    humble编译 FishBot主仓库-https://github.com/fishros/fishbot 代码报错
    ros2-humble fishbot cartographer
    407
    • 27616077292
      赤诚
      最后由 2761607729 编辑
      在编译到cartographer_ros功能包时报错
      [1.697s] WARNING:colcon.colcon_core.package_selection:Some selected packages are already built in one or more underlay workspaces:
      'cartographer_ros' is in: /home/hjq/fishbot/install/cartographer_ros, /opt/ros/humble
      --allow-overriding cartographer_ros
      Starting >>> cartographer_ros
      --- stderr: cartographer_ros
      /home/hjq/fishbot/src/cartographer_code/cartographer_ros/cartographer_ros/src/ros_log_sink.cpp: In member function ‘virtual void cartographer_ros::ScopedRosLogSink::send(google::LogSeverity, const char*, const char*, int, const tm*, const char*, size_t)’:
      /home/hjq/fishbot/src/cartographer_code/cartographer_ros/cartographer_ros/src/ros_log_sink.cpp:49:46: error: cannot convert ‘const tm* const’ to ‘const google::LogMessageTime&’
      49 | severity, GetBasename(filename), line, tm_time, message, message_len);
      | const tm* const
      In file included from /home/hjq/fishbot/src/cartographer_code/cartographer_ros/cartographer_ros/include/cartographer_ros/ros_log_sink.h:22,
      from /home/hjq/fishbot/src/cartographer_code/cartographer_ros/cartographer_ros/src/ros_log_sink.cpp:17:
      /usr/local/include/glog/logging.h:1777:53: note: initializing argument 4 of ‘static std::string google::LogSink::ToString(google::LogSeverity, const char*, int, const google::LogMessageTime&, const char*, size_t)’
      1777 | const LogMessageTime &logmsgtime,
      gmake[2]: *** [CMakeFiles/cartographer_ros.dir/build.make:188:CMakeFiles/cartographer_ros.dir/src/ros_log_sink.cpp.o] 错误 1
      gmake[2]: *** 正在等待未完成的任务....
      gmake[1]: *** [CMakeFiles/Makefile2:151:CMakeFiles/cartographer_ros.dir/all] 错误 2
      gmake: *** [Makefile:146:all] 错误 2****************************
      Failed <<< cartographer_ros [13.5s, exited with code 2]
      Summary: 0 packages finished [14.7s]
      1 package failed: cartographer_ros
      1 package had stderr output: cartographer_ros
        小鱼 技术大佬 @2761607729
        @2761607729 请直接二进制安装使用
        27616077292 1 条回复 最后回复 回复 引用 0
        • 27616077292
          赤诚 @小鱼
          @小鱼 具体怎么安装,是直接安装cartographer_ros这个功能包嘛
            小鱼 技术大佬 @2761607729
            @2761607729 对的 sudo apt 安装的就是二进制的
            • 27616077292
              赤诚 @小鱼
              @小鱼具体指令是什么呢
                小鱼 技术大佬 @2761607729
                @2761607729 https://fishros.org.cn/forum/topic/111/ros-ros2功能包在线索引网站 先到这里检索是否发布,发布了的就是
                sudo apt install ros-版本名称(如 humble)-xxx-xxx
                EG:
                sudo apt install ros-humble-ros-humble-cartographer
