initialization
      [joy_node-5] [INFO] [1676635823.094329099] [eca_a9.joystick]: Opened joystick: SHANWAN Android Gamepad.  deadzone: 0.050000
      [spawn_entity.py-1] [INFO] [1676635823.155215881] [eca_a9.urdf_spawner]: Waiting for entity xml on robot_description
      [robot_state_publisher-2] [WARN] [1676635823.157768385] [kdl_parser]: The root link eca_a9/base_link has an inertia specified in the URDF, but KDL does not support a root link with an inertia.  As a workaround, you can add an extra dummy link to your URDF.
      [robot_state_publisher-2] [INFO] [1676635823.157911755] [eca_a9.robot_state_publisher]: got segment eca_a9/base_link
      [robot_state_publisher-2] [INFO] [1676635823.157965126] [eca_a9.robot_state_publisher]: got segment eca_a9/battery_link
      [robot_state_publisher-2] [INFO] [1676635823.157972469] [eca_a9.robot_state_publisher]: got segment eca_a9/camera_link
      [robot_state_publisher-2] [INFO] [1676635823.157978942] [eca_a9.robot_state_publisher]: got segment eca_a9/camera_link_optical
      [robot_state_publisher-2] [INFO] [1676635823.157984462] [eca_a9.robot_state_publisher]: got segment eca_a9/cc_sensor_link
      [robot_state_publisher-2] [INFO] [1676635823.157990012] [eca_a9.robot_state_publisher]: got segment eca_a9/dvl_link
      [robot_state_publisher-2] [INFO] [1676635823.157995603] [eca_a9.robot_state_publisher]: got segment eca_a9/dvl_sonar0_link
      [robot_state_publisher-2] [INFO] [1676635823.158002356] [eca_a9.robot_state_publisher]: got segment eca_a9/dvl_sonar1_link
      [robot_state_publisher-2] [INFO] [1676635823.158007906] [eca_a9.robot_state_publisher]: got segment eca_a9/dvl_sonar2_link
      [robot_state_publisher-2] [INFO] [1676635823.158013336] [eca_a9.robot_state_publisher]: got segment eca_a9/dvl_sonar3_link
      [robot_state_publisher-2] [INFO] [1676635823.158019428] [eca_a9.robot_state_publisher]: got segment eca_a9/fin0
      [robot_state_publisher-2] [INFO] [1676635823.158025359] [eca_a9.robot_state_publisher]: got segment eca_a9/fin1
      [robot_state_publisher-2] [INFO] [1676635823.158030709] [eca_a9.robot_state_publisher]: got segment eca_a9/fin2
      [robot_state_publisher-2] [INFO] [1676635823.158035308] [eca_a9.robot_state_publisher]: got segment eca_a9/fin3
      [robot_state_publisher-2] [INFO] [1676635823.158040708] [eca_a9.robot_state_publisher]: got segment eca_a9/gps_link
      [robot_state_publisher-2] [INFO] [1676635823.158046198] [eca_a9.robot_state_publisher]: got segment eca_a9/imu_link
      [robot_state_publisher-2] [INFO] [1676635823.158051678] [eca_a9.robot_state_publisher]: got segment eca_a9/pose_sensor_link_default
      [robot_state_publisher-2] [INFO] [1676635823.158057419] [eca_a9.robot_state_publisher]: got segment eca_a9/pressure_link
      [robot_state_publisher-2] [INFO] [1676635823.158062920] [eca_a9.robot_state_publisher]: got segment eca_a9/sonarleft_link
      [robot_state_publisher-2] [INFO] [1676635823.158068490] [eca_a9.robot_state_publisher]: got segment eca_a9/sonarright_link
      [robot_state_publisher-2] [INFO] [1676635823.158074161] [eca_a9.robot_state_publisher]: got segment eca_a9/thruster_0
      [spawn_entity.py-1] [INFO] [1676635823.198087284] [eca_a9.urdf_spawner]: Waiting for entity xml on robot_description
      [spawn_entity.py-1] [INFO] [1676635823.299921918] [eca_a9.urdf_spawner]: Waiting for entity xml on robot_description
      [spawn_entity.py-1] [INFO] [1676635823.402145594] [eca_a9.urdf_spawner]: Waiting for entity xml on robot_description
      [spawn_entity.py-1] [INFO] [1676635823.504263923] [eca_a9.urdf_spawner]: Waiting for entity xml on robot_description
      [spawn_entity.py-1] [INFO] [1676635823.603517088] [eca_a9.urdf_spawner]: Waiting for entity xml on robot_description
      [spawn_entity.py-1] [INFO] [1676635823.704734641] [eca_a9.urdf_spawner]: Waiting for entity xml on robot_description
      [spawn_entity.py-1] [INFO] [1676635823.806152761] [eca_a9.urdf_spawner]: Waiting for entity xml on robot_description
      [spawn_entity.py-1] [INFO] [1676635823.821186097] [eca_a9.urdf_spawner]: Waiting for service /spawn_entity, timeout = 30
      [spawn_entity.py-1] [INFO] [1676635823.821512722] [eca_a9.urdf_spawner]: Waiting for service /spawn_entity
