    navigation2 demo程序编译出差
    工具软件
    ros2 编译出错
    3.1k
    • vico1999V
      vico1999
      程序编译时,提示找不到部分hpp文件,不过我查看了一下,都是有点,这个问题困挠好久了。我用的是demo代码。我没有修改过
      ico@wp:~/fishbot_ws$ colcon build --packages-up-to fishbot_navigation2
      [0.594s] WARNING:colcon.colcon_core.package_selection:Some selected packages are already built in one or more underlay workspaces:
      'nav2_map_server' is in: /opt/ros/humble
      --allow-overriding nav2_map_server
      Starting >>> nav2_common
      Starting >>> nav_2d_msgs
      Finished <<< nav2_common [0.77s]
      Starting >>> nav2_msgs
      Starting >>> nav2_voxel_grid
      Finished <<< nav2_voxel_grid [0.60s]
      Finished <<< nav_2d_msgs [1.55s]
      Starting >>> dwb_msgs
      --- stderr: dwb_msgs
      In file included from /home/vico/fishbot_ws/build/dwb_msgs/rosidl_typesupport_fastrtps_cpp/dwb_msgs/msg/detail/dds_fastrtps/critic_score__type_support.cpp:4:
      /home/vico/fishbot_ws/build/dwb_msgs/rosidl_typesupport_fastrtps_cpp/dwb_msgs/msg/detail/critic_score__rosidl_typesupport_fastrtps_cpp.hpp:11:10: fatal error: dwb_msgs/msg/detail/critic_score__struct.hpp: 没有那个文件或目录
      11 | #include "dwb_msgs/msg/detail/critic_score__struct.hpp"
      compilation terminated.
      In file included from /home/vico/fishbot_ws/build/dwb_msgs/rosidl_typesupport_fastrtps_cpp/dwb_msgs/msg/detail/dds_fastrtps/local_plan_evaluation__type_support.cpp:4:
      /home/vico/fishbot_ws/build/dwb_msgs/rosidl_typesupport_fastrtps_cpp/dwb_msgs/msg/detail/local_plan_evaluation__rosidl_typesupport_fastrtps_cpp.hpp:11:10: fatal error: dwb_msgs/msg/detail/local_plan_evaluation__struct.hpp: 没有那个文件或目录
      11 | #include "dwb_msgs/msg/detail/local_plan_evaluation__struct.hpp"
      gmake[2]: *** [CMakeFiles/dwb_msgs__rosidl_typesupport_fastrtps_cpp.dir/build.make:223:CMakeFiles/dwb_msgs__rosidl_typesupport_fastrtps_cpp.dir/rosidl_typesupport_fastrtps_cpp/dwb_msgs/msg/detail/dds_fastrtps/critic_score__type_support.cpp.o] 错误 1
      gmake[2]: *** 正在等待未完成的任务....
      gmake[2]: *** [CMakeFiles/dwb_msgs__rosidl_typesupport_fastrtps_cpp.dir/build.make:237:CMakeFiles/dwb_msgs__rosidl_typesupport_fastrtps_cpp.dir/rosidl_typesupport_fastrtps_cpp/dwb_msgs/msg/detail/dds_fastrtps/local_plan_evaluation__type_support.cpp.o] 错误 1
      In file included from /home/vico/fishbot_ws/build/dwb_msgs/rosidl_typesupport_fastrtps_cpp/dwb_msgs/msg/detail/dds_fastrtps/trajectory2_d__type_support.cpp:4:
      /home/vico/fishbot_ws/build/dwb_msgs/rosidl_typesupport_fastrtps_cpp/dwb_msgs/msg/detail/trajectory2_d__rosidl_typesupport_fastrtps_cpp.hpp:11:10: fatal error: dwb_msgs/msg/detail/trajectory2_d__struct.hpp: 没有那个文件或目录
      11 | #include "dwb_msgs/msg/detail/trajectory2_d__struct.hpp"
        小鱼 技术大佬 @vico1999
        @vico1999 如非必要请使用二进制安装,将源码中navigation2相关包删掉即可。如果需要源码编译请保证
        1. 将系统中的navigation2 删掉
        sudo apt remove ros-<你的ROS版本>-nav2*
        1. 下载对应版本的源码
        • 29180954962
          天问 @小鱼
          @小鱼 我今天也遇到了类似问题,按照鱼哥的方法,卸载后重新安装源码,现在这个重复的问题已经解决了。但是又有新的问题出现,如下:
          设备:Ubuntu20.04 foxy
          编译程序:“基于ROS2实现的Fishbot机器人仿真及实体机器人”的源码
          执行了如下命令:
