    使用colcon构建工作区时出错
    动手学ROS2
    环境ubuntu22.04 colcon build
      枯叶流水
      最后由 280390510 编辑
      我在跟着例程文档使用colcon构建工作区进行学习,在进行到colcon build时发生了如下错误:
      WARNING: given --rosdistro melodic but ROS_DISTRO is "humble". Ignoring environment.
      yyh@yyh-device:~/ros_dev_ws$ colcon build
      [0.193s] WARNING:colcon.colcon_core.package_selection:Some selected packages are already built in one or more underlay workspaces:
      	'turtlesim' is in: /opt/ros/humble
      	--allow-overriding turtlesim
      Starting >>> turtlesim
      --- stderr: turtlesim
      /home/yyh/ros_dev_ws/src/ros_tutorials/turtlesim/tutorials/teleop_turtle_key.cpp: In member function ‘void TeleopTurtle::sendGoal(float)’:
      /home/yyh/ros_dev_ws/src/ros_tutorials/turtlesim/tutorials/teleop_turtle_key.cpp:200:5: error: no match for ‘operator=’ (operand types are ‘rclcpp_action::Client<turtlesim::action::RotateAbsolute>::GoalResponseCallback’ {aka ‘std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)>’} and ‘TeleopTurtle::sendGoal(float)::<lambda(std::shared_future<std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> > >)>’)
        200 |     };
      In file included from /usr/include/c++/11/future:47,
                       from /opt/ros/humble/include/rclcpp/rclcpp/executors.hpp:18,
                       from /opt/ros/humble/include/rclcpp/rclcpp/rclcpp.hpp:155,
                       from /home/yyh/ros_dev_ws/src/ros_tutorials/turtlesim/tutorials/teleop_turtle_key.cpp:1:
      /usr/include/c++/11/bits/std_function.h:530:9: note: candidate: ‘template<class _Functor> std::function<_Res(_ArgTypes ...)>::_Requires<std::function<_Res(_ArgTypes ...)>::_Callable<_Functor>, std::function<_Res(_ArgTypes ...)>&> std::function<_Res(_ArgTypes ...)>::operator=(_Functor&&) [with _Functor = _Functor; _Res = void; _ArgTypes = {std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >}]’
        530 |         operator=(_Functor&& __f)
      /usr/include/c++/11/bits/std_function.h:530:9: note:   template argument deduction/substitution failed:
      In file included from /usr/include/c++/11/bits/move.h:57,
                       from /usr/include/c++/11/bits/stl_pair.h:59,
                       from /usr/include/c++/11/bits/stl_algobase.h:64,
                       from /usr/include/c++/11/memory:63,
                       from /opt/ros/humble/include/rclcpp/rclcpp/rclcpp.hpp:153,
      /usr/include/c++/11/type_traits: In substitution of ‘template<bool _Cond, class _Tp> using __enable_if_t = typename std::enable_if::type [with bool _Cond = false; _Tp = std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)>&]’:
      /usr/include/c++/11/bits/std_function.h:353:8:   required by substitution of ‘template<class _Res, class ... _ArgTypes> template<class _Cond, class _Tp> using _Requires = std::__enable_if_t<_Cond::value, _Tp> [with _Cond = std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)>::_Callable<TeleopTurtle::sendGoal(float)::<lambda(std::shared_future<std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> > >)>, TeleopTurtle::sendGoal(float)::<lambda(std::shared_future<std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> > >)>, std::__invoke_result<TeleopTurtle::sendGoal(float)::<lambda(std::shared_future<std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> > >)>&, std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> > > >; _Tp = std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)>&; _Res = void; _ArgTypes = {std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >}]’
      /usr/include/c++/11/bits/std_function.h:530:2:   required by substitution of ‘template<class _Functor> std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)>::_Requires<std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)>::_Callable<_Functor, typename std::enable_if<(! std::is_same<typename std::remove_cv<typename std::remove_reference<_Tp>::type>::type, std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)> >::value), std::decay<_Tp> >::type::type, std::__invoke_result<typename std::enable_if<(! std::is_same<typename std::remove_cv<typename std::remove_reference<_Tp>::type>::type, std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)> >::value), std::decay<_Tp> >::type::type&, std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> > > >, std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)>&> std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)>::operator=<_Functor>(_Functor&&) [with _Functor = TeleopTurtle::sendGoal(float)::<lambda(std::shared_future<std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> > >)>]’
