    ros安装报错:文件尺寸不符
    一键安装报错 文件尺寸不符
    2.0k
    • 佳崴佳
      佳崴
      [1]:更换系统源再继续安装
      [2]:不更换继续安装
      请输入[]内的数字以选择:1
      欢迎使用一键更换系统源,本工具由作者小鱼提供
      欢迎使用一键换源工具,本工具由[鱼香ROS]小鱼贡献..
      请选择换源方式,如果不知道选什么请选2
      [1]:仅更换系统源
      [2]:更换系统源并清理第三方源
      请输入[]内的数字以选择:2
      [-]Result:success
      删除一个资源文件
      [-]Result:success
      [-]Result:success
      [-]Result:success
      替换完成,尝试第一次更新....
      [-]Result:success                            bionic-security InReleasee
      搞定了,不信你看,累死宝宝了,还不快去给小鱼点个赞~
      ['命中:1 https://mirrors.ustc.edu.cn/ubuntu bionic InRelease', '命中:2 https://mirrors.ustc.edu.cn/ubuntu bionic-updates InRelease', '命中:3 https://mirrors.ustc.edu.cn/ubuntu bionic-backports InRelease', '命中:4 https://mirrors.ustc.edu.cn/ubuntu bionic-security InRelease', '正在读取软件包列表...', '正在分析软件包的依赖关系树...', '正在读取状态信息...', '所有软件包均为最新。', '']
      镜像修复完成.....
      [/]libcurl3-gnutls - easy-to-use client-side URL transfer library (GnuTLS flavou[/]libcurl4-gnutls-dev - development files and documentation for libcurl (GnuTLS[\]libcurl4-nss-dev - development files and documentation for libcurl (NSS flavo[|]libcurl4-openssl-dev - development files and documentation for libcurl (OpenS[/]libstrongswan-extra-plugins - strongSwan utility and crypto library (extra pl[-]cl-curry-compose-reader-macros - Reader macros for function partial applicati[-]flickcurl-doc - utilities to call the Flickr API from command line - document[/]gnupg1 - GNU privacy guard - a PGP implementation (deprecated "classic" versi[|]golang-github-moul-http2curl-dev - Go package for convert Golang's http.Reque[|]kubuntu-wallpapers-bionic - Selection of classic KDE wallpapers for Bionic Be[-]libcupt4-2-downloadmethod-curl - flexible package manager -- libcurl download[|]libcurl-openssl1.0-dev - development files and documentation for libcurl (Ope[/]libflickcurl0-dbg - C library for accessing the Flickr API - debugging symbol[|]libghc-curl-doc - Documentation for the libcurl Haskell bindings; documentati[-]libghc-curl-prof - Profiling libraries for the libcurl Haskell bindings; prof[/]libghc-hxt-doc - collection of tools for processing XML with Haskell; documen[|]libghc-hxt-http-doc - Interface to native Haskell HTTP package HTTP; document[-]libghc-hxt-http-prof - Interface to native Haskell HTTP package HTTP; profili[/]libghc-hxt-prof - collection of tools for processing XML with Haskell; profil[\]libresource-retriever-dev - Robot OS resource_retriever library - development[|]libwsman-curl-client-transport1 - Open Web Services Manager run-time librarie[-]Result:success                           age - all developer toolsnt filesMPD
