    请问gazebo无法显示静止的长方体模型如何解决:CCS for 3D textures is disabled, but a workaround is available?
    ros2 humble ros2 launch文件
    1.0k
    • 22481962182
      彼岸
      输出的日志信息如下:
      [INFO] [launch]: All log files can be found below /home/fins/.ros/log/2023-03-23-19-25-48-762078-fins-UTG-11522
      [INFO] [robot_state_publisher-1]: process started with pid [11523]
      [INFO] [gzserver-2]: process started with pid [11525]
      [INFO] [gzclient-3]: process started with pid [11527]
      [INFO] [spawn_entity.py-4]: process started with pid [11529]
      [robot_state_publisher-1] [INFO] [1679570749.093074638] [robot_state_publisher]: got segment base_link
      [robot_state_publisher-1] [INFO] [1679570749.093129855] [robot_state_publisher]: got segment dummy
      [robot_state_publisher-1] [INFO] [1679570749.093135121] [robot_state_publisher]: got segment front_link
      [spawn_entity.py-4] [INFO] [1679570749.351752070] [spawn_entity]: Spawn Entity started
      [spawn_entity.py-4] [INFO] [1679570749.351941495] [spawn_entity]: Loading entity published on topic robot_description
      [spawn_entity.py-4] /opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/qos.py:307: UserWarning: DurabilityPolicy.RMW_QOS_POLICY_DURABILITY_TRANSIENT_LOCAL is deprecated. Use DurabilityPolicy.TRANSIENT_LOCAL instead.
      [spawn_entity.py-4]   warnings.warn(
      [spawn_entity.py-4] [INFO] [1679570749.352830954] [spawn_entity]: Waiting for entity xml on robot_description
      [spawn_entity.py-4] [INFO] [1679570749.478006085] [spawn_entity]: Waiting for service /spawn_entity, timeout = 30
      [spawn_entity.py-4] [INFO] [1679570749.478191540] [spawn_entity]: Waiting for service /spawn_entity
      [spawn_entity.py-4] [INFO] [1679570750.231305805] [spawn_entity]: Calling service /spawn_entity
      [spawn_entity.py-4] [INFO] [1679570750.400439868] [spawn_entity]: Spawn status: SpawnEntity: Successfully spawned entity [rectangle]
      [INFO] [spawn_entity.py-4]: process has finished cleanly [pid 11529]
      [gzclient-3] ../src/intel/isl/isl.c:2216: FINISHME: ../src/intel/isl/isl.c:isl_surf_supports_ccs:
      CCS for 3D textures is disabled, but a workaround is available.
      code_text
      下面是具体的launch文件与urdf模型
      1、这是长方体的urdf文件:
      <?xml version="1.0" encoding="utf-8"?>
      <!-- This URDF was automatically created by SolidWorks to URDF Exporter! Originally created by Stephen Brawner (brawner@gmail.com)
           Commit Version: 1.6.0-4-g7f85cfe  Build Version: 1.6.7995.38578
           For more information, please see http://wiki.ros.org/sw_urdf_exporter -->
      <robot
        name="demo1-3">
        <link name="dummy">
        </link>
        <link
          name="base_link">
          <inertial>
            <origin
              xyz="0.059269 -0.004969 0.17749"
              rpy="0 0 0" />
            <mass
              value="1.746" />
            <inertia
              ixx="0.0029237"
              ixy="3.8969E-05"
              ixz="-6.1279E-19"
              iyy="0.0063175"
              iyz="9.5233E-20"
              izz="0.0062493" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="package://gazebo_simulation/meshes/base_link.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint name="dummy_joint" type="fixed">
           <parent link="dummy"/>
           <child link="base_link"/>
        </joint>
        <link
          name="front_link">
          <inertial>
            <origin
              xyz="0.0022355 0.01995 -0.00025958"
              rpy="0 0 0" />
            <mass
              value="0.071103" />
            <inertia
              ixx="1.4695E-05"
              ixy="-5.6331E-22"
              ixz="-2.0294E-22"
              iyy="2.6451E-05"
              iyz="-5.6257E-22"
              izz="3.0622E-05" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="package://gazebo_simualtion/meshes/front_link.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="0.79216 0.81961 0.93333 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="package://gazebo_simulation/meshes/front_link.STL" />
            </geometry>
          </collision>
        </link>
        <joint
          name="line_joint"
          type="fixed">
          <origin
            xyz="0.077552 -0.17785 0.016113"
            rpy="1.5708 0 0" />
          <parent
            link="base_link" />
          <child
            link="front_link" />
          <axis
            xyz="0 0 0" />
        </joint>
      </robot>
      2、然后launch文件如下:
      (1)view_gazebo_tribot.launch.py
      import os
      from launch.actions import IncludeLaunchDescription
      # Include the robot_state_publisher launch file, provided by our own package. Force sim time to be enabled
      # !!! MAKE SURE YOU SET THE PACKAGE NAME CORRECTLY !!!
      package_name='gazebo_simulation' #<--- CHANGE ME
      world_file_path = 'worlds/neighborhood.world'
      pkg_path = os.path.join(get_package_share_directory(package_name))
      world_path = os.path.join(pkg_path, world_file_path)
      # Pose where we want to spawn the robot
      spawn_x_val = '0.0'
      spawn_y_val = '0.0'
      spawn_z_val = '0.0'
      spawn_yaw_val = '0.0'
      tribot = IncludeLaunchDescription(
                  PythonLaunchDescriptionSource([os.path.join(
                      get_package_share_directory(package_name),'launch','tribot.launch.py'
                  )]), launch_arguments={'use_sim_time': 'true', 'world':world_path}.items()
      # Include the Gazebo launch file, provided by the gazebo_ros package
      gazebo = IncludeLaunchDescription(
                      get_package_share_directory('gazebo_ros'), 'launch', 'gazebo.launch.py')]),
      # Run the spawner node from the gazebo_ros package. The entity name doesn't really matter if you only have a single robot.
      spawn_entity = Node(package='gazebo_ros', executable='spawn_entity.py',
                          arguments=['-topic', 'robot_description',
                                     '-entity', 'rectangle',
                                     '-x', spawn_x_val,
                                     '-y', spawn_y_val,
                                     '-z', spawn_z_val,
                                     '-Y', spawn_yaw_val],
                          output='screen')
      # Launch them all!
      return LaunchDescription([
          tribot,
          gazebo,
          spawn_entity,
      其中调用的tribot.launch.py文件如下:
      import os
      import launch
      import xacro
      # Check if we're told to use sim time
      use_sim_time = LaunchConfiguration('use_sim_time')
      # Process the URDF file
      pkg_path = os.path.join(get_package_share_directory('gazebo_simulation'))
      xacro_file = os.path.join(pkg_path,'urdf','demo1-3.urdf')
      robot_description_config = xacro.process_file(xacro_file)
      # Create a robot_state_publisher node
      params = {'robot_description': robot_description_config.toxml(), 'use_sim_time': use_sim_time}
      node_robot_state_publisher = Node(
          output='screen',
          parameters=[params]
      # Launch!
          DeclareLaunchArgument(
              'use_sim_time',
              default_value='false',
              description='Use sim time if true'),
