    install (foxy)ROS2 failed with error
    动手学ROS2
    ros2-foxy ros2安装
    • 23364004982
      此生无悔
      [-]Result:success
      File "/tmp/fishinstall/install.py", line 123, in <module>
      File "/tmp/fishinstall/install.py", line 115, in main
      File "/tmp/fishinstall/tools/base.py", line 1297, in run_tool_file
      File "/tmp/fishinstall/tools/tool_install_ros.py", line 390, in run
      self.install_ros()
      File "/tmp/fishinstall/tools/tool_install_ros.py", line 383, in install_ros
      File "/tmp/fishinstall/tools/tool_install_ros.py", line 324, in choose_and_install_ros
      File "/tmp/fishinstall/tools/base.py", line 1236, in install_pkg
      for key in dic.keys():
        小鱼 技术大佬 @2336400498
        @2336400498 检查sudo apt update 结果是不是失败的
        5 1 条回复 最后回复 回复 引用 0
        • 5
          年少轻狂丶谈情不说爱 @小鱼
          @小鱼 $ sudo apt update
          Hit:1 https://download.docker.com/linux/ubuntu jammy InRelease
          Ign:2 http://packages.ros.org/ros/ubuntu jammy InRelease
          Err:3 http://packages.ros.org/ros/ubuntu jammy Release
          404 Not Found [IP: 64.50.233.100 80]
          Hit:4 https://packages.microsoft.com/repos/code stable InRelease
          Hit:5 http://security.ubuntu.com/ubuntu jammy-security InRelease
          Hit:6 http://ca.archive.ubuntu.com/ubuntu jammy InRelease
          Hit:7 http://archive.ubuntu.com/ubuntu jammy InRelease
          Hit:8 http://ca.archive.ubuntu.com/ubuntu jammy-updates InRelease
          Hit:9 http://ca.archive.ubuntu.com/ubuntu jammy-backports InRelease
          Hit:10 http://apt.puppet.com jammy InRelease
          Reading package lists... Done
          E: The repository 'http://packages.ros.org/ros/ubuntu jammy Release' does not have a Release file.
          N: Updating from such a repository can't be done securely, and is therefore disabled by default.
          N: See apt-secure(8) manpage for repository creation and user configuration details.
            小鱼 技术大佬 @573983271
            @573983271 在 install (foxy)ROS2 failed with error 中说:
            重新跑下一键换源试试