      [|]升级了 0 个软件包,新安装了 0 个软件包,要卸载 0 个软件包,有 0 个软件包未被[-]Result:success
      [-]Result:success
      [-]Result:success
      [|]获取:6 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu bionic InRelease [4,68[-]获取:7 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu bionic Release [3,798 B[/]获取:8 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu bionic Release.gpg [833[\]获取:9 http://192.168.111.241:8081/IXC34f298ef6923620bf4fc46a54e597ce4_115.15[|]错误:9 http://192.168.111.241:8081/IXC34f298ef6923620bf4fc46a54e597ce4_115.15[-]  文件尺寸不符(688715 != 688702)。您使用的镜像正在同步中? [IP: 192.168.111.2[|]获取:10 http://192.168.111.241:8081/IXC15e3e09df2d16278144094774ef94f01_115.1[-]错误:10 http://192.168.111.241:8081/IXC15e3e09df2d16278144094774ef94f01_115.1[/]  文件尺寸不符(787302 != 787291)。您使用的镜像正在同步中? [IP: 192.168.111.2[-]Result:code:100                           2 19:54:34 +00008fe6b7c70c9d5e9569
      你的系统当前apt存在问题,请先使用一键换源处理...若无法处理,请将下列错误信息告知小鱼...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: 无法下载 http://192.168.111.241:8081/IXC34f298ef6923620bf4fc46a54e597ce4_115.156.207.187/ros2/ubuntu/dists/bionic/main/binary-amd64/Packages.gz  文件尺寸不符(688715 != 688702)。您使用的镜像正在同步中? [IP: 192.168.111.241 8081]\n', '   Hashes of expected file:\n', '    - Filesize:688702 [weak]\n', '    - SHA256:75c42d5f2f962e23d64535858b45145af0fd067f950faca2adeacb73ef9982d7\n', '    - SHA1:2f6b2ef6486ec737c61f9fc4b911acac00903c9e [weak]\n', '    - MD5Sum:7372aaf1833a31a183882c1b9b260da0 [weak]\n', '   Release file created at: Fri, 27 May 2022 19:53:47 +0000\n', 'E: 无法下载 http://192.168.111.241:8081/IXC15e3e09df2d16278144094774ef94f01_115.156.207.187/ros/ubuntu/dists/bionic/main/binary-amd64/Packages.gz  文件尺寸不符(787302 != 787291)。您使用的镜像正在同步中? [IP: 192.168.111.241 8081]\n', '   Hashes of expected file:\n', '    - Filesize:787291 [weak]\n', '    - SHA256:f69b6678d08770ebfaaa2e3ad751761a91a0383e6ac2808fe6b7c70c9d5e9569\n', '    - SHA1:4a399f5647cb27d61e9d13038bf494b5e26cb4f4 [weak]\n', '    - MD5Sum:e0b19f2ede5f46562aa96b47c4719ab0 [weak]\n', '   Release file created at: Fri, 27 May 2022 19:54:34 +0000\n', 'E: 部分索引文件下载失败。如果忽略它们,那将转而使用旧的索引文件。\n']
      换源后更新失败,请联系小鱼处理!
      [-]Result:success                           e development metapackageKerberos
      请输入[]内的数字以选择:
      小鱼小 3 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @佳崴
        @佳崴 在 ros安装报错:文件尺寸不符 中说:
        请检查一下系统是否开了代理。
        佳崴佳 1 条回复 最后回复 回复 引用 0
        • 佳崴佳
          佳崴 @小鱼
          @小鱼 没有代理
            小鱼 技术大佬 @佳崴
            @佳崴 ping 一下这个ip看看 192.168.111.241
            • 佳崴佳
              佳崴 @小鱼
              ljw@ljw:~/catkin_ws$ ping 192.168.111.241
              PING 192.168.111.241 (192.168.111.241) 56(84) bytes of data.
