    No module named 'ament_cmake_test'
    colcon colcontest
    • A
      曼森的林佳树甜甜甜
      <?xml version="1.0" encoding="UTF-8"?>
      <Site BuildName="(empty)"
      	BuildStamp="20230413-1424-Experimental"
      	Name="20"
      	Generator="ctest-3.16.3"
      	CompilerName="/usr/bin/c++"
      	CompilerVersion="9.4.0"
      	OSName="Linux"
      	Hostname="20"
      	OSRelease="5.15.0-69-generic"
      	OSVersion="#76~20.04.1-Ubuntu SMP Mon Mar 20 15:54:19 UTC 2023"
      	OSPlatform="x86_64"
      	Is64Bits="1"
      	VendorString="AuthenticAMD"
      	VendorID="Advanced Micro Devices"
      	FamilyID="25"
      	ModelID="80"
      	ProcessorCacheSize="512"
      	NumberOfLogicalCPU="16"
      	NumberOfPhysicalCPU="8"
      	TotalVirtualMemory="2047"
      	TotalPhysicalMemory="15398"
      	LogicalProcessorsPerPhysical="2"
      	ProcessorClockFrequency="3602.64"
      	<Testing>
      		<StartDateTime>Apr 13 22:24 CST</StartDateTime>
      		<StartTestTime>1681395895</StartTestTime>
      		<TestList>
      			<Test>./copyright</Test>
      			<Test>./cppcheck</Test>
      			<Test>./cpplint</Test>
      			<Test>./flake8</Test>
      			<Test>./lint_cmake</Test>
      			<Test>./pep257</Test>
      			<Test>./uncrustify</Test>
      			<Test>./xmllint</Test>
      		</TestList>
      		<Test Status="failed">
      			<Name>copyright</Name>
      			<Path>.</Path>
      			<FullName>./copyright</FullName>
      			<FullCommandLine>/home/liumuran/miniconda3/bin/python3 "-u" "/opt/ros/foxy/share/ament_cmake_test/cmake/run_test.py" "/home/liumuran/ros2_ws/build/scout_base/test_results/scout_base/copyright.xunit.xml" "--package-name" "scout_base" "--output-file" "/home/liumuran/ros2_ws/build/scout_base/ament_copyright/copyright.txt" "--command" "/opt/ros/foxy/bin/ament_copyright" "--xunit-file" "/home/liumuran/ros2_ws/build/scout_base/test_results/scout_base/copyright.xunit.xml"</FullCommandLine>
      			<Results>
      				<NamedMeasurement type="text/string" name="Exit Code">
      					<Value>Failed</Value>
      				</NamedMeasurement>
      				<NamedMeasurement type="text/string" name="Exit Value">
      					<Value>1</Value>
      				</NamedMeasurement>
      				<NamedMeasurement type="numeric/double" name="Execution Time">
      					<Value>0.00982445</Value>
      				</NamedMeasurement>
      				<NamedMeasurement type="numeric/double" name="Processors">
      					<Value>1</Value>
      				</NamedMeasurement>
      				<NamedMeasurement type="text/string" name="Completion Status">
      					<Value>Completed</Value>
      				</NamedMeasurement>
      				<NamedMeasurement type="text/string" name="Command Line">
      					<Value>/home/liumuran/miniconda3/bin/python3 "-u" "/opt/ros/foxy/share/ament_cmake_test/cmake/run_test.py" "/home/liumuran/ros2_ws/build/scout_base/test_results/scout_base/copyright.xunit.xml" "--package-name" "scout_base" "--output-file" "/home/liumuran/ros2_ws/build/scout_base/ament_copyright/copyright.txt" "--command" "/opt/ros/foxy/bin/ament_copyright" "--xunit-file" "/home/liumuran/ros2_ws/build/scout_base/test_results/scout_base/copyright.xunit.xml"</Value>
      				</NamedMeasurement>
      				<Measurement>
      					<Value>Traceback (most recent call last):
        File "/opt/ros/foxy/share/ament_cmake_test/cmake/run_test.py", line 19, in &lt;module&gt;
          import ament_cmake_test
      ModuleNotFoundError: No module named 'ament_cmake_test'
      </Value>
      				</Measurement>
      			</Results>
      			<Labels>
      				<Label>copyright</Label>
      				<Label>linter</Label>
      			</Labels>
      		</Test>
      			<Name>cppcheck</Name>
      			<Path>.</Path>
      			<FullName>./cppcheck</FullName>
      			<FullCommandLine>/home/liumuran/miniconda3/bin/python3 "-u" "/opt/ros/foxy/share/ament_cmake_test/cmake/run_test.py" "/home/liumuran/ros2_ws/build/scout_base/test_results/scout_base/cppcheck.xunit.xml" "--package-name" "scout_base" "--output-file" "/home/liumuran/ros2_ws/build/scout_base/ament_cppcheck/cppcheck.txt" "--command" "/opt/ros/foxy/bin/ament_cppcheck" "--xunit-file" "/home/liumuran/ros2_ws/build/scout_base/test_results/scout_base/cppcheck.xunit.xml" "--include_dirs" "/home/liumuran/ros2_ws/src/scout_ros2/scout_base/include"</FullCommandLine>
      			<Results>
      				</NamedMeasurement>
      					<Value>1</Value>
      				</NamedMeasurement>
      					<Value>0.00793413</Value>
      				</NamedMeasurement>
      					<Value>1</Value>
      				</NamedMeasurement>
      				</NamedMeasurement>
      					<Value>/home/liumuran/miniconda3/bin/python3 "-u" "/opt/ros/foxy/share/ament_cmake_test/cmake/run_test.py" "/home/liumuran/ros2_ws/build/scout_base/test_results/scout_base/cppcheck.xunit.xml" "--package-name" "scout_base" "--output-file" "/home/liumuran/ros2_ws/build/scout_base/ament_cppcheck/cppcheck.txt" "--command" "/opt/ros/foxy/bin/ament_cppcheck" "--xunit-file" "/home/liumuran/ros2_ws/build/scout_base/test_results/scout_base/cppcheck.xunit.xml" "--include_dirs" "/home/liumuran/ros2_ws/src/scout_ros2/scout_base/include"</Value>
      				</NamedMeasurement>
      				<Measurement>
      colcon test 报错。已检查已安装ament_cmake_test. 如何解决 谢谢
        小鱼 技术大佬 @andrew_liumuran
        @andrew_liumuran 输入python3,然后输入
        看看
