    自定义插件未集成到ROS工具链
    自定义插件 工具链
    2.1k
    • 9
      924453613
      最后由 924453613 编辑
      已创建插件
      RAstar_ros.h
      /* iPath: A C++ Library of Intelligent Global Path Planners for Mobile Robots
       * with ROS Integration. Website: http://www.iroboapp.org/index.php?title=IPath
       * Contact:
       * Copyright (c) 2014
       * Owners: Al-Imam University/King AbdulAziz Center for Science and Technology
       * (KACST)/Prince Sultan University All rights reserved.
       * License Type: GNU GPL
       *   This program is free software: you can redistribute it and/or modify
       *   it under the terms of the GNU General Public License as published by
       *   the Free Software Foundation, either version 3 of the License, or
       *   (at your option) any later version.
       *   This program is distributed in the hope that it will be useful,
       *   but WITHOUT ANY WARRANTY; without even the implied warranty of
       *   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
       *   GNU General Public License for more details.
       *   You should have received a copy of the GNU General Public License
       *   along with this program.  If not, see <http://www.gnu.org/licenses/>.
      #include <netdb.h>
      #include <netinet/in.h>
      #include <stdio.h>
      #include <stdlib.h>
      #include <string.h>
      #include <sys/socket.h>
      #include <sys/types.h>
      #include <unistd.h>
      #include <string>
      /** include ros libraries**********************/
      #include <actionlib/client/simple_action_client.h>
      #include <geometry_msgs/PoseStamped.h>
      #include <geometry_msgs/PoseWithCovarianceStamped.h>
      #include <geometry_msgs/Twist.h>
      #include <move_base_msgs/MoveBaseAction.h>
      #include <move_base_msgs/MoveBaseActionGoal.h>
      #include <move_base_msgs/MoveBaseGoal.h>
      #include <nav_msgs/GetPlan.h>
      #include <nav_msgs/OccupancyGrid.h>
      #include <nav_msgs/Odometry.h>
      #include <nav_msgs/Path.h>
      #include <ros/ros.h>
      #include <tf/tf.h>
      #include <tf/transform_datatypes.h>
      #include <tf/transform_listener.h>
      #include "sensor_msgs/LaserScan.h"
      #include "sensor_msgs/PointCloud2.h"
      #include <boost/foreach.hpp>
      //#define forEach BOOST_FOREACH
      /** for global path planner interface */
      #include <angles/angles.h>
      #include <costmap_2d/costmap_2d.h>
      #include <costmap_2d/costmap_2d_ros.h>
      #include <nav_core/base_global_planner.h>
      //#include <pcl_conversions/pcl_conversions.h>
      #include <base_local_planner/costmap_model.h>
      #include <base_local_planner/world_model.h>
      #include <set>
      using namespace std;
      using std::string;
      #ifndef RASTAR_ROS_CPP
      #define RASTAR_ROS_CPP
       * @struct cells
       * @brief A struct that represents a cell and its fCost.
      struct cells {
        int currentCell;
        float fCost;
      // STEP1-2.your class should inherits from the interface
      // "nav_core::BaseGlobalPlanner"
      namespace RAstar_planner {
      class RAstarPlannerROS : public nav_core::BaseGlobalPlanner {
       public:
        RAstarPlannerROS(ros::NodeHandle&);  // this constructor is may be not needed
        RAstarPlannerROS();
        RAstarPlannerROS(std::string name, costmap_2d::Costmap2DROS* costmap_ros);
        ros::NodeHandle ROSNodeHandle;
        /** 公有继承 nav_core::BaseGlobalPlanner  接口 **/
        /** overriden classes from interface nav_core::BaseGlobalPlanner **/
        void initialize(std::string name, costmap_2d::Costmap2DROS* costmap_ros);
        bool makePlan(const geometry_msgs::PoseStamped& start,
                      const geometry_msgs::PoseStamped& goal,
                      std::vector<geometry_msgs::PoseStamped>& plan);
        void getCorrdinate(float& x, float& y);
        int convertToCellIndex(float x, float y);
        void convertToCoordinate(int index, float& x, float& y);
        bool isCellInsideMap(float x, float y);
        void mapToWorld(double mx, double my, double& wx, double& wy);
        vector<int> RAstarPlanner(int startCell, int goalCell);
        vector<int> findPath(int startCell, int goalCell, float g_score[]);
        vector<int> constructPath(int startCell, int goalCell, float g_score[]);
        float calculateHCost(int cellID, int goalCell) {
          int x1 = getCellRowID(goalCell);