      [spawn_entity.py-1] [INFO] [1676635823.825562634] [eca_a9.urdf_spawner]: Calling service /spawn_entity
      [finned_uuv_teleop.py-4] [INFO] [1676635823.957493336] [eca_a9.finned_uuv_teleop]: FinnedUUVControllerNode: initializing node
      [rviz2-6] [INFO] [1676635824.307615459] [rviz2]: Stereo is NOT SUPPORTED
      [rviz2-6] [INFO] [1676635824.307686202] [rviz2]: OpenGl version: 4.3 (GLSL 4.3)
      [rviz2-6] [INFO] [1676635824.317527045] [rviz2]: Stereo is NOT SUPPORTED
      [rviz2-6] Warning: Invalid frame ID "eca_a9/base_link" passed to canTransform argument source_frame - frame does not exist
      [rviz2-6]          at line 93 in ./src/buffer_core.cpp
      [rviz2-6] [INFO] [1676635824.431045751] [rviz2]: Stereo is NOT SUPPORTED
      [spawn_entity.py-1] [INFO] [1676635824.435702135] [eca_a9.urdf_spawner]: Spawn status: SpawnEntity: Successfully spawned entity [eca_a9]
      [INFO] [spawn_entity.py-1]: process has finished cleanly [pid 1009650]
      [finned_uuv_teleop.py-4] [INFO] [1676635824.615084982] [eca_a9.finned_uuv_teleop]: Thruster #0 - proportional - thrusters/id_0/input
      [finned_uuv_teleop.py-4] [INFO] [1676635824.615507727] [eca_a9.finned_uuv_teleop]: Thruster model:
      [finned_uuv_teleop.py-4] [INFO] [1676635824.615786171] [eca_a9.finned_uuv_teleop]:      Gain=4.9e-05
      其rviz配置文件如下:
      Panels:
        - Class: rviz_common/Displays
          Help Height: 78
          Property Tree Widget:
            Expanded:
              - /Global Options1
              - /Status1
              - /RobotModel1
              - /Sonar left1
              - /Sonar right1
              - /Waypoint path1
              - /Fin 0 - Wrench1
              - /Fin 1 - Wrench1
              - /Fin 2 - Wrench1
              - /Fin 3 - Wrench1
              - /Thrust Wrench1
            Splitter Ratio: 0.5
          Tree Height: 486
        - Class: rviz_common/Selection
        - Class: rviz_common/Tool Properties
          Expanded:
            - /2D Pose Estimate1
            - /2D Nav Goal1
            - /Publish Point1
          Name: Tool Properties
          Splitter Ratio: 0.588679016
        - Class: rviz_common/Views
          Expanded:
            - /Current View1
          Splitter Ratio: 0.5
        - Class: rviz_common/Time
          Experimental: false
          SyncMode: 0
          SyncSource: Sonar left
      Visualization Manager:
        Class: ""
        Displays:
          - Alpha: 0.5
            Cell Size: 1
            Class: rviz_default_plugins/Grid
            Color: 160; 160; 164
            Enabled: true
            Line Style:
              Line Width: 0.0299999993
              Value: Lines
            Normal Cell Count: 0
            Offset:
              X: 0
              Y: 0
              Z: 0
            Plane: XY
            Plane Cell Count: 10
            Reference Frame: <Fixed Frame>
            Value: true
          - Alpha: 1
            Class: rviz_default_plugins/RobotModel
            Collision Enabled: false
            Enabled: true
            Links:
              All Links Enabled: true
              Expand Joint Details: false
              Expand Link Details: false
              Expand Tree: false
              Link Tree Style: Links in Alphabetic Order
              eca_a9/base_link:
                Alpha: 1
                Show Axes: false
                Show Trail: false
                Value: true
              eca_a9/battery_link:
                Alpha: 1
                Show Axes: false
                Show Trail: false
              eca_a9/camera_link:
                Alpha: 1
                Show Axes: false
                Show Trail: false
                Value: true
              eca_a9/camera_link_optical:
                Alpha: 1
                Show Axes: false
                Show Trail: false
                Value: true
              eca_a9/cc_sensor_link:
                Alpha: 1
                Show Axes: false
                Show Trail: false
              eca_a9/dvl_link:
                Alpha: 1
                Show Axes: false
                Show Trail: false
                Value: true
              eca_a9/dvl_sonar0_link:
                Alpha: 1