          命令1:git clone https://github.com/fishros/fishbot.git -b foxy
          成功克隆
          命令2:cd fishbot
          进入到工作空间
          命令3:rosdep install --from-paths src -y
          结果:#All required rosdeps installed successfully是成功的
          命令4:colcon build
          出现错误:
          287 | auto* p = CreateMaybeMessage<::cartographer::mapping::constraints::proto::ConstraintBuilderOptions>(GetArenaNoVirtual());
          /opt/ros/foxy/include/cartographer/mapping/proto/pose_graph_options.pb.h:287:103: error: expected primary-expression before ‘>’ token
          /opt/ros/foxy/include/cartographer/mapping/proto/pose_graph_options.pb.h: In member function ‘void cartographer::mapping::proto::PoseGraphOptions::set_allocated_constraint_builder_options(cartographer::mapping::constraints::proto::ConstraintBuilderOptions*)’:
          /opt/ros/foxy/include/cartographer/mapping/proto/pose_graph_options.pb.h:301:66: error: ‘GetOwnedMessage’ is not a member of ‘google::protobuf::internal’
          301 | constraint_builder_options = ::google::protobuf::internal::GetOwnedMessage(
          /opt/ros/foxy/include/cartographer/mapping/proto/pose_graph_options.pb.h: In member function ‘cartographer::mapping::optimization::proto::OptimizationProblemOptions* cartographer::mapping::proto::PoseGraphOptions::mutable_optimization_problem_options()’:
          /opt/ros/foxy/include/cartographer/mapping/proto/pose_graph_options.pb.h:363:15: error: ‘CreateMaybeMessage’ was not declared in this scope
          363 | auto* p = CreateMaybeMessage<::cartographer::mapping::optimization::proto::OptimizationProblemOptions>(GetArenaNoVirtual());
          /opt/ros/foxy/include/cartographer/mapping/proto/pose_graph_options.pb.h:363:106: error: expected primary-expression before ‘>’ token
          /opt/ros/foxy/include/cartographer/mapping/proto/pose_graph_options.pb.h: In member function ‘void cartographer::mapping::proto::PoseGraphOptions::set_allocated_optimization_problem_options(cartographer::mapping::optimization::proto::OptimizationProblemOptions*)’:
          /opt/ros/foxy/include/cartographer/mapping/proto/pose_graph_options.pb.h:377:68: error: ‘GetOwnedMessage’ is not a member of ‘google::protobuf::internal’
          377 | optimization_problem_options = ::google::protobuf::internal::GetOwnedMessage(
          In file included from /home/aq/Documents/ROS_2/fishbot/src/cartographer_core/cartographer_ros/cartographer_ros/./cartographer_ros/node_options.h:25,
          from /home/aq/Documents/ROS_2/fishbot/src/cartographer_core/cartographer_ros/cartographer_ros/./cartographer_ros/map_builder_bridge.h:29,
          from /home/aq/Documents/ROS_2/fishbot/src/cartographer_core/cartographer_ros/cartographer_ros/./cartographer_ros/node.h:31,
          from /home/aq/Documents/ROS_2/fishbot/src/cartographer_core/cartographer_ros/cartographer_ros/cartographer_ros/node.cc:17:
          /opt/ros/foxy/include/cartographer/mapping/proto/map_builder_options.pb.h: At global scope:
          /opt/ros/foxy/include/cartographer/mapping/proto/map_builder_options.pb.h:201:41: error: ‘CachedSize’ in namespace ‘google::protobuf::internal’ does not name a type; did you mean ‘ToCachedSize’?
