    小鱼的一键安装系列
    工具软件
    一键安装 使用指南
    63
    134
    1.1m
    • ruoshuierR
      ruoshuier
      [-]Result:code:100 trusty-security InRelease InReleaseges [624 kB]
      apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: 仓库 “http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu trusty Release” 没有 Release 文件。\n']
      [-]Result:success rovides abstract RPC (Remote Procedure Call) structure for higher level of robot operations for the ROS-based robots..b.
      [-]Result:success
      [-]Result:code:100 buntu trusty/main amd64 Packages [624 kB]
      apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: 仓库 “https://repo.huaweicloud.com/ros2/ubuntu trusty Release” 没有 Release 文件。\n']
      根据您的系统,为您推荐安装源为['http://packages.ros.org/ros/ubuntu/', 'http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu/']
      [-]Result:success
      [-]Result:code:100 trusty/main amd64 Packages [624 kB]
      根据您的系统,为您推荐安装源为['https://packages.ros.org/ros/ubuntu/', 'http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu/']
      [-]Result:success
      [-]Result:code:100 org) does not match target host name 'packages.ros.org'
      检测到发生证书校验错误['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: 仓库 “http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu trusty Release” 没有 Release 文件。\n', 'E: 仓库 “https://packages.ros.org/ros/ubuntu trusty Release” 没有 Release 文件。\n'],自动取消https校验,如有需要请手动删除:rm /etc/apt/apt.conf.d/99verify-peer.conf
      [-]Result:success
      Run CMD Task:[echo "Acquire { https::Verify-Peer false }" > /etc/apt/apt.conf.d/99verify-peer.conf]
      [-]Result:success
      apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: 仓库 “http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu trusty Release” 没有 Release 文件。\n', 'E: 仓库 “https://packages.ros.org/ros/ubuntu trusty Release” 没有 Release 文件。\n']
      [-]Result:success
      [-]Result:success
      四次换源后都失败了,请及时联系小鱼获取解决方案并处理!
      • 19756016221
        ╰╮o( ̄▽ ̄///)
        忽略‘fishros’(于目录‘/etc/apt/sources.list.d/’),鉴于它没有文件扩展名
        这样的情况应该怎么处理
        • 26683502092
          不懂装懂
          PermissionError: [Errno 13] Permission denied: '/home/xzb/.fishros/bin/my_noetic'
          包这个错怎么回事啊
          • 15379415801
            Uncle
            • 5722160925
              Mr. Lu
              我用的是ubuntu 18.04,需要安装melodic版本,为什么没有呢
                lsiyu7 @小鱼
                --2023-04-22 21:11:40-- http://fishros.com/install
                正在解析主机 fishros.com (fishros.com)... 198.18.0.239
                正在连接 fishros.com (fishros.com)|198.18.0.239|:80... 已连接。
                --2023-04-22 21:11:40-- http://fishros.com/install/
                再次使用存在的到 fishros.com:80 的连接。
                已发出 HTTP 请求,正在等待回应... 200 OK
                正在保存至: “fishros”
                fishros 100%[===================>] 582 --.-KB/s in 0s
                2023-04-22 21:11:40 (193 MB/s) - 已保存 “fishros” [582/582])
                .: 没有那个文件或目录: fishros
                • 20156952912
                  一半醒
                  [-]Result:code:100
                  [-]Result:code:100
                  [-]Result:code:2
                  [-]Result:code:2
                  hfc@hfc-virtual-machine:~$ clear
                  hfc@hfc-virtual-machine:~$ wget http://fishros.com/install -O fishros && . fishros
                  --2023-04-24 13:42:14-- http://fishros.com/install
                  --2023-04-24 13:42:14-- http://fishros.com/install/
                  正在保存至: “fishros”
                  2023-04-24 13:42:14 (206 MB/s) - 已保存 “fishros” [582/582])
                  --2023-04-24 13:42:15-- http://fishros.com/install/install1s/tools/base.py
                  /tmp/fishinstall/to 100%[===================>] 41.21K --.-KB/s 用时 0.07s
                  2023-04-24 13:42:15 (601 KB/s) - 已保存 “/tmp/fishinstall/tools/base.py” [42195/42195])
                  [-]Result:success
                  基础检查通过...