                Show Axes: false
                Show Trail: false
                Value: true
              eca_a9/dvl_sonar1_link:
                Alpha: 1
                Show Axes: false
                Show Trail: false
                Value: true
              eca_a9/dvl_sonar2_link:
                Alpha: 1
                Show Axes: false
                Show Trail: false
                Value: true
              eca_a9/dvl_sonar3_link:
                Alpha: 1
                Show Axes: false
                Show Trail: false
                Value: true
              eca_a9/fin0:
                Alpha: 1
                Show Axes: false
                Show Trail: false
                Value: true
              eca_a9/fin1:
                Alpha: 1
                Show Axes: false
                Show Trail: false
                Value: true
              eca_a9/fin2:
                Alpha: 1
                Show Axes: false
                Show Trail: false
                Value: true
              eca_a9/fin3:
                Alpha: 1
                Show Axes: false
                Show Trail: false
                Value: true
              eca_a9/gps_link:
                Alpha: 1
                Show Axes: false
                Show Trail: false
              eca_a9/imu_link:
                Alpha: 1
                Show Axes: false
                Show Trail: false
              eca_a9/pose_sensor_link_default:
                Alpha: 1
                Show Axes: false
                Show Trail: false
              eca_a9/pressure_link:
                Alpha: 1
                Show Axes: false
                Show Trail: false
                Value: true
              eca_a9/sonarleft_link:
                Alpha: 1
                Show Axes: false
                Show Trail: false
                Value: true
              eca_a9/sonarright_link:
                Alpha: 1
                Show Axes: false
                Show Trail: false
                Value: true
              eca_a9/thruster_0:
                Alpha: 1
                Show Axes: false
                Show Trail: false
                Value: true
            Robot Description: eca_a9/robot_description
            TF Prefix: ""
            Update Interval: 0
            Value: true
            Visual Enabled: true
          - Class: rviz_default_plugins/TF
            Enabled: true
            Frame Timeout: 15
            Frames:
              All Enabled: true
              eca_a9/base_footprint:
                Value: true
              eca_a9/base_link:
                Value: true
              eca_a9/base_link_ned:
                Value: true
              eca_a9/base_stabilized:
                Value: true
                Value: true
              eca_a9/camera_link:
                Value: true
                Value: true
                Value: true
              eca_a9/dvl_link:
                Value: true
                Value: true
                Value: true
                Value: true
                Value: true
              eca_a9/fin0:
                Value: true
              eca_a9/fin1:
                Value: true
              eca_a9/fin2:
                Value: true
              eca_a9/fin3:
                Value: true
              eca_a9/gps_link:
                Value: true
              eca_a9/imu_link:
                Value: true
                Value: true
                Value: true
                Value: true
                Value: true
              eca_a9/thruster_0:
                Value: true
              world:
                Value: true
              world_ned:
                Value: true
            Marker Scale: 1
            Show Arrows: true
            Show Axes: true
            Show Names: true
            Tree:
              world:
                    eca_a9/base_link:
                      eca_a9/camera_link:
                      eca_a9/dvl_link:
                      eca_a9/fin0:
                      eca_a9/fin1:
                      eca_a9/fin2:
                      eca_a9/fin3:
                      eca_a9/gps_link:
                      eca_a9/imu_link:
                      eca_a9/thruster_0:
                world_ned:
            Update Interval: 0
            Value: true
          - Class: rviz_default_plugins/MarkerArray
            Enabled: true
            Marker Topic: /world_models
            Namespaces:
              "": true
            Queue Size: 100
            Value: true
          - Alpha: 1
            Autocompute Intensity Bounds: true
            Autocompute Value Bounds:
              Max Value: -91.8094254
              Min Value: -95.5871582
              Value: true
            Axis: Z
            Channel Name: intensity
            Class: rviz_default_plugins/LaserScan
            Color: 255; 255; 255
            Color Transformer: AxisColor
            Decay Time: 300
            Enabled: true
            Invert Rainbow: false
            Max Color: 255; 255; 255
            Max Intensity: 0
            Min Color: 0; 0; 0
            Min Intensity: 0
            Position Transformer: XYZ
            Queue Size: 10
            Selectable: true
            Size (Pixels): 3
            Size (m): 0.00999999978
            Style: Points
            Topic: /eca_a9/sss_left
            Unreliable: false
            Use Fixed Frame: true
            Use rainbow: true
            Value: true
          - Alpha: 1
              Max Value: -75.8892899
              Min Value: -95.6470261
              Value: true
            Axis: Z
            Decay Time: 300
            Enabled: true
            Max Intensity: 0
            Min Color: 0; 0; 0
            Min Intensity: 0
            Queue Size: 10
            Selectable: true
            Size (Pixels): 3
            Style: Points
            Topic: /eca_a9/sss_right
            Unreliable: false
            Use rainbow: true
            Value: true
          - Angle Tolerance: 0.100000001
            Class: rviz_default_plugins/Odometry
            Covariance:
              Orientation:
                Alpha: 0.5
                Color: 255; 255; 127
                Color Style: Unique
                Frame: Local
                Offset: 1
                Scale: 1
                Value: true
              Position:
                Alpha: 0.300000012
                Color: 204; 51; 204
                Scale: 1
                Value: true
              Value: true
            Enabled: true
            Keep: 100
            Position Tolerance: 0.100000001
            Shape:
              Alpha: 1
              Axes Length: 1
              Axes Radius: 0.100000001
              Color: 255; 25; 0
              Head Length: 0.300000012
              Head Radius: 0.100000001
              Shaft Length: 1
              Shaft Radius: 0.0500000007
              Value: Arrow
            Topic: /eca_a9/pose_gt
            Unreliable: false
            Value: true
          - Alpha: 1
            Buffer Length: 1
            Class: rviz_default_plugins/Path
            Color: 255; 85; 255
            Enabled: true
            Head Diameter: 0.300000012
            Head Length: 0.200000003
            Length: 0.300000012
            Line Style: Lines
            Offset:
              X: 0
              Y: 0
              Z: 0
            Pose Color: 255; 85; 255
            Pose Style: None
            Radius: 0.0299999993
            Shaft Diameter: 0.100000001
            Shaft Length: 0.100000001
            Topic: /eca_a9/trajectory_marker
            Unreliable: false
            Value: true
            Enabled: true
            Marker Topic: /eca_a9/waypoint_markers
            Namespaces:
              "": true
            Queue Size: 100
            Value: true
          - Alpha: 1
            Buffer Length: 1
            Color: 255; 85; 0
            Enabled: true
            Length: 0.300000012
            Line Style: Lines
            Offset:
              X: 0
              Y: 0
              Z: 0
            Pose Style: None
            Topic: /eca_a9/waypoint_path_marker
            Unreliable: false
            Value: true
          - Alpha: 1
            Arrow Width: 0.200000003
            Class: rviz_default_plugins/Wrench
            Enabled: true
            Force Arrow Scale: 0.100000001
            Force Color: 204; 51; 51
            History Length: 1
            Name: Fin 0 - Wrench
