    Debian10 安装ros1 noetic失败
    一键安装报错 debian10
    1.6k
    • 10480091971
      keep calm and carry on
      [-]Result:success end for Debian mirrorp your brain trainedsion
      [/]Get:7 https://mirrors.tuna.tsinghua.edu.cn/debian buster/main arm64 libsub-name-perl arm64 0.21-1+b3 [13.4 k[]Get:8 https://mirrors.tuna.tsinghua.edu.cn/debian buster/main arm64 libclass-accessor-perl all 0.51-1 [23.2 [-]Get:10 https://mirrors.tuna.tsinghua.edu.cn/debian buster/main arm64 libparse-debianchangelog-perl all 1.2.0[-]Result:success ...b10u2) ....provide /usr/bin/aptitude (aptitude) in auto mode
      [-]Result:success e and 6 not upgraded.
      Run CMD Task:[sudo apt install ros-noetic-desktop-full -y]
      Reading package lists... Done
      Building dependency tree
      E: Unable to locate package ros-noetic-desktop-full
      [-]Result:code:100
      Run CMD Task:[sudo apt-cache search python3-catkin-tools ]
      Run CMD Task:[sudo apt install python3-catkin-tools -y]
      []Get:7 https://mirrors.tuna.tsinghua.edu.cn/debian buster/main arm64 python3-docutils all 0.14+dfsg-4 [378 kB[|]Get:8 https://mirrors.tuna.tsinghua.edu.cn/debian buster/main arm64 python3-pyparsing all 2.2.0+dfsg1-2 [89.[-]Get:9 https://mirrors.tuna.tsinghua.edu.cn/debian buster/main arm64 python3-pygments all 2.3.1+dfsg-1+deb10u[|]update-alternatives: using /usr/share/docutils/scripts/python3/rst-buildhtml to provide /usr/bin/rst-buildht[-]update-alternatives: using /usr/share/docutils/scripts/python3/rst2html to provide /usr/bin/rst2html (rst2ht[/]update-alternatives: using /usr/share/docutils/scripts/python3/rst2html4 to provide /usr/bin/rst2html4 (rst2[]update-alternatives: using /usr/share/docutils/scripts/python3/rst2html5 to provide /usr/bin/rst2html5 (rst2[|]update-alternatives: using /usr/share/docutils/scripts/python3/rst2latex to provide /usr/bin/rst2latex (rst2[-]update-alternatives: using /usr/share/docutils/scripts/python3/rst2man to provide /usr/bin/rst2man (rst2man)[/]update-alternatives: using /usr/share/docutils/scripts/python3/rst2odt to provide /usr/bin/rst2odt (rst2odt)[]update-alternatives: using /usr/share/docutils/scripts/python3/rst2odt_prepstyles to provide /usr/bin/rst2od[|]update-alternatives: using /usr/share/docutils/scripts/python3/rst2pseudoxml to provide /usr/bin/rst2pseudox[-]update-alternatives: using /usr/share/docutils/scripts/python3/rst2s5 to provide /usr/bin/rst2s5 (rst2s5) in[/]update-alternatives: using /usr/share/docutils/scripts/python3/rst2xetex to provide /usr/bin/rst2xetex (rst2[]update-alternatives: using /usr/share/docutils/scripts/python3/rst2xml to provide /usr/bin/rst2xml (rst2xml)[|]update-alternatives: using /usr/share/docutils/scripts/python3/rstpep2html to provide /usr/bin/rstpep2html ([-]Result:success ...1) ...
      [-]Result:success anager abstraction tool for ROSPython 3)
      [-]Result:success -1) .....l.deb ....deb .....sdep all 0.22.2-1 [3532 B][52.6 kB]B]
      Run CMD Task:[ls /opt/ros/noetic/setup.bash]
      [-]Result:code:2
      [-]Result:code:2
        小鱼 技术大佬 @1048009197
        @1048009197 目前仅支持Ubuntu哈
        10480091971 1 条回复 最后回复 回复 引用 0
        • 10480091971
          keep calm and carry on @小鱼
          @小鱼 之前有安装过,但是安装的是ros-noetic-desktop版本