                  ---众多工具,等君来用---
                  [6]:一键安装:nodejs
                  [7]:一键安装:VsCode开发工具
                  [8]:一键安装:Docker
                  [10]:一键安装:微信(可以在Linux上使用的微信)
                  [77]:测试模式:运行自定义工具测试
                  请输入[]内的数字以选择:11
                  --2023-04-24 13:42:25-- http://fishros.com/install/install1s/tools/tool_install_ros_with_docker.py
                  长度: 11540 (11K) [application/octet-stream]
                  2023-04-24 13:42:25 (306 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_ros_with_docker.py” [11540/11540])
                  --2023-04-24 13:42:25-- http://fishros.com/install/install1s/tools/tool_install_vscode.py
                  长度: 1366 (1.3K) [application/octet-stream]
                  2023-04-24 13:42:25 (445 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_vscode.py” [1366/1366])
                  --2023-04-24 13:42:25-- http://fishros.com/install/install1s/tools/tool_install_docker.py
                  2023-04-24 13:42:25 (649 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_docker.py” [2882/2882])
                  [1]:noetic
                  [2]:humble
                  [3]:foxy
                  [4]:galactic
                  [5]:melodic
                  [6]:rolling
                  [7]:kinetic
                  [8]:eloquent
                  [9]:dashing
                  [10]:crystal
                  [11]:bouncy
                  [12]:ardent
                  [13]:lunar
                  [14]:indigo
                  请输入[]内的数字以选择:0
                  你选择退出。。。。
                  --2023-04-24 13:43:04-- http://fishros.com/install
                  --2023-04-24 13:43:04-- http://fishros.com/install/
                  正在保存至: “fishros”
                  2023-04-24 13:43:04 (177 MB/s) - 已保存 “fishros” [582/582])
                  --2023-04-24 13:43:04-- http://fishros.com/install/install1s/tools/base.py
                  /tmp/fishinstall/to 100%[===================>] 41.21K --.-KB/s 用时 0.1s
                  2023-04-24 13:43:05 (401 KB/s) - 已保存 “/tmp/fishinstall/tools/base.py” [42195/42195])
                  [-]Result:success
                  基础检查通过...
                  ---众多工具,等君来用---
                  [6]:一键安装:nodejs
                  [7]:一键安装:VsCode开发工具
                  [8]:一键安装:Docker
                  [77]:测试模式:运行自定义工具测试
                  请输入[]内的数字以选择:1
                  --2023-04-24 13:43:18-- http://fishros.com/install/install1s/tools/tool_install_ros.py
                  /tmp/fishinstall/to 100%[===================>] 18.60K --.-KB/s 用时 0.03s
                  2023-04-24 13:43:18 (538 KB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_ros.py” [19050/19050])
                  --2023-04-24 13:43:18-- http://fishros.com/install/install1s/tools/tool_config_rosenv.py
                  2023-04-24 13:43:18 (692 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_config_rosenv.py” [2457/2457])
                  --2023-04-24 13:43:18-- http://fishros.com/install/install1s/tools/tool_config_system_source.py
                  /tmp/fishinstall/to 100%[===================>] 7.33K --.-KB/s 用时 0s
                  2023-04-24 13:43:18 (1.27 GB/s) - 已保存 “/tmp/fishinstall/tools/tool_config_system_source.py” [7511/7511])
                  [1]:更换系统源再继续安装
                  [2]:不更换继续安装
                  请输入[]内的数字以选择:1
                  欢迎使用一键换源工具,本工具由[鱼香ROS]小鱼贡献..
                  请选择换源方式,如果不知道选什么请选2
                  [1]:仅更换系统源
                  [2]:更换系统源并清理第三方源
                  请输入[]内的数字以选择:2
                  [-]Result:success
                  删除一个资源文件
                  [-]Result:success
                  [-]Result:success
                  [-]Result:success
                  替换完成,尝试第一次更新....
                  搞定了,不信你看,累死宝宝了,还不快去给小鱼点个赞~
                  ['命中:1 https://mirrors.ustc.edu.cn/ubuntu bionic InRelease', '命中:2 https://mirrors.ustc.edu.cn/ubuntu bionic-updates InRelease', '命中:3 https://mirrors.ustc.edu.cn/ubuntu bionic-backports InRelease', '命中:4 https://mirrors.ustc.edu.cn/ubuntu bionic-security InRelease', '正在读取软件包列表...', '正在分析软件包的依赖关系树...', '正在读取状态信息...', '有 293 个软件包可以升级。请执行 ‘apt list --upgradable’ 来查看它们。']
                  镜像修复完成.....