            Topic: /eca_a9/fins/0/wrench_topic
            Torque Arrow Scale: 2
            Torque Color: 204; 204; 51
            Unreliable: false
            Value: true
          - Alpha: 1
            Arrow Width: 0.300000012
            Enabled: true
            History Length: 1
            Name: Fin 1 - Wrench
            Topic: /eca_a9/fins/1/wrench_topic
            Unreliable: false
            Value: true
          - Alpha: 1
            Enabled: true
            History Length: 1
            Name: Fin 2 - Wrench
            Topic: /eca_a9/fins/2/wrench_topic
            Unreliable: false
            Value: true
          - Alpha: 1
            Enabled: true
            History Length: 1
            Name: Fin 3 - Wrench
            Topic: /eca_a9/fins/3/wrench_topic
            Unreliable: false
            Value: true
          - Alpha: 1
            Enabled: true
            Force Color: 53; 98; 204
            History Length: 1
            Topic: /eca_a9/thrusters/0/thrust_wrench
            Unreliable: false
            Value: true
          - Class: rviz_default_plugins/Image
            Enabled: true
            Image Topic: /eca_a9/camera/camera_image
            Max Value: 1
            Median window: 5
            Min Value: 0
            Normalize Range: true
            Queue Size: 2
            Transport Hint: raw
            Unreliable: false
            Value: true
            Enabled: true
            Marker Topic: /eca_a9/reference_marker
            Namespaces:
              "": true
            Queue Size: 100
            Value: true
            Enabled: true
            Marker Topic: /eca_a9/interpolator_visual_markers
            Namespaces:
              dubins: true
            Queue Size: 100
            Value: true
        Enabled: true
        Global Options:
          Background Color: 48; 48; 48
          Fixed Frame: world
          Frame Rate: 30
        Tools:
          - Class: rviz_default_plugins/Interact
            Hide Inactive Objects: true
          - Class: rviz_default_plugins/MoveCamera
          - Class: rviz_default_plugins/Select
          - Class: rviz_default_plugins/FocusCamera
          - Class: rviz_default_plugins/Measure
          - Class: rviz_default_plugins/SetInitialPose
            Topic: /initialpose
          - Class: rviz_default_plugins/SetGoal
            Topic: /goal_pose
            #Topic: /move_base_simple/goal
          - Class: rviz_default_plugins/PublishPoint
            Single click: true
            Topic: /clicked_point
        Value: true
          Current:
            Class: rviz_default_plugins/Orbit
            Distance: 303.795349
            Enable Stereo Rendering:
              Stereo Eye Separation: 0.0599999987
              Stereo Focal Distance: 1
              Swap Stereo Eyes: false
              Value: false
            Focal Point:
              X: 0
              Y: 0
              Z: 0
            Focal Shape Fixed Size: true
            Focal Shape Size: 0.0500000007
            Invert Z Axis: false
            Near Clip Distance: 0.00999999978
            Pitch: 0.525398612
            Target Frame: eca_a9/base_link
            Value: Orbit (rviz)
            Yaw: 2.36903524
          Saved: ~
      Window Geometry:
        Displays:
          collapsed: false
        Height: 1176
        Hide Left Dock: false
        Hide Right Dock: false
        Image:
          collapsed: false
        QMainWindow State: 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
        Selection:
          collapsed: false
        Time:
          collapsed: false
        Tool Properties:
          collapsed: false
          collapsed: false
        Width: 1920
        X: 1920
        Y: 24
      请问这是怎么回事呢?
      yudonghou123Y 小鱼小 2 条回复 最后回复 回复 引用 0
      • yudonghou123Y
        小猴同学 @yudonghou123
        yudonghou123Y 1 条回复 最后回复 回复 引用 0
        • yudonghou123Y
          小猴同学 @yudonghou123
          • yudonghou123Y yudonghou123 将这个主题转为问答主题,在
          • yudonghou123Y yudonghou123 删除了该主题于
          • yudonghou123Y yudonghou123 恢复了该主题于
            小鱼 技术大佬 @yudonghou123
            @yudonghou123 看错误tf有问题,检查tf
            • yudonghou123Y yudonghou123 将这个主题标记为已解决,在
              大佬,请问怎么解决的
