ROS2-Control官方文档
推荐语:比ROS1更加完善的控制机制,小鱼有被惊艳到
地址:http://control.ros.org/getting_started.html其他地址
例程:https://github.com/ros-controls/ros2_control_demos
gazeo插件:https://github.com/ros-simulation/gazebo_ros2_control最近比较忙,等有时间把这部分文章也翻译成中文的,Mark一下先。
小 小伊 从 中的 学习资源 移动了该主题
我在Windows下尝试使用ros2_control这个工具包,在开始时我参考ros2_control官网上的步骤:The ros2_control framework is released for ROS 2 humble. To use it, you have to install
ros-humble-ros2-control
andros-humble-ros2-controllers
packages.想请教下,Windows下如何安装这个工具包?
@437985437
我尝试根据ros2_control官网使用ros2_control的源码编译安装,安装步骤如下:- 下载仓库源码
mkdir -p ~/ros2_ws/src
cd ~/ros2_ws/
wget https://raw.githubusercontent.com/ros-controls/control.ros.org/master/ros_controls.humble.repos
vcs import src < ros_controls.humble.repos
- 安装依赖
rosdep update --rosdistro=humble
rosdep install --from-paths src --ignore-src -r -y
- 执行
时,遇到以下问题:
ERROR: the following packages/stacks could not have their rosdep keys resolved to system dependencies: ros2_controllers_test_nodes: Unsupported OS [windows] ros2_control_demo_example_6: Unsupported OS [windows] ros2_control_demo_example_3: Unsupported OS [windows] control_toolbox: Unsupported OS [windows] position_controllers: Unsupported OS [windows] ros2_control_demo_example_1: Unsupported OS [windows] force_torque_sensor_broadcaster: Unsupported OS [windows] diff_drive_controller: Unsupported OS [windows] ros2_control_demo_example_8: Unsupported OS [windows] gripper_controllers: Unsupported OS [windows] ign_ros2_control: Unsupported OS [windows] ros2_control_demo_example_4: Unsupported OS [windows] bicycle_steering_controller: Unsupported OS [windows] tricycle_controller: Unsupported OS [windows] gz_ros2_control_tests: Unsupported OS [windows] gazebo_ros2_control: Unsupported OS [windows] joint_trajectory_controller: Unsupported OS [windows] ros2_control_demo_example_9: Unsupported OS [windows] controller_manager: Unsupported OS [windows] ros2_control_demo_example_2: Unsupported OS [windows] ros2_control_demo_example_7: Unsupported OS [windows] imu_sensor_broadcaster: Unsupported OS [windows] ros2_control_demo_example_5: Unsupported OS [windows] effort_controllers: Unsupported OS [windows] forward_command_controller: Unsupported OS [windows] admittance_controller: Unsupported OS [windows] steering_controllers_library: Unsupported OS [windows] ros2_control_demo_example_12: Unsupported OS [windows] ackermann_steering_controller: Unsupported OS [windows] velocity_controllers: Unsupported OS [windows] gazebo_ros2_control_demos: Unsupported OS [windows] ign_ros2_control_demos: Unsupported OS [windows] kinematics_interface: Unsupported OS [windows] kinematics_interface_kdl: Unsupported OS [windows] ros2controlcli: Unsupported OS [windows] joint_state_broadcaster: Unsupported OS [windows] rqt_joint_trajectory_controller: Unsupported OS [windows] tricycle_steering_controller: Unsupported OS [windows] Continuing to install resolvable dependencies... #All required rosdeps installed successfully
- 请问是否说明ros2_control无法在windows下编译运行?或者需要哪些步骤?
- 下载仓库源码