      /home/yyh/ros_dev_ws/src/ros_tutorials/turtlesim/tutorials/teleop_turtle_key.cpp:200:5:   required from here
      /usr/include/c++/11/type_traits:2205:11: error: no type named ‘type’ in ‘struct std::enable_if<false, std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)>&>’
       2205 |     using __enable_if_t = typename enable_if<_Cond, _Tp>::type;
      /usr/include/c++/11/bits/std_function.h:540:9: note: candidate: ‘template<class _Functor> std::function<_Res(_ArgTypes ...)>& std::function<_Res(_ArgTypes ...)>::operator=(std::reference_wrapper<_Functor>) [with _Functor = _Functor; _Res = void; _ArgTypes = {std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >}]’
        540 |         operator=(reference_wrapper<_Functor> __f) noexcept
      /usr/include/c++/11/bits/std_function.h:540:9: note:   template argument deduction/substitution failed:
      /home/yyh/ros_dev_ws/src/ros_tutorials/turtlesim/tutorials/teleop_turtle_key.cpp:200:5: note:   ‘TeleopTurtle::sendGoal(float)::<lambda(std::shared_future<std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> > >)>’ is not derived from ‘std::reference_wrapper<_Tp>’
        200 |     };
      /usr/include/c++/11/bits/std_function.h:469:7: note: candidate: ‘std::function<_Res(_ArgTypes ...)>& std::function<_Res(_ArgTypes ...)>::operator=(const std::function<_Res(_ArgTypes ...)>&) [with _Res = void; _ArgTypes = {std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >}]’
        469 |       operator=(const function& __x)
      /usr/include/c++/11/bits/std_function.h:469:33: note:   no known conversion for argument 1 from ‘TeleopTurtle::sendGoal(float)::<lambda(std::shared_future<std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> > >)>’ to ‘const std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)>&’
      /usr/include/c++/11/bits/std_function.h:487:7: note: candidate: ‘std::function<_Res(_ArgTypes ...)>& std::function<_Res(_ArgTypes ...)>::operator=(std::function<_Res(_ArgTypes ...)>&&) [with _Res = void; _ArgTypes = {std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >}]’
        487 |       operator=(function&& __x) noexcept
      /usr/include/c++/11/bits/std_function.h:487:28: note:   no known conversion for argument 1 from ‘TeleopTurtle::sendGoal(float)::<lambda(std::shared_future<std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> > >)>’ to ‘std::function<void(std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >)>&&’
      /usr/include/c++/11/bits/std_function.h:501:7: note: candidate: ‘std::function<_Res(_ArgTypes ...)>& std::function<_Res(_ArgTypes ...)>::operator=(std::nullptr_t) [with _Res = void; _ArgTypes = {std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> >}; std::nullptr_t = std::nullptr_t]’
        501 |       operator=(nullptr_t) noexcept
      /usr/include/c++/11/bits/std_function.h:501:17: note:   no known conversion for argument 1 from ‘TeleopTurtle::sendGoal(float)::<lambda(std::shared_future<std::shared_ptr<rclcpp_action::ClientGoalHandle<turtlesim::action::RotateAbsolute> > >)>’ to ‘std::nullptr_t’
      gmake[2]: *** [CMakeFiles/turtle_teleop_key.dir/build.make:76:CMakeFiles/turtle_teleop_key.dir/tutorials/teleop_turtle_key.cpp.o] 错误 1
      gmake[1]: *** [CMakeFiles/Makefile2:628:CMakeFiles/turtle_teleop_key.dir/all] 错误 2
      Failed   <<< turtlesim [2.10s, exited with code 2]
      Summary: 0 packages finished [2.25s]
        1 package failed: turtlesim
        1 package had stderr output: turtlesim
      系统环境ubuntu22.04,ros2安装正确,前面的教程反馈正常
      在不加入turtlesim时使用空文件colcon build成功
      请问这种情况该怎么解决?😵
      • 2 280390510 将这个主题转为问答主题,在
      • 2 280390510 删除了该主题于
      • 2 280390510 恢复了该主题于
        小鱼 技术大佬 @280390510
        @280390510 在 使用colcon构建工作区时出错 中说:
        given --rosdistro melodic but ROS_DISTRO is "humble" 是不是bashrc有什么配置错误的地方
