Warning: Invalid frame ID "back_wheel" passed to canTransform argument source_frame - frame does not exist
urdf文件
<?xml version="1.0" ?> <!-- =================================================================================== --> <!-- | This document was autogenerated by xacro from test03_my_car.xacro | --> <!-- | EDITING THIS FILE BY HAND IS NOT RECOMMENDED | --> <!-- =================================================================================== --> <!-- 组合小车底盘与摄像头与雷达 --> <robot name="my_car"> <!-- 圆柱惯性矩阵 --> <!-- 立方体惯性矩阵 --> <!-- 宏:黑色设置 --> <material name="black"> <color rgba="0.0 0.0 0.0 1.0"/> </material> <!-- 质量 --> <!-- 底盘 --> <link name="base_footprint"> <visual> <geometry> <sphere radius="0.001"/> </geometry> </visual> </link> <link name="base_link"> <visual> <geometry> <cylinder length="0.08" radius="0.1"/> </geometry> <origin rpy="0 0 0" xyz="0 0 0"/> <material name="yellow"> <color rgba="0.5 0.3 0.0 0.5"/> </material> </visual> <collision> <geometry> <cylinder length="0.08" radius="0.1"/> </geometry> <origin rpy="0 0 0" xyz="0 0 0"/> </collision> <inertial> <mass value="0.5"/> <inertia ixx="0.001516666666666667" ixy="0" ixz="0" iyy="0.001516666666666667" iyz="0" izz="0.0025000000000000005"/> </inertial> </link> <joint name="base_link2base_footprint" type="fixed"> <parent link="base_footprint"/> <child link="base_link"/> <origin xyz="0 0 0.055"/> </joint> <gazebo reference="base_link"> <material>Gazebo/Yellow</material> </gazebo> <!-- 质量 --> <link name="left_wheel"> <visual> <geometry> <cylinder length="0.015" radius="0.0325"/> </geometry> <origin rpy="1.5707963 0.0 0.0" xyz="0.0 0.0 0.0"/> <material name="black"/> </visual> <collision> <geometry> <cylinder length="0.015" radius="0.0325"/> </geometry> <origin rpy="1.5707963 0.0 0.0" xyz="0.0 0.0 0.0"/> </collision> <inertial> <mass value="0.05"/> <inertia ixx="1.4140625000000002e-05" ixy="0" ixz="0" iyy="1.4140625000000002e-05" iyz="0" izz="2.6406250000000005e-05"/> </inertial> </link> <joint name="left_wheel2base_link" type="continuous"> <parent link="base_link"/> <child link="left_wheel"/> <origin xyz="0 0.1 -0.0225"/> <axis xyz="0 1 0"/> </joint> <gazebo reference="left_wheel"> <material>Gazebo/Red</material> </gazebo> <link name="right_wheel"> <visual> <geometry> <cylinder length="0.015" radius="0.0325"/> </geometry> <origin rpy="1.5707963 0.0 0.0" xyz="0.0 0.0 0.0"/> <material name="black"/> </visual> <collision> <geometry> <cylinder length="0.015" radius="0.0325"/> </geometry> <origin rpy="1.5707963 0.0 0.0" xyz="0.0 0.0 0.0"/> </collision> <inertial> <mass value="0.05"/> <inertia ixx="1.4140625000000002e-05" ixy="0" ixz="0" iyy="1.4140625000000002e-05" iyz="0" izz="2.6406250000000005e-05"/> </inertial> </link> <joint name="right_wheel2base_link" type="continuous"> <parent link="base_link"/> <child link="right_wheel"/> <origin xyz="0 -0.1 -0.0225"/> <axis xyz="0 1 0"/> </joint> <gazebo reference="right_wheel"> <material>Gazebo/Red</material> </gazebo> <!-- 质量 --> <link name="front_wheel"> <visual> <geometry> <sphere radius="0.0075"/> </geometry> <origin rpy="0 0 0" xyz="0 0 0"/> <material name="black"/> </visual> <collision> <geometry> <sphere radius="0.0075"/> </geometry> <origin rpy="0 0 0" xyz="0 0 0"/> </collision> <inertial> <mass value="0.03"/> <inertia ixx="6.75e-07" ixy="0" ixz="0" iyy="6.75e-07" iyz="0" izz="6.75e-07"/> </inertial> </link> <joint name="front_wheel2base_link" type="continuous"> <parent link="base_link"/> <child link="front_wheel"/> <origin xyz="0.0925 0 -0.0475"/> <axis xyz="1 1 1"/> </joint> <gazebo reference="front_wheel"> <material>Gazebo/Red</material> </gazebo> <link name="back_wheel"> <visual> <geometry> <sphere radius="0.0075"/> </geometry> <origin rpy="0 0 0" xyz="0 0 0"/> <material name="black"/> </visual> <collision> <geometry> <sphere radius="0.0075"/> </geometry> <origin rpy="0 0 0" xyz="0 0 0"/> </collision> <inertial> <mass value="0.03"/> <inertia ixx="6.75e-07" ixy="0" ixz="0" iyy="6.75e-07" iyz="0" izz="6.75e-07"/> </inertial> </link> <joint name="back_wheel2base_link" type="continuous"> <parent link="base_link"/> <child link="back_wheel"/> <origin xyz="-0.0925 0 -0.0475"/> <axis xyz="1 1 1"/> </joint> <gazebo reference="back_wheel"> <material>Gazebo/Red</material> </gazebo> <!