    编译NAV2出现的错误 是怎么回事,ROS2 humble
    Nav2
    下载的有关nav2包编译出错 ros2 nav2
    1.8k
    • 1577630951
      /yiw
      git clone https://ghproxy.com/https://github.com/ros-planning/navigation2.git -b foxy-devel 是不是下载的版本错了
      wu@wu-virtual-machine:~/nav/src$ colcon build --packages-up-to navigation2
      [1.162s] WARNING:colcon.colcon_core.package_selection:Some selected packages are already built in one or more underlay workspaces:
      'nav2_common' is in: /opt/ros/humble
      'nav2_util' is in: /opt/ros/humble
      'nav2_map_server' is in: /opt/ros/humble
      'nav2_navfn_planner' is in: /opt/ros/humble
      'navigation2' is in: /opt/ros/humble
      'nav2_controller' is in: /opt/ros/humble
      'nav2_core' is in: /opt/ros/humble
      'nav_2d_utils' is in: /opt/ros/humble
      'nav2_amcl' is in: /opt/ros/humble
      'nav2_lifecycle_manager' is in: /opt/ros/humble
      'nav2_costmap_2d' is in: /opt/ros/humble
      'nav2_planner' is in: /opt/ros/humble
      'nav2_behavior_tree' is in: /opt/ros/humble
      'nav_2d_msgs' is in: /opt/ros/humble
      'nav2_regulated_pure_pursuit_controller' is in: /opt/ros/humble
      'nav2_msgs' is in: /opt/ros/humble
      If the overridden package is used by another package in any underlay, then the overriding package in the overlay must be API and ABI compatible or undefined behavior at run time may occur.
      If you understand the risks and want to override a package anyways, add the following to the command line:
      --allow-overriding nav2_amcl nav2_behavior_tree nav2_common nav2_controller nav2_core nav2_costmap_2d nav2_lifecycle_manager nav2_map_server nav2_msgs nav2_navfn_planner nav2_planner nav2_regulated_pure_pursuit_controller nav2_util nav_2d_msgs nav_2d_utils navigation2
      This may be promoted to an error in a future release of colcon-override-check.
      Starting >>> nav2_common
      Starting >>> nav_2d_msgs
      Finished <<< nav2_common [1.36s]
      Starting >>> nav2_msgs
      Finished <<< nav_2d_msgs [2.51s]
      Starting >>> nav2_voxel_grid
      Finished <<< nav2_voxel_grid [0.48s]
      Starting >>> dwb_msgs
      Finished <<< nav2_msgs [3.57s]
      Starting >>> nav2_util
      Finished <<< dwb_msgs [2.01s]
      --- stderr: nav2_util
      In file included from /home/wu/nav/src/navigation2/nav2_util/include/nav2_util/geometry_utils.hpp:24,
      from /home/wu/nav/src/navigation2/nav2_util/src/costmap.cpp:19:
      /opt/ros/humble/include/tf2_geometry_msgs/tf2_geometry_msgs/tf2_geometry_msgs.h:35:2: error: #warning This header is obsolete, please include tf2_geometry_msgs/tf2_geometry_msgs.hpp instead [-Werror=cpp]
      35 | #warning This header is obsolete, please include tf2_geometry_msgs/tf2_geometry_msgs.hpp instead
      In file included from /opt/ros/humble/include/rclcpp/rclcpp/logging.hpp:24,
      from /opt/ros/humble/include/rclcpp/rclcpp/client.hpp:40,
      from /opt/ros/humble/include/rclcpp/rclcpp/callback_group.hpp:24,
      from /opt/ros/humble/include/rclcpp/rclcpp/any_executable.hpp:20,
      from /opt/ros/humble/include/rclcpp/rclcpp/memory_strategy.hpp:25,
      from /opt/ros/humble/include/rclcpp/rclcpp/memory_strategies.hpp:18,
      from /opt/ros/humble/include/rclcpp/rclcpp/executor_options.hpp:20,
      from /opt/ros/humble/include/rclcpp/rclcpp/executor.hpp:37,
      from /opt/ros/humble/include/rclcpp/rclcpp/executors/multi_threaded_executor.hpp:25,
      from /opt/ros/humble/include/rclcpp/rclcpp/executors.hpp:21,
      from /home/wu/nav/src/navigation2/nav2_util/include/nav2_util/costmap.hpp:21,
      from /home/wu/nav/src/navigation2/nav2_util/src/costmap.cpp:17:
      /home/wu/nav/src/navigation2/nav2_util/src/costmap.cpp: In constructor ‘nav2_util::Costmap::Costmap(rclcpp::Node*, bool, bool, int, int)’:
      /home/wu/nav/src/navigation2/nav2_util/src/costmap.cpp:42:28: error: format ‘%f’ expects argument of type ‘double’, but argument 5 has type ‘int’ [-Werror=format=]
      42 | node_->get_logger(), "Costmap: Lethal threshold set to %.2f, it should be within"
      43 | " bounds 0-100. This could result in potential collisions!", lethal_threshold_);
      | int
      /home/wu/nav/src/navigation2/nav2_util/src/costmap.cpp:42:65: note: format string is defined here
      | double
      | %.2d
      cc1plus: all warnings being treated as errors
      gmake[2]: *** [src/CMakeFiles/nav2_util_core.dir/build.make:76: src/CMakeFiles/nav2_util_core.dir/costmap.cpp.o] Error 1
      gmake[1]: *** [CMakeFiles/Makefile2:212: src/CMakeFiles/nav2_util_core.dir/all] Error 2
      gmake[1]: *** Waiting for unfinished jobs....
      gmake: *** [Makefile:146: all] Error 2
      Failed <<< nav2_util [15.9s, exited with code 2]
      Summary: 5 packages finished [21.5s]
      1 package failed: nav2_util
      1 package had stderr output: nav2_util
      22 packages not processed
      小鱼小 1577630951 2 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @157763095
        @157763095 这个是foxy版本的,米系统Ros哪个版本
        • 1577630951
          /yiw @157763095
          @157763095 我装的是humble的有这个版本的代码吗
