    navigation2.launch.py 启动报错
    ros2 launch
    • 9046858779
      Sword
      [ERROR] [launch]: Caught exception in launch (see debug for traceback): 'NoneType' object has no attribute 'items'
        小鱼 技术大佬 @904685877
        @904685877 上下文