          int y1 = getCellColID(goalCell);
          int x2 = getCellRowID(cellID);
          int y2 = getCellColID(cellID);
          return abs(x1 - x2) + abs(y1 - y2);
          // return min(abs(x1-x2),abs(y1-y2))*sqrt(2) +
          // max(abs(x1-x2),abs(y1-y2))-min(abs(x1-x2),abs(y1-y2));
        void addNeighborCellToOpenList(multiset<cells>& OPL, int neighborCell,
        vector<int> findFreeNeighborCell(int CellID);
        bool isStartAndGoalCellsValid(int startCell, int goalCell);
        float getMoveCost(int CellID1, int CellID2);
        float getMoveCost(int i1, int j1, int i2, int j2);
        bool isFree(int CellID);  // returns true if the cell is Free
        bool isFree(int i, int j);
        int getCellIndex(int i,
                         int j)  // get the index of the cell to be used in Path
          return (i * width) + j;
        int getCellRowID(int index)  // get the row ID from cell index
          return index / width;
        int getCellColID(int index)  // get colunm ID from cell index
          return index % width;
        float originX;
        float originY;
        float resolution;
        costmap_2d::Costmap2DROS* costmap_ros_;
        double step_size_, min_dist_from_robot_;
        costmap_2d::Costmap2D* costmap_;
        // base_local_planner::WorldModel* world_model_;
        bool initialized_;
        int width;
        int height;
      };  // namespace RAstar_planner
      #endif
      已创建基类并注册插件
      RAstar_ros.cpp
       * Contact:
      #include <netdb.h>
      #include <stdio.h>
      #include <stdlib.h>
      #include <string.h>
      #include <unistd.h>
      #include <fstream>
      #include <iomanip>
      #include <iostream>
      #include <string>
      // STEP1-1.include core ROS libraries -> nav_core roscpp rospy std_msgs
      #include "RAstar_ros.h"
      // STEP1-4.include <pluginlib/class_list_macros.h>
      #include <pluginlib/class_list_macros.h>
      // register this planner as a BaseGlobalPlanner plugin
      /*注册一个插件
        STEP1-5.register this planner as a BaseGlobalPlanner plugin by adding
        PLUGINLIB_EXPORT_CLASS(RAstar_planner::RAstarPlannerROS,nav_core::BaseGlobalPlanner)*/
      int value;
      int mapSize;
      bool* OGM;
      static const float INFINIT_COST = INT_MAX;  //!< cost of non connected nodes
      float infinity = std::numeric_limits<float>::infinity();
      float tBreak;  // coefficient for breaking ties
      ofstream MyExcelFile("RA_result.xlsx", ios::trunc);
      int clock_gettime(clockid_t clk_id, struct timespect* tp);
      timespec diff(timespec start, timespec end) {
        timespec temp;
        if ((end.tv_nsec - start.tv_nsec) < 0) {
          temp.tv_sec = end.tv_sec - start.tv_sec - 1;
          temp.tv_nsec = 1000000000 + end.tv_nsec - start.tv_nsec;
        } else {
          temp.tv_sec = end.tv_sec - start.tv_sec;
          temp.tv_nsec = end.tv_nsec - start.tv_nsec;
        return temp;
      inline vector<int> findFreeNeighborCell(int CellID);
      // Default Constructor
      RAstarPlannerROS::RAstarPlannerROS() {}
      RAstarPlannerROS::RAstarPlannerROS(ros::NodeHandle& nh) { ROSNodeHandle = nh; }
      // STEP1-3.overriden the methods "initialize" and "makePlan"
      RAstarPlannerROS::RAstarPlannerROS(std::string name,
                                         costmap_2d::Costmap2DROS* costmap_ros) {
        initialize(name, costmap_ros);
      void RAstarPlannerROS::initialize(std::string name,
        if (!initialized_) {
          costmap_ros_ = costmap_ros;
          costmap_ = costmap_ros_->getCostmap();
          ros::NodeHandle private_nh("~/" + name);
          originX = costmap_->getOriginX();
          originY = costmap_->getOriginY();
          width = costmap_->getSizeInCellsX();
          height = costmap_->getSizeInCellsY();
          resolution = costmap_->getResolution();
          mapSize = width * height;
          tBreak = 1 + 1 / (mapSize);
          value = 0;
          OGM = new bool[mapSize];
          for (unsigned int iy = 0; iy < costmap_->getSizeInCellsY(); iy++) {
            for (unsigned int ix = 0; ix < costmap_->getSizeInCellsX(); ix++) {
              unsigned int cost = static_cast<int>(costmap_->getCost(ix, iy));
              // cout<<cost;
              if (cost == 0)
                OGM[iy * width + ix] = true;
              else
                OGM[iy * width + ix] = false;
