    更换源的问题,选择1会装失败(自己更换过源的情况下)
    一键安装报错 更换源的问题
    4.4k
      小鱼 技术大佬 @2229881459
      @2229881459 贴一下日志~~~
      6270705966 1 条回复 最后回复 回复 引用 0
      • 6270705966
        :-D @小鱼
        Run CMD Task:[sudo aptitude install ros-melodic-desktop-full -y]
        libcurl4-gnutls-dev : Conflicts: libcurl4-openssl-dev but 7.58.0-2ubuntu3.22[/] libcurl4-openssl-dev : Conflicts: libcurl4-gnutls-dev but 7.58.0-2ubuntu3.22[] libx11-dev : Depends: libx11-6 (= 2:1.6.4-3ubuntu0.4) but 2:1.6.4-3ubuntu0.5[-]Result:success ing 0 B will be used.upgraded.
        [-]Result:success e and 9 not upgraded.
        [-]Result:code:2
        [-]Result:code:2
          小鱼 技术大佬 @627070596
          @627070596 全部日志,错误在上面
          6270705966 4 条回复 最后回复 回复 引用 0
          • 6270705966
            :-D @小鱼
            @小鱼 内容太长,我分开发
            请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
            [1]:melodic(ROS1)桌面版
            [2]:melodic(ROS1)基础版(小)
            请输入[]内的数字以选择:1
            [|]aptitude-common - architecture independent files for the aptitude package man[-]aptitude-doc-en - English manual for aptitude, a terminal-based package manag[/]libcwidget-dev - high-level terminal interface library for C++ (development f[-]apticron-systemd - Simple tool to mail about pending package updates - system[]aptitude-doc-es - Spanish manual for aptitude, a terminal-based package manag[|]aptitude-doc-fi - Finnish manual for aptitude, a terminal-based package manag[-]aptitude-doc-fr - French manual for aptitude, a terminal-based package manage[/]aptitude-doc-it - Italian manual for aptitude, a terminal-based package manag[]aptitude-doc-ja - Japanese manual for aptitude, a terminal-based package mana[-]aptitude-doc-ru - Russian manual for aptitude, a terminal-based package manag[-]gbrainy - brain teaser game and trainer to have fun and to keep your brain tr[-]Result:success end for Debian
            [-]Result:success e and 0 not upgraded.
            Reading package lists... Done
            Building dependency tree
            ros-melodic-desktop-full : Depends: ros-melodic-desktop but it is not going to be installed
            Depends: ros-melodic-perception but it is not going to be installed
            Depends: ros-melodic-simulators but it is not going to be installed
            Depends: ros-melodic-urdf-sim-tutorial but it is not going to be installed
            E: Unable to correct problems, you have held broken packages.
            ros-melodic-desktop-full : Depends: ros-melodic-desktop but it is not going [/] Depends: ros-melodic-perception but it is not goi[] Depends: ros-melodic-simulators but it is not goi[|] Depends: ros-melodic-urdf-sim-tutorial but it is [-]Result:code:100
            确认了解情况,请输入回车继续安装
            • 6270705966
              :-D @小鱼
              Run CMD Task:[sudo aptitude install ros-melodic-desktop-full]
              cmake{a} cmake-data{a} cython{a} default-libmysqlclient-dev{a}
              dh-python{a} fltk1.3-doc{a} fluid{a} fonts-lato{a} freeglut3{a}
              freeglut3-dev{a} gazebo9{a} gazebo9-common{a} gazebo9-plugin-base{a}
              gdal-data{a} gir1.2-gtk-2.0{a} gir1.2-harfbuzz-0.0{a} google-mock{a}
              googletest{a} hddtemp{a} hdf5-helpers{a} ibverbs-providers{a}
              icu-devtools{a} libaacs0{a} libaec-dev{a} libaec0{a} libapr1{a}
              libapr1-dev{a} libaprutil1{a} libaprutil1-dev{a} libarmadillo-dev{a}
              libarmadillo8{a} libarpack2{a} libarpack2-dev{a} libass9{a}
              libassimp-dev{a} libassimp4{a} libassuan-dev{a} libatk1.0-dev{a}
              libavcodec-dev{a} libavcodec57{a} libavdevice-dev{a} libavdevice57{a}
              libavfilter-dev{a} libavfilter6{a} libavformat-dev{a} libavformat57{a}
              libavresample-dev{a} libavresample3{a} libavutil-dev{a} libavutil55{a}
              libbdplus0{a} libblas-dev{a} libblas3{a} libbluray2{a}
              libboost-all-dev{a} libboost-atomic-dev{a} libboost-atomic1.65-dev{a}
              libboost-atomic1.65.1{a} libboost-chrono-dev{a}
              libboost-chrono1.65-dev{a} libboost-chrono1.65.1{a}
              libboost-container-dev{a} libboost-container1.65-dev{a}
              libboost-container1.65.1{a} libboost-context-dev{a}
              libboost-context1.65-dev{a} libboost-context1.65.1{a}
              libboost-coroutine-dev{a} libboost-coroutine1.65-dev{a}
              libboost-coroutine1.65.1{a} libboost-date-time-dev{a}
              libboost-date-time1.65-dev{a} libboost-dev{a} libboost-exception-dev{a}
              libboost-exception1.65-dev{a} libboost-fiber-dev{a}
              libboost-fiber1.65-dev{a} libboost-fiber1.65.1{a}
              libboost-filesystem-dev{a} libboost-filesystem1.65-dev{a}
              libboost-graph-dev{a} libboost-graph-parallel-dev{a}
              libboost-graph-parallel1.65-dev{a} libboost-graph-parallel1.65.1{a}
              libboost-graph1.65-dev{a} libboost-graph1.65.1{a}
              libboost-iostreams-dev{a} libboost-iostreams1.65-dev{a}
              libboost-locale-dev{a} libboost-locale1.65-dev{a} libboost-log-dev{a}
              libboost-log1.65-dev{a} libboost-log1.65.1{a} libboost-math-dev{a}
              libboost-math1.65-dev{a} libboost-math1.65.1{a} libboost-mpi-dev{a}
              libboost-mpi-python-dev{a} libboost-mpi-python1.65-dev{a}
              libboost-mpi-python1.65.1{a} libboost-mpi1.65-dev{a}
              libboost-mpi1.65.1{a} libboost-numpy-dev{a} libboost-numpy1.65-dev{a}
