    用笔记本自带摄像头 奥比中光深度摄像头跑通ros1单目 rgbd
    移动平台分享
    rgbd摄像头 orbslam3 ros1
    1.3k
    • 毛哥成山轮胎机油保养毛
      毛哥成山轮胎机油保养 活跃VIP
      最后由 毛哥成山轮胎机油保养 编辑
      环境:ubuntu20.4 ros1 noetic
      奥比中光 Astra Pro RGBD深度摄像头。
      联想think pad x230自带摄像头
      前提:摄像头节点配置好,能够发布摄像头图像话题,orb_slam3编译成功,可以跑通自带的数据集。没有安装好请参考:
      https://fishros.org.cn/forum/topic/842/视觉slam-orb_slam3在ubuntu18-04-ubuntu20-04-安装运行测试
      https://fishros.org.cn/forum/topic/1118/ubuntu20-4-ros1noetic-安装奥比中光-astra-pro-rgbd摄像头
      orb_slam3 适配单目 双目 rgbd摄像头,最容易跑通的是单目,用笔记本自带的摄像头只需修改一下话题,就能启动。
      ros_mono.cc //单目主程序
      * This file is part of ORB-SLAM3
      * Copyright (C) 2017-2021 Carlos Campos, Richard Elvira, Juan J. Gómez Rodríguez, José M.M. Montiel and Juan D. Tardós, University of Zaragoza.
      * Copyright (C) 2014-2016 Raúl Mur-Artal, José M.M. Montiel and Juan D. Tardós, University of Zaragoza.
      * ORB-SLAM3 is free software: you can redistribute it and/or modify it under the terms of the GNU General Public
      * License as published by the Free Software Foundation, either version 3 of the License, or
      * (at your option) any later version.
      * ORB-SLAM3 is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even
      * the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
      * GNU General Public License for more details.
      * You should have received a copy of the GNU General Public License along with ORB-SLAM3.
      * If not, see <http://www.gnu.org/licenses/>.
      #include<iostream>
      #include<algorithm>
      #include<fstream>
      #include<chrono>
      #include<ros/ros.h>
      #include <cv_bridge/cv_bridge.h>
      #include<opencv2/core/core.hpp>
      #include"../../../include/System.h"
      using namespace std;
      class ImageGrabber
      public:
          ImageGrabber(ORB_SLAM3::System* pSLAM):mpSLAM(pSLAM){}
          void GrabImage(const sensor_msgs::ImageConstPtr& msg);
          ORB_SLAM3::System* mpSLAM;
          ros::init(argc, argv, "Mono");
          ros::start();
          if(argc != 3)
              cerr << endl << "Usage: rosrun ORB_SLAM3 Mono path_to_vocabulary path_to_settings" << endl;
              ros::shutdown();
              return 1;
          // Create SLAM system. It initializes all system threads and gets ready to process frames.
          ORB_SLAM3::System SLAM(argv[1],argv[2],ORB_SLAM3::System::MONOCULAR,true);
          ImageGrabber igb(&SLAM);
          ros::NodeHandle nodeHandler;
          //ros::Subscriber sub = nodeHandler.subscribe("/camera/image_raw", 1, &ImageGrabber::GrabImage,&igb);//原
          ros::Subscriber sub = nodeHandler.subscribe("/camera/color/image_raw", 1, &ImageGrabber::GrabImage,&igb);
          ros::spin();
          // Stop all threads
          SLAM.Shutdown();
          // Save camera trajectory
          SLAM.SaveKeyFrameTrajectoryTUM("KeyFrameTrajectory.txt");
          ros::shutdown();
          return 0;
      void ImageGrabber::GrabImage(const sensor_msgs::ImageConstPtr& msg)
          // Copy the ros image message to cv::Mat.