          MyExcelFile << "StartID\tStartX\tStartY\tGoalID\tGoalX\tGoalY\tPlannertime("
                         "ms)\tpathLength\tnumberOfCells\t"
                      << endl;
          ROS_INFO("RAstar planner initialized successfully");
          initialized_ = true;
        } else
          ROS_WARN("This planner has already been initialized... doing nothing");
      // STEP1-3.1Here we override the "makePlan" method,in which you should write or
      // call your path planning algorithm
      bool RAstarPlannerROS::makePlan(const geometry_msgs::PoseStamped& start,
                                      std::vector<geometry_msgs::PoseStamped>& plan) {
          ROS_ERROR(
              "The planner has not been initialized, please call initialize() to use "
              "the planner");
          return false;
        ROS_DEBUG("Got a start: %.2f, %.2f, and a goal: %.2f, %.2f",
                  start.pose.position.x, start.pose.position.y, goal.pose.position.x,
                  goal.pose.position.y);
        plan.clear();
        if (goal.header.frame_id != costmap_ros_->getGlobalFrameID()) {
          ROS_ERROR(
              "This planner as configured will only accept goals in the %s frame, "
              "but a goal was sent in the %s frame.",
              costmap_ros_->getGlobalFrameID().c_str(), goal.header.frame_id.c_str());
          return false;
        tf::Stamped<tf::Pose> goal_tf;
        tf::Stamped<tf::Pose> start_tf;
        poseStampedMsgToTF(goal, goal_tf);
        poseStampedMsgToTF(start, start_tf);
        // convert the start and goal positions
        float startX = start.pose.position.x;
        float startY = start.pose.position.y;
        float goalX = goal.pose.position.x;
        float goalY = goal.pose.position.y;
        getCorrdinate(startX, startY);
        getCorrdinate(goalX, goalY);
        int startCell;
        int goalCell;
        if (isCellInsideMap(startX, startY) && isCellInsideMap(goalX, goalY)) {
          startCell = convertToCellIndex(startX, startY);
          goalCell = convertToCellIndex(goalX, goalY);
          MyExcelFile << startCell << "\t" << start.pose.position.x << "\t"
                      << start.pose.position.y << "\t" << goalCell << "\t"
                      << goal.pose.position.x << "\t" << goal.pose.position.y;
        } else {
          ROS_WARN("the start or goal is out of the map");
          return false;
        // call relaxed Astar global planner
        if (isStartAndGoalCellsValid(startCell, goalCell)) {
          vector<int> bestPath;
          bestPath.clear();
          //两个参数为起始点和终点
          bestPath = RAstarPlanner(startCell, goalCell);
          // if the global planner find a path
          if (bestPath.size() > 0) {
            // convert the path
            for (int i = 0; i < bestPath.size(); i++) {
              float x = 0.0;
              float y = 0.0;
              int index = bestPath[i];
              convertToCoordinate(index, x, y);
              geometry_msgs::PoseStamped pose = goal;
              // your path should be stored in the "plan" vector
              pose.pose.position.x = x;
              pose.pose.position.y = y;
              pose.pose.position.z = 0.0;
              pose.pose.orientation.x = 0.0;
              pose.pose.orientation.y = 0.0;
              pose.pose.orientation.z = 0.0;
              pose.pose.orientation.w = 1.0;
              plan.push_back(pose);
            float path_length = 0.0;
            std::vector<geometry_msgs::PoseStamped>::iterator it = plan.begin();
            geometry_msgs::PoseStamped last_pose;
            last_pose = *it;
            it++;
            for (; it != plan.end(); ++it) {
              path_length += hypot((*it).pose.position.x - last_pose.pose.position.x,
                                   (*it).pose.position.y - last_pose.pose.position.y);
              last_pose = *it;
            cout << "The global path length: " << path_length << " meters" << endl;
            MyExcelFile << "\t" << path_length << "\t" << plan.size() << endl;
            // publish the plan
            return true;
          else {
            ROS_WARN("The planner failed to find a path, choose other goal position");
            return false;
        else {
          ROS_WARN("Not valid start or goal");
          return false;
      void RAstarPlannerROS::getCorrdinate(float& x, float& y) {
        x = x - originX;
        y = y - originY;