          201 | mutable ::google::protobuf::internal::CachedSize cached_size;
          | ToCachedSize
          /opt/ros/foxy/include/cartographer/mapping/proto/map_builder_options.pb.h: In member function ‘virtual cartographer::mapping::proto::MapBuilderOptions* cartographer::mapping::proto::MapBuilderOptions::New() const’:
          /opt/ros/foxy/include/cartographer/mapping/proto/map_builder_options.pb.h:114:12: error: ‘CreateMaybeMessage’ was not declared in this scope
          114 | return CreateMaybeMessage<MapBuilderOptions>(NULL);
          /opt/ros/foxy/include/cartographer/mapping/proto/map_builder_options.pb.h:114:48: error: expected primary-expression before ‘>’ token
          /opt/ros/foxy/include/cartographer/mapping/proto/map_builder_options.pb.h: In member function ‘virtual cartographer::mapping::proto::MapBuilderOptions* cartographer::mapping::proto::MapBuilderOptions::New(google::protobuf::Arena*) const’:
          /opt/ros/foxy/include/cartographer/mapping/proto/map_builder_options.pb.h:118:12: error: ‘CreateMaybeMessage’ was not declared in this scope
          118 | return CreateMaybeMessage<MapBuilderOptions>(arena);
          /opt/ros/foxy/include/cartographer/mapping/proto/map_builder_options.pb.h:118:48: error: expected primary-expression before ‘>’ token
          /opt/ros/foxy/include/cartographer/mapping/proto/map_builder_options.pb.h: In member function ‘virtual int cartographer::mapping::proto::MapBuilderOptions::GetCachedSize() const’:
          /opt/ros/foxy/include/cartographer/mapping/proto/map_builder_options.pb.h:134:44: error: ‘cached_size’ was not declared in this scope
          134 | int GetCachedSize() const final { return cached_size.Get(); }
          /opt/ros/foxy/include/cartographer/mapping/proto/map_builder_options.pb.h: In member function ‘cartographer::mapping::proto::PoseGraphOptions* cartographer::mapping::proto::MapBuilderOptions::mutable_pose_graph_options()’:
          /opt/ros/foxy/include/cartographer/mapping/proto/map_builder_options.pb.h:280:15: error: ‘CreateMaybeMessage’ was not declared in this scope
          280 | auto* p = CreateMaybeMessage<::cartographer::mapping::proto::PoseGraphOptions>(GetArenaNoVirtual());
          /opt/ros/foxy/include/cartographer/mapping/proto/map_builder_options.pb.h:280:82: error: expected primary-expression before ‘>’ token
          /opt/ros/foxy/include/cartographer/mapping/proto/map_builder_options.pb.h: In member function ‘void cartographer::mapping::proto::MapBuilderOptions::set_allocated_pose_graph_options(cartographer::mapping::proto::PoseGraphOptions*)’:
          /opt/ros/foxy/include/cartographer/mapping/proto/map_builder_options.pb.h:294:58: error: ‘GetOwnedMessage’ is not a member of ‘google::protobuf::internal’
          294 | pose_graph_options = ::google::protobuf::internal::GetOwnedMessage(
          make[2]: *** [CMakeFiles/cartographer_ros.dir/build.make:76:CMakeFiles/cartographer_ros.dir/cartographer_ros/msg_conversion.cc.o] 错误 1
          make[2]: *** [CMakeFiles/cartographer_ros.dir/build.make:63:CMakeFiles/cartographer_ros.dir/cartographer_ros/map_builder_bridge.cc.o] 错误 1
          make[2]: *** [CMakeFiles/cartographer_ros.dir/build.make:89:CMakeFiles/cartographer_ros.dir/cartographer_ros/node.cc.o] 错误 1
          make[1]: *** [CMakeFiles/Makefile2:104:CMakeFiles/cartographer_ros.dir/all] 错误 2
          Failed <<< cartographer_ros [18.1s, exited with code 2]
          Summary: 36 packages finished [21.5s]
          1 package failed: cartographer_ros
          1 package had stderr output: cartographer_ros
          1 package not processed
          我应该如何解决,已经困在这两三天了😢
            小鱼 技术大佬 @2918095496
            @2918095496 建议切换 humble 版本,真机导航源码 foxy没适配
            • 29180954962
              天问 @小鱼
              好的,那我对应的Ubuntu版本也需要换是吧?
                小鱼 技术大佬 @2918095496
                @2918095496 是的
