    roscore运行报错
    ros安装 rosrun
    2.5k
    • 10640440921
      深水炸弹
      RLException: Unable to contact my own server at [http://nubot1:33131/].
      This usually means that the network is not configured properly.
      A common cause is that the machine cannot connect to itself. Please check
      for errors by running:
      ping nubot1
      For more tips, please see
      http://wiki.ros.org/ROS/NetworkSetup
      The traceback for the exception was written to the log file
        小鱼 技术大佬 @1064044092
        @1064044092 在 roscore运行报错 中说:
        ping nubot1
        找到nubot1相关配置,删掉
        13435939051 1 条回复 最后回复 回复 引用 0
        • 13435939051
          1343593905 @小鱼
          @小鱼 直接在终端输入ping nubot1吗?
            小鱼 技术大佬 @1343593905
            @1343593905 我是引用的你的报错,你的环境里肯定配了ROS_MASTER_URI之类的,删掉
            • 20715056892
              123
              2023年3月9日 17:24
              Thank you for answering the question!
              For the problem that I confront, I solve it this way
              After installing Ros noetics, when I was running commend "roscore" I got this issue
              RLException: Unable to contact my own server at [http://192.168.123.20:46397/].
                      ping 192.168.123.20
              and solve it in this way
              Change your ROS_MASTER_URI and ROS_HOSTNAME in ~/.bashrc and delete POS_IP which is related to IP 192.168.123.20
              export ROS_MASTER_URI=http://robot.local:11311
              export ROS_HOSTNAME=localhost
              export ROS_IP='hostname -I'
              for other version of ros maybe will work with following ROS_HOSTNAME
              export ROS_HOSTNAME=robot.local
              Don't forget source ~/.bashrc
              For additional info can refer to following link
              https://blog.csdn.net/Will_Ye/article/details/119912488