      int RAstarPlannerROS::convertToCellIndex(float x, float y) {
        int cellIndex;
        float newX = x / resolution;
        float newY = y / resolution;
        cellIndex = getCellIndex(newY, newX);
        return cellIndex;
      void RAstarPlannerROS::convertToCoordinate(int index, float& x, float& y) {
        x = getCellColID(index) * resolution;
        y = getCellRowID(index) * resolution;
        x = x + originX;
        y = y + originY;
      bool RAstarPlannerROS::isCellInsideMap(float x, float y) {
        bool valid = true;
        if (x > (width * resolution) || y > (height * resolution)) valid = false;
        return valid;
      void RAstarPlannerROS::mapToWorld(double mx, double my, double& wx,
                                        double& wy) {
        costmap_2d::Costmap2D* costmap = costmap_ros_->getCostmap();
        wx = costmap->getOriginX() + mx * resolution;
        wy = costmap->getOriginY() + my * resolution;
      vector<int> RAstarPlannerROS::RAstarPlanner(int startCell, int goalCell) {
        // float g_score [mapSize][2];
        float g_score[mapSize];
        for (uint i = 0; i < mapSize; i++) g_score[i] = infinity;
        timespec time1, time2;
        /* take current time here */
        clock_gettime(CLOCK_PROCESS_CPUTIME_ID, &time1);
        bestPath = findPath(startCell, goalCell, g_score);
        clock_gettime(CLOCK_PROCESS_CPUTIME_ID, &time2);
        cout << "time to generate best global path by Relaxed A* = "
             << (diff(time1, time2).tv_sec) * 1e3 +
                    (diff(time1, time2).tv_nsec) * 1e-6
             << " microseconds" << endl;
        MyExcelFile << "\t"
                           (diff(time1, time2).tv_nsec) * 1e-6;
        return bestPath;
      // Function Name: findPath
      // Inputs: the map layout, the start and the goal Cells and a boolean to
      // indicate if we will use break ties or not Output: the best path Description:
      // it is used to generate the robot free path
      vector<int> RAstarPlannerROS::findPath(int startCell, int goalCell,
                                             float g_score[]) {
        value++;
        vector<int> emptyPath;
        cells CP;
        multiset<cells> OPL;
        int currentCell;
        // calculate g_score and f_score of the start position
        g_score[startCell] = 0;
        CP.currentCell = startCell;
        CP.fCost = g_score[startCell] + calculateHCost(startCell, goalCell);
        // add the start cell to the open list
        OPL.insert(CP);
        // while the open list is not empty continuie the search or g_score(goalCell)
        // is equal to infinity
        while (!OPL.empty() && g_score[goalCell] == infinity) {
          // choose the cell that has the lowest cost fCost in the open set which is
          // the begin of the multiset
          currentCell = OPL.begin()->currentCell;
          // remove the currentCell from the openList
          OPL.erase(OPL.begin());
          // search the neighbors of the current Cell
          vector<int> neighborCells;
          neighborCells = findFreeNeighborCell(currentCell);
          for (uint i = 0; i < neighborCells.size();
               i++)  // for each neighbor v of current cell
            // if the g_score of the neighbor is equal to INF: unvisited cell
            if (g_score[neighborCells[i]] == infinity) {
                  g_score[currentCell] + getMoveCost(currentCell, neighborCells[i]);
              addNeighborCellToOpenList(OPL, neighborCells[i], goalCell, g_score);
            }  // end if
          }    // end for
        }      // end while
        if (g_score[goalCell] !=
            infinity)  // if g_score(goalcell)==INF : construct path
          bestPath = constructPath(startCell, goalCell, g_score);
          return bestPath;
        } else {
          cout << "Failure to find a path !" << endl;
          return emptyPath;
      // Function Name: constructPath
      // Inputs: the start and the goal Cells
      // Output: the best path
      // Description: it is used to construct the robot path
      vector<int> RAstarPlannerROS::constructPath(int startCell, int goalCell,
                                                  float g_score[]) {
        vector<int> path;
        path.insert(path.begin() + bestPath.size(), goalCell);
        int currentCell = goalCell;
        while (currentCell != startCell) {
          vector<float> gScoresNeighbors;