              libboost-numpy1.65.1{a} libboost-program-options-dev{a}
              libboost-program-options1.65-dev{a} libboost-program-options1.65.1{a}
              libboost-python-dev{a} libboost-python1.65-dev{a}
              libboost-python1.65.1{a} libboost-random-dev{a}
              libboost-random1.65-dev{a} libboost-random1.65.1{a} libboost-regex-dev{a}
              libboost-regex1.65-dev{a} libboost-regex1.65.1{a}
              libboost-serialization-dev{a} libboost-serialization1.65-dev{a}
              libboost-serialization1.65.1{a} libboost-signals-dev{a}
              libboost-signals1.65-dev{a} libboost-signals1.65.1{a}
              libboost-stacktrace-dev{a} libboost-stacktrace1.65-dev{a}
              libboost-stacktrace1.65.1{a} libboost-system-dev{a}
              libboost-system1.65-dev{a} libboost-test-dev{a} libboost-test1.65-dev{a}
              libboost-test1.65.1{a} libboost-thread-dev{a} libboost-thread1.65-dev{a}
              libboost-timer-dev{a} libboost-timer1.65-dev{a} libboost-timer1.65.1{a}
              libboost-tools-dev{a} libboost-type-erasure-dev{a}
              libboost-type-erasure1.65-dev{a} libboost-type-erasure1.65.1{a}
              libboost-wave-dev{a} libboost-wave1.65-dev{a} libboost-wave1.65.1{a}
              libboost1.65-dev{a} libboost1.65-tools-dev{a} libbs2b0{a}
              libbullet-dev{a} libbullet2.87{a} libbz2-dev{a}
              libcairo-script-interpreter2{a} libcairo2-dev{a} libccd-dev{a} libccd2{a}
              libcharls1{a} libchromaprint1{a} libconsole-bridge-dev{a}
              libconsole-bridge0.4{a} libcurl4-gnutls-dev{ab} libcurl4-openssl-dev{ab}
              libdap-dev{a} libdap25{a} libdapclient6v5{a} libdapserver7v5{a}
              libdc1394-22{a} libdc1394-22-dev{a} libdrm-dev{a} libdrm-etnaviv1{a}
              libdrm-freedreno1{a} libdrm-tegra0{a} libegl1-mesa-dev{a}
              libeigen3-dev{a} libepsilon-dev{a} libepsilon1{a} libexif-dev{a}
              libexif-doc{a} libexpat1-dev{a} libflann-dev{a} libflann1.9{a}
              libflite1{a} libfltk-cairo1.3{a} libfltk-forms1.3{a} libfltk-gl1.3{a}
              libfltk-images1.3{a} libfltk1.3{a} libfltk1.3-dev{a}
              libfontconfig1-dev{a} libfreeimage-dev{a} libfreeimage3{a}
              libfreetype6-dev{a} libfreexl-dev{a} libfreexl1{a} libfyba-dev{a}
              libfyba0{a} libgazebo9{a} libgazebo9-dev{a} libgdal-dev{a} libgdal20{a}
              libgdcm2-dev{a} libgdcm2.8{a} libgdk-pixbuf2.0-dev{a} libgeos-3.6.2{a}
              libgeos-c1v5{a} libgeos-dev{a} libgeotiff-dev{a} libgeotiff2{a}
              libgfortran4{a} libgif-dev{a} libgif7{a} libgl1-mesa-dev{a}
              libgl2ps-dev{a} libgl2ps1.4{a} libgles1{a} libgles2-mesa-dev{a}
              libglib2.0-dev{a} libglib2.0-dev-bin{a} libglu1-mesa-dev{a}
              libglvnd-core-dev{a} libglvnd-dev{a} libgme0{a} libgpg-error-dev{a}
              libgpgme-dev{ab} libgphoto2-dev{a} libgraphite2-dev{a} libgraphviz-dev{a}
              libgsm1{a} libgtest-dev{a} libgtk2.0-dev{a} libgts-dev{a}
              libgvc6-plugins-gtk{a} libharfbuzz-dev{a} libharfbuzz-gobject0{a}
              libhdf4-0-alt{a} libhdf4-alt-dev{a} libhdf5-100{a} libhdf5-cpp-100{a}
              libhdf5-dev{a} libhdf5-mpi-dev{a} libhdf5-openmpi-100{a}
              libhdf5-openmpi-dev{a} libhwloc-dev{a} libhwloc-plugins{a} libhwloc5{a}
              libibverbs-dev{a} libibverbs1{a} libice-dev{a} libicu-dev{a}
              libicu-le-hb-dev{a} libicu-le-hb0{a} libiculx60{a}
              libignition-cmake-dev{a} libignition-common{a} libignition-common-dev{a}
              libignition-fuel-tools1-1{a} libignition-fuel-tools1-dev{a}
              libignition-math4{a} libignition-math4-dev{a} libignition-msgs{a}
              libignition-msgs-dev{a} libignition-transport4{a}
              libignition-transport4-dev{a} libilmbase-dev{a} libjbig-dev{a}
              libjpeg-dev{a} libjpeg-turbo8-dev{a} libjpeg8-dev{a} libjs-jquery-ui{a}
              libjson-c-dev{a} libjsoncpp-dev{a} libjsoncpp1{a} libjxr0{a}
              libkml-dev{a} libkmlbase1{a} libkmlconvenience1{a} libkmldom1{a}
              libkmlengine1{a} libkmlregionator1{a} libkmlxsd1{a} liblapack-dev{a}
              liblapack3{a} libldap2-dev{a} liblept5{a} liblog4cxx-dev{a}
              liblog4cxx10v5{a} liblz4-dev{a} liblzma-dev{a} libminizip-dev{a}
              libminizip1{a} libmysofa0{a} libmysqlclient-dev{a} libnetcdf-c++4{a}
              libnetcdf-cxx-legacy-dev{a} libnetcdf-dev{a} libnetcdf13{a}
              libnl-route-3-200{a} libnorm1{a} libnuma-dev{a} libodbc1{a} libogdi3.2{a}
              libogdi3.2-dev{a} libogg-dev{a} libogre-1.9-dev{a} libogre-1.9.0v5{a}
              libopenal-data{a} libopenal-dev{a} libopenal1{a} libopencv-calib3d-dev{a}
              libopencv-calib3d3.2{a} libopencv-contrib-dev{a} libopencv-contrib3.2{a}
              libopencv-core-dev{a} libopencv-core3.2{a} libopencv-dev{a}
              libopencv-features2d-dev{a} libopencv-features2d3.2{a}
              libopencv-flann-dev{a} libopencv-flann3.2{a} libopencv-highgui-dev{a}
              libopencv-highgui3.2{a} libopencv-imgcodecs-dev{a}
              libopencv-imgcodecs3.2{a} libopencv-imgproc-dev{a}
              libopencv-imgproc3.2{a} libopencv-ml-dev{a} libopencv-ml3.2{a}
              libopencv-objdetect-dev{a} libopencv-objdetect3.2{a}
              libopencv-photo-dev{a} libopencv-photo3.2{a} libopencv-shape-dev{a}