-- 摄像头安装的z坐标:底盘高度 / 2 + 摄像头高度 / 2 --> <!-- 摄像头质量 --> <!-- 摄像头关节以及link --> <link name="camera"> <visual> <geometry> <box size="0.01 0.025 0.025"/> </geometry> <origin rpy="0.0 0.0 0.0" xyz="0.0 0.0 0.0"/> <material name="black"/> </visual> <collision> <geometry> <box size="0.01 0.025 0.025"/> </geometry> <origin rpy="0.0 0.0 0.0" xyz="0.0 0.0 0.0"/> </collision> <inertial> <mass value="0.01"/> <inertia ixx="6.041666666666668e-07" ixy="0" ixz="0" iyy="6.041666666666668e-07" iyz="0" izz="1.041666666666667e-06"/> </inertial> </link> <joint name="camera2base_link" type="fixed"> <parent link="base_link"/> <child link="camera"/> <origin xyz="0.08 0.0 0.052500000000000005"/> </joint> <gazebo reference="camera"> <material>Gazebo/Blue</material> </gazebo> <!-- 支架安装的z坐标:底盘高度 / 2 + 支架高度 / 2 --> <!-- 支架质量 --> <link name="support"> <visual> <geometry> <cylinder length="0.15" radius="0.01"/> </geometry> <origin rpy="0.0 0.0 0.0" xyz="0.0 0.0 0.0"/> <material name="red"> <color rgba="0.8 0.2 0.0 0.8"/> </material> </visual> <collision> <geometry> <cylinder length="0.15" radius="0.01"/> </geometry> <origin rpy="0.0 0.0 0.0" xyz="0.0 0.0 0.0"/> </collision> <inertial> <mass value="0.02"/> <inertia ixx="3.8e-05" ixy="0" ixz="0" iyy="3.8e-05" iyz="0" izz="1.0000000000000002e-06"/> </inertial> </link> <joint name="support2base_link" type="fixed"> <parent link="base_link"/> <child link="support"/> <origin xyz="0.0 0.0 0.11499999999999999"/> </joint> <gazebo reference="support"> <material>Gazebo/White</material> </gazebo> <!-- 雷达安装的z坐标:支架高度 / 2 + 雷达高度 / 2 --> <!-- 雷达质量 --> <!-- 雷达关节以及link --> <link name="laser"> <visual> <geometry> <cylinder length="0.05" radius="0.03"/> </geometry> <origin rpy="0.0 0.0 0.0" xyz="0.0 0.0 0.0"/> <material name="black"/> </visual> <collision> <geometry> <cylinder length="0.05" radius="0.03"/> </geometry> <origin rpy="0.0 0.0 0.0" xyz="0.0 0.0 0.0"/> </collision> <inertial> <mass value="0.1"/> <inertia ixx="4.333333333333333e-05" ixy="0" ixz="0" iyy="4.333333333333333e-05" iyz="0" izz="4.4999999999999996e-05"/> </inertial> </link> <joint name="laser2support" type="fixed"> <parent link="support"/> <child link="laser"/> <origin xyz="0.0 0.0 0.1"/> </joint> <gazebo reference="laser"> <material>Gazebo/Black</material> </gazebo> <!-- 控制器 --> <gazebo> <plugin name='diff_drive' filename='libgazebo_ros_diff_drive.so'> <ros> <namespace>/</namespace> <remapping>cmd_vel:=cmd_vel</remapping> <remapping>odom:=odom</remapping> </ros> <update_rate>30</update_rate> <left_joint>left_wheel2base_link</left_joint> <right_joint>right_wheel2base_link</right_joint> <!-- kinematics --> <wheel_separation>0.2</wheel_separation> <wheel_diameter>0.065</wheel_diameter> <!-- limits --> <max_wheel_torque>20</max_wheel_torque> <max_wheel_acceleration>1.0</max_wheel_acceleration> <!-- output --> <publish_odom>true</publish_odom> <publish_odom_tf>true</publish_odom_tf> <publish_wheel_tf>false</publish_wheel_tf> <odometry_frame>odom</odometry_frame> <robot_base_frame>base_footprint</robot_base_frame> </plugin> <plugin name="fishbot_joint_state" filename="libgazebo_ros_joint_state_publisher.so"> <ros> <remapping>~/out:=joint_states</remapping> </ros> <update_rate>30</update_rate> <joint_name>left_wheel2base_link</joint_name> <joint_name>right_wheel2base_link</joint_name> </plugin> </gazebo> </robot>