              64 bytes from 192.168.111.241: icmp_seq=1 ttl=60 time=3.43 ms
              64 bytes from 192.168.111.241: icmp_seq=2 ttl=60 time=2.89 ms
              64 bytes from 192.168.111.241: icmp_seq=3 ttl=60 time=4.38 ms
              64 bytes from 192.168.111.241: icmp_seq=4 ttl=60 time=6.32 ms
              64 bytes from 192.168.111.241: icmp_seq=5 ttl=60 time=4.11 ms
              64 bytes from 192.168.111.241: icmp_seq=6 ttl=60 time=4.08 ms
              64 bytes from 192.168.111.241: icmp_seq=7 ttl=60 time=11.6 ms
              64 bytes from 192.168.111.241: icmp_seq=8 ttl=60 time=2.72 ms
              64 bytes from 192.168.111.241: icmp_seq=9 ttl=60 time=2.80 ms
              64 bytes from 192.168.111.241: icmp_seq=10 ttl=60 time=2.02 ms
              64 bytes from 192.168.111.241: icmp_seq=11 ttl=60 time=10.8 ms
              64 bytes from 192.168.111.241: icmp_seq=12 ttl=60 time=3.17 ms
              64 bytes from 192.168.111.241: icmp_seq=13 ttl=60 time=3.47 ms
              64 bytes from 192.168.111.241: icmp_seq=14 ttl=60 time=2.78 ms
              64 bytes from 192.168.111.241: icmp_seq=15 ttl=60 time=3.52 ms
              64 bytes from 192.168.111.241: icmp_seq=16 ttl=60 time=3.30 ms
              64 bytes from 192.168.111.241: icmp_seq=17 ttl=60 time=3.17 ms
              64 bytes from 192.168.111.241: icmp_seq=18 ttl=60 time=3.13 ms
              64 bytes from 192.168.111.241: icmp_seq=19 ttl=60 time=3.15 ms
              64 bytes from 192.168.111.241: icmp_seq=20 ttl=60 time=3.42 ms
              64 bytes from 192.168.111.241: icmp_seq=21 ttl=60 time=2.96 ms
              64 bytes from 192.168.111.241: icmp_seq=22 ttl=60 time=3.22 ms
              64 bytes from 192.168.111.241: icmp_seq=23 ttl=60 time=2.88 ms
              64 bytes from 192.168.111.241: icmp_seq=24 ttl=60 time=2.97 ms
              64 bytes from 192.168.111.241: icmp_seq=25 ttl=60 time=2.56 ms
              64 bytes from 192.168.111.241: icmp_seq=26 ttl=60 time=2.38 ms
              64 bytes from 192.168.111.241: icmp_seq=27 ttl=60 time=2.86 ms
              64 bytes from 192.168.111.241: icmp_seq=28 ttl=60 time=2.81 ms
              64 bytes from 192.168.111.241: icmp_seq=29 ttl=60 time=3.51 ms
              64 bytes from 192.168.111.241: icmp_seq=30 ttl=60 time=1.58 ms
              64 bytes from 192.168.111.241: icmp_seq=31 ttl=60 time=2.96 ms
              64 bytes from 192.168.111.241: icmp_seq=32 ttl=60 time=3.18 ms
              64 bytes from 192.168.111.241: icmp_seq=33 ttl=60 time=4.01 ms
              64 bytes from 192.168.111.241: icmp_seq=34 ttl=60 time=2.92 ms
              64 bytes from 192.168.111.241: icmp_seq=35 ttl=60 time=1.59 ms
              64 bytes from 192.168.111.241: icmp_seq=36 ttl=60 time=1.90 ms
              64 bytes from 192.168.111.241: icmp_seq=37 ttl=60 time=3.03 ms
              64 bytes from 192.168.111.241: icmp_seq=38 ttl=60 time=3.57 ms
              64 bytes from 192.168.111.241: icmp_seq=39 ttl=60 time=4.75 ms
              64 bytes from 192.168.111.241: icmp_seq=40 ttl=60 time=4.09 ms
              64 bytes from 192.168.111.241: icmp_seq=41 ttl=60 time=3.16 ms