              libopencv-shape3.2{a} libopencv-stitching-dev{a}
              libopencv-stitching3.2{a} libopencv-superres-dev{a}
              libopencv-superres3.2{a} libopencv-ts-dev{a} libopencv-video-dev{a}
              libopencv-video3.2{a} libopencv-videoio-dev{a} libopencv-videoio3.2{a}
              libopencv-videostab-dev{a} libopencv-videostab3.2{a} libopencv-viz-dev{a}
              libopencv-viz3.2{a} libopencv3.2-java{a} libopencv3.2-jni{a}
              libopenexr-dev{a} libopengl0{a} libopenjp2-7{a} libopenjp2-7-dev{a}
              libopenmpi-dev{a} libopenmpi2{a} libopenmpt0{a} libopenni-dev{a}
              libopenni-sensor-pointclouds0{a} libopenni0{a} libopenni2-0{a}
              libopenni2-dev{a} libpango1.0-dev{a} libpcl-apps1.8{a}
              libpcl-common1.8{a} libpcl-dev{a} libpcl-features1.8{a}
              libpcl-filters1.8{a} libpcl-io1.8{a} libpcl-kdtree1.8{a}
              libpcl-keypoints1.8{a} libpcl-ml1.8{a} libpcl-octree1.8{a}
              libpcl-outofcore1.8{a} libpcl-people1.8{a} libpcl-recognition1.8{a}
              libpcl-registration1.8{a} libpcl-sample-consensus1.8{a}
              libpcl-search1.8{a} libpcl-segmentation1.8{a} libpcl-stereo1.8{a}
              libpcl-surface1.8{a} libpcl-tracking1.8{a} libpcl-visualization1.8{a}
              libpcre16-3{a} libpcre3-dev{a} libpcre32-3{a} libpcrecpp0v5{a}
              libpgm-5.2-0{a} libpixman-1-dev{a} libpng-dev{a} libpng-tools{a}
              libpoco-dev{a} libpococrypto50{a} libpocodata50{a} libpocodatamysql50{a}
              libpocodataodbc50{a} libpocodatasqlite50{a} libpocofoundation50{a}
              libpocojson50{a} libpocomongodb50{a} libpoconet50{a} libpoconetssl50{a}
              libpocoredis50{a} libpocoutil50{a} libpocoxml50{a} libpocozip50{a}
              libpoppler-dev{a} libpoppler-private-dev{a} libpostproc-dev{a}
              libpostproc54{a} libpq-dev{a} libpq5{a} libproj-dev{a} libproj12{a}
              libprotobuf-dev{a} libprotobuf-lite10{a} libprotoc-dev{a} libprotoc10{a}
              libpthread-stubs0-dev{a} libpython-dev{a} libpython2.7-dev{a}
              libpython3-dev{a} libpython3.6-dev{a} libqhull-dev{a} libqhull-r7{a}
              libqhull7{a} libqt5concurrent5{a} libqt5designer5{a}
              libqt5designercomponents5{a} libqt5help5{a} libqt5opengl5{a}
              libqt5opengl5-dev{a} libqt5positioning5{a} libqt5printsupport5{a}
              libqt5qml5{a} libqt5quick5{a} libqt5quickparticles5{a}
              libqt5quicktest5{a} libqt5quickwidgets5{a} libqt5sensors5{a}
              libqt5sql5{a} libqt5sql5-sqlite{a} libqt5test5{a} libqt5webchannel5{a}
              libqt5webkit5{a} libqt5webkit5-dev{a} libqt5xml5{a}
              libqtpropertybrowser4{a} libqwt-headers{a} libqwt-qt5-6{a}
              libqwt-qt5-dev{a} libraw1394-dev{a} libraw1394-tools{a} librhash0{a}
              librubberband2{a} libruby2.5{a} libsctp-dev{a} libsctp1{a}
              libsdformat6{a} libsdformat6-dev{a} libsdl2-2.0-0{a} libshine3{a}
              libsimbody-dev{a} libsimbody3.5v5{a} libsm-dev{a} libsnappy1v5{a}
              libsocket++1{a} libsoxr0{a} libspatialite-dev{a} libspatialite7{a}
              libspnav0{a} libsqlite3-dev{a} libssh-gcrypt-4{a} libssl-dev{a}
              libsuperlu-dev{a} libsuperlu5{a} libswresample-dev{a} libswresample2{a}
              libswscale-dev{a} libswscale4{a} libsz2{a} libtar-dev{a} libtar0{a}
              libtbb-dev{a} libtbb2{a} libtesseract4{a} libtheora-dev{a} libtiff-dev{a}
              libtiff5-dev{a} libtiffxx5{a} libtinyxml-dev{a} libtinyxml2-6{a}
              libtinyxml2-dev{a} liburdfdom-dev{a} liburdfdom-headers-dev{a}
              liburdfdom-model{a} liburdfdom-model-state{a} liburdfdom-sensor{a}
              liburdfdom-world{a} liburiparser-dev{a} liburiparser1{a}
              libusb-1.0-0-dev{a} libusb-1.0-doc{a} libva-drm2{a} libva-x11-2{a}
              libva2{a} libvdpau1{a} libvtk6-dev{a} libvtk6-java{a} libvtk6-jni{a}
              libvtk6-qt-dev{a} libvtk6.3{a} libvtk6.3-qt{a} libwayland-bin{a}
              libwayland-dev{a} libwebp-dev{a} libwxbase3.0-0v5{a}
              libwxgtk3.0-gtk3-0v5{a} libx11-dev{ab} libx11-doc{a} libx11-xcb-dev{ab}
              libx264-152{a} libx265-146{a} libxau-dev{a} libxcb-dri2-0-dev{a}
              libxcb-dri3-dev{a} libxcb-glx0-dev{a} libxcb-present-dev{a}
              libxcb-randr0-dev{a} libxcb-render0-dev{a} libxcb-shape0-dev{a}
              libxcb-shm0-dev{a} libxcb-sync-dev{a} libxcb-xfixes0-dev{a}
              libxcb1-dev{a} libxcomposite-dev{a} libxcursor-dev{a} libxdamage-dev{a}
              libxdmcp-dev{a} libxdot4{a} libxerces-c-dev{a} libxerces-c3.2{a}
              libxext-dev{a} libxfixes-dev{a} libxft-dev{a} libxi-dev{a}
              libxinerama-dev{a} libxml2-dev{a} libxml2-utils{a} libxmu-dev{a}
              libxmu-headers{a} libxrandr-dev{a} libxrender-dev{a} libxshmfence-dev{a}
              libxss-dev{a} libxt-dev{a} libxvidcore4{a} libxxf86vm-dev{a}
              libyaml-cpp-dev{a} libyaml-cpp0.5v5{a} libyaml-dev{a} libzip-dev{a}
              libzip4{a} libzmq3-dev{a} libzmq5{a} libzvbi-common{a} libzvbi0{a}
              libzzip-0-13{a} mesa-common-dev{a} mesa-va-drivers{a}
              mesa-vdpau-drivers{a} mpi-default-bin{a} mpi-default-dev{a} odbcinst{a}
              odbcinst1debian2{a} opencv-data{a} openmpi-bin{a} openmpi-common{a}
              openni-utils{a} pkg-config{a} proj-bin{a} proj-data{a}
              protobuf-compiler{a} pyqt5-dev{a} python-asn1crypto{a} python-attr{a}
