    ROS2 机器人在静止下地图无法保存,需在移动时才能保存地图
    ros2 地图保存 地图无法保存
    1.4k
    • 11573543821
      大预言家·福尔摩斯·睿
      大佬 你们好
      版本 20.04 foxy
      在使用gmapping建好地图后,使用 map_saver无法正常保存地图,显示结果图下2023-02-21 10-19-25 的屏幕截图.png 日志如下
      ros2 run nav2_map_server map_saver_cli
      [INFO] [1676945889.284354723] [map_saver]:
      	map_saver lifecycle node launched.
      	Waiting on external lifecycle transitions to activate
      	See https://design.ros2.org/articles/node_lifecycle.html for more information.
      [INFO] [1676945889.284500481] [map_saver]: Creating
      [INFO] [1676945889.284764118] [map_saver]: Saving map from 'map' topic to '' file
      [WARN] [1676945889.284791241] [map_saver]: Free threshold unspecified. Setting it to default value: 0.250000
      [WARN] [1676945889.284822450] [map_saver]: Occupied threshold unspecified. Setting it to default value: 0.650000
      [ERROR] [1676945891.288356825] [map_saver]: Failed to save the map: timeout
      [INFO] [1676945891.288500232] [map_saver]: Destroying
      在移动时地图就能正常保存
      另附上我的tf树
      • 11573543821
        大预言家·福尔摩斯·睿
        我似乎是找到了原因,可能是Qos没有相匹配,导致信息不能相互传输。但是具体修改哪个东西的qos我不是很懂,因为map不是gmapping自己发布的嘛,那他这个要和什么相匹配呢。
        这是rviz上的日志:
        [INFO] [1677118775.546330774] [map_saver]:
        [INFO] [1677118775.546418351] [map_saver]: Creating
        [INFO] [1677118775.546718313] [map_saver]: Saving map from 'map' topic to '' file
        [WARN] [1677118775.546743987] [map_saver]: Free threshold unspecified. Setting it to default value: 0.250000
        [WARN] [1677118775.546763269] [map_saver]: Occupied threshold unspecified. Setting it to default value: 0.650000
        [WARN] [1677118775.547629798] [map_saver]: New publisher discovered on topic '/map', offering incompatible QoS. No messages will be sent to it. Last incompatible policy: DURABILITY_QOS_POLICY
        [ERROR] [1677118777.547682744] [map_saver]: Failed to spin map subscription
        [INFO] [1677118777.548951015] [map_saver]: Destroying
        这是gmapping报错部分:
        [slam_gmapping-6] [WARN] [1677118742.381892406] [slam_gmapping]: New subscription discovered on topic '/map', requesting incompatible QoS. No messages will be sent to it. Last incompatible policy: DURABILITY_QOS_POLICY
          小鱼 技术大佬 @1157354382
          @1157354382 ros2 topic info /mqp -v 可以查看详细的QOS
          11573543821 1 条回复 最后回复 回复 引用 0
          • 11573543821
            大预言家·福尔摩斯·睿 @小鱼
            @小鱼 感谢小鱼儿的帮助。我将 gmapping的 Durability 修改成了 transient_local ,map_saver保持一致了,也能进行保存工作。困扰了快一个星期了,感谢帮助。
            3748703613 1 条回复 最后回复 回复 引用 1
            • 3748703613
              孤独的幸存者
              我这里用ros2 eloquent也是gmapping建图,建好图之后直接执行
              就可以直接保存了
              1 条回复 最后回复 回复 引用 1
              • 3748703613
                孤独的幸存者 @1157354382
                @1157354382 我在ros2 galactic中也遇到了和你一样的问题,想问下你是怎么修改gmapping的Durabiliy的呢
                • 11573543821
                  大预言家·福尔摩斯·睿 @374870361
                  @374870361
                  void SlamGmapping::startLiveSlam() 里面的内容,好像是这一块,好久没搞了
                   // sst_ = this->create_publisher<nav_msgs::msg::OccupancyGrid>("map", rclcpp::SystemDefaultsQoS());
                      sstm_ = this->create_publisher<nav_msgs::msg::MapMetaData>("map_metadata", rclcpp::SystemDefaultsQoS());
                      scan_filter_sub_ = std::make_shared<message_filters::Subscriber<sensor_msgs::msg::LaserScan>>
                              (node_, "scan", rclcpp::SensorDataQoS().get_rmw_qos_profile());
                      sst_ = this->create_publisher<nav_msgs::msg::OccupancyGrid>("map", rclcpp::QoS(rclcpp::QoSInitialization::from_rmw(rmw_qos_profile_system_privated), rmw_qos_profile_system_privated));
                  //    sub_ = this->create_subscription<sensor_msgs::msg::LaserScan>(
                  //        "scan", rclcpp::SensorDataQoS(),
                  //        std::bind(&SlamGmapping::laserCallback, this, std::placeholders::_1));
                  我现在是使用 cartographer 来建图了,感觉也挺不错的