                  [/]libcurl3-gnutls - easy-to-use client-side URL transfer library (GnuTLS flavou[/]libcurl4-gnutls-dev - development files and documentation for libcurl (GnuTLS[]libcurl4-nss-dev - development files and documentation for libcurl (NSS flavo[|]libcurl4-openssl-dev - development files and documentation for libcurl (OpenS[/]libstrongswan-extra-plugins - strongSwan utility and crypto library (extra pl[-]cl-curry-compose-reader-macros - Reader macros for function partial applicati[-]flickcurl-doc - utilities to call the Flickr API from command line - document[/]gnupg1 - GNU privacy guard - a PGP implementation (deprecated "classic" versi[|]golang-github-moul-http2curl-dev - Go package for convert Golang's http.Reque[|]kubuntu-wallpapers-bionic - Selection of classic KDE wallpapers for Bionic Be[-]libcupt4-2-downloadmethod-curl - flexible package manager -- libcurl download[|]libcurl-openssl1.0-dev - development files and documentation for libcurl (Ope[/]libflickcurl0-dbg - C library for accessing the Flickr API - debugging symbol[|]libghc-curl-doc - Documentation for the libcurl Haskell bindings; documentati[-]libghc-curl-prof - Profiling libraries for the libcurl Haskell bindings; prof[/]libghc-hxt-doc - collection of tools for processing XML with Haskell; documen[|]libghc-hxt-http-doc - Interface to native Haskell HTTP package HTTP; document[-]libghc-hxt-http-prof - Interface to native Haskell HTTP package HTTP; profili[/]libghc-hxt-prof - collection of tools for processing XML with Haskell; profil[]libresource-retriever-dev - Robot OS resource_retriever library - development[|]libwsman-curl-client-transport1 - Open Web Services Manager run-time librarie[-]Result:success age - all developer toolsnt filesMPD
                  [-]Result:code:100
                  [-]Result:code:100
                  [-]Result:code:2
                  [-]Result:code:2
                  导入密钥失败,开始更换导入方式并二次尝试...
                  []Executing: /tmp/apt-key-gpghome.JkqukE2oiT/gpg.1.sh --keyserver keyserver.ubu[-]Result:success
                  [-]Result:success
                  [|]获取:2 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu bionic InRelease [4,68[-]获取:3 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu bionic Release [3,798 B[/]获取:4 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu bionic Release.gpg [833[]获取:5 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu bionic/main amd64 Pack[|]获取:10 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu bionic/main amd64 Pack[-]Result:success --upgradable’ 来查看它们。
                  [/]ros-melodic-end-effector - End-Effector package: provides a ROS-based set of []ros-melodic-ros-base - A metapackage which extends ros_core and includes other basic non-robot tools like actionlib, dynamic reconfigure, nodelets, and plugi[|]ros-bouncy-ros-base - A package which extends 'ros_core' and includes other b[-]ros-crystal-ros-base - A package which extends 'ros_core' and includes other [/]ros-dashing-ros-base - A package which extends 'ros_core' and includes other []ros-eloquent-ros-base - A package which extends 'ros_core' and includes other[-]Result:success
                  [1]:melodic(ROS1)
                  [2]:bouncy(ROS2)
                  [3]:crystal(ROS2)
                  [4]:dashing(ROS2)
                  [5]:eloquent(ROS2)
                  请输入[]内的数字以选择:1
                  请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
                  [1]:melodic(ROS1)桌面版
                  [2]:melodic(ROS1)基础版(小)
                  请输入[]内的数字以选择:1
                  [|]aptitude-common - architecture independent files for the aptitude package man[-]aptitude-doc-en - English manual for aptitude, a terminal-based package manag[/]libcwidget-dev - high-level terminal interface library for C++ (development f[|]aptitude-doc-es - Spanish manual for aptitude, a terminal-based package manag[-]aptitude-doc-fi - Finnish manual for aptitude, a terminal-based package manag[/]aptitude-doc-fr - French manual for aptitude, a terminal-based package manage[]aptitude-doc-it - Italian manual for aptitude, a terminal-based package manag[|]aptitude-doc-ja - Japanese manual for aptitude, a terminal-based package mana[/]aptitude-doc-ru - Russian manual for aptitude, a terminal-based package manag[-]apticron-systemd - Simple tool to mail about pending package updates - system[-]gbrainy - brain teaser game and trainer to have fun and to keep your brain tr[-]Result:success end for Debian
                  [-]Result:code:100
                  [-]Result:code:100
                  [-]Result:code:100
                  [-]Result:code:100
                  [-]Result:code:100
                  [-]Result:code:2
                  [-]Result:code:2
                  20156952912 小鱼小 3 条回复 最后回复 回复 引用 0
                  • 20156952912
                    一半醒 @2015695291
                    @2015695291 ubuntu18.04一键安装ROS失败
                    • 20156952912
                      一半醒 @2015695291
                      @2015695291 这个应该怎么办?
                        小鱼 技术大佬 @2015695291
                        @2015695291 在 小鱼的一键安装系列 中说:
                        重启下电脑,或者搜一下这个
                        • 28420958182
                          Mata
                          28420958182 1 条回复 最后回复 回复 引用 0
                          • 28420958182
                            Mata @2842095818
                            @2842095818 why
                            • 小鱼小 小鱼 在 中锁定了该主题