              python-autobahn{a} python-automat{a}
              python-backports.functools-lru-cache{a} python-cairo{a} python-cbor{a}
              python-cffi-backend{a} python-click{a} python-colorama{a}
              python-constantly{a} python-cryptography{a} python-cycler{a}
              python-defusedxml{a} python-dev{a} python-empy{a} python-enum34{a}
              python-gnupg{a} python-hyperlink{a} python-idna{a} python-incremental{a}
              python-ipaddress{a} python-lz4{a} python-matplotlib{a}
              python-matplotlib-data{a} python-mpi4py{a} python-nacl{a}
              python-netifaces{a} python-nose{a} python-numpy{a} python-opencv{a}
              python-opengl{a} python-openssl{a} python-pam{a} python-paramiko{a}
              python-psutil{a} python-pyasn1{a} python-pyasn1-modules{a}
              python-pycryptodome{a} python-pydot{a} python-pyqt5{a}
              python-pyqt5.qtopengl{a} python-pyqt5.qtsvg{a} python-pyqt5.qtwebkit{a}
              python-qrcode{a} python-rospkg{a} python-serial{a}
              python-service-identity{a} python-sip{a} python-sip-dev{a}
              python-snappy{a} python-subprocess32{a} python-trie{a} python-twisted{a}
              python-twisted-bin{a} python-twisted-core{a} python-txaio{a} python-tz{a}
              python-u-msgpack{a} python-ubjson{a} python-vtk6{a} python-wsaccel{a}
              python-wxgtk3.0{a} python-wxtools{a} python-wxversion{a}
              python-zope.interface{a} python2.7-dev{a} python3-dev{a}
              python3-distutils{a} python3-lib2to3{a} python3.6-dev{a} qt5-assistant{a}
              qt5-qmake{a} qt5-qmake-bin{a} qt5-qmltooling-plugins{a} qtbase5-dev{a}
              qtbase5-dev-tools{a} qtdeclarative5-dev{a} qttools5-dev{a}
              qttools5-dev-tools{a} qttools5-private-dev{a} rake{a}
              ros-melodic-actionlib{a} ros-melodic-actionlib-msgs{a}
              ros-melodic-actionlib-tutorials{a} ros-melodic-angles{a}
              ros-melodic-bond{a} ros-melodic-bond-core{a} ros-melodic-bondcpp{a}
              ros-melodic-bondpy{a} ros-melodic-camera-calibration{a}
              ros-melodic-camera-calibration-parsers{a}
              ros-melodic-camera-info-manager{a} ros-melodic-catkin{a}
              ros-melodic-class-loader{a} ros-melodic-cmake-modules{a}
              ros-melodic-common-msgs{a} ros-melodic-common-tutorials{a}
              ros-melodic-compressed-depth-image-transport{a}
              ros-melodic-compressed-image-transport{a} ros-melodic-control-msgs{a}
              ros-melodic-control-toolbox{a} ros-melodic-controller-interface{a}
              ros-melodic-controller-manager{a} ros-melodic-controller-manager-msgs{a}
              ros-melodic-cpp-common{a} ros-melodic-cv-bridge{a}
              ros-melodic-depth-image-proc{a} ros-melodic-desktop{a}
              ros-melodic-desktop-full ros-melodic-diagnostic-aggregator{a}
              ros-melodic-diagnostic-analysis{a}
              ros-melodic-diagnostic-common-diagnostics{a}
              ros-melodic-diagnostic-msgs{a} ros-melodic-diagnostic-updater{a}
              ros-melodic-diagnostics{a} ros-melodic-diff-drive-controller{a}
              ros-melodic-dynamic-reconfigure{a} ros-melodic-eigen-conversions{a}
              ros-melodic-executive-smach{a} ros-melodic-filters{a}
              ros-melodic-forward-command-controller{a} ros-melodic-gazebo-dev{a}
              ros-melodic-gazebo-msgs{a} ros-melodic-gazebo-plugins{a}
              ros-melodic-gazebo-ros{a} ros-melodic-gazebo-ros-control{a}
              ros-melodic-gazebo-ros-pkgs{a} ros-melodic-gencpp{a}
              ros-melodic-geneus{a} ros-melodic-genlisp{a} ros-melodic-genmsg{a}
              ros-melodic-gennodejs{a} ros-melodic-genpy{a} ros-melodic-geometry{a}
              ros-melodic-geometry-msgs{a} ros-melodic-geometry-tutorials{a}
              ros-melodic-gl-dependency{a} ros-melodic-hardware-interface{a}
              ros-melodic-image-common{a} ros-melodic-image-geometry{a}
              ros-melodic-image-pipeline{a} ros-melodic-image-proc{a}
              ros-melodic-image-publisher{a} ros-melodic-image-rotate{a}
              ros-melodic-image-transport{a} ros-melodic-image-transport-plugins{a}
              ros-melodic-image-view{a} ros-melodic-interactive-marker-tutorials{a}
              ros-melodic-interactive-markers{a} ros-melodic-joint-limits-interface{a}
              ros-melodic-joint-state-controller{a}
              ros-melodic-joint-state-publisher{a} ros-melodic-kdl-conversions{a}
              ros-melodic-kdl-parser{a} ros-melodic-kdl-parser-py{a}
              ros-melodic-laser-assembler{a} ros-melodic-laser-filters{a}
              ros-melodic-laser-geometry{a} ros-melodic-laser-pipeline{a}
              ros-melodic-librviz-tutorial{a} ros-melodic-map-msgs{a}
              ros-melodic-media-export{a} ros-melodic-message-filters{a}
              ros-melodic-message-generation{a} ros-melodic-message-runtime{a}
              ros-melodic-mk{a} ros-melodic-nav-msgs{a} ros-melodic-nodelet{a}
              ros-melodic-nodelet-core{a} ros-melodic-nodelet-topic-tools{a}
              ros-melodic-nodelet-tutorial-math{a} ros-melodic-orocos-kdl{a}
              ros-melodic-pcl-conversions{a} ros-melodic-pcl-msgs{a}
              ros-melodic-pcl-ros{a} ros-melodic-perception{a}
              ros-melodic-perception-pcl{a} ros-melodic-pluginlib{a}
