重要提示
ubuntu18.01安装ros1失败
hanxiaoyu@hanxiaoyu-virtual-machine:~$ wget http://fishros.com/install -O fishros && . fishros
--2023-02-27 09:01:19-- http://fishros.com/install
--2023-02-27 09:01:19-- http://fishros.com/install/
再次使用存在的到 fishros.com:80 的连接。
已发出 HTTP 请求,正在等待回应... 200 OK
2023-02-27 09:01:19 (92.6 MB/s) - 已保存 “fishros” [582/582])
[sudo] hanxiaoyu 的密码:
--2023-02-27 09:01:23-- http://fishros.com/install/install1s/tools/base.py
正在保存至: “/tmp/fishinstall/tools/base.py”/tmp/fishinstall/to 100%[===================>] 41.21K --.-KB/s 用时 0.06s
2023-02-27 09:01:23 (666 KB/s) - 已保存 “/tmp/fishinstall/tools/base.py” [42195/42195])
[-]Result:success基础检查通过...
---众多工具,等君来用---
[6]:一键安装:nodejs
[7]:一键安装:VsCode开发工具
[8]:一键安装:Docker
[10]:一键安装:微信(可以在Linux上使用的微信)
[77]:测试模式:运行自定义工具测试
请输入[]内的数字以选择:1
--2023-02-27 09:01:40-- http://fishros.com/install/install1s/tools/tool_install_ros.py
正在保存至: “/tmp/fishinstall/tools/tool_install_ros.py”/tmp/fishinstall/tools/tool_install_ros.py 100%[=================================================================================================>] 18.60K --.-KB/s 用时 0.02s
2023-02-27 09:01:40 (829 KB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_ros.py” [19050/19050])
--2023-02-27 09:01:40-- http://fishros.com/install/install1s/tools/tool_config_rosenv.py
正在保存至: “/tmp/fishinstall/tools/tool_config_rosenv.py”/tmp/fishinstall/tools/tool_config_rosenv.py 100%[=================================================================================================>] 2.40K --.-KB/s 用时 0.005s
2023-02-27 09:01:40 (517 KB/s) - 已保存 “/tmp/fishinstall/tools/tool_config_rosenv.py” [2457/2457])
--2023-02-27 09:01:40-- http://fishros.com/install/install1s/tools/tool_config_system_source.py
正在保存至: “/tmp/fishinstall/tools/tool_config_system_source.py”/tmp/fishinstall/tools/tool_config_system_sou 100%[=================================================================================================>] 7.33K --.-KB/s 用时 0.008s
2023-02-27 09:01:40 (880 KB/s) - 已保存 “/tmp/fishinstall/tools/tool_config_system_source.py” [7511/7511])
[1]:更换系统源再继续安装
[2]:不更换继续安装
请输入[]内的数字以选择:1
欢迎使用一键换源工具,本工具由[鱼香ROS]小鱼贡献..
请选择换源方式,如果不知道选什么请选2
[1]:仅更换系统源
[2]:更换系统源并清理第三方源
请输入[]内的数字以选择:1
[-]Result:success检测到当前系统架构为[amd64:bionic],正在为你更换对应源..
替换完成,尝试第一次更新....
[-]Result:success --upgradable’ 来查看它们。ase [4,680 B]搞定了,不信你看,累死宝宝了,还不快去给小鱼点个赞~
['忽略:1 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu bionic InRelease', '获取:2 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu bionic InRelease [4,680 B]', '命中:3 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu bionic Release', '命中:5 https://mirrors.ustc.edu.cn/ubuntu bionic InRelease', '命中:6 https://mirrors.ustc.edu.cn/ubuntu bionic-updates InRelease', '命中:7 https://mirrors.ustc.edu.cn/ubuntu bionic-backports InRelease', '命中:8 https://mirrors.ustc.edu.cn/ubuntu bionic-security InRelease', '已下载 4,680 B,耗时 1秒 (6,851 B/s)', '正在读取软件包列表...', '正在分析软件包的依赖关系树...', '正在读取状态信息...', '有 256 个软件包可以升级。请执行 ‘apt list --upgradable’ 来查看它们。']
镜像修复完成.....
[-]Result:success --upgradable’ 来查看它们。ase [4,680 B]Run CMD Task:[sudo apt-cache search curl ]
[-]Result:success ckage retrieves data from url-format files such as http://, ftp://, package:// file://, etc., and loads the data into memory.Run CMD Task:[sudo apt install curl -y]
[-]Result:code:100Run CMD Task:[sudo apt-cache search gnupg2 ]
[-]Result:success eplacement (dummy transitional package)Run CMD Task:[sudo apt install gnupg2 -y]
[-]Result:code:100Run CMD Task:[curl -s https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc | sudo apt-key add -]
[-]Result:success --upgradable’ 来查看它们。ase [4,680 B]Run CMD Task:[sudo apt-cache search ros-base ]
[-]Result:success xtends 'ros_core' and includes other basic functionalities like tf2 and urdf.ynamic reconfigure, nodelets, and pluginlib.恭喜,成功添加ROS源,接下来可以使用apt安装ROS或者使用[1]一键安装ROS安装!
[-]Result:success xtends 'ros_core' and includes other basic functionalities like tf2 and urdf.ynamic reconfigure, nodelets, and pluginlib.RUN Choose Task:[请输入括号内的数字]
[1]:melodic(ROS1)
[2]:bouncy(ROS2)
[3]:crystal(ROS2)
[4]:dashing(ROS2)
[5]:eloquent(ROS2)
请输入[]内的数字以选择:1
请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
[1]:melodic(ROS1)桌面版
[2]:melodic(ROS1)基础版(小)
请输入[]内的数字以选择:1
[-]Result:success end for Debian to keep your brain trainedsionRun CMD Task:[sudo apt install aptitude -y]
[-]Result:code:100Run CMD Task:[sudo apt-cache search aptitude ]
[-]Result:code:100Run CMD Task:[sudo apt install ros-melodic-desktop-full -y]
[-]Result:code:100Run CMD Task:[sudo apt-cache search python-catkin-tools ]
[-]Result:success for working with catkin.Run CMD Task:[sudo apt install python-catkin-tools -y]
[-]Result:code:100Run CMD Task:[sudo apt-cache search python-rosdep ]
[-]Result:success nager abstraction tool for ROSPython 2)Run CMD Task:[sudo apt install python-rosdep -y]
[-]Result:code:100Run CMD Task:[ls /opt/ros/melodic/setup.bash]
[-]Result:code:2欢迎加入机器人学习交流QQ群:686914208(入群口令:一键安装)
hanxiaoyu@hanxiaoyu-virtual-machine:~$ -
@2862281087 重启虚拟机电脑试一下
