重要提示
鱼香小铺正式开业,最低499可入手一台能建图会导航的移动机器人,淘宝搜店:鱼香ROS 或点击链接查看。
社区使用指南—如何添加标签修改密码
社区使用指南—如何添加标签修改密码
ROS1 移植到ROS2:如何用ros2 中colcon build 编译 ros中 catkin的功能包
虚拟机:Ubuntu20.04
ROS2: humble在移植livox_ros_driver(ROS1)功能包到ros2环境时,出现编译错误如下:
[项目连接]( https://github.com/Livox-SDK/livox_ros_driver.git ws_livox/src)andrew@ros2:~/ws_livox$ colcon build Starting >>> livox_ros_driver --- stderr: livox_ros_driver CMake Error at CMakeLists.txt:25 (find_package): By not providing "Findcatkin.cmake" in CMAKE_MODULE_PATH this project has asked CMake to find a package configuration file provided by "catkin", but CMake did not find one. Could not find a package configuration file provided by "catkin" with any of the following names: catkinConfig.cmake catkin-config.cmake Add the installation prefix of "catkin" to CMAKE_PREFIX_PATH or set "catkin_DIR" to a directory containing one of the above files. If "catkin" provides a separate development package or SDK, be sure it has been installed. --- Failed <<< livox_ros_driver [0.09s, exited with code 1] Summary: 0 packages finished [0.29s] 1 package failed: livox_ros_driver 1 package had stderr output: livox_ros_driver
查看功能包编译信息
andrew@ros2:~$ colcon info path: ws_livox/src/livox_ros_driver type: ros.catkin name: livox_ros_driver dependencies: build: apr catkin git message_generation pcl_ros rosbag roscpp rospy sensor_msgs std_msgs run: apr git message_runtime pcl_ros rosbag roscpp rospy sensor_msgs std_msgs metadata: maintainers: ['Livox Dev Team <dev@livoxtech.com>'] version: 2.0.0
电脑中colcon工具版本信息:
andrew@ros2:~$ colcon version-check /usr/lib/python3/dist-packages/pkg_resources/__init__.py:116: PkgResourcesDeprecationWarning: 0.1.43ubuntu1 is an invalid version and will not be supported in a future release warnings.warn( /usr/lib/python3/dist-packages/pkg_resources/__init__.py:116: PkgResourcesDeprecationWarning: 1.1build1 is an invalid version and will not be supported in a future release warnings.warn( colcon-argcomplete 0.3.3: up-to-date colcon-bash 0.4.2: up-to-date colcon-cd 0.1.1: up-to-date colcon-cmake 0.2.27: up-to-date colcon-core 0.12.0: newer version available (0.12.1) colcon-defaults 0.2.8: up-to-date colcon-devtools 0.2.3: up-to-date colcon-installed-package-information 0.1.0: up-to-date colcon-library-path 0.2.1: up-to-date colcon-metadata 0.2.5: up-to-date colcon-notification 0.2.15: up-to-date colcon-output 0.2.12: up-to-date colcon-override-check 0.0.1: up-to-date colcon-package-information 0.3.3: up-to-date colcon-package-selection 0.2.10: up-to-date colcon-parallel-executor 0.2.4: up-to-date colcon-pkg-config 0.1.0: up-to-date colcon-powershell 0.3.7: up-to-date colcon-python-setup-py 0.2.8: up-to-date colcon-recursive-crawl 0.2.1: up-to-date colcon-ros 0.3.23: up-to-date colcon-test-result 0.3.8: up-to-date colcon-zsh 0.4.0: up-to-date
相关文章:
Build catkin packages with colcon
ROS2编译器colcon是个啥,比catkin好用吗?
ROS 1 的迁移到ROS 2指南 -
@andrew_liumuran 需要修改源码和cmakelists把catkin相关的更换成ament,,最好找厂家给个ros2的驱动
哈哈哈哈还是找ros2版本的驱动吧,太难修改啦!