              ros-melodic-pluginlib-tutorials{a} ros-melodic-polled-camera{a}
              ros-melodic-position-controllers{a} ros-melodic-python-orocos-kdl{a}
              ros-melodic-python-qt-binding{a} ros-melodic-qt-dotgraph{a}
              ros-melodic-qt-gui{a} ros-melodic-qt-gui-cpp{a}
              ros-melodic-qt-gui-py-common{a} ros-melodic-qwt-dependency{a}
              ros-melodic-realtime-tools{a} ros-melodic-resource-retriever{a}
              ros-melodic-robot{a} ros-melodic-robot-state-publisher{a}
              ros-melodic-ros{a} ros-melodic-ros-base{a} ros-melodic-ros-comm{a}
              ros-melodic-ros-core{a} ros-melodic-ros-environment{a}
              ros-melodic-ros-tutorials{a} ros-melodic-rosbag{a}
              ros-melodic-rosbag-migration-rule{a} ros-melodic-rosbag-storage{a}
              ros-melodic-rosbash{a} ros-melodic-rosboost-cfg{a}
              ros-melodic-rosbuild{a} ros-melodic-rosclean{a} ros-melodic-rosconsole{a}
              ros-melodic-rosconsole-bridge{a} ros-melodic-roscpp{a}
              ros-melodic-roscpp-core{a} ros-melodic-roscpp-serialization{a}
              ros-melodic-roscpp-traits{a} ros-melodic-roscpp-tutorials{a}
              ros-melodic-roscreate{a} ros-melodic-rosgraph{a}
              ros-melodic-rosgraph-msgs{a} ros-melodic-roslang{a}
              ros-melodic-roslaunch{a} ros-melodic-roslib{a} ros-melodic-roslint{a}
              ros-melodic-roslisp{a} ros-melodic-roslz4{a} ros-melodic-rosmake{a}
              ros-melodic-rosmaster{a} ros-melodic-rosmsg{a} ros-melodic-rosnode{a}
              ros-melodic-rosout{a} ros-melodic-rospack{a} ros-melodic-rosparam{a}
              ros-melodic-rospy{a} ros-melodic-rospy-tutorials{a}
              ros-melodic-rosservice{a} ros-melodic-rostest{a} ros-melodic-rostime{a}
              ros-melodic-rostopic{a} ros-melodic-rosunit{a} ros-melodic-roswtf{a}
              ros-melodic-rqt-action{a} ros-melodic-rqt-bag{a}
              ros-melodic-rqt-bag-plugins{a} ros-melodic-rqt-common-plugins{a}
              ros-melodic-rqt-console{a} ros-melodic-rqt-dep{a}
              ros-melodic-rqt-graph{a} ros-melodic-rqt-gui{a}
              ros-melodic-rqt-gui-cpp{a} ros-melodic-rqt-gui-py{a}
              ros-melodic-rqt-image-view{a} ros-melodic-rqt-launch{a}
              ros-melodic-rqt-logger-level{a} ros-melodic-rqt-moveit{a}
              ros-melodic-rqt-msg{a} ros-melodic-rqt-nav-view{a}
              ros-melodic-rqt-plot{a} ros-melodic-rqt-pose-view{a}
              ros-melodic-rqt-publisher{a} ros-melodic-rqt-py-common{a}
              ros-melodic-rqt-py-console{a} ros-melodic-rqt-reconfigure{a}
              ros-melodic-rqt-robot-dashboard{a} ros-melodic-rqt-robot-monitor{a}
              ros-melodic-rqt-robot-plugins{a} ros-melodic-rqt-robot-steering{a}
              ros-melodic-rqt-runtime-monitor{a} ros-melodic-rqt-rviz{a}
              ros-melodic-rqt-service-caller{a} ros-melodic-rqt-shell{a}
              ros-melodic-rqt-srv{a} ros-melodic-rqt-tf-tree{a} ros-melodic-rqt-top{a}
              ros-melodic-rqt-topic{a} ros-melodic-rqt-web{a} ros-melodic-rviz{a}
              ros-melodic-rviz-plugin-tutorials{a} ros-melodic-rviz-python-tutorial{a}
              ros-melodic-self-test{a} ros-melodic-sensor-msgs{a}
              ros-melodic-shape-msgs{a} ros-melodic-simulators{a} ros-melodic-smach{a}
              ros-melodic-smach-msgs{a} ros-melodic-smach-ros{a} ros-melodic-smclib{a}
              ros-melodic-stage{a} ros-melodic-stage-ros{a} ros-melodic-std-msgs{a}
              ros-melodic-std-srvs{a} ros-melodic-stereo-image-proc{a}
              ros-melodic-stereo-msgs{a} ros-melodic-tf{a}
              ros-melodic-tf-conversions{a} ros-melodic-tf2{a} ros-melodic-tf2-eigen{a}
              ros-melodic-tf2-geometry-msgs{a} ros-melodic-tf2-kdl{a}
              ros-melodic-tf2-msgs{a} ros-melodic-tf2-py{a} ros-melodic-tf2-ros{a}
              ros-melodic-theora-image-transport{a} ros-melodic-topic-tools{a}
              ros-melodic-trajectory-msgs{a} ros-melodic-transmission-interface{a}
              ros-melodic-turtle-actionlib{a} ros-melodic-turtle-tf{a}
              ros-melodic-turtle-tf2{a} ros-melodic-turtlesim{a} ros-melodic-urdf{a}
              ros-melodic-urdf-parser-plugin{a} ros-melodic-urdf-sim-tutorial{a}
              ros-melodic-urdf-tutorial{a} ros-melodic-urdfdom-py{a}
              ros-melodic-vision-opencv{a}
              ros-melodic-visualization-marker-tutorials{a}
              ros-melodic-visualization-msgs{a} ros-melodic-visualization-tutorials{a}
              ros-melodic-viz{a} ros-melodic-webkit-dependency{a} ros-melodic-xacro{a}
              ros-melodic-xmlrpcpp{a} ruby{a} ruby-did-you-mean{a} ruby-minitest{a}
              ruby-net-telnet{a} ruby-power-assert{a} ruby-test-unit{a} ruby2.5{a}
              rubygems-integration{a} sbcl{a} sdformat-sdf{a} sip-dev{a} tcl-dev{a}
              tcl-vtk6{a} tcl8.6-dev{a} tk-dev{a} tk8.6-dev{a} ttf-dejavu-core{a}
              unixodbc-dev{a} uuid-dev{a} va-driver-all{a} vdpau-driver-all{a} vtk6{a}
              x11proto-composite-dev{a} x11proto-core-dev{a} x11proto-damage-dev{a}
              x11proto-dev{a} x11proto-fixes-dev{a} x11proto-input-dev{a}
              x11proto-randr-dev{a} x11proto-scrnsaver-dev{a} x11proto-xext-dev{a}
              x11proto-xf86vidmode-dev{a} x11proto-xinerama-dev{a}
              xorg-sgml-doctools{a} xtrans-dev{a} zlib1g-dev{a}
              0 packages upgraded, 935 newly installed, 0 to remove and 0 not upgraded.