          for (uint i = 0; i < neighborCells.size(); i++)
            gScoresNeighbors.push_back(g_score[neighborCells[i]]);
          int posMinGScore =
              distance(gScoresNeighbors.begin(),
                       min_element(gScoresNeighbors.begin(), gScoresNeighbors.end()));
          currentCell = neighborCells[posMinGScore];
          // insert the neighbor in the path
          path.insert(path.begin() + path.size(), currentCell);
        for (uint i = 0; i < path.size(); i++)
          bestPath.insert(bestPath.begin() + bestPath.size(),
                          path[path.size() - (i + 1)]);
        return bestPath;
      // Function Name: calculateHCost
      // Inputs:the cellID and the goalCell
      // Output: the distance between the current cell and the goal cell
      // Description: it is used to calculate the hCost
      float RAstarPlannerROS::calculateHCost(int cellID, int goalCell)
        int x1=getCellRowID(goalCell);
        int y1=getCellColID(goalCell);
        int x2=getCellRowID(cellID);
        int y2=getCellColID(cellID);
        //if(getNeighborNumber()==4)
          //The diagonal shortcut distance between two grid points (x1,y1) and (x2,y2)
      is:
        //else
          //manhatten distance for 8 neighbor
          return abs(x1-x2)+abs(y1-y2);
      // Function Name: addNeighborCellToOpenList
      // Inputs: the open list, the neighbors Cell, the g_score matrix, the goal cell
      // Output:
      // Description: it is used to add a neighbor Cell to the open list
      void RAstarPlannerROS::addNeighborCellToOpenList(multiset<cells>& OPL,
                                                       int neighborCell, int goalCell,
                                                       float g_score[]) {
        cells CP;
        CP.currentCell = neighborCell;  // insert the neighbor cell
        CP.fCost = g_score[neighborCell] + calculateHCost(neighborCell, goalCell);
        OPL.insert(CP);
        // multiset<cells>::iterator it = OPL.lower_bound(CP);
        // multiset<cells>::iterator it = OPL.upper_bound(CP);
        // OPL.insert( it, CP  );
       * Function Name: findFreeNeighborCell
       * Inputs: the row and columun of the current Cell
       * Output: a vector of free neighbor cells of the current cell
       * Description:it is used to find the free neighbors Cells of a the current Cell
       *in the grid Check Status: Checked by Anis, Imen and Sahar
      vector<int> RAstarPlannerROS::findFreeNeighborCell(int CellID) {
        int rowID = getCellRowID(CellID);
        int colID = getCellColID(CellID);
        int neighborIndex;
        vector<int> freeNeighborCells;
        for (int i = -1; i <= 1; i++)
          for (int j = -1; j <= 1; j++) {
            // check whether the index is valid
            if ((rowID + i >= 0) && (rowID + i < height) && (colID + j >= 0) &&
                (colID + j < width) && (!(i == 0 && j == 0))) {
              neighborIndex = getCellIndex(rowID + i, colID + j);
              if (isFree(neighborIndex)) freeNeighborCells.push_back(neighborIndex);
        return freeNeighborCells;
      // Function Name: isStartAndGoalCellsValid
      // Inputs: the start and Goal cells
      // Output: true if the start and the goal cells are valid
      // Description: check if the start and goal cells are valid
      bool RAstarPlannerROS::isStartAndGoalCellsValid(int startCell, int goalCell) {
        bool isvalid = true;
        bool isFreeStartCell = isFree(startCell);
        bool isFreeGoalCell = isFree(goalCell);
        if (startCell == goalCell) {
          // cout << "The Start and the Goal cells are the same..." << endl;
          isvalid = false;
        } else {
          if (!isFreeStartCell && !isFreeGoalCell) {
            // cout << "The start and the goal cells are obstacle positions..." <<
            // endl;
            isvalid = false;
          } else {
            if (!isFreeStartCell) {
              // cout << "The start is an obstacle..." << endl;
              isvalid = false;
            } else {
              if (!isFreeGoalCell) {
                // cout << "The goal cell is an obstacle..." << endl;
                isvalid = false;
              } else {
                if (findFreeNeighborCell(goalCell).size() == 0) {
                  // cout << "The goal cell is encountred by obstacles... "<< endl;
                  isvalid = false;