              64 bytes from 192.168.111.241: icmp_seq=42 ttl=60 time=3.23 ms
              64 bytes from 192.168.111.241: icmp_seq=43 ttl=60 time=3.67 ms
              64 bytes from 192.168.111.241: icmp_seq=44 ttl=60 time=2.90 ms
              64 bytes from 192.168.111.241: icmp_seq=45 ttl=60 time=3.21 ms
              64 bytes from 192.168.111.241: icmp_seq=46 ttl=60 time=2.93 ms
              64 bytes from 192.168.111.241: icmp_seq=47 ttl=60 time=3.00 ms
              64 bytes from 192.168.111.241: icmp_seq=48 ttl=60 time=2.84 ms
              64 bytes from 192.168.111.241: icmp_seq=49 ttl=60 time=2.90 ms
              64 bytes from 192.168.111.241: icmp_seq=50 ttl=60 time=1.71 ms
              64 bytes from 192.168.111.241: icmp_seq=51 ttl=60 time=3.61 ms
              64 bytes from 192.168.111.241: icmp_seq=52 ttl=60 time=2.97 ms
              64 bytes from 192.168.111.241: icmp_seq=53 ttl=60 time=2.89 ms
              64 bytes from 192.168.111.241: icmp_seq=54 ttl=60 time=3.09 ms
              64 bytes from 192.168.111.241: icmp_seq=55 ttl=60 time=2.72 ms
              64 bytes from 192.168.111.241: icmp_seq=56 ttl=60 time=2.12 ms
              64 bytes from 192.168.111.241: icmp_seq=57 ttl=60 time=3.45 ms
              64 bytes from 192.168.111.241: icmp_seq=58 ttl=60 time=2.89 ms
              64 bytes from 192.168.111.241: icmp_seq=59 ttl=60 time=2.98 ms
              64 bytes from 192.168.111.241: icmp_seq=60 ttl=60 time=2.90 ms
              64 bytes from 192.168.111.241: icmp_seq=61 ttl=60 time=3.10 ms
              64 bytes from 192.168.111.241: icmp_seq=62 ttl=60 time=3.02 ms
              64 bytes from 192.168.111.241: icmp_seq=63 ttl=60 time=4.27 ms
              64 bytes from 192.168.111.241: icmp_seq=64 ttl=60 time=2.71 ms
              64 bytes from 192.168.111.241: icmp_seq=65 ttl=60 time=2.78 ms
              64 bytes from 192.168.111.241: icmp_seq=66 ttl=60 time=3.29 ms
              64 bytes from 192.168.111.241: icmp_seq=67 ttl=60 time=2.66 ms
              64 bytes from 192.168.111.241: icmp_seq=68 ttl=60 time=1.70 ms
              64 bytes from 192.168.111.241: icmp_seq=69 ttl=60 time=1.75 ms
              64 bytes from 192.168.111.241: icmp_seq=70 ttl=60 time=3.02 ms
              64 bytes from 192.168.111.241: icmp_seq=71 ttl=60 time=2.91 ms
              64 bytes from 192.168.111.241: icmp_seq=72 ttl=60 time=2.84 ms
              64 bytes from 192.168.111.241: icmp_seq=73 ttl=60 time=3.64 ms
              64 bytes from 192.168.111.241: icmp_seq=74 ttl=60 time=5.07 ms
              64 bytes from 192.168.111.241: icmp_seq=75 ttl=60 time=1.64 ms
              64 bytes from 192.168.111.241: icmp_seq=76 ttl=60 time=2.14 ms
              64 bytes from 192.168.111.241: icmp_seq=77 ttl=60 time=3.20 ms
              64 bytes from 192.168.111.241: icmp_seq=78 ttl=60 time=3.91 ms
              64 bytes from 192.168.111.241: icmp_seq=79 ttl=60 time=3.18 ms
              64 bytes from 192.168.111.241: icmp_seq=80 ttl=60 time=2.89 ms
              64 bytes from 192.168.111.241: icmp_seq=81 ttl=60 time=3.00 ms
              64 bytes from 192.168.111.241: icmp_seq=82 ttl=60 time=1.88 ms
              64 bytes from 192.168.111.241: icmp_seq=83 ttl=60 time=2.76 ms