          cv_bridge::CvImageConstPtr cv_ptr;
          try
              cv_ptr = cv_bridge::toCvShare(msg);
          catch (cv_bridge::Exception& e)
              ROS_ERROR("cv_bridge exception: %s", e.what());
              return;
          mpSLAM->TrackMonocular(cv_ptr->image,cv_ptr->header.stamp.toSec());
      改动的地方:
      1.把主程序原来的接收topic /camera/image_raw改成 /usb_cam/image_raw"笔记本摄像头发布的话题
      ros::Subscriber sub = nodeHandler.subscribe("/usb_cam/image_raw", 1, &ImageGrabber::GrabImage,&igb);
      ros::spin();
      2安装启动摄像头
      sudo apt-get install ros-noetic-usb-cam //安装摄像头驱动
      roscore //启动ros核心
      rosrun usb_cam usb_cam_node //启动摄像头节点
      3启动单目节点
      摄像头配置文件先用程序自带的,目的是先跑起来,过后在标定摄像头。
      cd ORB_SLAM3
      rosrun ORB_SLAM3 Mono ./Vocabulary/ORBvoc.txt ./Examples/Monocular/EuRoC.yaml
      如果一切顺利,就应该能启动了,只是我的笔记本有点太老了,有点卡,但是能看到程序能正常运行了。
      rgbd主程序:
      ros_rgbd.cc
      #include<iostream>
      #include<algorithm>
      #include<fstream>
      #include<chrono>
      #include<ros/ros.h>
      #include <message_filters/subscriber.h>
      #include <message_filters/time_synchronizer.h>
      #include <message_filters/sync_policies/approximate_time.h>
      class ImageGrabber
      public:
          void GrabRGBD(const sensor_msgs::ImageConstPtr& msgRGB,const sensor_msgs::ImageConstPtr& msgD);
          ros::init(argc, argv, "RGBD");
          ros::start();
          if(argc != 3)
              cerr << endl << "Usage: rosrun ORB_SLAM3 RGBD path_to_vocabulary path_to_settings" << endl;
              ros::shutdown();
              return 1;
          ORB_SLAM3::System SLAM(argv[1],argv[2],ORB_SLAM3::System::RGBD,true);
          ros::NodeHandle nh;
          // message_filters::Subscriber<sensor_msgs::Image> rgb_sub(nh, "/camera/rgb/image_raw", 100);
          // message_filters::Subscriber<sensor_msgs::Image> depth_sub(nh, "camera/depth_registered/image_raw", 100);
           message_filters::Subscriber<sensor_msgs::Image> rgb_sub(nh, "/camera/color/image_raw", 100);
          message_filters::Subscriber<sensor_msgs::Image> depth_sub(nh, "/camera/depth/image_raw", 100);
          typedef message_filters::sync_policies::ApproximateTime<sensor_msgs::Image, sensor_msgs::Image> sync_pol;
          message_filters::Synchronizer<sync_pol> sync(sync_pol(10), rgb_sub,depth_sub);
          sync.registerCallback(boost::bind(&ImageGrabber::GrabRGBD,&igb,_1,_2));
          ros::spin();
          // Stop all threads
          SLAM.Shutdown();
          ros::shutdown();
          return 0;
      void ImageGrabber::GrabRGBD(const sensor_msgs::ImageConstPtr& msgRGB,const sensor_msgs::ImageConstPtr& msgD)
          cv_bridge::CvImageConstPtr cv_ptrRGB;
          try
              cv_ptrRGB = cv_bridge::toCvShare(msgRGB);
              return;
          cv_bridge::CvImageConstPtr cv_ptrD;
          try
              cv_ptrD = cv_bridge::toCvShare(msgD);
              return;
          mpSLAM->TrackRGBD(cv_ptrRGB->image,cv_ptrD->image,cv_ptrRGB->header.stamp.toSec());
      修改orb_slam3话题为自己的rgbd相机话题
      启动rgbd摄像头
      . devel/setup.bash
      roslaunch astra_camera astra_pro.launch
      m@r:~$ rostopic list
      /camera/color/camera_info
      /camera/depth/camera_info
      /camera/depth/points
      /camera/depth_registered/points
      /camera/extrinsic/depth_to_color
      /camera/ir/camera_info
      /camera/ir/image_raw
      /camera/reset_device
      /rosout
      /rosout_agg
      /tf
      /tf_static
      启动rgbd主程序 (摄像头都没有标定,用的程序自带的配置文件)
      cd ORB_SLAM3
      rosrun ORB_SLAM3 RGBD ./Vocabulary/ORBvoc.txt ./Examples_old/ROS/ORB_SLAM3/Asus.yaml
      程序能跑起来了,要想数据准确,需要给摄像头作标定,rgbd深度摄像头计算量应该是比单目的小,运行比较流畅。
      1 条回复 最后回复 回复 引用 2
