    gazebo报错,exit code 134
    gazebo ros1-melodic
    2.2k
    • 14147031131
      低保600,花不完根本花不完
      环境是ros1-melodic,gazebo11,一直是这个报错,在gazebo9时也是。
        小鱼 技术大佬 @1414703113
        @1414703113
        终端打印一定复制粘贴,方便回答者检索和引用(你可以在linux系统上打开浏览器进社区)
        • 14147031131
          低保600,花不完根本花不完
          zhang@zhang-virtual-machine:~/a工作$ roslaunch gazebo_ros empty_world.launch
          ... logging to /home/zhang/.ros/log/fc5663cc-aaa1-11ed-a845-000c2919b3b3/roslaunch-zhang-virtual-machine-27785.log
          Press Ctrl-C to interrupt
          Error in sitecustomize; set PYTHONVERBOSE for traceback:
          AttributeError: module 'sys' has no attribute 'setdefaultencoding'
          started roslaunch server http://zhang-virtual-machine:35989/
          SUMMARY
          PARAMETERS
          • /gazebo/enable_ros_network: True
          • /rosdistro: melodic
          • /rosversion: 1.14.13
          • /use_sim_time: True
          NODES
          gazebo (gazebo_ros/gzserver)
          gazebo_gui (gazebo_ros/gzclient)
          auto-starting new master
          process[master]: started with pid [27802]
          ROS_MASTER_URI=http://localhost:11311
          setting /run_id to fc5663cc-aaa1-11ed-a845-000c2919b3b3
          process[rosout-1]: started with pid [27820]
          started core service [/rosout]
          process[gazebo-2]: started with pid [27824]
          process[gazebo_gui-3]: started with pid [27832]
          terminate called after throwing an instance of 'std::runtime_error'
          what(): locale::facet::_S_create_c_locale name not valid
          Aborted (core dumped) //这往下是报错
          [gazebo_gui-3] process has died [pid 27832, exit code 134, cmd /opt/ros/melodic/lib/gazebo_ros/gzclient __name:=gazebo_gui __log:=/home/zhang/.ros/log/fc5663cc-aaa1-11ed-a845-000c2919b3b3/gazebo_gui-3.log].
          log file: /home/zhang/.ros/log/fc5663cc-aaa1-11ed-a845-000c2919b3b3/gazebo_gui-3*.log
          [gazebo-2] process has died [pid 27824, exit code 134, cmd /opt/ros/melodic/lib/gazebo_ros/gzserver -e ode worlds/empty.world __name:=gazebo __log:=/home/zhang/.ros/log/fc5663cc-aaa1-11ed-a845-000c2919b3b3/gazebo-2.log].
          log file: /home/zhang/.ros/log/fc5663cc-aaa1-11ed-a845-000c2919b3b3/gazebo-2*.log
          • 14147031131
            低保600,花不完根本花不完
              ?_?
              大佬找到原因了吗?我在使用qt运行gazebo时也出现了同样的问题。