                } else {
                  if (findFreeNeighborCell(startCell).size() == 0) {
                    // cout << "The start cell is encountred by obstacles... "<< endl;
                    isvalid = false;
        return isvalid;
      float RAstarPlannerROS::getMoveCost(int i1, int j1, int i2, int j2) {
        float moveCost = INFINIT_COST;  // start cost with maximum value. Change it to
                                        // real cost of cells are connected
        // if cell2(i2,j2) exists in the diagonal of cell1(i1,j1)
        if ((j2 == j1 + 1 && i2 == i1 + 1) || (i2 == i1 - 1 && j2 == j1 + 1) ||
            (i2 == i1 - 1 && j2 == j1 - 1) || (j2 == j1 - 1 && i2 == i1 + 1)) {
          // moveCost = DIAGONAL_MOVE_COST;
          moveCost = 1.4;
        // if cell 2(i2,j2) exists in the horizontal or vertical line with
        // cell1(i1,j1)
        else {
          if ((j2 == j1 && i2 == i1 - 1) || (i2 == i1 && j2 == j1 - 1) ||
              (i2 == i1 + 1 && j2 == j1) || (i1 == i2 && j2 == j1 + 1)) {
            // moveCost = MOVE_COST;
            moveCost = 1;
        return moveCost;
      float RAstarPlannerROS::getMoveCost(int CellID1, int CellID2) {
        int i1 = 0, i2 = 0, j1 = 0, j2 = 0;
        i1 = getCellRowID(CellID1);
        j1 = getCellColID(CellID1);
        i2 = getCellRowID(CellID2);
        j2 = getCellColID(CellID2);
        return getMoveCost(i1, j1, i2, j2);
      // verify if the cell(i,j) is free
      bool RAstarPlannerROS::isFree(int i, int j) {
        int CellID = getCellIndex(i, j);
        return OGM[CellID];
      bool RAstarPlannerROS::isFree(int CellID) { return OGM[CellID]; }
      bool operator<(cells const& c1, cells const& c2) { return c1.fCost < c2.fCost; }
      已构建插件库并导出插件
      CMakeLists.txt
      cmake_minimum_required(VERSION 3.0.2)
      project(relaxed_astar)
      find_package(catkin REQUIRED COMPONENTS
        nav_core
        roscpp
        rospy
        std_msgs
        actionlib
        actionlib_msgs
      catkin_package()
      include_directories(
      # include
        ${catkin_INCLUDE_DIRS}
      add_library(relaxed_astar_lib
        src/RAstar_ros.cpp
      package.xml
      <?xml version="1.0"?>
      <package format="2">
        <buildtool_depend>catkin</buildtool_depend>
        <build_depend>nav_core</build_depend>
        <build_depend>roscpp</build_depend>
        <build_depend>rospy</build_depend>
        <build_depend>std_msgs</build_depend>
        <build_depend>actionlib</build_depend>
        <build_depend>actionlib_msgs</build_depend>
        <build_export_depend>nav_core</build_export_depend>
        <build_export_depend>roscpp</build_export_depend>
        <build_export_depend>rospy</build_export_depend>
        <build_export_depend>std_msgs</build_export_depend>
        <build_export_depend>actionlib</build_export_depend>
        <build_export_depend>actionlib_msgs</build_export_depend>
        <exec_depend>nav_core</exec_depend>
        <exec_depend>roscpp</exec_depend>
        <exec_depend>rospy</exec_depend>
        <exec_depend>std_msgs</exec_depend>
        <exec_depend>actionlib</exec_depend>
        <exec_depend>actionlib_msgs</exec_depend>
        <!-- The export tag contains other, unspecified, tags -->
        <export>
          <!-- Other tools can request additional information be placed here -->
          <!--STEP2-3.registering plugin with ROS package system-->
          <nav_core plugin="${prefix}/relaxed_astar_planner_plugin.xml" />
        </export>
      </package>
      构建插件库成功但未集成到ROS工具链
      <!--增加一个配置文件说明该插件的功能-->
      <!--STEP2-2.write all the important information about your plugin-->
      <library path="lib/librelaxed_astar_lib">
          <class name="RAstar_planner/RAstarPlannerROS" type="RAstar_planner::RAstarPlannerROS" base_class_type="nav_core::BaseGlobalPlanner">
              <description>This is RA∗ global planner plugin by iroboapp project.</description>
          </class>
      </library>
        小鱼 技术大佬 @924453613
        @924453613 用rospack之前是否source了devel下的setup.bash
        9 1 条回复 最后回复 回复 引用 0
        • 9
          924453613
          代码是github上的,还在学习阶段👼
            小鱼 技术大佬 @924453613
            • 9
              924453613 @小鱼
              @小鱼 rospack之前原来要先source一下,已解决,谢谢鱼总
              • 9 924453613 将这个主题标记为已解决,在
                小鱼 技术大佬 @924453613
                @924453613 解决了就好,主要你的提问格式和内容描述的都很好,可以让我很快定位问题,赞一个👍