              Need to get 450 MB of archives. After unpacking 2,082 MB will be used.
              libx11-xcb-dev : Depends: libx11-xcb1 (= 2:1.6.4-3ubuntu0.4) but 2:1.6.4-3ubuntu0.5 is installed
              libgpgme-dev : Depends: libgpgme11 (= 1.10.0-1ubuntu2) but 1.10.0-1ubuntu2.1 is installed
              libcurl4-gnutls-dev : Conflicts: libcurl4-openssl-dev but 7.58.0-2ubuntu3.22 is to be installed
              libcurl4-openssl-dev : Conflicts: libcurl4-gnutls-dev but 7.58.0-2ubuntu3.22 is to be installed
              libx11-dev : Depends: libx11-6 (= 2:1.6.4-3ubuntu0.4) but 2:1.6.4-3ubuntu0.5 is installed
              1.   freeglut3-dev [Not Installed]
              2.   libcairo2-dev [Not Installed]
              3.   libcurl4-gnutls-dev [Not Installed]
              4.   libegl1-mesa-dev [Not Installed]
              5.   libfltk1.3-dev [Not Installed]
              6.   libgazebo9-dev [Not Installed]
              7.   libgdk-pixbuf2.0-dev [Not Installed]
              8.   libgl1-mesa-dev [Not Installed]
              9.   libgles2-mesa-dev [Not Installed]
              10.  libglu1-mesa-dev [Not Installed]
              11.  libgpgme-dev [Not Installed]
              12.  libgtk2.0-dev [Not Installed]
              13.  libpango1.0-dev [Not Installed]
              14.  libpcl-dev [Not Installed]
              15.  libqt5opengl5-dev [Not Installed]
              16.  libqt5webkit5-dev [Not Installed]
              17.  libsimbody-dev [Not Installed]
              18.  libvtk6-dev [Not Installed]
              19.  libvtk6-qt-dev [Not Installed]
              20.  libx11-dev [Not Installed]
              21.  libx11-xcb-dev [Not Installed]
              22.  libxcomposite-dev [Not Installed]
              23.  libxcursor-dev [Not Installed]
              24.  libxdamage-dev [Not Installed]
              25.  libxext-dev [Not Installed]
              26.  libxfixes-dev [Not Installed]
              27.  libxft-dev [Not Installed]
              28.  libxi-dev [Not Installed]
              29.  libxinerama-dev [Not Installed]
              30.  libxmu-dev [Not Installed]
              31.  libxmu-headers [Not Installed]
              32.  libxrandr-dev [Not Installed]
              33.  libxrender-dev [Not Installed]
              34.  libxss-dev [Not Installed]
              35.  libxt-dev [Not Installed]
              36.  libxxf86vm-dev [Not Installed]
              37.  mesa-common-dev [Not Installed]
              38.  qtbase5-dev [Not Installed]
              39.  qtdeclarative5-dev [Not Installed]
              40.  qttools5-dev [Not Installed]
              41.  qttools5-private-dev [Not Installed]
              42.  ros-melodic-actionlib [Not Installed]
              43.  ros-melodic-actionlib-tutorials [Not Installed]
              44.  ros-melodic-common-tutorials [Not Installed]
              45.  ros-melodic-compressed-depth-image-transport [Not Installed]
              46.  ros-melodic-compressed-image-transport [Not Installed]
              47.  ros-melodic-control-toolbox [Not Installed]
              48.  ros-melodic-controller-manager [Not Installed]
              49.  ros-melodic-controller-manager-msgs [Not Installed]
              50.  ros-melodic-depth-image-proc [Not Installed]
              51.  ros-melodic-desktop [Not Installed]
              52.  ros-melodic-desktop-full [Not Installed]
              53.  ros-melodic-diagnostic-analysis [Not Installed]
              54.  ros-melodic-diagnostic-common-diagnostics [Not Installed]
              55.  ros-melodic-diagnostics [Not Installed]
              56.  ros-melodic-diff-drive-controller [Not Installed]
              57.  ros-melodic-dynamic-reconfigure [Not Installed]
              58.  ros-melodic-executive-smach [Not Installed]
              59.  ros-melodic-forward-command-controller [Not Installed]
              60.  ros-melodic-gazebo-dev [Not Installed]
              61.  ros-melodic-gazebo-plugins [Not Installed]
              62.  ros-melodic-gazebo-ros [Not Installed]
              63.  ros-melodic-gazebo-ros-control [Not Installed]
              64.  ros-melodic-gazebo-ros-pkgs [Not Installed]
              65.  ros-melodic-geometry [Not Installed]
              66.  ros-melodic-geometry-tutorials [Not Installed]
              67.  ros-melodic-image-pipeline [Not Installed]
              68.  ros-melodic-image-proc [Not Installed]
              69.  ros-melodic-image-publisher [Not Installed]
              70.  ros-melodic-image-rotate [Not Installed]
              71.  ros-melodic-image-transport-plugins [Not Installed]
              72.  ros-melodic-image-view [Not Installed]
              73.  ros-melodic-interactive-marker-tutorials [Not Installed]
              74.  ros-melodic-interactive-markers [Not Installed]
              75.  ros-melodic-joint-state-controller [Not Installed]
              76.  ros-melodic-laser-assembler [Not Installed]
              77.  ros-melodic-laser-filters [Not Installed]
              78.  ros-melodic-laser-geometry [Not Installed]
              79.  ros-melodic-laser-pipeline [Not Installed]
              80.  ros-melodic-librviz-tutorial [Not Installed]
              81.  ros-melodic-nodelet-core [Not Installed]
              82.  ros-melodic-nodelet-topic-tools [Not Installed]
              83.  ros-melodic-pcl-conversions [Not Installed]
              84.  ros-melodic-pcl-ros [Not Installed]
              85.  ros-melodic-perception [Not Installed]
              86.  ros-melodic-perception-pcl [Not Installed]
              87.  ros-melodic-position-controllers [Not Installed]
              88.  ros-melodic-realtime-tools [Not Installed]
              89.  ros-melodic-robot [Not Installed]
              90.  ros-melodic-robot-state-publisher [Not Installed]
              91.  ros-melodic-ros-base [Not Installed]
              92.  ros-melodic-ros-comm [Not Installed]
              93.  ros-melodic-ros-core [Not Installed]
              94.  ros-melodic-rosbag [Not Installed]
              95.  ros-melodic-rosbag-storage [Not Installed]
              96.  ros-melodic-rosmsg [Not Installed]
              97.  ros-melodic-rosnode [Not Installed]
              98.  ros-melodic-rosservice [Not Installed]
