    自定义主题发布Path消息不可在rviz显示,运行ros2 topic echo报warning
    ros2 nav2 rviz2不显示
    1.0k
    • 10520957131
      Spike
      求助大佬们:
      主题发布如下
      self.path_pub = self.create_publisher(Path,"/path_my_A_star", 10 )
          def publisher_path(self):
              print('Start Publishing the msg!!!')
              time = 1
              y1 = []
              y2 = []
              for i in range(self.path_map.shape[1]):
                  current_time = self.get_clock().now().to_msg()
                  current_pose = PoseStamped()
                  current_pose.pose.position.x, current_pose.pose.position.y= self.mapToWorld(self.path_map[0][i], self.path_map[0][i])
                  y1.append(self.mapToWorld(self.path_map[0][i], self.path_map[0][i])[0])
                  y2.append(self.mapToWorld(self.path_map[0][i], self.path_map[0][i])[1])
                  current_pose.pose.position.z = 0.0
                  current_pose.pose.orientation.x = 0.0
                  current_pose.pose.orientation.y = 0.0
                  current_pose.pose.orientation.z = 0.0
                  current_pose.pose.orientation.w = 1.0
                  time += 1
                  self.current_path.header.stamp = current_time
                  self.current_path.header.frame_id = "odom"
                  self.current_path.poses.append(current_pose)
                  self.path_pub.publish(self.current_path)
                  self.last_time = current_time
              print('Finish Publishing the msg!')
      rviz并不显示path
      由于rviz无法显示path轨迹,利用topic echo检看msg但是结果如下
      peter@ubuntu:~$ ros2 topic echo /path_my_A_starh
      WARNING: topic [/path_my_A_starh] does not appear to be published yet
      Could not determine the type for the passed topic
      • 10520957131 1052095713 将这个主题转为问答主题,在
