    ubuntu20.4 ros1noetic 安装奥比中光 Astra Pro RGBD摄像头
    移动平台分享
    ros1 noetic astra pro rgbd摄像头
    2.9k
    • 毛哥成山轮胎机油保养毛
      毛哥成山轮胎机油保养 活跃VIP
      最后由 毛哥成山轮胎机油保养 编辑
      最牛b的机器视觉ORB_SLAM3运行的是ros1环境,所以ros1还要走一遍,先从安装摄像头开始。
      这款摄像头我在ubuntu22.04 ros2 humble安装过,还算顺利,换了ros1,遇到很多的坑,几经波折,终于安装成功。
      环境:ubuntu20.4 ros1 noetic
      参考官网使用手册
      https://developer.orbbec.com.cn/technical_library.html?id=49
      安装依赖
      sudo apt install libgflags-dev  ros-$ROS_DISTRO-image-geometry ros-$ROS_DISTRO-camera-info-manager\
      ros-$ROS_DISTRO-image-transport ros-$ROS_DISTRO-image-publisher libgoogle-glog-dev libusb-1.0-0-dev libeigen3-dev
      E: 无法定位软件包 ros-noetic-camera-info-managerros-noetic-image-transport
      少2个包,貌似不影响使用,先忽略,以后有用在想办法。
      安装libuvc
      git clone https://github.com/libuvc/libuvc.git
      cd libuvc
      mkdir build && cd build
      cmake .. && make -j4
      sudo make install
      sudo ldconfig
      新建 ros workspace
      mkdir -p ~/ros1_ws/src
      下载网址:
      https://developer.orbbec.com.cn/download.html?id=181
      将 OpenNISDK_ROS_xxx.tar.gz 解压并复制到 ~/ros_ws/src
      编译
      cd ~/ros1_ws
      catkin_make
      安装libusb rules
      cd ~/ros1_ws
      source ./devel/setup.bash
      roscd astra_camera
      ./scripts/create_udev_rules
      sudo udevadm control --reload && sudo  udevadm trigger
      VID:Vender ID供应商识别码
      PID:Product ID产品识别码
      每一个USB(Universal Serial BUS)都有VID和PID
      通过PID&VID来判断相机是否正常被识别
       lsusb
      Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
      Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
      Bus 001 Device 006: ID 04f2:b2ea Chicony Electronics Co., Ltd Integrated Camera [ThinkPad]
      Bus 001 Device 005: ID 8086:0187 Intel Corp.
      Bus 001 Device 004: ID 0a5c:2110 Broadcom Corp. BCM2045B (BDC-2) [Bluetooth Controller]
      Bus 001 Device 024: ID 0e8f:0021 GreenAsia Inc. Multimedia Keyboard Controller
      Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
      Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
      Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
      Bus 003 Device 009: ID 0000:3825   USB OPTICAL MOUSE
      Bus 003 Device 005: ID 2bc5:0403   USB OPTICAL MOUSE
      Bus 003 Device 004: ID 2bc5:0501  USB2.0 Hub
      Bus 003 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
      Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
      ID 2bc5:0403 (彩色相机)
      ID 2bc5:0501 (深度相机)
      但是我的是USB OPTICAL MOUSE,我总觉得和我的鼠标冲突,每次运行都拔掉鼠标,可是测试好了以后插着鼠标也正常了,不知道是哪里不对。
      到这步usb好像和什么冲突,不出图像,卡了我2天重装了好几次才弄好,也不知道具体怎么好的。
      采取的方法
      ubuntu20.04的 brltty 导致 USB 转串口连接失败
      sudo dmesg | grep brltty
      [ 0.077725] printk: console [tty0] enabled //控制台[tty0]已启用
      sudo apt remove brltty //删除brltty
      卸载了brltty还是不行,以为系统内缺东西,想重装ubuntu,usb启动盘坏了没有重装,重新下载的OpenNI_SDK_ROS_v1.1.4_20220927_e5a9dc_Linux才出来图像,好像是不同版本sdk有差异。
      启动相机
      一定要注意摄像头版本,里面的launch文件对应不同摄像头,错了出不来图像。我的是astra_pro
      在terminal 1
      roslaunch astra_camera astra_pro.launch
      在terminal 2
      rviz
      2023-02-27 14-06-22屏幕截图.png 2023-02-27 14-06-54屏幕截图.png 2023-02-27 14-07-26屏幕截图.png
      彩图和深度图都出来了。
      查看 topics / services/ parameters (新开一个终端)
      rostopic list
      rosservice list
      rosparam list
      rostopic list
      /camera/color/camera_info
      /camera/color/image_raw
      /camera/depth/camera_info
      /camera/depth/image_raw
      /camera/depth/points
      /camera/depth_registered/points
      /camera/extrinsic/depth_to_color
      /camera/ir/camera_info
      /camera/ir/image_raw
      /camera/reset_device
      /clicked_point
      /initialpose
      /move_base_simple/goal
      /rosout
      /rosout_agg
      /tf
      /tf_static
      通过这2个topic :
      我们就可以随意给其他节点传彩图和深度图像了。
      到此安装结束,有遇到问题的我们可以一切探讨。
      小鱼小 1 条回复 最后回复 回复 引用 1
      • 毛哥成山轮胎机油保养毛 毛哥成山轮胎机油保养 在 中 引用了 这个主题
        小鱼 技术大佬 @毛哥成山轮胎机油保养
        @毛哥成山轮胎机油保养 👍