              99.  ros-melodic-rostopic [Not Installed]
              100. ros-melodic-roswtf [Not Installed]
              101. ros-melodic-rqt-action [Not Installed]
              102. ros-melodic-rqt-bag [Not Installed]
              103. ros-melodic-rqt-bag-plugins [Not Installed]
              104. ros-melodic-rqt-common-plugins [Not Installed]
              105. ros-melodic-rqt-console [Not Installed]
              106. ros-melodic-rqt-dep [Not Installed]
              107. ros-melodic-rqt-graph [Not Installed]
              108. ros-melodic-rqt-launch [Not Installed]
              109. ros-melodic-rqt-logger-level [Not Installed]
              110. ros-melodic-rqt-moveit [Not Installed]
              111. ros-melodic-rqt-msg [Not Installed]
              112. ros-melodic-rqt-nav-view [Not Installed]
              113. ros-melodic-rqt-plot [Not Installed]
              114. ros-melodic-rqt-pose-view [Not Installed]
              115. ros-melodic-rqt-publisher [Not Installed]
              116. ros-melodic-rqt-py-common [Not Installed]
              117. ros-melodic-rqt-reconfigure [Not Installed]
              118. ros-melodic-rqt-robot-dashboard [Not Installed]
              119. ros-melodic-rqt-robot-monitor [Not Installed]
              120. ros-melodic-rqt-robot-plugins [Not Installed]
              121. ros-melodic-rqt-robot-steering [Not Installed]
              122. ros-melodic-rqt-rviz [Not Installed]
              123. ros-melodic-rqt-service-caller [Not Installed]
              124. ros-melodic-rqt-srv [Not Installed]
              125. ros-melodic-rqt-tf-tree [Not Installed]
              126. ros-melodic-rqt-topic [Not Installed]
              127. ros-melodic-rviz [Not Installed]
              128. ros-melodic-rviz-plugin-tutorials [Not Installed]
              129. ros-melodic-rviz-python-tutorial [Not Installed]
              130. ros-melodic-simulators [Not Installed]
              131. ros-melodic-smach-ros [Not Installed]
              132. ros-melodic-stage [Not Installed]
              133. ros-melodic-stage-ros [Not Installed]
              134. ros-melodic-stereo-image-proc [Not Installed]
              135. ros-melodic-tf [Not Installed]
              136. ros-melodic-tf-conversions [Not Installed]
              137. ros-melodic-tf2-geometry-msgs [Not Installed]
              138. ros-melodic-tf2-kdl [Not Installed]
              139. ros-melodic-tf2-ros [Not Installed]
              140. ros-melodic-theora-image-transport [Not Installed]
              141. ros-melodic-turtle-actionlib [Not Installed]
              142. ros-melodic-turtle-tf [Not Installed]
              143. ros-melodic-turtle-tf2 [Not Installed]
              144. ros-melodic-urdf-sim-tutorial [Not Installed]
              145. ros-melodic-urdf-tutorial [Not Installed]
              146. ros-melodic-visualization-tutorials [Not Installed]
              147. ros-melodic-viz [Not Installed]
              148. tk-dev [Not Installed]
              149. tk8.6-dev [Not Installed]
                Leave the following dependencies unresolved:
              150. fluid recommends libfltk1.3-dev
              Accept this solution? [Y/n/q/?] n
              • 6270705966
                :-D @小鱼
                3.   libcurl4-openssl-dev [Not Installed]
                13.  libignition-fuel-tools1-dev [Not Installed]
                14.  libpango1.0-dev [Not Installed]
                15.  libpcl-dev [Not Installed]
                16.  libqt5opengl5-dev [Not Installed]
                17.  libqt5webkit5-dev [Not Installed]
                18.  libsimbody-dev [Not Installed]
                19.  libvtk6-dev [Not Installed]
                20.  libvtk6-qt-dev [Not Installed]
                21.  libx11-dev [Not Installed]
                22.  libx11-xcb-dev [Not Installed]
                23.  libxcomposite-dev [Not Installed]
                24.  libxcursor-dev [Not Installed]
                25.  libxdamage-dev [Not Installed]
                26.  libxext-dev [Not Installed]
                27.  libxfixes-dev [Not Installed]
                28.  libxft-dev [Not Installed]
                29.  libxi-dev [Not Installed]
                30.  libxinerama-dev [Not Installed]
                31.  libxmu-dev [Not Installed]
                32.  libxmu-headers [Not Installed]
                33.  libxrandr-dev [Not Installed]
                34.  libxrender-dev [Not Installed]
                35.  libxss-dev [Not Installed]
                36.  libxt-dev [Not Installed]
                37.  libxxf86vm-dev [Not Installed]
                38.  mesa-common-dev [Not Installed]
                39.  qtbase5-dev [Not Installed]
                40.  qtdeclarative5-dev [Not Installed]
                41.  qttools5-dev [Not Installed]
                42.  qttools5-private-dev [Not Installed]
                43.  ros-melodic-actionlib [Not Installed]
                44.  ros-melodic-actionlib-tutorials [Not Installed]
                45.  ros-melodic-common-tutorials [Not Installed]
                46.  ros-melodic-compressed-depth-image-transport [Not Installed]
                47.  ros-melodic-compressed-image-transport [Not Installed]
                48.  ros-melodic-control-toolbox [Not Installed]
                49.  ros-melodic-controller-manager [Not Installed]
                50.  ros-melodic-controller-manager-msgs [Not Installed]
                51.  ros-melodic-depth-image-proc [Not Installed]
                52.  ros-melodic-desktop [Not Installed]
                53.  ros-melodic-desktop-full [Not Installed]
                54.  ros-melodic-diagnostic-analysis [Not Installed]
                55.  ros-melodic-diagnostic-common-diagnostics [Not Installed]
                56.  ros-melodic-diagnostics [Not Installed]
                57.  ros-melodic-diff-drive-controller [Not Installed]
                58.  ros-melodic-dynamic-reconfigure [Not Installed]
                59.  ros-melodic-executive-smach [Not Installed]
                60.  ros-melodic-forward-command-controller [Not Installed]
                61.  ros-melodic-gazebo-dev [Not Installed]
                62.  ros-melodic-gazebo-plugins [Not Installed]