              64 bytes from 192.168.111.241: icmp_seq=84 ttl=60 time=2.64 ms
              64 bytes from 192.168.111.241: icmp_seq=85 ttl=60 time=2.88 ms
              64 bytes from 192.168.111.241: icmp_seq=86 ttl=60 time=2.71 ms
              64 bytes from 192.168.111.241: icmp_seq=87 ttl=60 time=2.88 ms
              64 bytes from 192.168.111.241: icmp_seq=88 ttl=60 time=3.02 ms
              64 bytes from 192.168.111.241: icmp_seq=89 ttl=60 time=1.67 ms
              64 bytes from 192.168.111.241: icmp_seq=90 ttl=60 time=7.14 ms
              64 bytes from 192.168.111.241: icmp_seq=91 ttl=60 time=3.14 ms
              64 bytes from 192.168.111.241: icmp_seq=92 ttl=60 time=2.85 ms
              64 bytes from 192.168.111.241: icmp_seq=93 ttl=60 time=3.44 ms
              64 bytes from 192.168.111.241: icmp_seq=94 ttl=60 time=2.21 ms
              64 bytes from 192.168.111.241: icmp_seq=95 ttl=60 time=2.00 ms
              64 bytes from 192.168.111.241: icmp_seq=96 ttl=60 time=2.88 ms
              64 bytes from 192.168.111.241: icmp_seq=97 ttl=60 time=3.74 ms
              64 bytes from 192.168.111.241: icmp_seq=98 ttl=60 time=3.36 ms
              64 bytes from 192.168.111.241: icmp_seq=99 ttl=60 time=2.95 ms
              64 bytes from 192.168.111.241: icmp_seq=100 ttl=60 time=3.75 ms
              64 bytes from 192.168.111.241: icmp_seq=101 ttl=60 time=2.85 ms
              64 bytes from 192.168.111.241: icmp_seq=102 ttl=60 time=1.52 ms
              64 bytes from 192.168.111.241: icmp_seq=103 ttl=60 time=3.06 ms
              64 bytes from 192.168.111.241: icmp_seq=104 ttl=60 time=1.48 ms
              64 bytes from 192.168.111.241: icmp_seq=105 ttl=60 time=3.15 ms
              64 bytes from 192.168.111.241: icmp_seq=106 ttl=60 time=1.81 ms
              64 bytes from 192.168.111.241: icmp_seq=107 ttl=60 time=3.41 ms
              64 bytes from 192.168.111.241: icmp_seq=108 ttl=60 time=2.67 ms
              64 bytes from 192.168.111.241: icmp_seq=109 ttl=60 time=2.93 ms
              64 bytes from 192.168.111.241: icmp_seq=110 ttl=60 time=2.94 ms
              64 bytes from 192.168.111.241: icmp_seq=111 ttl=60 time=2.73 ms
              64 bytes from 192.168.111.241: icmp_seq=112 ttl=60 time=4.03 ms
              64 bytes from 192.168.111.241: icmp_seq=113 ttl=60 time=2.71 ms
              64 bytes from 192.168.111.241: icmp_seq=114 ttl=60 time=3.01 ms
              64 bytes from 192.168.111.241: icmp_seq=115 ttl=60 time=2.41 ms
              64 bytes from 192.168.111.241: icmp_seq=116 ttl=60 time=2.17 ms
              64 bytes from 192.168.111.241: icmp_seq=117 ttl=60 time=2.49 ms
              64 bytes from 192.168.111.241: icmp_seq=118 ttl=60 time=3.25 ms
              64 bytes from 192.168.111.241: icmp_seq=119 ttl=60 time=2.80 ms
              64 bytes from 192.168.111.241: icmp_seq=120 ttl=60 time=2.71 ms
              64 bytes from 192.168.111.241: icmp_seq=121 ttl=60 time=6.30 ms
              64 bytes from 192.168.111.241: icmp_seq=122 ttl=60 time=4.63 ms
              64 bytes from 192.168.111.241: icmp_seq=123 ttl=60 time=2.76 ms
