    docker arm64 Error creating default "bridge" network iptables v1.8.7 (nf_tables): CHAIN_ADD failed (No such file or directory): chain POSTROUTING
    docker bridge
    1.3k
      INFO[2023-03-03T19:38:32.823784513+08:00] stopping event stream following graceful shutdown  error="<nil>" module=libcontainerd namespace=moby
      DEBU[2023-03-03T19:38:32.825174902+08:00] Cleaning up old mountid : done.
      failed to start daemon: Error initializing network controller: Error creating default "bridge" network: Failed to Setup IP tables: Unable to enable NAT rule:  (iptables failed: iptables --wait -t nat -I POSTROUTING -s 172.17.0.0/16 ! -o docker0 -j MASQUERADE: iptables v1.8.7 (nf_tables):  CHAIN_ADD failed (No such file or directory): chain POSTROUTING
       (exit status 4))
      问题解决方案
      sudo update-alternatives --set iptables /usr/sbin/iptables-legacy
      sudo update-alternatives --set ip6tables /usr/sbin/ip6tables-legacy
      原因是deian的iptables命令问题
      • 小鱼小 小鱼 将这个主题转为普通主题,在