launch代码
import os from launch import LaunchDescription from launch.actions import ExecuteProcess from launch.substitutions import LaunchConfiguration from launch_ros.actions import Node from launch_ros.substitutions import FindPackageShare def generate_launch_description(): package_name = 'fishbot_description' urdf_name = "test04.urdf" rviz_name = "demo01.rviz" robot_name_in_model = 'fishbot' ld = LaunchDescription() pkg_share = FindPackageShare(package=package_name).find(package_name) urdf_model_path = os.path.join(pkg_share, f'urdf/{urdf_name}') rviz_path_ = os.path.join(pkg_share, f'config/{rviz_name}') gazebo_world_path = os.path.join(pkg_share, 'world/box_house.world') # Start Gazebo server start_gazebo_cmd = ExecuteProcess( cmd=['gazebo', '--verbose', '-s', 'libgazebo_ros_factory.so',gazebo_world_path], output='screen') # Launch the robot spawn_entity_cmd = Node( package='gazebo_ros', executable='spawn_entity.py', arguments=['-entity', robot_name_in_model, '-file', urdf_model_path ], output='screen') # 添加机器人状态发布节点 robot_state_publisher_node = Node( package='robot_state_publisher', executable='robot_state_publisher', name='robot_state_publisher', arguments=[urdf_model_path] ) # 可选:用于控制关节运动的节点 joint_state_publisher_gui_node = Node( package='joint_state_publisher_gui', executable='joint_state_publisher_gui', name='joint_state_publisher_gui', arguments=[urdf_model_path] ) rviz2_node = Node( package='rviz2', executable='rviz2', name='rviz2', output='screen', arguments=['-d', rviz_path_] # arguments=['-d', rviz_path] ) ld.add_action(start_gazebo_cmd) ld.add_action(spawn_entity_cmd) ld.add_action(robot_state_publisher_node) # ld.add_action(joint_state_publisher_gui_node) ld.add_action(rviz2_node) return ld
运行launch文件后会出现警告是怎么回事呢 [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "back_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "front_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "back_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "front_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "back_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "front_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "back_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "front_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "back_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "front_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "back_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "front_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "back_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "front_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "back_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "front_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "back_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "front_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "back_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "front_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "back_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "front_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "back_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp [rviz2-4] Warning: Invalid frame ID "front_wheel" passed to canTransform argument source_frame - frame does not exist [rviz2-4] at line 133 in /tmp/binarydeb/ros-foxy-tf2-0.13.13/src/buffer_core.cpp
@271658536 在 Warning: Invalid frame ID "back_wheel" passed to canTransform argument source_frame - frame does not exist 中说:
在这里加入下front_wheel back_wheel
@小鱼 感谢小鱼大佬,问题得到解决
2 271658536 将这个主题标记为已解决,在