                63.  ros-melodic-gazebo-ros [Not Installed]
                64.  ros-melodic-gazebo-ros-control [Not Installed]
                65.  ros-melodic-gazebo-ros-pkgs [Not Installed]
                66.  ros-melodic-geometry [Not Installed]
                67.  ros-melodic-geometry-tutorials [Not Installed]
                68.  ros-melodic-image-pipeline [Not Installed]
                69.  ros-melodic-image-proc [Not Installed]
                70.  ros-melodic-image-publisher [Not Installed]
                71.  ros-melodic-image-rotate [Not Installed]
                72.  ros-melodic-image-transport-plugins [Not Installed]
                73.  ros-melodic-image-view [Not Installed]
                74.  ros-melodic-interactive-marker-tutorials [Not Installed]
                75.  ros-melodic-interactive-markers [Not Installed]
                76.  ros-melodic-joint-state-controller [Not Installed]
                77.  ros-melodic-laser-assembler [Not Installed]
                78.  ros-melodic-laser-filters [Not Installed]
                79.  ros-melodic-laser-geometry [Not Installed]
                80.  ros-melodic-laser-pipeline [Not Installed]
                81.  ros-melodic-librviz-tutorial [Not Installed]
                82.  ros-melodic-nodelet-core [Not Installed]
                83.  ros-melodic-nodelet-topic-tools [Not Installed]
                84.  ros-melodic-pcl-conversions [Not Installed]
                85.  ros-melodic-pcl-ros [Not Installed]
                86.  ros-melodic-perception [Not Installed]
                87.  ros-melodic-perception-pcl [Not Installed]
                88.  ros-melodic-position-controllers [Not Installed]
                89.  ros-melodic-realtime-tools [Not Installed]
                90.  ros-melodic-robot [Not Installed]
                91.  ros-melodic-robot-state-publisher [Not Installed]
                92.  ros-melodic-ros-base [Not Installed]
                93.  ros-melodic-ros-comm [Not Installed]
                94.  ros-melodic-ros-core [Not Installed]
                95.  ros-melodic-rosbag [Not Installed]
                96.  ros-melodic-rosbag-storage [Not Installed]
                97.  ros-melodic-rosmsg [Not Installed]
                98.  ros-melodic-rosnode [Not Installed]
                99.  ros-melodic-rosservice [Not Installed]
                100. ros-melodic-rostopic [Not Installed]
                101. ros-melodic-roswtf [Not Installed]
                102. ros-melodic-rqt-action [Not Installed]
                103. ros-melodic-rqt-bag [Not Installed]
                104. ros-melodic-rqt-bag-plugins [Not Installed]
                105. ros-melodic-rqt-common-plugins [Not Installed]
                106. ros-melodic-rqt-console [Not Installed]
                107. ros-melodic-rqt-dep [Not Installed]
                108. ros-melodic-rqt-graph [Not Installed]
                109. ros-melodic-rqt-launch [Not Installed]
                110. ros-melodic-rqt-logger-level [Not Installed]
                111. ros-melodic-rqt-moveit [Not Installed]
                112. ros-melodic-rqt-msg [Not Installed]
                113. ros-melodic-rqt-nav-view [Not Installed]
                114. ros-melodic-rqt-plot [Not Installed]
                115. ros-melodic-rqt-pose-view [Not Installed]
                116. ros-melodic-rqt-publisher [Not Installed]
                117. ros-melodic-rqt-py-common [Not Installed]
                118. ros-melodic-rqt-reconfigure [Not Installed]
                119. ros-melodic-rqt-robot-dashboard [Not Installed]
                120. ros-melodic-rqt-robot-monitor [Not Installed]
                121. ros-melodic-rqt-robot-plugins [Not Installed]
                122. ros-melodic-rqt-robot-steering [Not Installed]
                123. ros-melodic-rqt-rviz [Not Installed]
                124. ros-melodic-rqt-service-caller [Not Installed]
                125. ros-melodic-rqt-srv [Not Installed]
                126. ros-melodic-rqt-tf-tree [Not Installed]
                127. ros-melodic-rqt-topic [Not Installed]
                128. ros-melodic-rviz [Not Installed]
                129. ros-melodic-rviz-plugin-tutorials [Not Installed]
                130. ros-melodic-rviz-python-tutorial [Not Installed]
                131. ros-melodic-simulators [Not Installed]
                132. ros-melodic-smach-ros [Not Installed]
                133. ros-melodic-stage [Not Installed]
                134. ros-melodic-stage-ros [Not Installed]
                135. ros-melodic-stereo-image-proc [Not Installed]
                136. ros-melodic-tf [Not Installed]
                137. ros-melodic-tf-conversions [Not Installed]
                138. ros-melodic-tf2-geometry-msgs [Not Installed]
                139. ros-melodic-tf2-kdl [Not Installed]
                140. ros-melodic-tf2-ros [Not Installed]
                141. ros-melodic-theora-image-transport [Not Installed]
                142. ros-melodic-turtle-actionlib [Not Installed]
                143. ros-melodic-turtle-tf [Not Installed]
                144. ros-melodic-turtle-tf2 [Not Installed]
                145. ros-melodic-urdf-sim-tutorial [Not Installed]
                146. ros-melodic-urdf-tutorial [Not Installed]
                147. ros-melodic-visualization-tutorials [Not Installed]
                148. ros-melodic-viz [Not Installed]
                149. tk-dev [Not Installed]
                150. tk8.6-dev [Not Installed]
                151. fluid recommends libfltk1.3-dev
                Accept this solution? [Y/n/q/?] y
                0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                Need to get 0 B of archives. After unpacking 0 B will be used.
                  小鱼 技术大佬 @627070596
                  @627070596 ny不行,就n,ny 和 nnny 和 nnnny都试一试
                  • 6270705966
                    :-D @小鱼
                    [-]Result:code:2
                    [-]Result:code:2
                    • 6270705966
                      :-D @小鱼
                      @小鱼 成功了!谢谢大佬!
                        小鱼 技术大佬 @627070596
                        @627070596 代码格式整理下
                        • 小伊小 小伊 将这个主题转为问答主题,在
                        • 小伊小 小伊 将这个主题标记为已解决,在