              64 bytes from 192.168.111.241: icmp_seq=124 ttl=60 time=3.00 ms
              64 bytes from 192.168.111.241: icmp_seq=125 ttl=60 time=1.65 ms
              64 bytes from 192.168.111.241: icmp_seq=126 ttl=60 time=9.61 ms
              64 bytes from 192.168.111.241: icmp_seq=127 ttl=60 time=2.75 ms
              64 bytes from 192.168.111.241: icmp_seq=128 ttl=60 time=3.61 ms
              64 bytes from 192.168.111.241: icmp_seq=129 ttl=60 time=3.23 ms
              64 bytes from 192.168.111.241: icmp_seq=130 ttl=60 time=3.52 ms
              64 bytes from 192.168.111.241: icmp_seq=131 ttl=60 time=2.80 ms
              64 bytes from 192.168.111.241: icmp_seq=132 ttl=60 time=1.56 ms
              64 bytes from 192.168.111.241: icmp_seq=133 ttl=60 time=3.18 ms
              64 bytes from 192.168.111.241: icmp_seq=134 ttl=60 time=2.31 ms
              64 bytes from 192.168.111.241: icmp_seq=135 ttl=60 time=2.73 ms
              64 bytes from 192.168.111.241: icmp_seq=136 ttl=60 time=2.41 ms
              64 bytes from 192.168.111.241: icmp_seq=137 ttl=60 time=2.93 ms
              64 bytes from 192.168.111.241: icmp_seq=138 ttl=60 time=3.01 ms
              64 bytes from 192.168.111.241: icmp_seq=139 ttl=60 time=2.79 ms
              64 bytes from 192.168.111.241: icmp_seq=140 ttl=60 time=2.96 ms
              64 bytes from 192.168.111.241: icmp_seq=141 ttl=60 time=2.88 ms
              64 bytes from 192.168.111.241: icmp_seq=142 ttl=60 time=3.15 ms
              64 bytes from 192.168.111.241: icmp_seq=143 ttl=60 time=2.84 ms
              64 bytes from 192.168.111.241: icmp_seq=144 ttl=60 time=3.57 ms
              64 bytes from 192.168.111.241: icmp_seq=145 ttl=60 time=2.83 ms
              64 bytes from 192.168.111.241: icmp_seq=146 ttl=60 time=1.62 ms
              64 bytes from 192.168.111.241: icmp_seq=147 ttl=60 time=3.88 ms
              64 bytes from 192.168.111.241: icmp_seq=148 ttl=60 time=3.08 ms
              64 bytes from 192.168.111.241: icmp_seq=149 ttl=60 time=3.34 ms
              64 bytes from 192.168.111.241: icmp_seq=150 ttl=60 time=2.72 ms
              64 bytes from 192.168.111.241: icmp_seq=151 ttl=60 time=1.83 ms
              64 bytes from 192.168.111.241: icmp_seq=152 ttl=60 time=3.95 ms
              64 bytes from 192.168.111.241: icmp_seq=153 ttl=60 time=3.24 ms
              ^C
              --- 192.168.111.241 ping statistics ---
              153 packets transmitted, 153 received, 0% packet loss, time 152221ms
              rtt min/avg/max/mdev = 1.484/3.172/11.616/1.349 ms
                小鱼 技术大佬 @佳崴
                真的有这个ip,你看一下你的报错,去请求这个ip拿数据了,这个ip是一个局域网ip,校园网之类的,建议你换个网络试试,然后仔细检查下是不是经过什么代理之类的了,代理的地址应该就是这个ip。
                • 佳崴佳
                  佳崴
                  @September 可能是代理的问题,因为我用的是校园网,但是我是把下载源换成了阿里源,然后用ROS wiki 上的正常安装步骤安装完了
                    小鱼 技术大佬 @佳崴
                    @佳崴 感谢反馈,是阿里云的ROS源吗?方便给个地址,我加到一键安装里。
                    • 佳崴佳
                      佳崴 @小鱼
                      @小鱼 只是ubuntu的下载源
                      https://developer.aliyun.com/mirror/ubuntu?spm=a2c6h.13651102.0.0.5bc71b11fSxLI9
                        小鱼 技术大佬 @佳崴
                        @佳崴 哈哈,那就很奇怪了,因为你报错的是ROS的源😂
